查看: 1591|回复: 0
[Allegro16.6以下] TWR-K60D100M Kinetis K60 100 MHz MCU塔式系统模块 8-1106
发表于 2018-11-29 22:31:50 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
18 TWR-K60D100M Kinetis K60 100 MHz MCU塔式系统模块.rar (4.89 MB, 下载次数: 2)
Bill of MaterialReport
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_TOLCOMP_CLASSREFDES
SKT_BAT_780X1210BATTERY_SKT_3V_SKT_BAT_780X1210BK-883 ICBT1
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF10%DISCRETEC1
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UF DISCRETEC2
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9_10.1UF DISCRETEC3
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9_10.1UF DISCRETEC4
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9_10.1UF DISCRETEC5
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UF DISCRETEC6
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UF DISCRETEC7
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.90M18PF DISCRETEC8
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9_10.1UF DISCRETEC9
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.90M18PF DISCRETEC10
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9_10.1UF DISCRETEC11
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9_10.1UF DISCRETEC12
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9_10.1UF DISCRETEC13
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9_10.1UF DISCRETEC14
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9_10.1UF DISCRETEC15
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9_10.1UF DISCRETEC16
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9_10.1UF DISCRETEC17
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9_10.1UF DISCRETEC18
CC3528-21CAP_POL_CC3528-21_2.1MM_150-7854.7uF ICC19
CC3528-21CAP_POL_CC3528-21_2.1MM_150-7854.7uF ICC20
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9_10.1UF DISCRETEC21
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9_10.1UF DISCRETEC22
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9_10.1UF DISCRETEC23
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9_10.1UF DISCRETEC24
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.90M18PF DISCRETEC25
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9650.01UF DISCRETEC26
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9_10.1UF DISCRETEC27
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9650.01UF DISCRETEC28
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9_10.1UF DISCRETEC29
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9_10.1UF DISCRETEC30
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.90M18PF DISCRETEC31
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9_10.1UF DISCRETEC32
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9_10.1UF DISCRETEC33
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9_10.1UF DISCRETEC34
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UF DISCRETEC35
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9_10.1UF DISCRETEC36
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9_10.1UF DISCRETEC37
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UF DISCRETEC38
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UF DISCRETEC39
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1.25M2.2UF DISCRETEC40
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9_10.1UF DISCRETEC41
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9_10.1UF DISCRETEC42
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9_10.1UF DISCRETEC43
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9_10.1UF DISCRETEC44
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UF DISCRETEC45
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9_10.1UF DISCRETEC46
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9_10.1UF DISCRETEC47
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9MM1000PF DISCRETEC48
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9_10.1UF DISCRETEC49
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UF DISCRETEC50
LED_0603LED_LED_0603_IC_0.8MM_370-75076LED_YELLOW ICD1
LED_0603LED_LED_0603_IC_1.0MM_370-76472YEL/GRN ICD2
LED_0603LED_LED_0603_IC_0.8MM_370-75080ORANGE ICD3
LED_0603LED_LED_0603_IC_1.0MM_370-76472YEL/GRN ICD4
DIODE_3P2X2P2LED_DIODE_3P2X2P2_IC_1.1MM_480-QTLP610CIR ICD5
SOT-23BAT721B_SOT-23_IC_1.3MM_480-779BAT54C ICD6
LED2_ELECTRODELED2_ELECTRODE_LED2_ELECTRODE_1LED_OR + ELECTRODE ICD7
LED2_ELECTRODELED2_ELECTRODE_LED2_ELECTRODE_2LED_YEL + ELECTRODE ICD8
LED2_ELECTRODELED2_ELECTRODE_LED2_ELECTRODE_3LED_GRN + ELECTRODE ICD9
SMB_2P7X1P4DIODE_SCHTKY_SMB_2P7X1P4_IC_0.7MSS1P3L ICD10
LED2_ELECTRODELED2_ELECTRODE_LED2_ELECTRODE_ILED2_ELECTRODE ICD11
HDR103CONN_HDR_3X1_HDR103_IO_8.65MM_2HDR TH 1X3 IOJ1
HDR102CONN_HDR_2X1_HDR102_IO_8.71MM_HDR 1X2 TH IOJ2
HDR102CONN_HDR_2X1_HDR102_IO_8.71MM_HDR 1X2 TH IOJ3
HDR102CONN_HDR_2X1_HDR102_IO_8.71MM_HDR 1X2 TH IOJ4
HDR102CONN_HDR_2X1_HDR102_IO_8.71MM_HDR 1X2 TH IOJ5
CON_TFM_20M_50_SMCONN_SHRHDR_10X2_CON_TFM_20M_50CON_2X10 IOJ6
HDR102CONN_HDR_2X1_HDR102_IO_8.71MM_HDR 1X2 TH IOJ7
CON_TFM_20M_50_SMCONN_SHRHDR_10X2_CON_TFM_20M__1CON_2X10 IOJ8
CON_TFM_20M_50_SMCONN_SHRHDR_10X2_CON_TFM_20M__1CON_2X10 IOJ9
HDR104_STAG_TSM_SMCONN_HDR_4X1_HDR104_STAG_TSM_SMHDR_4X1 IOJ10
CN2X82_FINGER_ASSCONN_PCI_XPRESS_X16_328P_CN2X82PCI EXPRESS TOWERSYSTEM IOJ11
HDR103CONN_HDR_3X1_HDR103_IO_8.65MM_2HDR TH 1X3 IOJ12
HDR103CONN_HDR_3X1_HDR103_IO_8.65MM_2HDR TH 1X3 IOJ13
HDR102CONN_HDR_2X1_HDR102_IO_8.71MM_HDR 1X2 TH IOJ14
HDR102CONN_HDR_2X1_HDR102_IO_8.71MM_HDR 1X2 TH IOJ15
CON_FTSH_19M_50_SMCONN_HDR_19_CON_FTSH_19M_50_SM_HDR_19P IOJ16
CON5_MUSB_AB_0P8_RA_SMTUSB_MINI_B_SKT_CON5_MUSB_AB_0P8USB_MINI_B 5 IOJ17
HDR203_TSM_SMCONN_HDR_3X2_HDR203_TSM_SM_IO_9HDR_2X3 IOJ18
HDR102CONN_HDR_2X1_HDR102_IO_8.71MM_HDR 1X2 TH IOJ19
CONN-MMC_SD_OPTMMC_SD_CONN_2405_CONN-MMC_SD_OPMMC-SD Connector IOJ20
IND_0603BEAD_FERRITE_IND_0603_DISCRETE_120OHM DISCRETEL1
IND_0603IND_IND_0603_0.8MM_180-75495_10100 OHM@100MHZ ICL2
IND_0805BEAD_IND_0805_DISCRETE_1.05MM_330 OHM DISCRETEL3
IND_0805BEAD_IND_0805_DISCRETE_1.05MM_330 OHM DISCRETEL4
IND_0603IND_IND_0603_0.8MM_180-75495_10100 OHM@100MHZ ICL5
IND_0603IND_IND_0603_0.8MM_180-75495_10100 OHM@100MHZ ICL6
IND_0603IND_IND_0603_0.8MM_180-75495_10100 OHM@100MHZ ICL7
IND_0603IND_IND_0603_0.8MM_180-75495_10100 OHM@100MHZ ICL8
SOT23NPN_SOT23_IC_1.12MM_480-75173_MMBT3904LT1G ICQ1
QTLP610TRAN_PHOTO_QTLP610_IC_1.1MM_480QTLP610CPD ICQ2
SOT-23TRAN_NPN_RES_SOT-23_IC_1.3MM_48PDTC115T ICQ3
RC0402_25RES_RC0402_25_DISCRETE_470-76031.0K DISCRETER1
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER2
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER3
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER4
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER5
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER6
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER7
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER8
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER9
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER10
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER11
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER12
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER13
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER14
RC0603_OVRES_RC0603_OV_DISCRETE_470-75434.70K DISCRETER15
RC0603_OVRES_RC0603_OV_DISCRETE_470-75434.70K DISCRETER16
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0K DISCRETER17
RC0402_25RES_RC0402_25_DISCRETE_470-76031.0K DISCRETER18
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0K DISCRETER19
RC0402_25RES_RC0402_25_DISCRETE__470-7601.0K DISCRETER20
RC0402_25RES_RC0402_25_DISCRETE_470-7646330 DISCRETER21
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0K DISCRETER22
RC0402_25RES_RC0402_25_DISCRETE_470-3078270 DISCRETER23
RC0603_OVRES_RC0603_OV_DISCRETE_470-75434.70K DISCRETER24
RC0402_25RES_RC0402_25_DISCRETE_470-757933 DISCRETER25
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0K DISCRETER26
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0K DISCRETER27
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0K DISCRETER28
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0K DISCRETER29
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0K DISCRETER30
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER31
RC0603_OVRES_RC0603_OV_DISCRETE_470-758262.0K DISCRETER32
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0K DISCRETER33
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0K DISCRETER34
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0K DISCRETER35
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0K DISCRETER36
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0K DISCRETER37
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0K DISCRETER38
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER39
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0K DISCRETER40
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0K DISCRETER41
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0K DISCRETER42
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER43
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER44
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER45
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER46
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER47
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER48
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER49
POT3_3352TPOT_POT3_3352T_DISCRETE_470-8015K DISCRETER50
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0K DISCRETER51
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0K DISCRETER52
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0K DISCRETER53
RC0402_25RES_RC0402_25_DISCRETE_470-757933 DISCRETER54
RC0402_25RES_RC0402_25_DISCRETE_470-757933 DISCRETER55
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER56
RC0603_OVRES_RC0603_OV_DISCRETE_470-75434.70K DISCRETER57
RC0402_25RES_RC0402_25_DISCRETE_470-76031.0K DISCRETER58
RC0805_OVRES_RC0805_OV_DISCRETE_470-75440 DISCRETER59
RC0603_OVRES_RC0603_OV_DISCRETE_470-75841.0M DISCRETER60
RC0805_OVRES_RC0805_OV_DISCRETE_470-75440 DISCRETER61
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER62
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0K DISCRETER63
RC0402_25RES_RC0402_25_DISCRETE_470-30851.54K DISCRETER64
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0K DISCRETER65
RC0402_25RES_RC0402_25_DISCRETE_470-76031.0K DISCRETER66
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER67
RC0805_OVRES_RC0805_OV_DISCRETE_470-75440 DISCRETER68
RC0805_OVRES_RC0805_OV_DISCRETE_470-75440 DISCRETER69
RC0402_25RES_RC0402_25_DISCRETE_470-76031.0K DISCRETER70
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER71
RC0402_25RES_RC0402_25_DISCRETE_470-78352.2K DISCRETER72
RC0402_25RES_RC0402_25_DISCRETE_470-757933 DISCRETER73
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER74
RC0402_25RES_RC0402_25_DISCRETE_470-764810M DISCRETER75
RC0402_25RES_RC0402_25_DISCRETE_470-757933 DISCRETER76
RC0402_25RES_RC0402_25_DISCRETE_470-76031.0K DISCRETER77
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER78
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0K DISCRETER79
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0K DISCRETER80
RC0402_25RES_RC0402_25_DISCRETE_470-30914.99K DISCRETER81
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0K DISCRETER82
SW4_4MMSW_TACT-SPST-2_SM_SW4_4MM_IC_4.PB switch ICSW1
SW4_4MMSW_TACT-SPST-2_SM_SW4_4MM_IC_4.PB switch ICSW2
SW4_4MMSW_TACT-SPST-2_SM_SW4_4MM_IC_4.PB switch ICSW3
TEST_LOOPTESTLOOP_TEST_LOOP_IC_4.8MM_21TEST POINT WHITE ICT1
TEST_LOOPTESTLOOP_TEST_LOOP_IC_4.8MM_21TEST POINT WHITE ICTP1
TEST_LOOPTESTLOOP_TEST_LOOP_IC_4.8MM_21TEST POINT WHITE ICTP2
TEST_LOOPTESTLOOP_TEST_LOOP_IC_4.8MM_21TEST POINT WHITE ICTP3
TEST_LOOPTESTLOOP_TEST_LOOP_IC_4.8MM_21TEST POINT WHITE ICTP4
TEST_LOOPTESTLOOP_TEST_LOOP_IC_4.8MM_21TEST POINT WHITE ICTP5
TEST_LOOPTESTLOOP_TEST_LOOP_IC_4.8MM_21TEST POINT WHITE ICTP6
TEST_LOOPTESTLOOP_TEST_LOOP_IC_4.8MM_21TEST POINT WHITE ICTP7
TEST_LOOPTESTLOOP_TEST_LOOP_IC_4.8MM_21TEST POINT WHITE ICTP8
TEST_LOOPTESTLOOP_TEST_LOOP_IC_4.8MM_21TEST POINT WHITE ICTP9
TEST_LOOPTESTLOOP_TEST_LOOP_IC_4.8MM_21TEST POINT WHITE ICTP10
TEST_LOOPTESTLOOP_TEST_LOOP_IC_4.8MM_21TEST POINT WHITE ICTP11
TEST_LOOPTESTLOOP_TEST_LOOP_IC_4.8MM_210TEST POINT BLACK ICTP12
TEST_LOOPTESTLOOP_TEST_LOOP_IC_4.8MM_21TEST POINT WHITE ICTP13
TEST_LOOPTESTLOOP_TEST_LOOP_IC_4.8MM_21TEST POINT WHITE ICTP14
TEST_LOOPTESTLOOP_TEST_LOOP_IC_4.8MM_21TEST POINT WHITE ICTP15
TEST_LOOPTESTLOOP_TEST_LOOP_IC_4.8MM_21TEST POINT WHITE ICTP16
TEST_LOOPTESTLOOP_TEST_LOOP_IC_4.8MM_21TEST POINT WHITE ICTP17
TEST_LOOPTESTLOOP_TEST_LOOP_IC_4.8MM_21TEST POINT WHITE ICTP18
TEST_LOOPTESTLOOP_TEST_LOOP_IC_4.8MM_210TEST POINT BLACK ICTP19
TEST_LOOPTESTLOOP_TEST_LOOP_IC_4.8MM_21TEST POINT WHITE ICTP20
TEST_LOOPTESTLOOP_TEST_LOOP_IC_4.8MM_21TEST POINT WHITE ICTP21
TEST_LOOPTESTLOOP_TEST_LOOP_IC_4.8MM_21TEST POINT WHITE ICTP22
QFN5X3_0P5_3X3MMA8451Q_16P_A_QFN5X3_0P5_3X3_IMMA8451Q ICU1
MAPBGA144_1_13X13PK60DN512VMD10_BGA_144P_MAPBGA1PK60DN512VMD10 ICU2
SO6_A1T45_SO6_A_IC_1.1MM_312-75172_SSN74LVC1T45 ICU3
SO6_A1T45_SO6_A_IC_1.1MM_312-75172_SSN74LVC1T45 ICU4
SO8MIC2526_8P_SO8_IC_1.73MM_312-75MIC2026-1YM ICU5
SOT_143SPB0503_SOT_143_IC_1.22MM_480-7SP0503B ICU6
TSSOP14SN74LVC126A_TSSOP14_TSSOP14_IC_SN74LVC126APWG4 ICU7
SO6_A1T45_SO6_A_IC_1.1MM_312-75172_SSN74LVC1T45 ICU8
SOT223LT1129CST-3.3_SOT223_IC_1.8MM_3MIC2920A-3.3WS ICU9
SOT223MIC37139-1.8BS-1_SOT223_IC_1.8MMIC5239-1.8 ICU10
TQFP44MC9S08JM60CFGE_TQFP44_IC_1.60MMC9S08JM60CLD ICU11
SO6_A1T45_SO6_A_IC_1.1MM_312-75172_SSN74LVC1T45 ICU12
XTLOSC4_SMCLKGEN-SM_XTLOSC4_SM_IC_1.75MM_50MHZ ICY1
XTL2_ECS_SMXTAL_XTL2_ECS_SM_IC_2.25MM_230-32.768KHz ICY2
XTL2_ECS_CSM7_SMXTAL_XTL2_ECS_CSM7_SM_IC_4.3MM_4MHz ICY3
重要提示:PCB作品文件展下载说明
