查看: 2464|回复: 3
[Allegro16.6以下] CY8CKIT-050B, PSoC 5LP Development Kit使用CY8C5868AXI-LP035的参考设计
终身成就奖原创先锋奖特殊贡献奖优秀斑竹奖金点子奖
发表于 2018-11-26 01:12:24 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
Item
Qty
Reference
Value
Description
Manufacturer
Mfr Part Number
PCB
Cypress
PDC-09356
BH1
BAT 9V MALE
BATTERY HOLDER 9V Male PC MT
Keystone Electronics
593
BH2
BAT 9V FEMALE
BATTERY HOLDER 9V Female PC MT
594
C2,C4,C5,C13,C14,C15,C28,C45,C46
10 uFd 16v
CAP 10UF 16V TANTALUM 10% 3216
AVX
TAJA106K016R
C6,C22
22 uFd
CAP CER 22UF 10V 10% X5R 1210
Kemet
C1210C226K8PACTU
C7,C10,C12,C16,C17,C18,C19,C20,C21,C26,C32,C33,C34,C35,C36,C38,C40,C41,C43,C47,C48,C49,C50,C51,C52,C53, C1, C3, C23
0.1 uFd
CAP .1UF 16V CERAMIC Y5V 0402
Panasonic - ECG
ECJ-0EF1C104Z
C8,C9
0.01 uFd
CAP 10000PF 16V CERAMIC 0402 SMD
Panasonic - ECG
ECJ-0EB1C103K
C11
2.2 uFd
CAP CER 2.2UF 6.3V 20% X5R 0402
Panasonic - ECG
ECJ-0EB0J225M
C29,C37,C42,C44
1.0 uFd
CAP CERAMIC 1.0UF 25V X5R 0603 10%
Taiyo Yuden
TMK107BJ105KA-T
9
C25, C27
22pF
CAP, CER, 22 pF, 50V, 5%, COG, 0603, SMD
Panasonic - ECG
ECJ-0EC1H220J
C39
2200 pFd
SMD/SMT 0805 2200pF 50volts C0G 5%
Murata
GRM2165C1H222JA01D
C54,C55
1.0 uFd
Taiyo Yuden
TMK107BJ105KA-T
D1,D2,D3,D4, D7, D8
SS12-E3/61T
DIODE SCHOTTKY 20V 1A SMA
Vishay/General Semiconductor
SS12-E3/61T
13
D5
LED Green
LED GREEN CLEAR 0805 SMD
Chicago Miniature
CMD17-21VGC/TR8
14
D6
ZHCS
DIODE SCHOTTKY 40V 1.0A SOT23-3
Zetex
ZHCS1000TA
D9, D10, D11, D12, D13, D14
ESD diode
SUPPRESSOR ESD 5VDC 0603 SMD
Bourns Inc.
CG0603MLC-05LE
16
D15
4.3V zener diode
DIODE ZENER 4.3V 1W SOD-106
Rohm Semiconductor
PTZTE254.3B
17
D16
2.0V Zener Diode
DIODE ZENER 2V 500MW SOD-123
Diodes Inc
BZT52C2V0-7-F
18
J1,J2
USB MINI B
CONN USB MINI B SMT RIGHT ANGLE
TYCO
1734035-2
J3, J40
50MIL KEYED SMD
CONN HEADER 10 PIN 50MIL KEYED SMD
Samtec
FTSH-105-01-L-DV-K
J4
POWER JACK P-5
CONN JACK POWER 2.1mm PCB RA
CUI
PJ-102A
J50
Breadboard
BREADBOARD 17x5x2
3M
923273-I
22
TP1, J26, J27, J35, J28
BLACK TEST POINT
TEST POINT PC MINI .040"D Black
KeystoneElectronics
5001
23
LED1,LED2,LED3,LED4
LED Red
LED RED CLEAR 0805 SMD
Rohm Semiconductor
SML-210LTT86
24
L1
22 uH
INDUCTOR SHIELD PWR 22UH 7032
TDK Corporation
SLF7032T-220MR96-2-PF
25
P1,P2
20x2 RECP RA
CONN FMALE 40POS DL .100 R/A GOLD
Sullins Electronics Corp.
PPPC202LJBN-RC
26
P7
DB9 FEMALE
CONN DB9 FMALE VERT PRESSFIT SLD
Norcomp Inc.
191-009-223R001
27
P8
LCD HEADER W/O BACKLIGHT
CONN RECEPT 16POS .100 VERT AU
Tyco Electronics
1-534237-4
P3,P4,P6,P9
RECP 8X1
CONN RECT 8POS .100 VERT
3M
929850-01-08-RA
29
Q1,Q2,Q3,Q4,Q5,Q6
P-MOS, 30V 3.8A SOT23 in Protectioncircuit
MOSFET P-CH 30V 3.8A SOT23-3
Diodes Inc
DMP3098L-7
30
R7
RES 220 OHM 1/10W 1% 0603 SMD
Panasonic - ECG
ERJ-3EKF2200V
YES
31
R16
RES 442 OHM 1/10W 1% 0603 SMD
Panasonic - ECG
ERJ-3EKF4420V
YES
32
R3,R4
100K
RES 100K OHM 1/16W 5% 0402 SMD
Panasonic - ECG
ERJ-2GEJ104X
33
R9,R23,R24,R26,R27,R71
ZERO
RES 0.0 OHM 1/10W 5% 0805 SMD
Panasonic-ECG
ERJ-6GEY0R00V
34
R5,R6
2.2K
RES 2.2K OHM 1/16W 5% 0402 SMD
Panasonic - ECG
ERJ-2GEJ222X
35
R11,R10,R18
1K
RES 1.0K OHM 1/8W 5% 0805 SMD
Panasonic - ECG
ERJ-6GEYJ102V
36
R12
3.16K
RES 3.16K OHM 1/10W .5% 0603 SMD
Yageo
RT0603DRD073K16L
37
R13
3.74K
RES 3.74K OHM 1/10W 1% 0603 SMD
Panasonic - ECG
ERJ-3EKF3741V
38
R14
100K
RES 100K OHM 1/10W 1% 0603 SMD
Yageo
RC0603FR-07100KL
39
R15,R59,R60,R61,R62
330 ohm
RES 330 OHM 1/10W 5% 0805 SMD
Panasonic - ECG
ERJ-6GEYJ331V
40
R17,R40,R41,R42,R43,R44,R45,R46
10K
RES 10K OHM 1/16W 5% 0402 SMD
Stackpole Electronics Inc
RMCF 1/16S 10K 5% R
41
13
R35,R36,R39,R47,R48,R49,R50,R51,R52,R53,R54,R64,R66
ZERO
RES ZERO OHM 1/16W 5% 0603 SMD
Panasonic - ECG
ERJ-3GEY0R00V
42
R32,R33
22E
RES 22 OHM 1/16W 1% 0603 SMD
Panasonic - ECG
ERJ-3EKF22R0V
43
R63,R65
100 ohm
RES 100 OHM 1/8W 5% 0805 SMD
Rohm
MCR10EZHJ101
44
R56
POT 10K
POT 10K OHM 1/8W CARB VERTICAL
CTS Electrocomponents
296UD103B1N
45
R58
10E
RES 10 OHM 1/8W 5% 0805 SMD
RMCF 1/10 10 5% R
46
R68
100 ohm
RES 100 OHM 1/16W 5% 0603 SMD
Panasonic - ECG
ERJ-3GEYJ101V
47
R69
10K
RES 10K OHM 1/16W 5% 0603 SMD
Panasonic - ECG
ERJ-3GEYJ103V
48
SW1,SW2,SW3
SW PUSHBUTTON
LT SWITCH 6MM 160GF H=2.5MM SMD
Panasonic - ECG
EVQ-Q2P02W
49
U1
LT1763CS8
IC LDO REG LOW NOISE ADJ 8-SOIC
Linear Technology
LT1763CS8#PBF
50
U2
AP1117D50G
IC REG LDO 1.0A 5.0V TO-252
Diodes Inc
AP1117D50G-13
51
U3
24LC00/SN
IC EEPROM 128BIT 400KHZ 8SOIC
Microchip Technology
24LC00/SN
52
U4
LM1117MPX-3.3
IC REG 3.3V 800MA LDO SOT-223
National Semiconductor
LM1117IMP-3.3/NOPB
53
U5
CY7C68013A-56LTXC
IC, FX2 HIGH-SPEED USB PERIPHERALCONTROLLER QFN56
Cypress Semiconductor
CY7C68013A-56LTXC
54
U7
CY8C5868AXI-LP035 TQFP100
PSoC 5 Mixed-Signal Array
CY8C5868AXI-LP035
55
U8
MAX3232CDR
IC 3-5.5V LINE DRVR/RCVR 16-SOIC
Texas Insturments
MAX3232IDR
56
Y1
24 MHz
CER RESONATOR 24.0 MHz SMD
Murata
CSTCW24M0X53-R0
57
Y2
32.768KHz XTAL
CRYSTAL 32.768 KHZ CYL 12.5PF CFS308
Citizen America Corporation
CFS308-32.768KDZF-UB
58
Y3
24 MHz Crystal
CRYSTAL 24.000MHZ 20PF SMD
ECS Inc
ECS-240-20-5PX-TR
59
J8,J33, TP2
RED TEST POINT
TEST POINT PC MINI .040"D RED
5000
60
R38
2.2K
RES 2.2KOHM 1/16W 2700PPM 5%0603
Panasonic - ECG
ERA-V27J222V
61
J10,J11
3p_jumper
CONN HEADER VERT SGL 3POS GOLD
3M
961103-6404-AR
62
J30,J43,J44
2p_jumper
CONN HEADER VERT SGL 2POS GOLD
3M
961102-6404-AR
63
NA
3.3V LCD Module 16POS w/16 pin headerinstalled
Lumex
LCM-S01602DTR/A-3
64
NA
16 pin header
CONN HEADER VERT SGL 16POS GOLD
3M
961116-6404-AR
65
R21
39K
RES 39.0K OHM 1/10W 1% 0603 SMD
Rohm Semiconductor
MCR03EZPFX3902
66
R22
62K
RES 62.0K OHM 1/10W 1% 0603 SMD
Rohm Semiconductor
MCR03EZPFX6202
67
C30,C31
22pF
Panasonic - ECG
ECJ-1VC1H220J
68
P5
4x1 RECP
CONN RECEPT 4POS .100 VERT GOLD
3M
929850-01-04-RA
69
J31, J32, J29, J34
4x1 RECP
3M
929850-01-04-RA
No Load Components
70
C24
1.0 uFd
Taiyo Yuden
TMK107BJ105KA-T
71
J5,J6,J12,J14,J18,J22,J25,TP3,TP4,J16,J39
RED
5000
72
J7,J36
BLACK
KeystoneElectronics
5001
73
TP5
WHITE
TEST POINT PC MINI .040"D WHITE
5002
74
R67
10K
POT 10K OHM 1/4" SQ CERM SL ST
Bourns Inc.
3362P-1-103LF
75
R30,R34,R57,R72,R25,R31,R70,R37,R29,R73,R74,R75
ZERO
Panasonic-ECG
ERJ-6GEY0R00V
76
R55
10K
TRIMPOT 10K OHM 4MM TOP ADJ SMD
Bourns Inc.
3214W-1-103E
77
R1,R28,
ZERO
RES ZERO OHM 1/10W 5% 0603 SMD
Panasonic - ECG
ERJ-3GEY0R00V
78
U6
LM4140
IC REF PREC VOLT MICROPWR 8-SOIC
LM4140ACM-1.0/NOPB
79
R8
1.5K
RES 1.5KOHM 1/10W 1500PPM 5%0805
Panasonic - ECG
ERA-S15J152V
80
R2
3K
RES 1/10W 3K OHM 0.1% 0805
RNC 20 T9 3K 0.1% R
81
J38
3p_jumper
3M
961103-6404-AR
J37
2p_jumper
3M
961102-6404-AR
83
CSB1,CSB2
CapSense
CapSense Button
Cypress
84
CSS1
CapSense Linear Slider 5 Seg
CapSense Slider
Cypress
85
J9,J13,J15,J17,J19,J20,J21,J23,J24,J41,J42
PADS
PADS
86
TV1,TV2
PADS
PADS
Install On Bottom of PCB As Close ToCorners As Possible
87
BUMPER CLEAR .500X.23" SQUARE
Richco Plastic Co
RBS-3R
Special Jumper InstallationInstructions
88
J30
Install jumper across pins 1 and 2
Rectangular Connectors MINI JUMPER GF13.5 CLOSE TYPE BLACK
Kobiconn
151-8030-E
89
J10, J11
Kobiconn
151-8030-E
90
J43,J44
Kobiconn
151-8030-E
External Assembly
91
Install 3.3V label  as per assembly spec
3.3V label
92
4-40 X 5 +13 Brass Spacer Stud with Nut
Spacer and nut for RS232 Connector P7
Additional assembly instructions:
RoHS compliant assembly.  Use only non-lead solder.
Install 5 rubber bumper feet per board onsecondary side
Install 16 pin header on LCD pin-1aligned.  Load LCD/header combo at P8left justified.
Solder bare wire across Y2 crystal as perbelow image
Install Spacer and nut on RS232 ConnectorP7
重要提示:PCB作品文件展下载说明
 楼主| 发表于 2018-11-26 01:13:21 | 显示全部楼层
[hide=2,money] CY8CKIT-050B_SCHEMATIC.DSN.rar (90 KB, 下载次数: 2) CY8CKIT-050B_Board_Layout.brd.rar (680 KB, 下载次数: 2) [/hide]
    5 天前
  • 签到天数: 114 天
    发表于 2018-11-26 01:43:44 | 显示全部楼层
    发表于 2018-11-26 09:10:36 | 显示全部楼层
