查看: 2220|回复: 2
[Pads_VX.2x] DC2321A, Dust Energy Harvesting Application Demo Board with E-Ink Display 使
终身成就奖原创先锋奖特殊贡献奖优秀斑竹奖金点子奖
发表于 2018-11-28 15:23:47 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
BRD1
SMARTMESH IP NODE, 2.4GHz, 802.15.4e,WIRELESS MOTE MODULE
LINEAR TECH, LTP5901IPC-IPMA1D0#PBF
R11-R17, R29-R31
RES, CHIP, 10MΩ, ±5%, 1/10W, 0603
PANASONIC, ERJ3GEYJ106V
DISPLAY COMPONENTS:
C1-C4, C10-C13
CAP, CHIP, 2.2μF, 25V, ±10%, X7R, 0805
WURTH ELEKTRONIK, 885012207079
C5
CAP, CHIP, 1μF, 10V, ±10%, X7R, 0805
WURTH ELEKTRONIK, 885012207022
C6-C9, C14-C15
CAP, CHIP, 2.2μF, 16V, ±10%, X7R, 0805
WURTH ELEKTRONIK, 885012207052
C16
CAP, CHIP, 2.2μF, 10V, ±10%, X7R, 0805
WURTH ELEKTRONIK, 885012207024
D1
DIODE, SCHOTTKY, 30V, 0.1A, SOD-523
CENTRAL SEMICONDUCTOR, CMOSH-3
EPD1
1.44" E-PAPER DISPLAY
PERVASIVE DISPLAYS, E1144CS021
9
Q1
MOSFET, N/P-CH, 20V, 660mA, SC70-6
VISHAY, SI1553CDL-T1-GE3
Q2, Q3
N-CHANNEL MOSFET, 60V, SOT-323
FAIRCHILD, 2N7002KW
R9
RES, CHIP, 2kΩ, ±1%, 1/10W, 0603
PANASONIC, ERJ-3EKF2001V
R10
RES, CHIP, 5.1MΩ, ±5%, 1/10W, 0603
PANASONIC, ERJ-3GEYJ515V
13
R48
RES, CHIP, 10MΩ, ±1%, 1/10W, 0603
SAMSUNG, RC1608F106CS
ADDITIONAL DEMO BOARD CIRCUITCOMPONENTS:
14
C22-C23 (OPT)
CAP, CHIP, 47pF, 10V, ±5%, C0G, 0603
WURTH ELEKTRONIK, 885012006006
D3 (OPT)
DIODE ZENER 3.6V 500MW MINIMELF
MICRO COMMERCIAL, BZV55C3V6-TP
16
D4 (DOES NOT EXIST)
17
R27, R28 (OPT)
RES, CHIP, 0Ω, 1/10W, 0603
VISHAY, CRCW06030000Z0EA
HARDWARE FOR DEMO BOARD ONLY:
18
C17, C21
CAP, CHIP, 0.22μF, 10V, ±10%, X7R, 0603
WURTH ELEKTRONIK, 885012206022
C18, C25-C26
CAP, CHIP, 1μF, 10V, ±10%, X7R, 0603
WURTH ELEKTRONIK, 885012206026
C19, C24
CAP, CHIP, 0.01μF, 10V, ±10%, X7R, 0603
WURTH ELEKTRONIK, 885012206014
C20
CAP, CHIP, 10μF, 6.3V, ±20%, X5R, 0603
WÜRTH, 885012106006
22
D2, D5, D7-D9
23
D6, D10
DIODE, LOW-LEAKAGE, 75V, 250MA, SOT23
CENTRAL SEMICONDUCTOR, CMPD6001
24
DB1
SHIELD BOARD FOR DC2321A
LINEAR TECH, DC2510A
25
E1-E7
TURRET, 0.061 DIA
MILL-MAX, 2308-2-00-80-00-00-07-0
26
J1
2X10, 20-PIN, RIGHT ANGLE MALE HEADER (WITHKEY PIN 14), 0.100"
WURTH ELEKTRONIK, 61302021021
27
J2
2x5, 1.27MM PITCH, VERTICAL MALE HEADER(WITH KEY PIN 7)
WURTH ELEKTRONIK, 62201021121
J3
2x5, 2.00MM PITCH, VERTICAL MALE HEADER
WURTH ELEKTRONIK, 62001021121
29
J4, J6
2x16, 2MM PITCH, VERTICAL SOCKET
WURTH ELEKTRONIK, 62003221821
30
J5
2 PIN, 2MM PITCH, VERTICAL SOCKET
WURTH ELEKTRONIK, 62000211821
31
J7
MICRO USB CONNECTOR
WURTH ELEKTRONIK, 629105136821
32
J8
40-PIN, 0.5MM PITCH, HORIZ FCP CONNECTORWITH BOTTOM CONTACTS
WURTH ELEKTRONIK, 68714014522
33
J9 (OPT)
CONN, HEADER, 2.54MM, 20POS, GOLD, SMD
SULLINS, SBH11-NBPC-D10-SM-BK
34
PB1
SWITCH, TACTILE, SPST-NO, 0.05A 12V
WÜRTH,  434111025826
35
Q8, Q9
36
Q4, Q5, Q6
MOSFET N-CH 20V 4.1A SOT23
DIODES INC., ZXMN2F30FHTA
37
Q7
MOSFET 2N-CH 30V 5.7A 8SOIC
DIODES INC., ZXMN3F31DN8TA
38
17
R1-R8, R26, R32, R41-R46, R49
39
R18
RES, CHIP, 2MΩ, 1/10W, ±5%, 0603
PANASONIC, ERJ-3GEYJ205V
40
R19
41
R20-R23, R35-R40, R47
RES, CHIP, 10kΩ, 1/10W, 0603
PANASONIC, ERJ-3EKF1002V
42
R24, R25
RES, CHIP, 3.32Ω, 1%, 1/8W, 0805
VISHAY, CRCW08053R32FKEA
43
R33, R34
RES, CHIP, 1KΩ, 1%, 1/10W, 0603
VISHAY, CRCW06031K00FKEA
44
R50, R51
RES, CHIP, 300M, 5%, 0805
VISHAY, CRCW0805300MJPEAHR
45
SW1
DP3T SLIDE SWITCH, 12mmx3.5mm, 0.2A 12VDC
COPAL, CL-SB-23A-01T
46
SW2, SW4
DPDT SLIDE SWITCH, 8.5mm x 3.5mm, 0.2A12VDC
COPAL, CL-SB-22A-01T
47
SW3
5xSPST, SMD, LOW-PROFILE, DIP SWITCH,1.27mm PITCH
WURTH ELEKTRONIK, 416131160805
48
U1
2-CHANNEL, 2-WIRE BUS MULTIPLEXER WITHCAPACITANCE BUFFERING
LINEAR TECH, LTC4305CDHD#PBF
49
U2, U3
BATTERY GAS GAUGE W/ TEMPERATURE &VOLTAGE MEASUREMENT
LINEAR TECH,  LTC2942CDCB#TRMPBF
50
U4, U5
DUAL OP AMPS, CHOPPER, R-R OUTPUT, 8SO
LINEAR TECH,  LTC2051CS8#PBF
51
U6
3.3V, 100 mA, LOW NOISE, LDO MICROPOWERREGULATOR, TSOT23-5
LINEAR TECH, LT1761ES5-3.3#PBF
52
U7
IC USB TO I2C BRIDGE DEVICE 14TS
MICROCHIP, MCP2221-I/ST
53
U8
IC, UHS UNIV. CONFIG. TWO-INPUT GATES,SC70-6
FAIRCHILD, NC7SZ58P6X
54
0.001
SCOTCH, REMOVABLE POSTER TAPEW/DISPENSER, 0.75in.x150in. (cut to 0.75in. X 1.5in.)
3M, MMM109
55
STANDOFF (NOT IN EH KIT)*
STANDOFF, HEX .625"L, 4-40, THRNYLON
KEYSTONE, 1902F
56
SCREW (NOT IN EH KIT)*
SCREW, MACH, PHIL, 4-40, .250 IN, NYLON
B&F FASTENER SUPPLY, NY PMS 440 0025PH
57
FAB, PRINTED CIRCUIT BOARD
DEMO CIRCUIT 2321A
58
STENCILS TOP & BOTTOM
STENCILS, DC2321A
*Parts labeled "NOT IN EH KIT"(items 55 and 56) are omitted from boards used in Würth Elektronik'sGleanergy EH / WSN Development Platform. These parts will be populated onboards built by Linear Technology.
重要提示:PCB作品文件展下载说明
 楼主| 发表于 2018-11-28 15:24:32 | 显示全部楼层
DC2321A-5.DSN.rar (97 KB, 下载次数: 0) DC2321A-5.PCB.rar (224 KB, 下载次数: 0)
发表于 2018-12-2 09:39:19 | 显示全部楼层
