查看: 2491|回复: 3
[Allegro16.6以下] 艾睿USB-Powered BeagleBoard based on OMAP3530 SoC使用CircuitCo的OMAP3530
终身成就奖原创先锋奖特殊贡献奖优秀斑竹奖金点子奖
发表于 2018-11-27 17:50:47 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
REV
Changes
ECO
Date
By
C3
Added C130, C140, L7, L8, BT1, and R66.
2009/3/6
GC
Added S-video fix and optional battery.
Corrected OMAP Rev to ES3.0
Switched to TPS65950 as inventory is nowavailable.
C3A
Added part number to R66
2009/4/5
GC
Replaced R70, R71, R72, R73 with 1%resistors.
Updated the Micron part number to matchthe orderable version.
C3B
Updated part number on Items 50 and 53.
2009/4/10
GC
C3C
Changed values of R64 and R65 to 1%.Concern over tolerance variance that could affect the incoming signaldetection.
2009/4/16
GC
Fixed several part number descriptions.
C3D
Added battery B1 to the BOM and removedR66. Corrected description on items 51, 54, and 55.
2009/4/21
GC
C3E
Removed BT1 from the BOM and added R66.
2009/5/11
GC
C3F
Added 22uf Capacitor in parallell withC97 to help increase yields on the EHCI issue.
2009/10/5
GC
C4
Switched OMAP processor to OMAP3530DCBB72which is the 720MHz version of the OMAP.
2009/10/5
GC
Added ability to run the USB PHY from1.8V or VAUX2 and replaced R68 with an inductor prior to first build.
Added 22uf Capacitor to the 1.8V VIOrail.
Switched to C4 PCB with required changes.
C4A
Switch R67 and R68. Switch R67 and R68.Corrected error on value of R112.
2009/11/5
GC
C4B
Changed Item #17 to a PGB1010603MR
2009/11/14
GC
C4C
Added R69 to item #36.
2009/11/16
GC
C4D
Changed R112 to 0603 package.
2009/11/17
GC
C5
Changed item # from to because thecurrent memory device is no longer made. Moved from 256MB NAND to 512MB.
2011/7/18
GC
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image002.gif
Document Title
Beagle PCB Assy BOM
Document Number
100-5000-000
Revision
C4D
Item
Description
Reference Designators
QTY
Part Number
Beagle PCB 6 layer, 3"x3", RevC4
N/A
BATTERY LITHIUM 3.1V RECHARGE
BT1
VL-1220/VCN
CAP CER .10UF 10V X5R 0402
C1,C3,C4,C7,C8,C9,C10,C11,C12,C13,C14,C15,C16,C17,C18,C19,C20,C21,C22,C23,C24,C25,C26,C27,C28,C29,C30,C31,C32,C33,C34,C35,C36,C37,C38,C39,C40,C41,C42,C43,C46,C50,C52,C64,C65,C73,C78,C84,C99,C103,C105,C107,C109,C110,C111,C113,C114,C115,C116,C117,C118,C119,C120,C121,C122,C123,C124,C125,C126,C129
70
LMK105BJ104KV-F
CAP CER 10UF 6.3V X5R 0805
C76,C77,C83,C85,C95,C97
JMK212BJ106KD-T
CAPACITOR TANT 10UF 6.3V 10% SMD, 3216
C2,C112,C128
T491A106K006AT
CAP CER .22UF 10V X5R 0402
C44,C45
GRM155R61A224KE19D
CAP CER 1UF 10V X5R 0402
C47,C48,C49,C55,C71,C74,C75,C79,C80,C81,C82,C86,C88,C89,C90,C91,C92,C93,C94,C96,C98,C100,C131,C132
24
GRM155R61A105KE15D
CAP CERAMIC 100PF 25V NP0 0402
C51,C58,C59,C60,C61,C62,C63
C0402C101J3GACTU
9
CAP CER 47UF 10V X5R 1210
C53,C54
GRM32ER61A476KE20L
CAP CER 47PF 50V C0G 5% 0402
C56,C57,C66,C67,C130,C140
C1005C0G1H470J
CAP 22PF 50V CERAMIC 0402 SMD
C69,C68
ECJ-0EC1H220J
CAP TANTALUM 2.2UF 6.3V 20% SMD
C72
TAJA225M006R
13
CAP TANT 100UF 6.3V 10% SMD
C101
T491M107K006ZT
14
CAP CERAMIC 4.7UF 6.3V X5R 0402
C102,C106,C108,C133, C134, C135, C136,C137, C138, C139, C127
ECJ-0EB0J475M
CAP CER 2.2UF 6.3V X5R 0402
C87
JMK105BJ225MV-F
16
CAP CER 22UF 6.3V X5R 20% 0805
C141,C104
C2012X5R0J226M
17
PulseGuard Supressors 0603 24VDC 45A
D1,D2,D3,D4
PGB1010603MR
18
LED GREEN CLEAR 1206 SMD
D5,D6,D7,D12
LTST-C150GKT
VARISTOR TVS MULTI 5.5V 30A 0603
D8,D9,D10,D11
V5.5MLA0603H
CONN POWER JACK 2.1MM
J1
PJ-002A
IND,POWER,1.0UH,30%,ISAT=2.0A,SMT
L1,L3
LPS3015-102MLC
22
IND,POWER,1.0UH,30%,SMT
L2
LPS3010-102MLC
23
FERRITE CHIP 300 OHM 500MA 0603
L4,L5,L6
MMZ1608R301A
24
INDUCTOR 3.3UH 10% 0603 SMD
L7,L8
83R3K-T
25
CONN RECEPT USB 5POS RT ANG SMD
P1
26
HEADER 14POS .100" STR TIN, DUALROW, 7 x2
P2
0.2
67997-472HLF
27
CONN RECEPT RTANG 4 POS GOLD PCB
P4
5749181-1-ND
CONN JACK STEREO 3POS 3.5MM SMD
P5,P6
SJ1-3513-SMT
29
CONN RCPT USB TYPE A R/A PCB
P7
87520-0010BLF
30
CONN 6 in 1, MMC/SD
P8
MHC-W21-601-LF
7SDMM-B0-0011
31
HEADER 10POS .100" STR TIN, DUALROW, 5 x 2
P9
0.14
67997-472HLF
32
CONN RCPT HDMI R/A SMD
P10
10029449-001RLF
33
TRANS ARRAY PNP/PNP W/RES S MINI
Q1
XP0421400L
34
RES ARRAY 10 OHM 5% 8 RES SMD
RP1,RP2,RP3,RP4
EXB-2HV100JV
35
POLYSWITCH RXE SERIES 0.10A HOLD
RT1
RXEF010
36
RES 0.0 OHM 1/10W 5% 0603 SMD
R43,R66,R69
ERJ-3GEY0R00V
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image003.gif
Document Title
Beagle PCB Assy BOM
Document Number
100-5000-000
Revision
C4D
37
Description
QTY
Part Number
37
RES 620K OHM 1/10W 1% 0603 SMD
R3
MCR03EZPFX6203
37
RES 200K OHM 1/10W 1% 0603 SMD
R4
MCR03EZPFX2003
38
RES 0.10 OHM 1/8W 5% 0805
R6
73L3R10J
39
RES 56.2K OHM 1/16W 1% 0402 SMD
R7
CRCW040256K2FKED
40
RES 22.6K OHM 1/10W 1% 0603 SMD
R8
MCR03EZPFX2262
41
RES, 330 OHM 1/10W 1% 0603 SMD
R9,R34,R35,R48
MCR03EZPFX3300
42
RES 33 OHM 1/16W 5% 0402 SMD
R10,R38,R40,R42,R44,R46,R53
CRCW040233R0JNED
43
RES 4.7K OHM 1/16W 5% 0402 SMD
R11,R12,R13,R14,R41,R45,R47,R97,R100
9
CRCW04024K70JNED
44
RES 10.0K OHM 1/16W 1% 0402 SMD
R15,R16,R22,R36,R37,R39,R49,R54,R55,R56,R57,R58,R59,R60,R61,R62,R63,R82,R98,R101,R102,R109,R111
22
MCR01MZPJ103
45
RES 100K OHM 1/16W 5% 0402 SMD
R17,R18,R19,R20,R21
CRCW0402100KJNED
46
RES 1.65K OHM 1/16W 1% 0402 SMD
R27,R28
CRCW04021K65FKED
47
RES 10K OHM 1/10W 5% 0603 SMD
R29,R32,R33,R50,R112
MCR03EZPJ103
48
RES 0.0 OHM 1/16W 5% 0402 SMD
R51
MCR01MZPJ000
49
RES 8.06K OHM 1/10W 1% 0603 SMD
R52,R65
MCR03EZPFX8061
50
RES 8.45K OHM 1/10W 1% 0603 SMD
R64
MCR03EZPFX8451
51
RES 1.2K OHM 1/10W 1% 0603SMD
R70,R72
MCR03EZPFX1201
52
RES, 510 OHM 1/10W 1% 0603 SMD
R95
MCR03EZPFX5100
53
RES 1.0K OHM 1/16W 5% 0402 SMD
R99,R96
CRCW04021K00JNED
54
RES 1.0K OHM 1/10W 1% 0603 SMD
R71,R73
MCR03EZPFX1001
55
RES 1.0K OHM 1/5W 5% 0603 SMD
R110
ESR03EZPJ102
56
INDUCTOR 10UH 50MA 0603
R67
LQM18FN100M00
57
SWITCH TACT 6MM MOM 100GF
S1,S2
B3F-1000
58
TESTPTL, large
TP1
0.025
67997-472HLF
59
HEADER, 2 POS
J2
0.1
67997-472HLF
60
IC USB ADJ LDO 5V HP 14-HTSSOP, TSP2141
U1
TPS2141IPWP
61
IC REG LDO CAP FREE 8-SON
U2
TPS73701DRBR
62
IC_OMAP3530D,BGA,515 PIN, ProductionRelease
U3
OMAP3530DCBB72
63
IC, POP Memory 2Gb Flash/2Gb SDRAM,Micron
U3x
MT29C4G48MAZAPAKQ-5 IT
64
IC DUAL BUFF/DRVR W/OD SOT23-6
U4
SN74LVC2G07DBVR
65
IC, TPS65950
U5
TPS65950
66
IC SWITCH PWR DISTRIB 1A 8-MSOP
U6
TPS2061DGNR
HS USB Trnscvr w/1.8V ULPI -12MHz Ref Clk
U7
USB3326A-GL-TR
67
HS USB Trnscvr w/1.8V ULPI -19MHz Ref Clk
USB3322A-GL-TR
68
IC TRANSMITTER DIGITAL 64-PQFP
U8
TFP410PAP
69
IC VOLT-LEVEL TRANSLATOR 8-US8
U9,U11
TXS0102DCUR
70
IC LINE DVR/RCVR 1CH 16-TSSOP
U10
SN65C3221EPWR
71
Oscillator, 1.8V, 26MHz
Y1 (Y1A)*
EP16E7E2H-26.000M_TR
(SG-210SEB 26.0000MF)
72
CRYSTAL 32.768KHZ 12.5PF SMD
Y2
FX135A-327
Document Title
Beagle PCB Assy BOM
Document Number
100-5000-000
Revision
C4D
37
COMPONENTS NOT INSTALLED
* Install either Y1 or Y1A.
R30, R31, R5, J3,J4,J5,TP2, C70,R68,R103, R104, R105, R106, R107, R108, R113,C70,J12,J13
重要提示:PCB作品文件展下载说明
 楼主| 发表于 2018-11-27 17:51:30 | 显示全部楼层
BEAGLE_PUB_C5.DSN.rar (169 KB, 下载次数: 2) ctc057.brd.rar (1.14 MB, 下载次数: 2)
    昨天 09:12
    PADS-180606高级班
    发表于 2018-11-27 18:22:02 | 显示全部楼层
    昨天 18:42
  • 签到天数: 141 天
    你必须非常努力才能显
    发表于 2018-11-27 19:06:50 | 显示全部楼层
