查看: 4326|回复: 15
[Allegro16.6以下] 艾睿USB-Powered BeagleBoard based on OMAP3530 SoC使用CircuitCo的OMAP3530
终身成就奖原创先锋奖特殊贡献奖优秀斑竹奖金点子奖
发表于 2018-11-27 17:52:39 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
REV
Changes
ECO
Date
By
B
Initial release for revison B PCBassembly.
2008/3/14
GC
B1
Corrected R6 to be a .1 ohm resistor
2008/5/6
GC
Changed C102, C104, and C106 to a 4.7uf.This is back to the original value.
B1A
Changed quantity of Item #3 and Item #4.Changed part number for Items #13, #51, & #26.
2008/5/19
GC
B1B
Changed item #15 part number to thecorrect part number
2008/6/2
GC
B2
Added new item to the BOM for a 1ufCapacitor to be used in place of a .1uf Capacitor for 19 devices.
2008/6/3
GC
Change C2 from 1uF to 10uF.
B2A
Deleted P7, the USB Host connector, fromthe BOM. Changed QTY on item 35 to 2 to match the reference designators..
2008/6/3
GC
B3
Remove all associated parts that are usedon the USB host port. Removed C101-C107, R49-R51, U6, U7, and P7
2008/6/11
GC
B3A
Removed C87 from item 6
2008/6/18
GC
B3B
2008/6/20
GC
B3C
Added C104 and C106 back into the BOM tohelp with some noise issues.
2008/6/23
GC
B4
Added 4.7uF capacitor across D3 for issueof some hubs not working.
2008/6/25
GC
B4A
Changed partnumber on item 28 to thesupplier part number
2008/7/17
GC
B5
Remove C70 form the BOM t improve 32KHzclock rise and fall times.
2008/8/13
GC
B5A
Change PCB revision to B1
2008/9/22
GC
Update BOM to reflect new packages forPCB Revsion B1
Remove DX modification and updated thenot populated section.
B6
Changed revsion to B6 to reduce confusionin the field
2008/10/1
GC
B6A
Changed OMAP3530 to ES3.0 version
2008/10/20
GC
B6B
Added Kingconn as supplier to item #26.
2008/11/3
GC
Added Epson as supplier to Item #65.
Changed item 56 back to ES2.1 due toavailability issues with ES3.0
B7
Changed item 56 back to ES3.0
2008/11/17
GC
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image002.gif
Document Title
Beagle PCB Assy BOM
Document Number
100-5000-000
Revision
B7
Item
Description
Reference Designators
QTY
Part Number
Beagle PCB 6 layer, 3"x3", RevB1
N/A
CAP CER .10UF 10V X5R 0402
C1,C3,C4,C7,C8,C9,C10,C11,C12,C13,C14,C15,C16,C17,C18,C19,C20,C21,C22,C23,C24,C25,C26,C27,C28,C29,C30,C31,C32,C33,C34,C35,C36,C37,C38,C39,C40,C41,C42,C43,C46,C50,C52,C64,C65,C73,C78,C84,C99,C105,C107,C109,C110,C111,C113,C114,C115,C116,C117,C118,C119,C120,C121,C122,C123,C124,C125,C126,C129
69
LMK105BJ104KV-F
CAP CER 10UF 6.3V X5R 0805
C76,C77,C83,C85,C95,C97
JMK212BJ106KD-T
CAPACITOR TANT 10UF 6.3V 10% SMD, 3216
C2,C112,C128
T491A106K006AT
CAP CER .22UF 10V X5R 0402
C44,C45
GRM155R61A224KE19D
CAP CER 1UF 10V X5R 0402
C47,C48,C49,C55,C71,C74,C75,C79,C80,C81,C82,C86,C88,C89,C90,C91,C92,C93,C94,C96,C98,C100
22
GRM155R61A105KE15D
CAP CERAMIC 100PF 25V NP0 0402
C51,C58,C59,C60,C61,C62,C63
C0402C101J3GACTU
CAP CER 47UF 10V X5R 1210
C53,C54
GRM32ER61A476KE20L
9
CAP CER 47PF 50V C0G 5% 0402
C56,C57,C66,C67
C1005C0G1H470J
CAP 22PF 50V CERAMIC 0402 SMD
C69,C68
ECJ-0EC1H220J
CAP TANTALUM 2.2UF 6.3V 20% SMD
C72
TAJA225M006R
CAP TANT 100UF 6.3V 10% SMD
C101
T491M107K006ZT
13
CAP CERAMIC 4.7UF 6.3V X5R 0402
C104,C106,C108,C127
ECJ-0EB0J475M
14
CAP CER 2.2UF 6.3V X5R 0402
C87
GRM155R60J225ME15D
14
PulseGuard Supressors 0603 24VDC 45A
D1,D2,D3,D4
PGB0010603MR
LED GREEN CLEAR 1206 SMD
D5,D6,D7,D12
LTST-C150GKT
16
VARISTOR TVS MULTI 5.5V 30A 0603
D8,D9,D10,D11
V5.5MLA0603H
17
CONN POWER JACK 2.1MM
J1
PJ-002A
18
IND,POWER,1.0UH,30%,ISAT=2.0A,SMT
L1,L3
LPS3015-102MLC
IND,POWER,1.0UH,30%,SMT
L2
LPS3010-102MLC
FERRITE CHIP 300 OHM 500MA 0603
L4,L5,L6
MMZ1608R301A
CONN RECEPT USB 5POS RT ANG SMD
P1
22
HEADER 14POS .100" STR TIN, DUALROW, 7 x2
P2
0.2
67997-472HLF
23
CONN RECEPT RTANG 4 POS GOLD PCB
P4
5749181-1-ND
24
CONN JACK STEREO 3POS 3.5MM SMD
P5,P6
SJ1-3513-SMT
25
CONN RCPT USB TYPE A R/A PCB
P7
87520-0010BLF
26
CONN 6 in 1, MMC/SD
P8
MHC-W21-601-LF
7SDMM-B0-0011
27
HEADER 10POS .100" STR TIN, DUALROW, 5 x 2
P9
0.14
67997-472HLF
CONN RCPT HDMI R/A SMD
P10
10029449-001RLF
29
TRANS ARRAY PNP/PNP W/RES S MINI
Q1
XP0421400L
30
RES ARRAY 10 OHM 5% 8 RES SMD
RP1,RP2,RP3,RP4
EXB-2HV100JV
31
POLYSWITCH RXE SERIES 0.10A HOLD
RT1
RXEF010
32
RES 0.0 OHM 1/10W 5% 0603 SMD
R1,R43
ERJ-3GEY0R00V
33
RES 620K OHM 1/10W 1% 0603 SMD
R3
MCR03EZPFX6203
Document Title
Beagle PCB Assy BOM
Document Number
100-5000-000
Revision
B7
37
Description
QTY
Part Number
34
RES 200K OHM 1/16W 5% 0603 SMD
R4
MCR03EZPFX2003
35
RES 0.10 OHM 1/8W 5% 0805
R6
73L3R10J
36
RES 56.2K OHM 1/16W 1% 0402 SMD
R7
CRCW040256K2FKED
37
RES 22.6K OHM 1/10W 1% 0603 SMD
R8
MCR03EZPFX2262
38
RES, 330 OHM 1/10W 1% 0603 SMD
R9,R34,R35,R48
MCR03EZPFX3300
39
RES 33 OHM 1/16W 5% 0402 SMD
R10,R38,R40,R42,R44,R46
CRCW040233R0JNED
40
RES 4.7K OHM 1/16W 5% 0402 SMD
R11,R12,R13,R14,R41,R45,R47,R97,R100
9
CRCW04024K70JNED
41
RES 10.0K OHM 1/10W 1% 0402 SMD
R15,R16,R22,R36,R37,R39,R54,R55,R56,R57,R58,R59,R60,R61,R62,R63,R82,R98,R101,R102,R109
MCR01MZPJ103
42
RES 100K OHM 1/16W 5% 0402 SMD
R17,R18,R19,R20,R21
CRCW0402100KJNED
43
RES 1.65K OHM 1/16W 1% 0402 SMD
R27,R28
CRCW04021K65FKED
44
RES 10K OHM 1/10W 5% 0603 SMD
R29,R32,R33,R64,R65,R71,R73
MCR03EZPJ103
45
RES 820 OHM 1/10W 1% 0603 SMD
R50
MCR03EZPFX8200
46
RES 0.0 OHM 1/16W 5% 0402 SMD
R51
MCR01MZPJ000
47
RES 8.064K OHM 1/10W 1% 0603 SMD
R52
MCR03EZPFX8061
48
RES 12K OHM 1/10W 5% 0603 SMD
R70,R72
MCR03EZPJ123
49
RES, 510 OHM 1/10W 1% 0603 SMD
R95
MCR03EZPFX5100
50
RES 1.0K OHM 1/16W 5% 0402 SMD
R99,R96
CRCW04021K00JNED
51
RES, 1K OHM 1/10W 1% 0603 SMD
R110
RT0603DRD071KL
52
SWITCH TACT 6MM MOM 100GF
S1,S2
B3F-1000
53
TESTPTL, large
TP1,TP2
0.05
67997-472HLF
54
IC USB ADJ LDO 5V HP 14-HTSSOP, TSP2141
U1
TPS2141IPWP
55
IC REG LDO CAP FREE 8-SON
U2
TPS73701DRBR
56
IC_OMAP3530C,BGA,515 PIN
U3
OMAP3530 ES3.0
57
IC, POP Memory 2Gb Flash/1Gb SDRAM,Micron
U3x
MT29C2G24MAKLAJG-6 IT ES
58
IC DUAL BUFF/DRVR W/OD SOT23-6
U4
SN74LVC2G07DBVR
59
IC, TWL4030/TPS65950
U5
TWL4030/TPS65950
60
IC SWITCH PWR DISTRIB 1A 8-MSOP
U6
TPS2061DGNR
61
HS USB Trnscvr w/1.8V ULPI -12MHz Ref Clk
U7
USB3326A-GL-TR
HS USB Trnscvr w/1.8V ULPI -19MHz Ref Clk
USB3322A-GL-TR
62
IC TRANSMITTER DIGITAL 64-PQFP
U8
TFP410PAP
63
IC VOLT-LEVEL TRANSLATOR 8-WCSP
U9,U11
TXS0102DCUR
64
IC LINE DVR/RCVR 1CH 16-TSSOP
U10
SN65C3221EPWR
65
Oscillator, 1.8V, 26MHz
Y1
EP16E7E2H-26.000M_TR
SG-210SEB 26.0000MF
66
CRYSTAL 32.768KHZ 12.5PF SMD
Y2
FX135A-327
COMPONENTS NOT INSTALLED
R30, R31, R5, J3,  J2, C70, R70,R72,R49,P7,U7,R103, R104,R105, R106, R107, R108, C70,Y1A,R50,R51,R52,C101,C102,C103,U6
重要提示:PCB作品文件展下载说明
 楼主| 发表于 2018-11-27 17:53:34 | 显示全部楼层
[hide=2,money] BEAGLEBOARD_B7.DSN.rar (171 KB, 下载次数: 3) ctc036.brd.rar (1.1 MB, 下载次数: 2) [/hide]
    昨天 09:12
    PADS-180606高级班
    发表于 2018-11-27 18:21:33 | 显示全部楼层
    发表于 2018-11-27 18:44:58 | 显示全部楼层
    昨天 18:42
  • 签到天数: 141 天
    你必须非常努力才能显
    发表于 2018-11-27 19:06:24 | 显示全部楼层
    终身成就奖社区居民优秀斑竹奖
    发表于 2018-11-27 19:07:51 | 显示全部楼层
    谢谢分享艾睿USB-Powered BeagleBoard based on OMAP3530 SoC使用CircuitCo的OMAP3530DCBB72的参考设计第7版原理图PCB
  • 签到天数: 54 天
    1元学习PADS(5期)
    发表于 2018-11-27 19:45:33 | 显示全部楼层
    郁闷
    2024-12-1 17:54
    发表于 2018-11-27 20:41:25 | 显示全部楼层
    发表于 2018-11-27 21:36:24 | 显示全部楼层
    终身成就奖原创先锋奖优秀斑竹奖
    发表于 2018-11-28 06:49:27 | 显示全部楼层
