查看: 3837|回复: 14
[AD格式] B_F446E_96B01A_板载STM32F446VET6单片机的传感器板 MB1126
发表于 2018-12-5 23:08:34 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
B_F446E_96B01A_sch.zip (6.73 MB, 下载次数: 13)
Comment             Pattern     Quantity  Components
0R                  0402_RES         2    R25, R26                     Resistor
100                 0402_RES         4    R1, R4, R13, R18             Resistor
100K                0402_RES         4    R6, R10, R15, R33            Resistor
100nF               0402_CAP_NP     34    C3, C4, C5, C6, C7, C8, C9   Capacitor 0402 / 0603 / 0805
                                           C10, C12, C13, C14, C16, C18
                                           C21, C22, C26, C29, C31, C33
                                           C34, C35, C36, C37, C38, C40
                                           C45, C46, C49, C50, C51, C52
                                           C53, C54, C56
1050170001          Molex_1050170001    1    J14
10K                 0402_RES        13    R5, R7, R17, R20, R21, R22   Resistor
                                           R34, R35, R36, R37, R38, R39
                                           R46
10nF                0402_CAP_NP      1    C27                          Capacitor_not polarized
10pF                0402_CAP_NP      2    C1, C2                       Capacitor 0402 / 0603 / 0805
10uF                0603_CAP_NP      1    C17                          Capacitor_not polarized
12pF                0402_CAP_NP      2    C30, C32                     Capacitor_not polarized
15K                 0402_RES         2    R42, R43                     Resistor
18K                 0402_RES         1    R45                          Resistor
1K                  0402_RES         1    R32                          Resistor
1K5                 0402_RES         1    R16                          Resistor
1uF                 0603_CAP_NP      5    C23, C24, C25, C28, C42      Capacitor_not polarized
2K2                 0402_RES         4    R23, R24, R27, R28           Resistor
2K7                 0402_RES         1    R2                           Resistor
2N2222              SOT-23           1    Q1                           NPN Bipolar Transistor
2uF2                0805_CAP_NP      2    C39, C41                     Capacitor_not polarized
36K                 0402_RES         1    R19                          Resistor
47K                 0402_RES         1    R41                          Resistor
4K7                 0402_RES         3    R3, R11, R12                 Resistor
4uF7                0603_CAP_NP      3    C11, C15, C55                Capacitor_not polarized
51                  0402_RES         2    R9, R40                      Resistor
680                 0402_RES         3    R29, R30, R31                Resistor
6pF                 0402_CAP_NP      2    C19, C20                     Capacitor_not polarized
74LVC8T245          DHVQFN24_3.5_5.5_0.85    3    IC4, IC6, IC7                8-bit dual supply translating transceiver; 3-state
8K2                 0402_RES         1    R44                          Resistor
ABS06-107-32.768kHz-T X2012            1    X2                           Crystal 2.0x1.2mm ABS06 32.768 KHz
APC I2C             GROVE_4PTS       1    J12                          Wafer 2mm 4pts DIP Grove
APC UART            GROVE_4PTS       1    J13                          Wafer 2mm 4pts DIP Grove
BAT54K              SOD523           1    D7                           Schottky Diode
BAT60JFILM          SOD-323          5    D1, D5, D6, D8, D9           Default Diode
BLUE LED            0603_LED_Blue    1    D4                           Light-Emitting Diode
BSS138              SOT23-3          4    Q2, Q3, Q4, Q5               MMBF170 N-Channel MOSFET
Close               SB-tiny         26    JP18, JP32, JP36, JP37, JP39 Solder Jumper
                                           JP40, JP46, JP47, JP60, JP62
                                           JP67, JP68, JP69, JP71, JP72
                                           JP73, JP74, JP79, JP80, JP81
                                           JP82, JP85, JP86, JP87, JP88
                                           JP89
Comment             96boards_Size1    1    Logo_96boards
Comment             LOGO_ST_Size3    2    Designator6, Logo_ST
CON30               FPC_30pts_3-1734742    2    J16, J17                     Connector
DIP_Switch_4P_SMD   DIP_SWITCH_4P_SMD    3    SW3, SW4, SW5                DIP_Switch_4P_SMD pitch 1.27mm
FCM1608KF-601T03    0603L            1    L1                           Inductor
GREEN LED           0603_LED_GREEN    1    D3                           Light-Emitting Diode
Header 10X1_Female  F-V50XC-1X10R-LF    1    J2                           Header, 10-Pin, Single row,female
Header 6X1_Female   F-V50XC-1X06R-LF    1    J8                           Header, 6-Pin, Single row,female
Header 8X1_Female   F-V50XC-1X08R-LF    2    J4, J6                       Header, 8-Pin, Single row,female
HEADER_1X2          Header F 1x2x2.00 TH V with Jumper    1    JP5
HEADER_1X2          Header M/F 1x2x1.27 NF    1    J19
HEADER_1X5          Header M/F 1x5x1.27 NF    1    J1
High Speed Ext.     BERGSTACK60PTS_08MM_F    1    J15                          FCI 61083-064x00LF 60pts
LD_BICOLOR_CMS      HSMF-A201        1    LD1                          Bicolor Led
LD39050PU33R        DFN6 3x3mm       1    IC2                          3.3V voltage regulator 500mA
LD3985M33R          SOT-23-5L        1    IC13                         Ultra low drop-low noise BiCMOS voltage, regulators low ESR capacitors compatible
LIS3MDL             VFLGA12-2x2x1    1    IC10                         IC,Sensor
Low Speed Ext.      FCI-57202-G52-20LF    1    J18                          FCI-57202-G52-20LF
LPS22HB             HLGA10L-2X2X0.76    1    IC11                         IC,Sensor
LSM6DS3H            LGA14L-2.5X3X0.86p0.5    1    IC9                          IC,Sensor
MP34DT01-M          HCLGA-4LD 3x4x1    1    IC1                          MEMS audio microphone
nc                  HDR1X2           1    J20                          Header, 2-Pin
NC                  SW-PB SMD KMR2    1    SW2                          Push-button SMD
Not Fitted          0402_RES         2    R8, R14                      Resistor
Open                SB-tiny         18    JP1, JP2, JP3, JP4, JP7, JP20 Solder Jumper
                                           JP26, JP27, JP52, JP53, JP54
                                           JP55, JP59, JP61, JP66, JP70
                                           JP83, JP84
RED LED             0603_LED_RED     1    D2                           Light-Emitting Diode
SN74LVC1T45         SN74LVC1T45_DRL    1    IC14                         Voltage-Level Translator
STM CAN1            GROVE_4PTS       1    J9                           Wafer 2mm 4pts DIP Grove
STM GPIO            GROVE_4PTS       1    J3                           Wafer 2mm 4pts DIP Grove
STM I2C2            GROVE_4PTS       1    J7                           Wafer 2mm 4pts DIP Grove
STM IC2C2           GROVE_4PTS       1    J11                          Wafer 2mm 4pts DIP Grove
STM SPI4            GROVE_4PTS-NO-MARK    1    J5                           Wafer 2mm 4pts DIP Grove
STM UART3           GROVE_4PTS       1    J10                          Wafer 2mm 4pts DIP Grove
STM32F103CBT6       LQFP48_0R5_7x7    1    IC8                          Medium-density performance line ARM-based 32-bit MCU with 64KB Flash
STM32F446VxT        STM32F446VxT_LQFP100    1    IC12                         STM32F446 LQFP100
TS3USB30            UQFN10 1.8x1.4mm    1    IC15                         TS3USB30 HS USB 2.0  1to2 switch
User PB             SW-PB SMD KMR2    1    SW1                          Push-button SMD
X2520-16MHz         X2520            1    X3                           Crystal 2.5x2.0mm
X2520-8MHz          Y 3225 2520      1    X1                           Crystal 2.5x2.0mm
重要提示:PCB作品文件展下载说明
    发表于 2018-12-6 07:59:04 | 显示全部楼层
    发表于 2018-12-6 08:49:03 | 显示全部楼层
    终身成就奖金点子奖
    发表于 2022-6-18 07:27:33 | 显示全部楼层
    发表于 2022-6-18 08:50:28 | 显示全部楼层
    5 天前
  • 签到天数: 114 天
    发表于 2022-6-18 08:52:53 | 显示全部楼层
  • 签到天数: 6 天
    发表于 2022-6-18 11:40:08 | 显示全部楼层
    社区居民终身成就奖优秀斑竹奖社区明星宣传大使奖特殊贡献奖原创先锋奖
    发表于 2022-6-18 12:43:24 | 显示全部楼层
  • 签到天数: 7 天
    社区居民终身成就奖特殊贡献奖
    发表于 2022-6-18 13:33:06 | 显示全部楼层
    昨天 13:10
  • 签到天数: 26 天
    发表于 2022-6-18 20:54:37 | 显示全部楼层
