查看: 2583|回复: 2
[Allegro16.6以下] 艾睿CY8CKIT-059, PSoC 5LP Prototyping Kit a features the CY8C5888LTI-LP097
终身成就奖原创先锋奖特殊贡献奖优秀斑竹奖金点子奖
发表于 2018-11-26 20:52:20 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
Item
Qty
Cy_Part#
Reference
Value
Description
Mfr Name
Mfr Part Number
N/A
N/A
PCB, 108.89mm x 24.13mm, High Tg, ENIGfinish, 2 layer, Color = BLACK, Silk = WHITE
Cypress Semiconductors
600-60178-01
C1,C3,C5,C6,C10,C11,C14,
C18,C20,C22,C23,C27,C29,
C32,C33,C34,C35,C39,C40
0.1 uF
CAP .1UF 16V CERAMIC Y5V 0402
AVX Corporation
0402YG104ZAT2A
C4
2200 pF
CAP CER 2200PF 50V 5% NP0 0805
Murata Electronics
GRM2165C1H222JA01D
510-60088-01
C7,C8,C9,C12,C13,C15,C16,
C21,C24,C25,C26,C28,C30,
C31,C36,C37,C38
1.0 uF
CAP CERAMIC 1.0UF 25V X5R 0603 10%
Taiyo Yuden
TMK107BJ105KA-T
C19
0.01 uF
CAP 10000PF 16V CERAMIC 0402 SMD
TDK Corporation
C1005X7R1C103K050BA
C41,C42
22 pF
CAP CER 22PF 50V 2% C0G 0402
TDK Corporation
C1005C0G1H220G050BA
D1,D2
MBR0520L
DIODE , SCHOTTKY, 20V, 0.5A, 400mW,SOD-123
Fairchild Semiconductor
MBR0520L
F1,F2
PTC Resettable Fuse
FUSE, PTC Resettable, 0.50A, 16V, 1210,SMD
Bel Fuse Inc
0ZCH0050FF2G
9
J6
USB Micro-B
CONN RCPT STD MICRO USB TYPE B
FCI
10103594-0001LF
LED1
User LED BLUE
LED, BLUE, CLEAR, 0805, SMD
Lite-On Inc
LTST-C170TBKT
LED2
POWER LED Amber
LED 595NM AMB DIFF 0805 SMD
Avago Technologies US Inc.
HSMA-C170
LED3
Status LED Green
LED GREEN CLEAR 0805 SMD
Chicago Miniature/Visual CommunicationsCompany-VCC
CMD17-21VGC/TR8
13
R2,R3
15K
RES SMD 15K OHM 5% 1/10W 0402
Panasonic - ECG
ERJ-2GEJ153X
14
R4,R6,R16,R17
22E
RES, 22 OHM, 1%, 100PPM, 1/16W, 0402
Panasonic - ECG
ERJ-2RKF22R0X
R5,R22,R23
ZERO
RES SMD 0.0 OHM JUMPER 06O3 1/10W
Panasonic - ECG
ERJ-3GEY0R00V
16
R7,R9
2.2K
RES 2.2K OHM 1/10W 5% 0603 SMD
Panasonic - ECG
ERJ-3GEYJ222V
17
R10
560 ohm
RES, 560 OHM, 5%, 200PPM, 1/10W, 0603,SMD
Panasonic-ECG
ERJ-3GEYJ561V
18
R12
100K
RES 100K OHM 1/10W 5% 0402 SMD
Panasonic - ECG
ERJ-2GEJ104X
R13,R14
30K
RES SMD 30K OHM 5% 1/10W 0402
Panasonic - ECG
ERJ-2GEJ303X
R8,R11,R15,R20
ZERO
RES SMD 0.0 OHM JUMPER 1/8W 0805
Panasonic - ECG
ERJ-6GEY0R00V
R18,R21
820 ohm
RES, 820 OHM, 5%, 1/10W, 0603
Panasonic - ECG
ERJ-3GEYJ821V
22
SW1,SW3
Switch
SW, TACTILE SWITCH, SPST-NO, 0.05A, 32V
C&K Components
KMR221GLFS
23
TVS1
TVS DIODE
DIODE, TVS, 5V, 350W, SOD-323
Semtech
SD05.TCT
24
CY8C5868LTI-LP039
U1
CY8C5868LTI-LP039 QFN68
PSoC 5LP CYC58LP, 67 MHz
CY8C5868LTI-LP039
25
CY8C5888LTI-LP097
U2
CY8C5888LTI-LP097 QFN68
PSoC 5LP CYC58LP, 80 MHz
CY8C5888LTI-LP097
26
U3
NTZD3152P
FET DUAL P-CH 20V 430mA SOT-563
ON Semiconductor
NTZD3152PT1G
No Load Components
C2,C17
0.1 uF
AVX Corporation
0402YG104ZAT2A
xxx-xxxxxx
J1,J2
HDR 1x26
CONN HDR BRKWAY 26POS VERT 2.54mm,15AU,TH
TE Connectivity
2-104427-4
J3,J7
HDR 1x5
CONN HEADER 5POS .100 VERT TIN
Molex
22-23-2051
J4
HDR 1x2
CONN HEADR BRKWAY .100 02POS STR
TE Connectivity
9-146280-0-02
J5
50MIL KEYED SMD
CONN, HEADER, MALE, 1.27mm, 10POS, GOLD,SMD
Samtec Inc
FTSH-105-01-L-DV-K
xxx-xxxxx
J8,J9
HDR 1x7
CONN HEADER FEMALE 7POS .1" GOLD
Sullins Connector Solutions
PPPC071LFBN-RC
R1,R19
4.7K
RES SMD 4.7K OHM 5% 1/10W 0402
Panasonic - ECG
ERJ-2GEJ472X
xxx-xxxx
SW2
SW PUSHBUTTON
SWITCH TACTILE SPST-NO 0.05A 12V
C&K Components
PTS635SL50 LFS
9
TP1,TP2,TP3
BLACK
TP, TEST POINT, 0.040"D, BLACK, TH
Keystone Electronics
5000
Y1
BLACK
CRYSTAL 32.768KHZ 12.5PF THRU
Citizen Finetech Miyota
CFS308-32.768KDZF-UB
Label
38
N/A
N/A
LBL, PCA Label, Vendor Code, Datecode,Serial Number 121-60210-01 REV 01 (YYWWVVXXXXX)
39
N/A
N/A
LBL, PCBA Anti-Static Warning, 10mm X10mm
重要提示:PCB作品文件展下载说明
 楼主| 发表于 2018-11-26 20:53:04 | 显示全部楼层
[hide=2,money] CY8CKIT-059_Schematics.DSN.rar (86 KB, 下载次数: 4) CY8CKIT-059_Layout.brd.rar (318 KB, 下载次数: 4)
[/hide]
    5 天前
  • 签到天数: 114 天
    发表于 2018-11-27 04:00:50 | 显示全部楼层
