查看: 1487|回复: 0
[Allegro16.6以下] Kinetis K40 100 MHz低功耗MCU塔式系统模块 8-1210
发表于 2018-11-29 22:29:14 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
16 TWR-K40D100M Kinetis K40 100 MHz低功耗MCU塔式系统模块.rar (5.32 MB, 下载次数: 2)
Bill of MaterialReport
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_TOLCOMP_CLASSREFDES
SKT_BAT_780X1210BATTERY_SKT_3V_SKT_BAT_780X1210BK-883 ICBT1
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UF DISCRETEC1
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC2
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC3
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC4
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC5
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.90M18PF DISCRETEC6
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC7
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UF DISCRETEC8
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UF DISCRETEC9
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9MM1000PF DISCRETEC10
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC11
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UF DISCRETEC12
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.90M18PF DISCRETEC13
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UF DISCRETEC14
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC15
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC16
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC17
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC18
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC19
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC20
CC3528-21CAP_POL_CC3528-21_2.1MM_150-7854.7uF ICC21
CC3528-21CAP_POL_CC3528-21_2.1MM_150-7854.7uF ICC22
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC23
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC24
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC25
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.90M18PF DISCRETEC26
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC27
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9650.01UF DISCRETEC28
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC29
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC30
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC31
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9650.01UF DISCRETEC32
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC33
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.90M18PF DISCRETEC34
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC35
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC36
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC37
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC38
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC39
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC40
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC41
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UF DISCRETEC42
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC43
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC44
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC45
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UF DISCRETEC46
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1.25M2.2UF DISCRETEC47
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC48
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UF DISCRETEC49
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UF DISCRETEC50
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UF DISCRETEC51
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC52
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UF DISCRETEC53
LED_0603LED_LED_0603_IC_1.0MM_370-76472YEL/GRN ICD1
LED_0603LED_LED_0603_IC_0.8MM_370-75076LED_YELLOW ICD2
LED_0603LED_LED_0603_IC_0.8MM_370-75080ORANGE ICD3
LED_0603LED_LED_0603_IC_1.0MM_370-76472YEL/GRN ICD4
SMB_2P7X1P4DIODE_SCHTKY_SMB_2P7X1P4_IC_0.7MSS1P3L ICD5
DIODE_3P2X2P2LED_DIODE_3P2X2P2_IC_1.1MM_480-QTLP610CIR ICD6
SOT-23BAT721B_SOT-23_IC_1.3MM_480-779BAT54C ICD7
LED2_ELECTRODELED2_ELECTRODE_LED2_ELECTRODE_2LED_OR + ELECTRODE ICD8
LED2_ELECTRODELED2_ELECTRODE_LED2_ELECTRODE_3LED_YEL + ELECTRODE ICD9
LED2_ELECTRODELED2_ELECTRODE_LED2_ELECTRODE_ILED_GRN + ELECTRODE ICD10
LED2_ELECTRODELED2_ELECTRODE_LED2_ELECTRODE_1LED2_ELECTRODE ICD11
HDR103CONN_HDR_3X1_HDR103_IO_8.65MM_2HDR TH 1X3 IOJ1
HDR102CONN_HDR_2X1_HDR102_IO_8.71MM_HDR 1X2 TH IOJ2
HDR103CONN_HDR_3X1_HDR103_IO_8.65MM_2HDR TH 1X3 IOJ3
HDR2X4_TSM_SMCONN_HDR_4X2_HDR2X4_TSM_SM_IO_9HDR_2x4 IOJ4
CON_TFM_20M_50_SMCONN_SHRHDR_10X2_CON_TFM_20M_50CON_2X10 IOJ5
CON_TFM_20M_50_SMCONN_SHRHDR_10X2_CON_TFM_20M__1CON_2X10 IOJ6
CON_TFM_20M_50_SMCONN_SHRHDR_10X2_CON_TFM_20M__1CON_2X10 IOJ7
CN2X82_FINGER_ASSCONN_PCI_XPRESS_X16_328P_CN2X82PCI EXPRESS TOWERSYSTEM IOJ8
HDR103CONN_HDR_3X1_HDR103_IO_8.65MM_2HDR TH 1X3 IOJ9
HDR103CONN_HDR_3X1_HDR103_IO_8.65MM_2HDR TH 1X3 IOJ10
HDR102CONN_HDR_2X1_HDR102_IO_8.71MM_HDR 1X2 TH IOJ11
HDR102CONN_HDR_2X1_HDR102_IO_8.71MM_HDR 1X2 TH IOJ12
HDR102CONN_HDR_2X1_HDR102_IO_8.71MM_HDR 1X2 TH IOJ13
HDR102CONN_HDR_2X1_HDR102_IO_8.71MM_HDR 1X2 TH IOJ14
HDR102CONN_HDR_2X1_HDR102_IO_8.71MM_HDR 1X2 TH IOJ15
CON_FTSH_19M_50_SMCONN_HDR_19_CON_FTSH_19M_50_SM_HDR_19P IOJ16
CON5_MUSB_AB_0P8_RA_SMTUSB_MINI_B_SKT_CON5_MUSB_AB_0P8USB_MINI_B 5 IOJ17
HDR203_TSM_SMCONN_HDR_3X2_HDR203_TSM_SM_IO_9HDR_2X3 IOJ18
CONN-MMC_SD_OPTMMC_SD_CONN_2405_CONN-MMC_SD_OPMMC-SD Connector IOJ19
IND_0603IND_IND_0603_0.8MM_180-75495_10100 OHM@100MHZ ICL1
IND_0805BEAD_IND_0805_DISCRETE_1.05MM_330 OHM DISCRETEL2
IND_0805BEAD_IND_0805_DISCRETE_1.05MM_330 OHM DISCRETEL3
IND_0603IND_IND_0603_0.8MM_180-75495_10100 OHM@100MHZ ICL4
IND_0603IND_IND_0603_0.8MM_180-75495_10100 OHM@100MHZ ICL5
IND_0603IND_IND_0603_0.8MM_180-75495_10100 OHM@100MHZ ICL6
IND_0603IND_IND_0603_0.8MM_180-75495_10100 OHM@100MHZ ICL7
SOT23NPN_SOT23_IC_1.12MM_480-75173_MMBT3904LT1G ICQ1
SOT-23TRAN_NPN_RES_SOT-23_IC_1.3MM_48PDTC115T ICQ2
QTLP610TRAN_PHOTO_QTLP610_IC_1.1MM_480QTLP610CPD ICQ3
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER1
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER2
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER3
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER4
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER5
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER6
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER7
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER8
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0K DISCRETER9
RC0603_OVRES_RC0603_OV_DISCRETE_470-75434.70K DISCRETER10
RC0603_OVRES_RC0603_OV_DISCRETE_470-75434.70K DISCRETER11
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0K DISCRETER12
RC0402_25RES_RC0402_25_DISCRETE__470-7601.0K DISCRETER13
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0K DISCRETER14
RC0402_25RES_RC0402_25_DISCRETE_470-76031.0K DISCRETER15
RC0402_25RES_RC0402_25_DISCRETE_470-7646330 DISCRETER16
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0K DISCRETER17
RC0402_25RES_RC0402_25_DISCRETE_470-3078270 DISCRETER18
RC0603_OVRES_RC0603_OV_DISCRETE_470-75434.70K DISCRETER19
RC0402_25RES_RC0402_25_DISCRETE_470-757933 DISCRETER20
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0K DISCRETER21
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0K DISCRETER22
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0K DISCRETER23
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0K DISCRETER24
RC0402_25RES_RC0402_25_DISCRETE_470-75360 DISCRETER25
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0K DISCRETER26
RC0402_25RES_RC0402_25_DISCRETE_470-75360 DISCRETER27
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0K DISCRETER28
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0K DISCRETER29
RC0402_25RES_RC0402_25_DISCRETE_470-757933 DISCRETER30
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0K DISCRETER31
RC0402_25RES_RC0402_25_DISCRETE_470-757933 DISCRETER32
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0K DISCRETER33
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0K DISCRETER34
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0K DISCRETER35
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0K DISCRETER36
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0K DISCRETER37
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0K DISCRETER38
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER39
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER40
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER41
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER42
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER43
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER44
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER45
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER46
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER47
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER48
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER49
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER50
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER51
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER52
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0K DISCRETER53
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER54
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER55
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER56
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER57
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER58
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER59
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER60
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER61
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER62
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER63
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER64
POT3_3352TPOT_POT3_3352T_DISCRETE_470-8015K DISCRETER65
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0K DISCRETER66
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0K DISCRETER67
RC0805_OVRES_RC0805_OV_DISCRETE_470-75440 DISCRETER68
RC0805_OVRES_RC0805_OV_DISCRETE_470-75440 DISCRETER69
RC0805_OVRES_RC0805_OV_DISCRETE_470-75440 DISCRETER70
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0K DISCRETER71
RC0603_OVRES_RC0603_OV_DISCRETE_470-75841.0M DISCRETER72
RC0805_OVRES_RC0805_OV_DISCRETE_470-75440 DISCRETER73
RC0805_OVRES_RC0805_OV_DISCRETE_470-75440 DISCRETER74
RC0805_OVRES_RC0805_OV_DISCRETE_470-75440 DISCRETER75
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER76
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER77
RC0603_OVRES_RC0603_OV_DISCRETE_470-75434.70K DISCRETER78
RC0402_25RES_RC0402_25_DISCRETE_470-76031.0K DISCRETER79
RC0805_OVRES_RC0805_OV_DISCRETE_470-75440 DISCRETER80
RC0805_OVRES_RC0805_OV_DISCRETE_470-75440 DISCRETER81
RC0603_OVRES_RC0603_OV_DISCRETE_470-75841.0M DISCRETER82
RC0805_OVRES_RC0805_OV_DISCRETE_470-75440 DISCRETER83
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER84
RC0805_OVRES_RC0805_OV_DISCRETE_470-75440 DISCRETER85
RC0402_25RES_RC0402_25_DISCRETE_470-30851.54K DISCRETER86
RC0402_25RES_RC0402_25_DISCRETE_470-76031.0K DISCRETER87
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0K DISCRETER88
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0K DISCRETER89
RC0402_25RES_RC0402_25_DISCRETE_470-76031.0K DISCRETER90
RC0402_25RES_RC0402_25_DISCRETE_470-757933 DISCRETER91
RC0402_25RES_RC0402_25_DISCRETE_470-757933 DISCRETER92
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER93
RC0805_OVRES_RC0805_OV_DISCRETE_470-75440 DISCRETER94
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER95
RC0402_25RES_RC0402_25_DISCRETE_470-76031.0K DISCRETER96
RC0402_25RES_RC0402_25_DISCRETE_470-764810M DISCRETER97
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER98
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0K DISCRETER99
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER100
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0K DISCRETER101
RC0402_25RES_RC0402_25_DISCRETE_470-76031.0K DISCRETER102
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER103
RC0402_25RES_RC0402_25_DISCRETE_470-30914.99K DISCRETER104
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER105
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER106
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER107
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER108
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER109
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER110
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER111
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER112
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER113
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER114
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER115
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER116
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER117
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER118
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER119
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER120
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER121
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER122
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER123
RC0402_25RES_RC0402_25_DISCRETE_470-78352.2K DISCRETER124
SW4_4MMSW_TACT-SPST-2_SM_SW4_4MM_IC_4.PB switch ICSW1
SW4_4MMSW_TACT-SPST-2_SM_SW4_4MM_IC_4.PB switch ICSW2
SW4_4MMSW_TACT-SPST-2_SM_SW4_4MM_IC_4.PB switch ICSW3
TEST_LOOPTESTLOOP_TEST_LOOP_IO_4.8MM_21TEST POINT WHITE IOTP1
TEST_LOOPTESTLOOP_TEST_LOOP_IO_4.8MM_21TEST POINT WHITE IOTP2
TEST_LOOPTESTLOOP_TEST_LOOP_IO_4.8MM_210TEST POINT BLACK IOTP3
TEST_LOOPTESTLOOP_TEST_LOOP_IO_4.8MM_21TEST POINT WHITE IOTP4
TEST_LOOPTESTLOOP_TEST_LOOP_IO_4.8MM_21TEST POINT WHITE IOTP5
TEST_LOOPTESTLOOP_TEST_LOOP_IO_4.8MM_21TEST POINT WHITE IOTP6
TEST_LOOPTESTLOOP_TEST_LOOP_IO_4.8MM_21TEST POINT WHITE IOTP7
TEST_LOOPTESTLOOP_TEST_LOOP_IO_4.8MM_210TEST POINT BLACK IOTP8
TEST_LOOPTESTLOOP_TEST_LOOP_IO_4.8MM_21TEST POINT WHITE IOTP9
TEST_LOOPTESTLOOP_TEST_LOOP_IO_4.8MM_21TEST POINT WHITE IOTP10
TEST_LOOPTESTLOOP_TEST_LOOP_IO_4.8MM_21TEST POINT WHITE IOTP11
TEST_LOOPTESTLOOP_TEST_LOOP_IO_4.8MM_21TEST POINT WHITE IOTP12
TEST_LOOPTESTLOOP_TEST_LOOP_IO_4.8MM_21TEST POINT WHITE IOTP13
TEST_LOOPTESTLOOP_TEST_LOOP_IO_4.8MM_21TEST POINT WHITE IOTP14
TEST_LOOPTESTLOOP_TEST_LOOP_IO_4.8MM_210TEST POINT BLACK IOTP15
TSSOP2074LVC573A_TSSOP20_IC_1.2MM_312-74LVC573A ICU1
QFN5X3_0P5_3X3MMA8451Q_16P_A_QFN5X3_0P5_3X3_IMMA8451Q ICU2
MAPBGA144_1_13X13PK40DX256VMD10_BGA144_MAPBGA144PK40DX256VMD10 ICU3
SO6_A1T45_SO6_A_IC_1.1MM_312-75172_SSN74LVC1T45 ICU4
SO6_A1T45_SO6_A_IC_1.1MM_312-75172_SSN74LVC1T45 ICU5
SO8MIC2526_8P_SO8_IC_1.73MM_312-75MIC2026-1YM ICU6
SOT_143SPB0503_SOT_143_IC_1.22MM_480-7SP0503B ICU7
SO6_A1T45_SO6_A_IC_1.1MM_312-75172_SSN74LVC1T45 ICU8
TSSOP14SN74LVC126A_TSSOP14_TSSOP14_IC_SN74LVC126APWG4 ICU9
SOT223LT1129CST-3.3_SOT223_IC_1.8MM_3MIC2920A-3.3WS ICU10
SOT223MIC37139-1.8BS-1_SOT223_IC_1.8MMIC5239-1.8 ICU11
TQFP44MC9S08JM60CFGE_TQFP44_IC_1.60MMC9S08JM60CLD ICU12
SO6_A1T45_SO6_A_IC_1.1MM_312-75172_SSN74LVC1T45 ICU13
XTAL3_3P35X1P45_SMXTAL_CS_XTAL3_3P35X1P45_SM_IC_08.00MHZ ICX1
XTL2_ECS_SMXTAL_XTL2_ECS_SM_IC_2.25MM_230-32.768KHz ICY1
XTL2_ECS_CSM7_SMXTAL_XTL2_ECS_CSM7_SM_IC_4.3MM_4MHz ICY2
重要提示:PCB作品文件展下载说明
