查看: 3297|回复: 5
[Pads_VX.2x] KSZ8462_8852HLE-EVAL, Evaluation Board使用 Microchip Technology的KSZ8462_8
终身成就奖原创先锋奖特殊贡献奖优秀斑竹奖金点子奖
发表于 2018-11-28 15:26:08 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
Item
Quantity
Reference
Part
MFG
MFG P/N
Digikey P/N
DNI
Footprint
Datasheet Link
Comment
C1,C2
18PF
Panasonic - ECG
ECJ-2VC1H180J
PCC180CNCT-ND
0805
http://media.digikey.com/pdf/Dat ... s/ECJ_(General).pdf
C4,C5,C6
10UF
AVX Corporation
TAJB106K020R
478-1674-1-ND
1210
http://www.avx.com/docs/Catalogs/taj.pdf
C9,C66,C87,C88
1000pf/2KV
Panasonic - ECG
ECK-A3D102KBP
P9565-ND
http://industrial.panasonic.com/ ... 0000/ABB0000CE4.pdf
C10,C11,C13,C15,C16,C17,C18,C19,C20,C21,C22,C23,C24,C25,C26,C30,C31,C33,C34,C35,C36,C37,C38,C39,C67,C68,C93,C94,C100,C101,C102,C103,C106,C107,C109,C110,C111,C112,C114,C115,C116,C117,C118,C119
0.1UF
Kemet
C0603C104J4RACTU
399-1097-1-ND
DNI in "RED"
0603
http://www.kemet.com/kemet/web/h ... $file/F3102_X7R.pdf
C14,C32
47UF / 16V
AVX Corporation
TAJD476K016R
478-1739-1-ND
DNI in "RED"
2917
C120
470pF
Murata
GRM1885C1H471JA01D
490-1443-1-ND
0603
http://search.murata.co.jp/Ceram ... M1885C1H471JA01.pdf
C124,C128,C129,C131,C134,C137
22UF / 20V
AVX Corporation
TAJB226K020R
478-1683-1-ND
1210
tantalum, 1.8ohm ESR
C130,C132,C133,C135,C136
100UF / 16V
AVX Corporation
TAJD107K016RNJ
478-1723-2-ND
2917
tantalum, 900mohm ESR
9
C144
470UF / 16V
Panasonic - ECG
ECA-1CM471
P5141-ND
http://industrial.panasonic.com/ ... 000/ABA0000CE12.pdf
alum electrolytic, radial
D2,D16
MBR0520L
ON Semiconductor
MBR0520LT1G
MBR0520LT1G0SCT-ND
SOD-123
http://www.fairchildsemi.com/ds/MB/MBR0520L.pdf
D5,D6,D9,D10
PLC03-3.3
Bourns
CDNBS08-PLC03-3.3
CDNBS08-PLC03-3.3CT-ND
DNI in "RED"
SOIC-8
http://www.bourns.com/data/global/pdfs/CDNBS08-PLC03-33.pdf
D7,D8,D11,D12
SR3.3
Semtech
SR3.3.TCT
SR3.3CT-ND
DNI in "RED"
SOT-143
http://www.semtech.com/images/datasheet/sr3.3.pdf
13
D13
POWER LED
Panasonic - SSG
LN28RCPX
P606-ND
http://datasheet.octopart.com/LN ... atasheet-137095.pdf
14
D14,D15
LEDX2
Lumex
SSF-LXH240GGD
67-1321-ND
http://www.lumex.com/specs/SSF-LXH240GGD.pdf
FB4,FB5,FB6,FB7,FB16,FB19,FB20,FB21,FB22,FB23,FB24
FBEAD
Steward
HI1206T500R-10
240-2412-1-ND
DNI in "RED"
1206
http://www.steward.com/web_info/ ... I1206T500R-10-C.pdf
6A, 50ohm, 10mohm series R, 1206
16
JP2,JP3,JP403,JP405,JP406,JP408,JP409
2X1
2x1 header (0.100 inch)
17
JP10,JP11,JP77,JP78,JP301,JP302,JP303,JP404
3X1
DNI in "RED"
3x1 header (0.100 inch)
18
J1,J2
RJ45 CAT5 SHLD
Tyco
5558342-1
A31466-ND
http://documents.tycoelectronics ... &DocLang=EN
J11
PWRJACK-TH
Switchcraft
RAPC712X
SC237-ND
http://www.switchcraft.com/Drawings/rapc712x_cd.pdf
J12,J13
CON4A
2x2 header (0.100 inch)
J15
67996-114HLF
FCI
67996-114HLF
609-3491-ND
http://portal.fciconnect.com/Comergent//fci/drawing/67996.pdf
7x2 header (0.100 inch)
22
J16
90131-0780
Molex
90131-0780
WM8152-ND
http://www.molex.com/pdm_docs/sd/901310780_sd.pdf
20 x 2 header (0.100 inch)
23
Q1,Q2
SC89
Fairchild
FDY3000NZ
FDY3000NZCT-ND
http://www.fairchildsemi.com/ds/FD/FDY3000NZ.pdf
N-Ch-MOSFET
24
R4
6.49K
Panasonic - ECG
ERJ-3EKF6491V
P6.49KHCT-ND
0603
http://industrial.panasonic.com/ ... 0000/AOA0000CE2.pdf
0603
25
R5
10K
Panasonic - ECG
ERJ-3EKF1002V
P10.0KHCT-ND
0603
0603
26
R6,R9,R11,R123,R127,R129,R218
1K
Panasonic - ECG
ERJ-3EKF1001V
P1.00KHCT-ND
0603
0603
27
R8,R10,R15,R16,R17,R22,R26,R124,R128,R130
4.7K
Panasonic - ECG
ERJ-3EKF4701V
P4.70KHCT-ND
0603
0603
R18,R19,R21,R23,R24,R25,R171,R174,R183,R184,R185,R186
51
Panasonic - ECG
ERJ-3EKF51R1V
P51.1HCT-ND
0603
0603
29
R20,R172
75
Panasonic - ECG
ERJ-3EKF75R0V
P75.0HCT-ND
0603
0603
30
R31,R34,R60,R178,R188
220
Panasonic - ECG
ERJ-3EKF2200V
P220HCT-ND
0603
0603
31
R62,R63,R72,R73,R78,R84,R85,R90
49.9
Panasonic - ECG
ERJ-3EKF49R9V
P49.9HCT-ND
DNI in "RED"
0603
0603
32
R64,R65,R68,R69,R79,R80,R81,R93
Panasonic - ECG
ERJ-3EKF82R0V
P82.0HCT-ND
DNI in "RED"
0603
0603
33
R66,R67,R70,R71,R77,R82,R87,R88,R89,R92
130
Panasonic - ECG
ERJ-3EKF1300V
P130HCT-ND
DNI in "RED"
0603
0603
34
R74,R75,R83,R91
NC (0 ohms)
Panasonic - ECG
ERJ-3GEY0R00V
P0.0GCT-ND
DNI in "RED"
0603
0603
35
R76,R86,R199,R200,R201,R202,R205,R208,R210,R211
0 (0 ohms)
Panasonic - ECG
ERJ-3GEY0R00V
P0.0GCT-ND
DNI in "RED"
0603
0603
36
R179
2.49K
Panasonic - ECG
ERJ-3EKF2491V
P2.49KHCT-ND
0603
0603
37
R180
1.50K
Panasonic - ECG
ERJ-3EKF1501V
P1.50KHCT-ND
0603
0603
38
R194
10.7K
Panasonic - ECG
ERJ-3EKF1072V
P10.7KHCT-ND
0603
0603
39
R195,R196,R197,R198,R206,R207,R209,R212
R (0 ohms)
Panasonic - ECG
ERJ-3GEY0R00V
P0.0GCT-ND
DNI in "RED"
0603
0603
40
R203
10.5K
Panasonic - ECG
ERJ-3EKF1052V
P10.5KHCT-ND
0603
0603
41
R204
8.45K
Panasonic - ECG
ERJ-3EKF8451V
P8.45KHCT-ND
0603
0603
42
26
R215,R216,R217,R219,R220,R221,R222,R223,R224,R225,R226,R227,R228,R229,R230,R231,R232,R233,R234,R235,R236,R237,R238,R239,R240,R241
33
Panasonic - ECG
ERJ-3EKF33R0V
P33.0HCT-ND
0603
0603
43
R242,R243
10.0M
Yageo
CFR-25JR-52-10M
10MQTR-ND
DNI in "RED"
http://www.yageo.com/exep/pages/ ... s/Leaded-R_2011.pdf
44
S2
SW PUSHBUTTON
Panasonic - ECG
EVQ-PHP03T
P8002SCT-ND
http://media.digikey.com/pdf/Dat ... 0PDFs/EVQ_PH_QW.pdf
45
X1,X2,TP9,TP10,TP21,TP22,TP23,TP24
TestPoint
46
T1,T2
H1102
Pulse
H1102NL
553-1323-ND
http://ww2.pulseeng.com/products/datasheets/H325.pdf
47
U2
CAT93C66LI-G
Atmel
Tyco
AT93C46E-PU
1825093-2
AT93C46-PU-ND
A32361-ND
http://documents.tycoelectronics.com/commerce/DocumentDelivery/DDEController?Action=srchrtrv&DocNm=1825093&DocType=CD&DocLang=EN
Atmel serial EEPROM, 1Kbit, three-wire
8-pin DIP socket for Atmel AT93C46
48
U4
MIC29302BT
Micrel
MIC29302BT
MIC29302BT-ND
http://www.micrel.com/_PDF/mic29150.pdf
LDO - adj
49
U6,U10
1x9/SC/SIP
AVAGO
AFBR-5803Z
Option for FQL
DNI in "RED"
http://www.avagotech.com/docs/AV02-0606EN
50
U11
KSZ8462HLL
Micrel
KSZ8462HLI
51
U21
MIC5209YM
Micrel
MIC5209YM
576-1278-ND
http://www.micrel.com/_PDF/mic5209.pdf
LDO - adj
52
Y1
25MHz
Citizen
CSA309-25.000MABJ-UB
300-8451-ND
http://www.citizencrystal.com/images/pdf/m-csa.pdf
crystal
重要提示:PCB作品文件展下载说明
 楼主| 发表于 2018-11-28 15:26:49 | 显示全部楼层
KSZ8462_8852_REF_SCHEM_V1_0.DSN.rar (177 KB, 下载次数: 0) KSZ8462_8852_eval_bd_v1.0_layout.pcb.rar (330 KB, 下载次数: 0)
发表于 2018-11-28 22:00:08 | 显示全部楼层
这个是不是同时发布好几个版本
 楼主| 发表于 2018-11-28 22:44:50 | 显示全部楼层
发表于 2018-12-2 09:39:31 | 显示全部楼层
    4 天前
  • 签到天数: 45 天
    1元学习Allegro(1期)
    发表于 2022-3-17 16:03:03 | 显示全部楼层
