查看: 1576|回复: 0
[Allegro16.6以下] TWR-AUDIO-SGTL SGTL5000编解码器塔式系统音频模块 4-742
发表于 2018-11-29 22:21:03 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
TWR-AUDIO-SGTL SGTL5000编解码器塔式系统音频模块.rar (4.06 MB, 下载次数: 5)
Bill of MaterialReport
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_TOLCOMP_CLASSREFDES
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9MM1uF DISCRETEC1
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9MM1uF DISCRETEC2
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9MM1uF DISCRETEC3
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9MM1uF DISCRETEC4
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9MM1uF DISCRETEC5
CC3216_10CAP_POL_CC3216_10_1.2MM_150-785220UF ICC6
CC3216_10CAP_POL_CC3216_10_1.2MM_150-785220UF ICC7
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.965100PF DISCRETEC8
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.965100PF DISCRETEC9
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9MM1uF DISCRETEC10
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.965100PF DISCRETEC11
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.965100PF DISCRETEC12
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF DISCRETEC13
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF DISCRETEC14
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF DISCRETEC15
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF DISCRETEC16
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UF DISCRETEC36
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.55M0.1uF10%DISCRETEC37
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_110UF10%DISCRETEC925
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6350.1UF10%DISCRETEC1007
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6350.1UF10%DISCRETEC1008
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6350.1UF10%DISCRETEC1009
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6350.1UF10%DISCRETEC1010
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6350.1UF10%DISCRETEC1014
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6350.1UF10%DISCRETEC1015
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6350.1UF10%DISCRETEC1017
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6350.1UF10%DISCRETEC1018
SOD-123DIODE_SCHTKY_SOD-123_IC_1MM_48MBR130LSFT1G ICD45
CON5_AUD_JACK_RA_THAUDIO_JACK_5_CON5_AUD_JACK_RA_TCONN AUD JACK 5 IOJ1
CON5_AUD_JACK_RA_THAUDIO_JACK_5_CON5_AUD_JACK_RA_TCONN AUD JACK 5 IOJ2
CON5_AUD_JACK_RA_TH_SJ-43515TSSJ-43515TS_CON5_AUD_JACK_RA_TH_AUD_5 IOJ3
CON5_AUD_JACK_RA_TH_SJ-43515TSSJ-43515TS_CON5_AUD_JACK_RA_TH_AUD_5 IOJ4
CN2X82_FINGER_ASSCONN_PCI_XPRESS_X16_328P_CN2X82PCI EXPRESS TOWERSYSTEM IOJ5
HDR102CONN_HDR_1X2_HDR102_IO_8.6MM_21HDR 1X2 TH IOJ7
HDR102CONN_HDR_1X2_HDR102_IO_8.6MM_21HDR 1X2 TH IOJ8
HDR102CONN_HDR_1X2_HDR102_IO_8.6MM_21HDR 1X2 TH IOJ9
HDR102CONN_HDR_1X2_HDR102_IO_8.6MM_21HDR 1X2 TH IOJ10
HDR102CONN_HDR_1X2_HDR102_IO_8.6MM_21HDR 1X2 TH IOJ11
HDR102CONN_HDR_1X2_HDR102_IO_8.6MM_21HDR 1X2 TH IOJ12
HDR102CONN_HDR_1X2_HDR102_IO_8.6MM_21HDR 1X2 TH IOJ13
HDR102CONN_HDR_1X2_HDR102_IO_8.6MM_21HDR 1X2 TH IOJ14
HDR102CONN_HDR_1X2_HDR102_IO_8.6MM_21HDR 1X2 TH IOJ15
CON_TFM-120-01-S-DCONN_SHRHDR_20X2_CON_TFM-120-01HDR_2X20 IOJ16
HDR102CONN_HDR_1X2_HDR102_IO_8.6MM_21HDR 1X2 TH IOJ19
HDR102CONN_HDR_1X2_HDR102_IO_8.6MM_21HDR 1X2 TH IOJ21
HDR102CONN_HDR_1X2_HDR102_IO_8.6MM_21HDR 1X2 TH IOJ22
HDR205CONN_HDR_5X2_HDR205_IO_8.38MM_HDR 2X5 IOJ23
IND_0402INDUCTOR_IND_0402_DISCRETE_0.55600OHM DISCRETEL1
IND_0402INDUCTOR_IND_0402_DISCRETE_0.55600OHM DISCRETEL2
IND_0603BEAD_FERRITE_IND_0603_DISCRETE_120OHM DISCRETEL3
MIC_WM-63PRMIC_MIC_WM-63PR_IC_2.2MM_510-77WM-64PNT ICP1
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER1
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER2
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER3
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER4
RC0603_OVRES_RC0603_OV_DISCRETE_470-75392.2K DISCRETER5
RC0402_25RES_RC0402_25_DISCRETE_470-75_110K DISCRETER6
RC0402_25RES_RC0402_25_DISCRETE_470-75390 DISCRETER7
RC0402_25RES_RC0402_25_DISCRETE_470-75_110K DISCRETER8
RC0402_25RES_RC0402_25_DISCRETE_470-75390 DISCRETER9
RC0402_25RES_RC0402_25_DISCRETE_470-75390 DISCRETER10
RC0402_25RES_RC0402_25_DISCRETE_470-75390 DISCRETER11
RC0402_25RES_RC0402_25_DISCRETE_470-75390 DISCRETER12
RC0402_25RES_RC0402_25_DISCRETE_470-75390 DISCRETER13
RC0402_25RES_RC0402_25_DISCRETE_470-75390 DISCRETER14
RC0402_25RES_RC0402_25_DISCRETE_470-75390 DISCRETER15
RC0402_25RES_RC0402_25_DISCRETE_470-75390 DISCRETER16
RC0402_25RES_RC0402_25_DISCRETE_470-757822 DISCRETER17
RC0402_25RES_RC0402_25_DISCRETE_470-75_110K DISCRETER18
RC0402_25RES_RC0402_25_DISCRETE_470-75390 DISCRETER19
RC0402_25RES_RC0402_25_DISCRETE_470-75_110K DISCRETER20
RC0402_25RES_RC0402_25_DISCRETE_470-75390 DISCRETER21
RC0402_25RES_RC0402_25_DISCRETE_470-75390 DISCRETER22
RC0402_25RES_RC0402_25_DISCRETE_470-75390 DISCRETER23
RC0402_25RES_RC0402_25_DISCRETE_470-75390 DISCRETER24
RC0402_25RES_RC0402_25_DISCRETE_470-75390 DISCRETER25
RC0402_25RES_RC0402_25_DISCRETE_470-75390 DISCRETER26
RC0402_25RES_RC0402_25_DISCRETE_470-75390 DISCRETER27
RC0402_25RES_RC0402_25_DISCRETE_470-75390 DISCRETER28
RC0402_25RES_RC0402_25_DISCRETE_470-75390 DISCRETER29
RC0402_25RES_RC0402_25_DISCRETE_470-75390 DISCRETER30
RC0402_25RES_RC0402_25_DISCRETE_470-75390 DISCRETER31
RC0402_25RES_RC0402_25_DISCRETE_470-75390 DISCRETER32
RC0402_25RES_RC0402_25_DISCRETE_470-75390 DISCRETER33
RC0402_25RES_RC0402_25_DISCRETE_470-75390 DISCRETER34
RC0402_25RES_RC0402_25_DISCRETE_470-75390 DISCRETER35
RC0402_25RES_RC0402_25_DISCRETE_470-75390 DISCRETER36
RC0402_25RES_RC0402_25_DISCRETE_470-75390 DISCRETER37
RC0402_25RES_RC0402_25_DISCRETE_470-756333 DISCRETER38
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER39
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_44.7K5%DISCRETER41
RC0402_25RES_RC0402_25_DISCRETE_470-75_110K DISCRETER42
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER43
RC0402_25RES_RC0402_25_DISCRETE_470-75390 DISCRETER44
RC0402_25RES_RC0402_25_DISCRETE_470-75390 DISCRETER45
RC0402_25RES_RC0402_25_DISCRETE_0.35MM_44.7K1%DISCRETER271
RC0402_25RES_RC0402_25_DISCRETE_0.35MM_44.7K1%DISCRETER272
RC0402_25RES_RC0402_25_DISCRETE_0.35MM_44.7K1%DISCRETER273
RC0402_25RES_RC0402_25_DISCRETE_470-75551K DISCRETER1138
TESTPOINT_35MILTESTPAD_TESTPOINT_35MIL_IC_0.135 MIL ICTP3
TESTPOINT_35MILTESTPAD_TESTPOINT_35MIL_IC_0.135 MIL ICTP4
TESTPOINT_35MILTESTPAD_TESTPOINT_35MIL_IC_0.135 MIL ICTP5
TESTPOINT_35MILTESTPAD_TESTPOINT_35MIL_IC_0.135 MIL ICTP6
TESTPOINT_35MILTESTPAD_TESTPOINT_35MIL_IC_0.135 MIL ICTP7
TESTPOINT_35MILTESTPAD_TESTPOINT_35MIL_IC_0.135 MIL ICTP8
TESTPOINT_35MILTESTPAD_TESTPOINT_35MIL_IC_0.135 MIL ICTP9
TESTPOINT_35MILTESTPAD_TESTPOINT_35MIL_IC_0.135 MIL ICTP10
TESTPOINT_35MILTESTPAD_TESTPOINT_35MIL_IC_0.135 MIL ICTP11
SOD-923DIODE_TVS_BIDIR_SOD-923_IC_0.4MESD9B3.3ST5G ICTVS1
SOD-923DIODE_TVS_BIDIR_SOD-923_IC_0.4MESD9B3.3ST5G ICTVS2
SOD-923DIODE_TVS_BIDIR_SOD-923_IC_0.4MESD9B3.3ST5G ICTVS3
QFN32SGTL5000_QFN32_0.9MM_315-77907_SGTL5000 32QFN ICU1
FPBGA100_1P0_11X11EPM570F_FBGA_100P_FPBGA100_1P0_EPM570F100C5N ICU4
XTLOSC4_5X7_5SG8002_XTLOSC4_5X7_5_IC_1.8MM_233.333M ICX1
XTL4_14X8OSC3_XTL4_14X8_IC_4.7MM_230-30012.288MHZ ICY1
重要提示:PCB作品文件展下载说明
