查看: 3479|回复: 7
[Pads_VX.2x] DC2509A, Gleanergy Multi-Source Energy Harvesting Demo Board使用 Analog Dev
终身成就奖原创先锋奖特殊贡献奖优秀斑竹奖金点子奖
发表于 2018-11-28 15:21:58 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
C1, C2
CAP, CHIP,100μF, 10V, 20%, X5R, 1206
TDK,C3216X5R1A107M160AC
C3
CAP, CHIP,4.7μF, 10V, 10%, X7R, 0805
WÜRTH, 885012 207 025
C4, C5
CAP, CHIP,47μF, 10V, 20%, X5R, 1206
WÜRTH, 885012 108 012
C6
CAP, CHIP,0.1μF, 10V, 10%, X7R, 0603
WÜRTH, 885012 206 020
C34
CAP, CHIP,X7R, 2.2μF, 10%, 10V, 0603
WÜRTH,885012206027
D2
DIODESCHOTTKY 20V, 1A, SOD-323
NXP,PMEG2010EA
D3
DIODEZENER (5.1V, 55mA, REVERSE)
CENTRAL,CMHZ4689
L1
INDUCTOR,SHIELDED 15μH, 1.03A, 0.22Ω, 4.8mm x 4.8mm
WÜRTH,744042150
9
R1, R18
RES, CHIP,2.37MΩ, 1%, 1/10W, 0603
VISHAY,CRCW06032M37FKEA
R2
RES, CHIP,453kΩ, 1%, 1/10W, 0603
VISHAY,CRCW0603453KFKEA
R5
RES, CHIP,1MΩ, 1/10W, 1%, 0603
PANASONIC,ERJ-3EKF1004V
U1
LOW QUIESCENTCURRENT, BUCK-BOOST POWER MANAGER WITH MPPC
LINEARTECH, LTC3106EUDC
LTC3107CIRCUIT COMPONENTS:
13
C7
CAP,TANTALUM-POLYMER, 330μF, 6.3V, 20%
PANASONIC,6TPE330MIL
14
C8
CAP, CHIP,1000pF, 50V, 10%, X7R, 0603
WÜRTH, 885012 206 083
C9
CAP, CHIP,330pF, 50V, 10%, X7R, 0603
WÜRTH, 885012 206 080
16
C10, C13
CAP, CHIP,10μF, 6.3V, 20%, X5R, 0603
WÜRTH, 885012 106 006
17
C11
CAP, CHIP,X5R, 2.2μF, 6.3V, 20%, 0603
WÜRTH, 885012 106 004
18
C12
CAP,TANTALUM-POLYMER, 220μF, 6.3V, 20%
PANASONIC,6TPE220MI
C35
CAP, CHIP,X5R, 0.1μF, 20%, 10V, 0402
WÜRTH, 885012 105 010
R19
RES, CHIP,499kΩ, 1/10W, 0603
PANASONIC,ERJ-3EKF4993V
T1
TRANSFORMER,100:1 TURNS RATIO, 6.0mm x 6.0mm
WÜRTH,74488540070
22
U2
ULTRA-LOWVOLTAGE ENERGY HARVESTER / PRIMARY
BATTERYLIFE EXTENDER
LINEARTECH, LTC3107EDD
23
U6
IC,ULTRA-LOW POWER SUPERVISOR WITH POWER-FAIL OUTPUT, TSOT-23
LINEARTECH, LTC2935CTS8-2
LTC3330CIRCUIT COMPONENTS:
24
C14
CAP, CHIP,X5R, 22uF, 20%, 25V, 1210
WÜRTH, 885012 109 014
25
C15, C17
CAP, CHIP,X5R, 1μF, 20%, 6.3V, 0402
WÜRTH, 885012 105 006
26
C16
CAP, CHIP,X5R, 4.7μF, 20%, 6.3V, 0603
WÜRTH, 885012 106 005
27
C18, C21
CAP, CHIP,X5R, 22μF, 20%, 6.3V, 1206
WÜRTH, 885012 108 003
C19
CAP, CHIP,X5R, 150μF, 20%, 6.3V, 1210
SAMSUNG,CL32A157MQVNNNE
29
C20
30
L2
INDUCTOR,100μH , 0.51A, 0.60Ω, 4.8mm x 4.8mm
WÜRTH,744043101
31
L3
INDUCTOR,22μH, 1.00A, 0.37Ω, 4mm x 4.5mm
WÜRTH,744773122
32
U3
ENERGYHARVESTING DC/DC WITH BATTERY BACKUP
LINEARTECH,  LTC3330EUH
LTC3331CIRCUIT COMPONENTS:
33
C22
34
C23
35
C24
36
C26
37
C27
38
C25
39
D1
DIODE,SCHOTTKY, 30V, 0.1A, SOD-523
CENTRAL,CMOSH-3
40
L4
WÜRTH,744043101
41
L5
WÜRTH,744773122
42
Q1
SMT,BIPOLAR, PNP, 40V, SOT-23
CENTRAL,CMPT3906E
43
Q2
SMT, DUALMOSFET, NCHANNEL/PCHANNEL, 60V, SuperSOT-6
FAIRCHILD,NDC7001C
44
R72
RES, CHIP,113Ω, 1/16W,1%, 0402
VISHAY,CRCW0402113RFKED
45
R73, R75
RES, CHIP,1MΩ, 1/16W,1%, 0402
VISHAY,CRCW04021M00FKED
46
R74
RES, CHIP,100kΩ, 1/16W,1%, 0402
VISHAY,CRCW0402100KFKED
47
R76
RES, CHIP,3.01kΩ, 1/16W,1%, 0402
VISHAY,CRCW04023K01FKED
48
R77
RES, CHIP,100Ω, 1/16W,1%, 0402
VISHAY,CRCW0402100RFKED
49
U4
NANOPOWERBUCK-BOOST DC/DC WITH EH BATTERY CHARGER
LINEARTECH,  LTC3331EUH
SWITCHEDOUTPUT AND SIGNAL BUFFERING COMPONENTS:
50
C28
51
Q3
N-CHANNELMOSFET, 30V, SOT23
ZETEX,ZXMN2F30FH
52
Q4-Q14
DUALMOSFET 20V N-TYPE/P-TYPE
VISHAY,SI1553CDL-T1-GE3
53
R91
RES, CHIP,3MΩ, 1%, 1/10W, 0603
VISHAY,CRCW06033M00FKEA
54
24
R92,R100-R113, R120-R128
RES, CHIP,10MΩ, 1%, 1/10W, 0603
VISHAY,CRCW060310M0FKEA
55
U5
POWERSOURCES AND ENERGY STORAGE COMPONENTS:
56
BAT1
CR2032COIN LI-ION BATTERY
ENERGIZER, CR2032VP
57
BAT2
COINLI-ION BATTERY Lir2032
POWERSTREAM,Lir2032
58
BTH1, BTH2
BATTERYHOLDER COIN CELL 2032 SMD
WÜRTH,79527141
59
C30
SUPERCAP,15mF, -20%, +80%, 5.5V, SMD
AVX,BZ055B153ZSB
60
CO1-CO10
ADDITIONALDEMO BOARD CIRCUIT COMPONENTS:
61
C31 (OPT)
SUPERCAP,85mF, 5.0V, 20mm x 18mm
CAP-XX,GA209F
62
C32, C33(OPT)
63
D4-D7(OPT)
DIODE,SCHOTTKY, 40V, 1A, SOD-123
DIODESINC, 1N5819HW-7-F
64
R87, R88(OPT)
RES, CHIP,7.5kΩ, 1/16W, 1%, 0402
VISHAY,CRCW04027K50FKED
HARDWAREFOR DEMO BOARD ONLY:
65
E1-E19
TURRET,0.061 DIA
MILL-MAX,2308-2
66
J1
2X10,20-PIN, SMT RIGHT ANGLE SOCKET w/KEY (PIN 14), 0.100"
SAMTEC,SMH-110-02-L-D-14
67
J2
2X6,12-PIN, SMT RIGHT ANGLE SOCKET w/KEY (PIN 5), 0.100"
SAMTEC,SMH-106-02-L-D-05
68
JP1-JP4,JP5-JP8
SMTHEADER, 2 PINS, 2mm
SAMTEC,TMM-102-01-F-S-SM
69
JP17
SMTHEADER, 6 TOTAL PINS, 2 ROWS, 2mm
WÜRTH, 621006 219 21
70
JP18
SMTHEADER, 8 TOTAL PINS, 2 ROWS, 2mm
WÜRTH, 621008 219 21
71
JP19
HEADER, 3PINS, 2mm
WÜRTH, 620003 111 21
72
JP20
HEADER, 4PINS, 2mm
WÜRTH, 620004 111 21
73
JP21
HEADER, 4TOTAL PINS, 2 ROWS, 2mm
WÜRTH, 620004 211 21
74
JP3, JP7,JP17B, JP18C, JP19, JP20, JP21A
SHUNT 2MM
WÜRTH, 608002 134 21
75
PB1
SWITCHTACTILE, SPST-NO, 0.05A 12V
WÜRTH, 434111025826
76
34
R3, R6,R9, R10, R12, R15, R16, R20, R23, R25, R26, R28, R31, R32, R35, R37, R39,R41, R42, R44, R46, R49, R51, R53, R55, R56, R58, R61, R63, R65, R67, R68,R70, R89
RES, CHIP,0Ω, 0603
VISHAY,CRCW06030000Z0EA
77
R4, R7,R8, R11, R13, R14, R17, R21, R22, R24, R27, R29, R30, R33, R34, R36, R38,R40, R43, R45, R47, R48, R50, R52, R54, R57, R59, R60, R62, R64, R66, R69,R71, R90, R99 (OPT)
RES, CHIP,0Ω, 0603
78
R78, R79,R81, R83, R85, R86,  R96, R97, R98,R114, R117, R119 (OPT)
RES, CHIP,0Ω, 0402
VISHAY,CRCW04020000Z0ED
79
9
R80, R82,R84, R93, R94, R95,  R115, R116, R118
RES, CHIP,0Ω, 0402
80
SW1, SW4,SW7
DP3T SLIDESWITCH, 12mmx3.5mm, 0.2A 12VDC
COPAL,CL-SB-23A-02T
81
SW2
4PDT SLIDESWITCH, 16.5mmx7mm, 0.1A 30VDC
ALPS,SSSF040800
DPDT SLIDESWITCH, 8.5mm x 3.5mm, 0.2A 12VDC
COPAL,CL-SB-22A-01T
83
0.001
ELECTRICALTAPE, 3/4" x 1/2"
3M, 33+SUPER (3/4"X66')
84
STANDOFFx6 (OPT)
STANDOFF,HEX .625"L, 4-40, THR NYLON
KEYSTONE,1902F
85
SCREW x6(OPT)
SCREW,MACH, PHIL, 4-40, .250 IN, NYLON
B&F FASTENERSUPPLY, NY PMS 440 0025 PH
86
FAB,PRINTED CIRCUIT BOARD
DEMOCIRCUIT 2344A
87
STENCIL -TOP
STENCIL  #2590A-TOP
88
STENCIL -BOTTOM
STENCIL  #2509A-BOTTOM
SKIPPEDREFERENCE DESIGNATORS (TO MATCH DC2344A):
89
C29 (DOESNOT EXIST)
90
JP9-JP16(DOES NOT EXIST)
91
SW3, SW5,SW6 (DOES NOT EXIST)
C1, C2
CAP, CHIP, 100μF, 10V, 20%, X5R, 1206
TDK, C3216X5R1A107M160AC
C3
CAP, CHIP, 4.7μF, 10V, 10%, X7R, 0805
WÜRTH, 885 012 207 025
C4, C5
CAP, CHIP, 47μF, 10V, 20%, X5R, 1206
WÜRTH, 885 012 108 012
C6
CAP, CHIP, 0.1μF, 10V, 10%, X7R, 0603
WÜRTH, 885 012 206 020
C34
CAP, CHIP, X7R, 2.2μF, 10%, 10V, 0603
WÜRTH, 885012206027
D2
DIODE SCHOTTKY 20V, 1A, SOD-323
NXP, PMEG2010EA
D3
DIODE ZENER (5.1V, 55mA, REVERSE)
CENTRAL, CMHZ4689
L1
INDUCTOR, SHIELDED 15μH, 1.03A, 0.22Ω,4.8mm x 4.8mm
WÜRTH, 744042150
9
R1, R18
RES, CHIP, 2.37MΩ, 1%, 1/10W, 0603
VISHAY, CRCW06032M37FKEA
R2
RES, CHIP, 453kΩ, 1%, 1/10W, 0603
VISHAY, CRCW0603453KFKEA
R5
RES, CHIP, 1MΩ, 1/10W, 1%, 0603
PANASONIC, ERJ-3EKF1004V
U1
LOW QUIESCENT CURRENT, BUCK-BOOST POWERMANAGER WITH MPPC
LINEAR TECH, LTC3106EUDC
LTC3107 CIRCUIT COMPONENTS:
13
C7
CAP, TANTALUM-POLYMER, 330μF, 6.3V, 20%
PANASONIC, 6TPE330MIL
14
C8
CAP, CHIP, 1000pF, 50V, 10%, X7R, 0603
WÜRTH, 885 012 206 083
C9
CAP, CHIP, 330pF, 50V, 10%, X7R, 0603
WÜRTH, 885 012 206 080
16
C10, C13
CAP, CHIP, 10μF, 6.3V, 20%, X5R, 0603
WÜRTH, 885 012 106 006
17
C11
CAP, CHIP, X5R, 2.2μF, 6.3V, 20%, 0603
WÜRTH, 885 012 106 004
18
C12
CAP, TANTALUM-POLYMER, 220μF, 6.3V, 20%
PANASONIC, 6TPE220MI
C35
CAP, CHIP, X5R, 0.1μF, 20%, 10V, 0402
WÜRTH, 885 012 105 010
R19
RES, CHIP, 499kΩ, 1/10W, 0603
PANASONIC, ERJ-3EKF4993V
T1
TRANSFORMER, 100:1 TURNS RATIO, 6.0mm x6.0mm
WÜRTH, 74488540070
22
U2
ULTRA-LOW VOLTAGE ENERGY HARVESTER /PRIMARY
BATTERY LIFE EXTENDER
LINEAR TECH, LTC3107EDD
23
U6
IC, ULTRA-LOW POWER SUPERVISOR WITHPOWER-FAIL OUTPUT, TSOT-23
LINEAR TECH, LTC2935CTS8-2
LTC3330 CIRCUIT COMPONENTS:
24
C14
CAP, CHIP, X5R, 22uF, 20%, 25V, 1210
WÜRTH, 885 012 109 014
25
C15, C17
CAP, CHIP, X5R, 1μF, 20%, 6.3V, 0402
WÜRTH, 885 012 105 006
26
C16
CAP, CHIP, X5R, 4.7μF, 20%, 6.3V, 0603
WÜRTH, 885 012 106 005
27
C18, C21
CAP, CHIP, X5R, 22μF, 20%, 6.3V, 1206
WÜRTH, 885 012 108 003
C19
CAP, CHIP, X5R, 150μF, 20%, 6.3V, 1210
SAMSUNG, CL32A157MQVNNNE
29
C20
30
L2
INDUCTOR, 100μH , 0.51A, 0.60Ω, 4.8mm x4.8mm
WÜRTH, 744043101
31
L3
INDUCTOR, 22μH, 1.00A, 0.37Ω, 4mm x 4.5mm
WÜRTH, 744773122
32
U3
ENERGY HARVESTING DC/DC WITH BATTERYBACKUP
LINEAR TECH,  LTC3330EUH
LTC3331 CIRCUIT COMPONENTS:
33
C22
34
C23
35
C24
36
C26
37
C27
38
C25
39
D1
DIODE, SCHOTTKY, 30V, 0.1A, SOD-523
CENTRAL, CMOSH-3
40
L4
WÜRTH, 744043101
41
L5
WÜRTH, 744773122
42
Q1
SMT, BIPOLAR, PNP, 40V, SOT-23
CENTRAL, CMPT3906E
43
Q2
SMT, DUAL MOSFET, NCHANNEL/PCHANNEL, 60V,SuperSOT-6
FAIRCHILD, NDC7001C
44
R72
RES, CHIP, 113Ω, 1/16W,1%, 0402
VISHAY, CRCW0402113RFKED
45
R73, R75
RES, CHIP, 1MΩ, 1/16W,1%, 0402
VISHAY, CRCW04021M00FKED
46
R74
RES, CHIP, 100kΩ, 1/16W,1%, 0402
VISHAY, CRCW0402100KFKED
47
R76
RES, CHIP, 3.01kΩ, 1/16W,1%, 0402
VISHAY, CRCW04023K01FKED
48
R77
RES, CHIP, 100Ω, 1/16W,1%, 0402
VISHAY, CRCW0402100RFKED
49
U4
NANOPOWER BUCK-BOOST DC/DC WITH EHBATTERY CHARGER
LINEAR TECH,  LTC3331EUH
SWITCHED OUTPUT AND SIGNAL BUFFERINGCOMPONENTS:
50
C28
51
Q3
N-CHANNEL MOSFET, 30V, SOT23
ZETEX, ZXMN2F30FH
52
Q4-Q14
DUAL MOSFET 20V N-TYPE/P-TYPE
VISHAY, SI1553CDL-T1-GE3
53
R91
RES, CHIP, 3MΩ, 1%, 1/10W, 0603
VISHAY, CRCW06033M00FKEA
54
24
R92, R100-R113, R120-R128
RES, CHIP, 10MΩ, 1%, 1/10W, 0603
VISHAY, CRCW060310M0FKEA
55
U5
IC, ULTRA-LOW POWER SUPERVISOR WITH POWER-FAILOUTPUT, TSOT-23
POWER SOURCES AND ENERGY STORAGECOMPONENTS:
56
BAT1
CR2032 COIN LI-ION BATTERY
ENERGIZER , CR2032VP
57
BAT2
COIN LI-ION BATTERY Lir2032
POWERSTREAM, Lir2032
58
BTH1, BTH2
BATTERY HOLDER COIN CELL 2032 SMD
WÜRTH, 79527141
59
C30
SUPERCAP, 15mF, -20%, +80%, 5.5V, SMD
AVX, BZ055B153ZSB
60
CO1-CO10
ADDITIONAL DEMO BOARD CIRCUIT COMPONENTS:
61
C31 (OPT)
SUPERCAP, 85mF, 5.0V, 20mm x 18mm
CAP-XX, GA209F
62
C32, C33 (OPT)
63
D4-D7 (OPT)
DIODE, SCHOTTKY, 40V, 1A, SOD-123
DIODES INC, 1N5819HW-7-F
64
R87, R88 (OPT)
RES, CHIP, 7.5kΩ, 1/16W, 1%, 0402
VISHAY, CRCW04027K50FKED
HARDWARE FOR DEMO BOARD ONLY:
65
E1-E19
TURRET, 0.061 DIA
MILL-MAX, 2308-2
66
J1
2X10, 20-PIN, SMT RIGHT ANGLE SOCKETw/KEY (PIN 14), 0.100"
SAMTEC, SMH-110-02-L-D-14
67
J2
2X6, 12-PIN, SMT RIGHT ANGLE SOCKET w/KEY(PIN 5), 0.100"
SAMTEC, SMH-106-02-L-D-05
68
JP1-JP4, JP5-JP8
SMT HEADER, 2 PINS, 2mm
SAMTEC, TMM-102-01-F-S-SM
69
JP17
SMT HEADER, 6 TOTAL PINS, 2 ROWS, 2mm
WÜRTH, 621 006 219 21
70
JP18
SMT HEADER, 8 TOTAL PINS, 2 ROWS, 2mm
WÜRTH, 621 008 219 21
71
JP19
HEADER, 3 PINS, 2mm
WÜRTH, 620 003 111 21
72
JP20
HEADER, 4 PINS, 2mm
WÜRTH, 620 004 111 21
73
JP21
HEADER, 4 TOTAL PINS, 2 ROWS, 2mm
WÜRTH, 620 004 211 21
74
JP3, JP7, JP17B, JP18C, JP19, JP20, JP21A
SHUNT 2MM
WÜRTH, 608 002 134 21
75
PB1
SWITCH TACTILE, SPST-NO, 0.05A 12V
WÜRTH,  434111025826
76
34
R3, R6, R9, R10, R12, R15, R16, R20, R23,R25, R26, R28, R31, R32, R35, R37, R39, R41, R42, R44, R46, R49, R51, R53,R55, R56, R58, R61, R63, R65, R67, R68, R70, R89
RES, CHIP, 0Ω, 0603
VISHAY, CRCW06030000Z0EA
77
R4, R7, R8, R11, R13, R14, R17, R21, R22,R24, R27, R29, R30, R33, R34, R36, R38, R40, R43, R45, R47, R48, R50, R52,R54, R57, R59, R60, R62, R64, R66, R69, R71, R90, R99 (OPT)
RES, CHIP, 0Ω, 0603
78
R78, R79, R81, R83, R85, R86,  R96, R97, R98, R114, R117, R119 (OPT)
RES, CHIP, 0Ω, 0402
VISHAY, CRCW04020000Z0ED
79
9
R80, R82, R84, R93, R94, R95,  R115, R116, R118
RES, CHIP, 0Ω, 0402
80
SW1, SW4, SW7
DP3T SLIDE SWITCH, 12mmx3.5mm, 0.2A 12VDC
COPAL, CL-SB-23A-02T
81
SW2
4PDT SLIDE SWITCH, 16.5mmx7mm, 0.1A 30VDC
ALPS, SSSF040800
DPDT SLIDE SWITCH, 8.5mm x 3.5mm, 0.2A12VDC
COPAL, CL-SB-22A-01T
83
0.001
ELECTRICAL TAPE, 3/4" x 1/2"
3M, 33+ SUPER (3/4"X66')
84
STANDOFF x6 (OPT)
STANDOFF, HEX .625"L, 4-40, THRNYLON
KEYSTONE, 1902F
85
SCREW x6 (OPT)
SCREW, MACH, PHIL, 4-40, .250 IN, NYLON
B&F FASTENER SUPPLY, NY PMS 440 0025PH
86
FAB, PRINTED CIRCUIT BOARD
DEMO CIRCUIT 2344A
87
STENCIL - TOP
STENCIL #2590A-TOP
88
STENCIL - BOTTOM
SKIPPED REFERENCE DESIGNATORS (TO MATCHDC2344A):
89
C29 (DOES NOT EXIST)
90
JP9-JP16 (DOES NOT EXIST)
91
SW3, SW5, SW6 (DOES NOT EXIST)
重要提示:PCB作品文件展下载说明
 楼主| 发表于 2018-11-28 15:22:39 | 显示全部楼层
DC2509A-1.DSN.rar (136 KB, 下载次数: 0) DC2509A-1.PCB.rar (297 KB, 下载次数: 0)
社区居民忠实会员终身成就奖
发表于 2018-11-28 15:32:16 | 显示全部楼层
貌似很不错,E文不太好,看不懂
    昨天 08:27
  • 签到天数: 268 天
    发表于 2018-11-29 08:52:07 | 显示全部楼层
    PADS高级班留级2期
    发表于 2018-11-29 08:52:22 | 显示全部楼层
    PADS20220105初级班
    发表于 2018-11-29 08:52:50 | 显示全部楼层
    发表于 2018-12-2 09:38:46 | 显示全部楼层
    发表于 2021-12-16 10:10:12 | 显示全部楼层
