查看: 1528|回复: 0
[Allegro16.6以下] TWR-KL46Z48M Kinetis KL3x, KL4x塔式系统模块 6-1177
发表于 2018-11-29 22:42:37 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
23 TWR-KL46Z48M Kinetis KL3x, KL4x塔式系统模块.rar (8.34 MB, 下载次数: 2)
Bill of MaterialReport
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_TOLCOMP_CLASSREFDES
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UF10%DISCRETEC1
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UF10%DISCRETEC2
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.56M47PF5%DISCRETEC3
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF10%DISCRETEC4
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF10%DISCRETEC5
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF10%DISCRETEC8
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF10%DISCRETEC16
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.56M47PF5%DISCRETEC17
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF10%DISCRETEC19
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.56M47PF5%DISCRETEC20
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.56M47PF5%DISCRETEC21
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF10%DISCRETEC22
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF10%DISCRETEC23
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF10%DISCRETEC24
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF10%DISCRETEC25
CC3216CAP_POL_CC3216_DISCRETE_1.8MM_12.2UF10%DISCRETEC500
CC3216CAP_POL_CC3216_DISCRETE_1.8MM_12.2UF10%DISCRETEC501
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF10%DISCRETEC502
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UF10%DISCRETEC503
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF10%DISCRETEC504
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UF10%DISCRETEC505
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF10%DISCRETEC506
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF10%DISCRETEC507
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UF10%DISCRETEC508
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF10%DISCRETEC509
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF10%DISCRETEC510
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF10%DISCRETEC512
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF10%DISCRETEC513
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UF10%DISCRETEC514
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF10%DISCRETEC515
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1.25M2.2UF10%DISCRETEC516
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UF10%DISCRETEC517
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.90M18PF5%DISCRETEC518
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.90M18PF5%DISCRETEC519
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF10%DISCRETEC520
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.90M18PF5%DISCRETEC521
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UF10%DISCRETEC522
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UF10%DISCRETEC523
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1.25M2.2UF10%DISCRETEC524
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_10.01UF20%DISCRETEC525
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF10%DISCRETEC526
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_10.01UF20%DISCRETEC527
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF10%DISCRETEC528
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF10%DISCRETEC529
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9MM4.7uF10%DISCRETEC530
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.56M47PF5%DISCRETEC531
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_10.01UF20%DISCRETEC532
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_10.01UF20%DISCRETEC533
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF10%DISCRETEC534
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF10%DISCRETEC535
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF10%DISCRETEC536
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF10%DISCRETEC537
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF10%DISCRETEC538
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF10%DISCRETEC539
LED_0603LED_LED_0603_IC_0.67MM_370-7656LED GREEN ICD1
LED_0603LED_LED_0603_IC_0.8MM_370-76537YEL/GRN ICD3
LED_0603LED_LED_0603_IC_0.67MM_370-7656LED GREEN ICD4
LED_0603LED_LED_0603_IC_0.8MM_370-75083LED RED ICD5
DIODE_3P2X2P2_SMDLED_DIODE_3P2X2P2_SMD_IC_1.10MIR12-21C/TR8 ICD6
LED_0603LED_LED_0603_IC_0.8MM_370-76537YEL/GRN ICD500
SMB_2P7X1P4DIODE_SCHTKY_SMB_2P7X1P4_IC_0.7MSS1P3L ICD501
LED2_ELECTRODELED2_ELECTRODE_LED2_ELECTRODE_ILED_OR + ELECTRODE ICD502
LED2_ELECTRODELED2_ELECTRODE_LED2_ELECTRODE_1LED_YEL + ELECTRODE ICD503
CON_TFM_20M_50_SMCONN_SHRHDR_10X2_CON_TFM_20M_50CON_2X10 IOJ1
CON_TFM_20M_50_SMCONN_SHRHDR_10X2_CON_TFM_20M__1CON_2X10 IOJ2
HDR103CONN_HDR_3X1_HDR103_IO_8.65MM_2HDR TH 1X3 IOJ3
HDR103CONN_HDR_3X1_HDR103_IO_8.65MM_2HDR TH 1X3 IOJ4
CON_USB_5_548190572USB_MINI_B_SKT_CON_USB_5_548190CONN USB MINI-B 1x5 IOJ5
CON_TFM_20M_50_SMCONN_SHRHDR_10X2_CON_TFM_20M_50CON_2X10 IOJ6
HDR203CONN_HDR_3X2_HDR203_IO_8.58MM_2HDR_2X3 IOJ7
CON_2RH_10_50CONN_HDR_5X2_CON_2RH_10_50_IO_3HDR 2X5 IOJ8
HDR210CONN_HDR_10X2_HDR210_IO_8.71MMHDR_10X2 IOJ9
HDR103CONN_HDR_3X1_HDR103_IO_8.65MM_2HDR TH 1X3 IOJ10
HDR103CONN_HDR_3X1_HDR103_IO_8.65MM_2HDR TH 1X3 IOJ11
CN2X82_FINGER_ASSCONN_PCI_XPRESS_X16_328P_CN2X82PCI EXPRESS TOWERSYSTEM IOJ12
HDR102CONN_HDR_2X1_HDR102_IO_8.71MM_HDR 1X2 TH IOJ13
CON5_MICROUSBUSB_MINI_AB_RECEPTACLE_CON5_MICMICRO USB AB 5 IOJ14
HDR102CONN_HDR_2X1_HDR102_IO_8.71MM_HDR 1X2 TH IOJ15
HDR102CONN_HDR_2X1_HDR102_IO_8.71MM_HDR 1X2 TH IOJ16
HDR102CONN_HDR_2X1_HDR102_IO_8.71MM_HDR 1X2 TH IOJ17
HDR103CONN_HDR_3X1_HDR103_IO_8.65MM_2HDR TH 1X3 IOJ18
HDR102CONN_HDR_2X1_HDR102_IO_8.71MM_HDR 1X2 TH IOJ19
HDR102CONN_HDR_2X1_HDR102_IO_8.71MM_HDR 1X2 TH IOJ20
HDR102CONN_HDR_2X1_HDR102_IO_8.71MM_HDR 1X2 TH IOJ21
HDR102CONN_HDR_2X1_HDR102_IO_8.71MM_HDR 1X2 TH IOJ22
HDR102CONN_HDR_2X1_HDR102_IO_8.71MM_HDR 1X2 TH IOJ23
HDR102CONN_HDR_2X1_HDR102_IO_8.71MM_HDR 1X2 TH IOJ24
HDR102CONN_HDR_2X1_HDR102_IO_8.71MM_HDR 1X2 TH IOJ25
HDR102CONN_HDR_2X1_HDR102_IO_8.71MM_HDR 1X2 TH IOJ26
HDR102CONN_HDR_2X1_HDR102_IO_8.71MM_HDR 1X2 TH IOJ27
HDR102CONN_HDR_2X1_HDR102_IO_8.71MM_HDR 1X2 TH IOJ28
CON_2RH_10_50CONN_HDR_5X2_CON_2RH_10_50_IO_3HDR 2X5 IOJ29
IND_0805BEAD_IND_0805_DISCRETE_1.05MM_330 OHM25%DISCRETEL1
IND_0805BEAD_IND_0805_DISCRETE_1.05MM_330 OHM25%DISCRETEL2
IND_0805BEAD_IND_0805_DISCRETE_1.05MM_330 OHM25%DISCRETEL3
IND_1608IND_IND_1608_DISCRETE_0.95MM_18100 OHM@100MHZ25%DISCRETEL6
IND_0805BEAD_IND_0805_DISCRETE_1.05MM_330 OHM25%DISCRETEL500
IND_1608IND_IND_1608_DISCRETE_0.95MM_18100 OHM@100MHZ25%DISCRETEL501
IND_1608IND_IND_1608_DISCRETE_0.95MM_18100 OHM@100MHZ25%DISCRETEL502
IND_1608IND_IND_1608_DISCRETE_0.95MM_18100 OHM@100MHZ25%DISCRETEL503
IND_1608IND_IND_1608_DISCRETE_0.95MM_18100 OHM@100MHZ25%DISCRETEL504
SOT23NPN_SOT23_IC_1.11MM_480-75151_MMBT2484L ICQ1
PHTRANS_2P2X3P2PT12_PHTRANS_2P_PHTRANS_2P2X3P2PT12-21C/TR8 ICQ2
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER1
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER2
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER3
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER4
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER5
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER6
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER7
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER8
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER9
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER10
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER11
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER12
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER13
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER14
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER15
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER16
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER17
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER18
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER19
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER20
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER21
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER22
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER23
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER24
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER25
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER26
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER27
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER29
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER30
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER31
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER32
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER33
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER34
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER38
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER39
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_4710.0K1%DISCRETER40
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_44.7K5%DISCRETER42
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_4710.0K1%DISCRETER43
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_4710.0K1%DISCRETER44
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_335%DISCRETER45
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_335%DISCRETER46
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_4710.0K1%DISCRETER47
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_4710.0K1%DISCRETER48
RC0805_OVRES_RC0805_OV_DISCRETE_0.65MM_2701%DISCRETER49
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_11.0K5%DISCRETER50
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_335%DISCRETER51
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_335%DISCRETER52
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_44.7K5%DISCRETER53
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__23301%DISCRETER54
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__23301%DISCRETER55
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_335%DISCRETER56
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__11.0K1%DISCRETER57
RC0402_25RES_RC0402_25_DISCRETE_0.40M_21.54K1%DISCRETER58
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER500
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER501
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER502
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER503
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER504
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER505
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER506
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER507
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER508
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER509
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER510
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER511
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER512
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER513
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER514
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER515
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER516
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER517
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER518
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_42.2K5%DISCRETER519
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER520
RC0805_OVRES_RC0805_OV_DISCRETE_0.65M_12701%DISCRETER521
RC0402_25RES_RC0402_25_DISCRETE_0.55MM_410.0K5%DISCRETER522
RC0402_25RES_RC0402_25_DISCRETE_0.55MM_3301%DISCRETER523
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_44.7K5%DISCRETER524
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_44.7K5%DISCRETER525
RC0402_25RES_RC0402_25_DISCRETE_0.55MM_410.0K5%DISCRETER526
RC0402_25RES_RC0402_25_DISCRETE_0.40MM_15K1%DISCRETER527
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER528
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_11.0M5%DISCRETER529
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_4710.0K1%DISCRETER530
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER531
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_4710.0K1%DISCRETER532
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER533
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__11.0K1%DISCRETER534
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_415K1%DISCRETER535
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_4710.0K1%DISCRETER536
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_11.0M5%DISCRETER537
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__11.0K1%DISCRETER538
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER539
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER540
RC0402_25RES_RC0402_25_DISCRETE_0.40M_15.1K1%DISCRETER541
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_4710.0K1%DISCRETER542
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_335%DISCRETER543
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_335%DISCRETER544
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_4710.0K1%DISCRETER545
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_44.7K5%DISCRETER546
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__11.0K1%DISCRETER547
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER548
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER549
POT3_3352TPOT_POT3_3352T_DISCRETE_4.32MM5K20%DISCRETER550
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_4710.0K1%DISCRETER551
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_4710.0K1%DISCRETER552
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_44.7K5%DISCRETER553
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER554
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER555
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER556
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER557
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER558
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER559
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER560
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_05%DISCRETER561
SW4_4MMSW_TACT-SPST-2_SM_SW4_4MM_IC_4.PB switch ICSW1
SW4_4MMSW_TACT-SPST-2_SM_SW4_4MM_IC_4.PB switch ICSW2
SW_DIP8_4POS_SMSW_DIP4_SW_DIP8_4POS_SM_IC_2.32SW DIP-4 ICSW3
SW4_4MMSW_TACT-SPST-2_SM_SW4_4MM_IC_4.PB switch ICSW4
TEST_LOOPTESTLOOP_TEST_LOOP_IO_4.8MM_21TEST POINT WHITE IOTP1
TPAD_040TESTLOOP_TPAD_040_IC_0.1MM_211-TPAD_040 ICTP2
TEST_LOOPTESTLOOP_TEST_LOOP_IO_4.8MM_21TEST POINT WHITE IOTP3
TEST_LOOPTESTLOOP_TEST_LOOP_IO_4.8MM_21TEST POINT WHITE IOTP4
TEST_LOOPTESTLOOP_TEST_LOOP_IO_4.8MM_21TEST POINT WHITE IOTP5
TPAD_040TESTLOOP_TPAD_040_IC_0.1MM_211-TPAD_040 ICTP6
TPAD_040TESTLOOP_TPAD_040_IC_0.1MM_211-TPAD_040 ICTP7
TPAD_040TESTLOOP_TPAD_040_IC_0.1MM_211-TPAD_040 ICTP8
TPAD_040TESTLOOP_TPAD_040_IC_0.1MM_211-TPAD_040 ICTP9
TPAD_040TESTLOOP_TPAD_040_IC_0.1MM_211-TPAD_040 ICTP10
TEST_LOOPTESTLOOP_TEST_LOOP_IC_4.8MM_21TEST POINT WHITE ICTP11
TEST_LOOPTESTLOOP_TEST_LOOP_IC_4.8MM_21TEST POINT WHITE ICTP12
TEST_LOOPTESTLOOP_TEST_LOOP_IO_4.8MM_21TEST POINT WHITE IOTP13
TEST_LOOPTESTLOOP_TEST_LOOP_IO_4.8MM_21TEST POINT WHITE IOTP14
TPAD_040TESTLOOP_TPAD_040_IC_0.1MM_211-TPAD_040 ICTP15
TPAD_040TESTLOOP_TPAD_040_IC_0.1MM_211-TPAD_040 ICTP16
TPAD_040TESTLOOP_TPAD_040_IC_0.1MM_211-TPAD_040 ICTP17
TEST_LOOPTESTLOOP_TEST_LOOP_IO_4.8MM_21TEST POINT WHITE IOTP18
TPAD_040TESTLOOP_TPAD_040_IC_0.1MM_211-TPAD_040 ICTP19
TPAD_040TESTLOOP_TPAD_040_IC_0.1MM_211-TPAD_040 ICTP20
TEST_LOOPTESTLOOP_TEST_LOOP_IO_4.8MM_21TEST POINT WHITE IOTP21
SOT223LT1129CST-3.3_SOT223_IC_1.8MM_3MIC2920A-3.3WS ICU1
0402_MLPDIODE_TVS_BIDIR_0402_MLP_IC_0.40402ESDA-MLP ICU2
0402_MLPDIODE_TVS_BIDIR_0402_MLP_IC_0.40402ESDA-MLP ICU3
SOT23-6TXB0101_6P_SOT23-6_IC_1.45MM_3TXB0101 ICU4
SO6_A1T45_SO6_A_IC_1.1MM_312-75172_SSN74LVC1T45 ICU5
0402_MLPDIODE_TVS_BIDIR_0402_MLP_IC_0.40402ESDA-MLP ICU6
SO6_A1T45_SO6_A_IC_1.1MM_312-75172_SSN74LVC1T45 ICU7
LQFP100_0P5_14X14PKL46Z_LQFP100_LQFP100_0P5_14X1PKL46Z256VLL4 ICU10
0402_MLPDIODE_TVS_BIDIR_0402_MLP_IC_0.40402ESDA-MLP ICU12
0402_MLPDIODE_TVS_BIDIR_0402_MLP_IC_0.40402ESDA-MLP ICU13
0402_MLPDIODE_TVS_BIDIR_0402_MLP_IC_0.40402ESDA-MLP ICU14
SOT223MIC37139-1.8BS-1_SOT223_IC_1.8MMIC5239-1.8 ICU500
SSOP1474LVC125_SSOP14_IC_2MM_312-799374LVC125ADB ICU501
SOT23-6TXB0101_6P_SOT23-6_IC_1.45MM_1TXS0101 ICU502
QFN32_S142EPPK20DX128V_QFN_32P_QFN32_S142EPPK20DX128VFM5 ICU503
SO6_A1T45_SO6_A_IC_1.1MM_312-75172_SSN74LVC1T45 ICU504
SOT23-6_AMIC2005-0.8YM6_SOT23-6_A_IC_1.4MIC2005-0.8YM6 ICU505
SO8MIC2526_8P_SO8_IC_1.73MM_312-75MIC2026-1YM ICU506
QFN5X3_0P5_3X3MMA8451Q_16P_A_QFN5X3_0P5_3X3_IMMA8451Q ICU507
SO6_A1T45_SO6_A_IC_1.1MM_312-75172_SSN74LVC1T45 ICU508
SO6_A1T45_SO6_A_IC_1.1MM_312-75172_SSN74LVC1T45 ICU509
XTAL3_3P35X1P45_SMXTAL_CS_XTAL3_3P35X1P45_SM_IC_08.00MHZ ICX500
XTAL3_3P35X1P45_SMXTAL_CS_XTAL3_3P35X1P45_SM_IC_08.00MHZ ICX501
OSC4_10P5X5MMCRYSTAL-SG3030JF_OSC4_10P5X5MM_32.768KHZ ICY500
重要提示:PCB作品文件展下载说明
