查看: 4291|回复: 16
[AD格式] B_L072Z_LRWAN1_板载STM32L072CZ单片机的探索套件板 MB1126LRA
发表于 2018-12-5 23:09:34 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
b_072z_lrwan1_sch.zip (1.74 MB, 下载次数: 8)
Bill of Material for
On 2018/12/5/周三 at 21:55:58
Comment             Pattern     Quantity  Components
                     0402             8    C12, C13, C14, C15, L1, L2   0402
                                           L3, L4
                     HEADER 1X26 (2.54) MALE    2    CN2, CN3                     Connector header 26x1 2.54mm female
                     SIP2/2.54        2    JP4, JP6
                     SIP2/2.54-BOT    2    JP7, JP8
0                   0603             1    R31                          Resistor 0402 / 0603 / 0805
0R_0603             0603             3    R1, R3, R4                   0603 0R 50V 0.1W
10μF                0603C            3    C5, C6, C7                   Capacitor SMD 0805 10000000pF X7R 10V +/-10%
100                 0603             6    R19, R25, R28, R29, R30, R35 Resistor 0603
100K                0603             4    R2, R9, R16, R32             0603 100K 75V 5% 0.1W
100nF               0603C           19    C4, C8, C9, C11, C16, C17    Capacitor 100nF
                                           C18, C19, C20, C24, C25, C26
                                           C27, C28, C29, C32, C34, C35
                                           C40
100R                0603R            1    R6                           Resistor
1050170001          Molex_1050170001    2    CN7, CN11
10K                 0603             4    R7, R17, R18, R34            Resistor 0603
10K                 0603R            2    R15, R38                     Resistor 0603
10nF_X7R_0603       0603C            1    C33                          0603  X7R 10NF
10uF(25V)           TAN-B            2    C36, C37                     Polarized Capacitor (Radial)
1K_5%_0603          0603             1    R37                          0603 1K 50V 5% 0.063W
1K                  0603R            1    R39                          Resistor 0603
1K5                 0603             1    R33                          0603 1K5 75V 5% 0.1W
1uF_X5R_0603        0603C            4    C30, C31, C38, C39           0603  X5R 1礔
1uF                 0603C            2    C3, C10                      0603  X5R 1礔
20 pF               0603C            4    C1, C2, C22, C23             Capacitor 0603
22                  0603             4    R20, R21, R22, R23           Resistor 0603
2K2                 0603R            1    R24                          Resistor
2K7                 0603             1    R13                          Resistor
3 x AAA Battery Holder 3 X AAA BATTERY HOLDER    1    BT1                          3 x AAA Battery Holder
36K                 0603             1    R36                          Resistor
4.7uF(25V)          TAN-B            1    C21                          Polarized Capacitor (Radial)
4K7                 0603             3    R14, R26, R27                Resistor
4K7                 0603R            1    R5                           Resistor
510R                0603R            2    R8, R11                      Resistor
680R                0603R            2    R10, R12                     Resistor
8MHz(12pF)          CRY_NX3225GD_2P    1    X2                           Crystal Oscillator
9013                SOT-23           1    T1                           NPN Bipolar Transistor
BAT60JFILM          SOD323/A         4    D1, D2, D3, D8               BAT60JFILM
BLM15HG102SN1D      0402             1    L5                           BLM15HG102SN1D
Blue                0603D            1    LD3                          Typical RED, GREEN, YELLOW, AMBER GaAs LED
Circuit Breaker     JP2_SMD         37    SB1, SB2, SB3, SB4, SB5, SB6 Circuit Breaker
                                           SB7, SB8, SB9, SB10, SB11
                                           SB12, SB13, SB14, SB15, SB16
                                           SB17, SB18, SB19, SB20, SB21
                                           SB22, SB24, SB26, SB27, SB28
                                           SB29, SB30, SB31, SB32, SB33
                                           SB34, SB35, SB36, SB37, SB38
                                           SB40
Circuit Breaker     SB-tiny          4    SB23, SB25, SB39, SB41       Circuit Breaker
Comment             LOGO_ST_Size3    1    Logo_ST
External 3V3        SIP2             1    CN13                         Header 2
Green               0603D            1    LD1                          Typical RED, GREEN, YELLOW, AMBER GaAs LED
Header 10X1_Female  Header 1x10 Female (Wrapping)    1    CN1                          Header, 10-Pin, Single row,female
Header 4            SIP4             1    CN8                          Header, 4-Pin, Single row
Header 6X1_Female   Header 1x6 Female (Wrapping)    1    CN6                          Header, 6-Pin, Single row,female
Header 6X1          Header 1x6 Female (Wrapping)    1    CN12                         Header, 6-Pin, Single row
Header 8X1_Female   Header 1x8Female (Wrapping)    2    CN4, CN5                     Header, 8-Pin, Single row,female
LD_BICOLOR_CMS      LED SMD HSMF-A201-A00J1    1    LD5                          Bicolor Led
LD1117S50TR         SOT-223          1    U2
LD39050PU33R        DFN6(3X3)        1    U7
LD3985M33R          SOT-23-5L        1    U4                           Ultra low drop-low noise BiCMOS voltage, regulators low ESR capacitors compatible
LRA Module ES0      Lora Module ES0    1    U1                           LRA Module ES0
NU/8MHz(12pF)       CRY_NX3225GD_2P    1    X1                           Crystal Oscillator
Red                 0603D            4    LD2, LD4, LD6, LD7           Typical RED, GREEN, YELLOW, AMBER GaAs LED
Reset (Black)       PB10             1    B2                           SE PUSHBUTTON
RESET source selection SIP3             1    JP10                         Header 3
SMA                 SMA_COMBO_B      1    CN10
ST890CDR            SOIC8_1R27_4R9X6    1    U8
STM32F103CBT6       QFP48 7X7        1    U3                           Medium-density performance line ARM-based 32-bit MCU with 64KB Flash
STPS2L30A           SMA              4    D4, D5, D6, D7               STPS2L30A
TCXO Selection      SIP3             1    JP9                          Header 3
U.FL-R-SMT          UFL-SMD          1    CN9
USB_CHARGER         SIP2/2.54        1    JP5
USBLC6-2SC6         SOT23-6L         2    U5, U6
USER (Blue)         PB10             1    B1                           SE PUSHBUTTON
VDD_MCU_LRA         SIP2/2.54        1    JP3
VDD_RF_LRA          SIP2/2.54        1    JP1
VDD_USB_LRA         SIP2/2.54        1    JP2
重要提示:PCB作品文件展下载说明
社区居民忠实会员社区劳模原创达人最爱沙发终身成就奖特殊贡献奖原创先锋奖优秀斑竹奖
发表于 2018-12-6 07:45:29 | 显示全部楼层
    发表于 2018-12-6 07:59:32 | 显示全部楼层
    发表于 2018-12-6 08:48:21 | 显示全部楼层
  • 签到天数: 31 天
    终身成就奖社区居民
    发表于 2018-12-6 08:50:45 | 显示全部楼层
    发表于 2018-12-6 08:51:01 | 显示全部楼层
    发表于 2018-12-6 09:14:02 | 显示全部楼层
  • 签到天数: 62 天
    PADS-171101高级班
    终身成就奖特殊贡献奖优秀斑竹奖
    发表于 2018-12-6 12:08:16 | 显示全部楼层
  • 签到天数: 11 天
    社区居民忠实会员社区劳模最爱沙发原创达人终身成就奖特殊贡献奖优秀斑竹奖
    发表于 2018-12-6 17:09:17 | 显示全部楼层
    昨天 08:27
  • 签到天数: 268 天
    发表于 2018-12-7 08:36:39 | 显示全部楼层
