重要提示:PCB作品文件展下载说明
ITM |
QTY |
REF DESIGNATOR |
PART |
FOOTPRINT |
DESCRIPTION |
MAN |
PART # |
1 |
3 |
C1,C2,C13 |
10uF,10V |
805 |
CAP CER 10UF 10V Y5V 0805 |
C2012Y5V1A106Z |
2 |
10 |
C5,C6,C7,C8,C9,C10,C11,C12,C23,C41 |
0.1uF |
402 |
Capacitor 0.1uF 16V 10% 0402 X7R |
C0402C104K4RACT |
3 |
2 |
C38,C40 |
4.7uF, 25V |
c805-35x60 |
CAP CER 4.7UF 50V X5R 10% 0805 |
C2012X5R1H475K |
4 |
0 |
C39 |
47nF, DNI |
c402-25 |
CAP CER 0.047UF 25V X5R 0402 |
TMK105B7473KV-F |
5 |
2 |
D3,D5 |
LTST-C190GKT |
led2-31sq |
LED GREEN CLEAR 0603 SMD |
LTST-C190GKT |
6 |
0 |
D4 |
MBRX140-TP, DNI |
SOD-123 |
DIODE SCHOTTKY 40V 1A SOD123 |
MBRX140-TP |
7 |
1 |
FB8 |
MMZ1608R301A |
IND603-24X32 |
FERRITE CHIP 300 OHM 500MA 0603 |
TDK |
MMZ1608R301A |
8 |
1 |
J1 |
CONN PCB 10x2-S |
HDR2x10 |
MLE |
BSTS-110-D-A-16-T-300-LF |
9 |
1 |
J2 |
MALE HEADER 2x23 |
HDR2x23 |
MLE |
BSTS-123-D-A-16-T-300-LF |
10 |
0 |
J3 |
HEADER 3X2, DNI |
HDR2x3 |
MLE |
BSTS-103-D-A-16-T-300-LF |
11 |
1 |
J4 |
62684-5521N0ALF |
CONN55_P5MM_5X33SMD |
CONN FPC/FFC 55POS .5MM R/A SMD |
62684-5521N0ALF |
12 |
1 |
L2 |
4.7uH |
ind-lqh32m |
INDUCTOR 4.7UH 20% 450MA 1210 |
LQH32CN4R7M23L |
13 |
0 |
L3 |
18uH, DNI |
IND390SMD_472SQ |
INDUCTOR POWER 18UH 3.2A SMD |
Wruth |
7447715180 |
14 |
0 |
L4 |
10uH, DNI |
INDUCTOR POWER 10UH 2.5A SMD |
TDK |
VLC6045T-100M |
15 |
1 |
Q1 |
DMC56404 |
SMini6-F3-B |
TRANS PREBIASED DUAL NPN SOT363 |
DDC114YU-7-F |
16 |
1 |
Q3 |
BSS138 |
SOT23-3 |
MOSFET Nchan 50V 200mA |
Diodes Inc. |
BSS138-7-F |
17 |
20 |
R1,R4,R7,R8,R10,R12,R13,R14,R15,R19,R21,R23,R25,R27,R29,R31,R33,R35,R37,R39 |
33,402 |
402 |
RES 33.0 OHM 1/16W 1% 0402 SMD |
Yaego |
RC0402FR-0733RL |
18 |
21 |
R2,R3,R5,R6,R9,R11,R16,R17,R18,R20,R22,R24,R26,R28,R30,R32,R34,R36,R38,R40,R120 |
10,402 |
402 |
RES 10.0 OHM 1/16W 1% 0402 SMD |
Yaego |
RC0402FR-0710RL |
19 |
2 |
R63,R119 |
470 |
r402-25 |
Resistor 470ohm 1/16W 5% 0402 |
ERJ-2GEJ471X |
20 |
2 |
R65,R66 |
5.6K,5% |
402 |
RES 5.6K OHM 1/16W 5% 0402 SMD |
Yaego |
RC0402JR-075K6L |
21 |
4 |
R67,R68,R69,R72 |
4.75K |
402 |
RES 4.75K OHM 1/16W 1% 0402 SMD |
Stackpole Electronics |
RMCF0402FT4K75 |
22 |
0 |
R70,R71,R129 |
100K, DNI |
r402-25 |
23 |
0 |
R74,R76,R78,R84,R86,R87,R88,R123,R125,R128 |
0,DNI |
c402-25 |
24 |
7 |
R75,R77,R79,R85,R90,,R126,R127 |
0 |
c402-25 |
RES 0.0 OHM 1/16W 0402 SMD |
RMCF0402ZT0R00 |
25 |
6 |
R80,R81,R82,R83,R89,R139 |
10K |
SM-7351-RES-0402 |
Resistor 10Kohm 1/16W 5% 0402 |
Rohm |
MCR01MZPJ103 |
26 |
2 |
R121,R122 |
100K,1% |
402 |
RES 100K OHM 1/16W 5% 0402 SMD |
RMCF0402JT100K |
27 |
1 |
R124 |
6.8K |
c402-25 |
RES 6.8K OHM 1/16W 1% 0402 SMD |
ERJ-2RKF6801X |
28 |
1 |
R130 |
2R |
603 |
RES 2.00 OHM 1/10W 1% 0603 SMD |
Yaego |
RC0603FR-072RL |
29 |
0 |
R131,R132,R134 |
0, DNI |
603 |
30 |
3 |
R133,R135,R136 |
0 |
603 |
RES 0.0 OHM 1/10W 0603 SMD |
Yaego |
RC0603JR-070RL |
31 |
1 |
SW1 |
SW DIP-2 |
swdip4_100-339smd |
SWITCH TAPE SEAL 2 POS SMD |
CTS |
219-2MST |
32 |
1 |
S1 |
B3U-1100 |
SW3_4X2P5 |
SWITCH TACTILE SPST-NO 0.05A 12V |
B3U-1100P |
33 |
1 |
S6 |
B3F-3100 |
SWRST4_177X256LS-1 |
SWITCH TACTILE SPST-NO 0.05A 24V, RA |
Omron |
B3F-3100 |
34 |
5 |
S2,S3,S4,S5,S7 |
B3F-1000 |
sw4-b3f-315x |
SWITCH TACTILE SPST-NO 0.05A 24V |
Omron |
B3F-1000 |
35 |
0 |
TP1,TP2 |
T POINT A |
36 |
1 |
U1 |
74avc32t245 |
BGA96-ZKE |
IC BUS TRANSCVR 32BIT 96BGA |
TI |
SN74AVC32T245ZKER |
37 |
1 |
U4 |
CAT24C256W |
SOIC_8 |
IC EEPROM 256KBIT 400KHZ 8SOIC |
ON |
CAT24C256WI-G |
38 |
1 |
U5 |
TPS61080DRC |
drc10-11x33 |
IC REG LDO CAP FREE 8-SON |
TI |
TPS61080DRC |
39 |
1 |
U6 |
SN74LVC1G06DCK |
DCK5 |
TI |
SN74LVC1G06DCK |
40 |
1 |
PCB |
BB-BONE-LCD3-PCB-03 |
41 |
1 |
LCD |
3.5" TOUCHSREEN TFT LCD |
Elpa |
TO112T |
重要提示:PCB作品文件展下载说明
