Item |
Quantity |
Reference |
Value |
MFG_NAME01 |
Description |
MFG_PN01 |
Tolerance |
Assy_Opt |
1 |
9 |
C1,C198,C199,C202,C203, |
100uF | |
TCAP,100UF,+/-10%,6.3V,SMD1210(B) | | |
C204,C274,C275,C438 | | | | |
2 |
11 |
C2,C4,C10,C56,C57,C257, |
22uF | |
CAP,22UF,+80%/-20%,Y5V,10V,SMD0805 | | |
C259,C261,C363,C418,C439 | | | | |
3 |
47 |
C3,C20,C21,C22,C29,C58, |
1uF | |
CAP,1UF,+/-10%,X5R,10V,SMD0402 | | |
C59,C61,C194,C220,C221, | | | | | | |
C276,C277,C308,C309,C310, | | | | | | |
C311,C313,C315,C316,C317, | | | | | | |
C318,C324,C326,C327,C329, | | | | | | |
C331,C333,C334,C336,C338, | | | | | | |
C340,C341,C342,C343,C345, | | | | | | |
C377,C382,C387,C392,C393, | | | | | | |
C411,C412,C414,C426,C427, | | | | | | |
C428 | | | | | | |
4 |
103 |
C5,C7,C11,C12,C13,C60, |
220nF | |
CAP,220NF,+/-10%,X5R,10V,SMD0402 | | |
C63,C64,C66,C68,C69,C70, | | | | | | |
C71,C72,C74,C75,C78,C79, | | | | | | |
C80,C81,C82,C83,C84,C86, | | | | | | |
C88,C90,C92,C93,C94,C98, | | | | | | |
C99,C101,C104,C107,C108, | | | | | | |
C110,C117,C118,C119,C122, | | | | | | |
C124,C125,C127,C129,C130, | | | | | | |
C136,C137,C138,C139,C140, | | | | | | |
C142,C143,C144,C145,C146, | | | | | | |
C147,C149,C150,C151,C152, | | | | | | |
C153,C154,C155,C157,C158, | | | | | | |
C159,C160,C161,C162,C163, | | | | | | |
C165,C166,C167,C168,C169, | | | | | | |
C170,C171,C173,C174,C175, | | | | | | |
C176,C177,C178,C179,C190, | | | | | | |
C191,C192,C237,C241,C245, | | | | | | |
C265,C278,C279,C280,C284, | | | | | | |
C357,C376,C378,C380,C381, | | | | | | |
C388,C389,C408 | | | | | |
5 |
88 |
C6,C24,C28,C30,C37,C42, |
100nF | |
CAP,100NF,+/-10%,X5R,10V,SMD0402 | | |
C46,C50,C52,C141,C181, | | | | | | |
C182,C184,C185,C186,C187, | | | | | | |
C196,C201,C206,C207,C208, | | | | | | |
C209,C210,C211,C212,C213, | | | | | | |
C216,C217,C222,C223,C227, | | | | | | |
C229,C230,C231,C240,C246, | | | | | | |
C247,C248,C249,C250,C251, | | | | | | |
C253,C256,C258,C260,C262, | | | | | | |
C264,C266,C267,C268,C271, | | | | | | |
C300,C320,C322,C347,C348, | | | | | | |
C351,C352,C359,C360,C361, | | | | | | |
C365,C367,C368,C379,C384, | | | | | | |
C385,C396,C404,C405,C407, | | | | | | |
C409,C410,C415,C417,C419, | | | | | | |
C444,C446,C448,C450,C451, | | | | | | |
C453,C456,C457,C458,C459, | | | | | | |
C460,C461 | | | | | |
6 |
31 |
C8,C9,C14,C16,C32,C33, |
22uF | |
CAP,22UF,+/-20%,X5R,6.3V,SMD0603 | | |
C34,C35,C38,C39,C40,C41, | | | | | | |
C44,C45,C54,C55,C65,C73, | | | | | | |
C85,C148,C156,C164,C172, | | | | | | |
C180,C215,C225,C263,C344, | | | | | | |
C346,C362,C390 | | | | | |
7 |
8 |
C15,C18,C394,C429,C430, |
10nF | |
CAP,10NF,+/-10%,X7R,25V,SMD0402 | | |
C431,C432,C433 | | | | | |
8 |
2 |
C17,C19 |
560pF | |
CAP,560PF,+/-5%,C0G,50V,SMD0402 |
9 |
26 |
C23,C26,C49,C67,C76,C77, |
2.2uF | |
CAP,2.2UF,+/-20%,X5R,6.3V,SMD0402 | | |
C87,C89,C91,C95,C97,C100, | | | | | | |
C109,C111,C115,C116,C120, | | | | | | |
C126,C128,C131,C238,C254, | | | | | | |
C255,C356,C374,C452 | | | | |
10 |
29 |
C25,C27,C36,C43,C47,C48, |
4.7uF | |
CAP,4.7UF,+/-10%,X5R,10V,SMD0603 | | |
C51,C53,C96,C183,C188, | | | | | | |
C189,C193,C200,C205,C228, | | | | | | |
C232,C233,C235,C269,C270, | | | | | | |
C272,C273,C354,C355,C386, | | | | | | |
C445,C447,C449 | | | | | |
11 |
4 |
C31,C112,C113,C114 |
470nF | |
CAP,470NF,+/-10%,X5R,10V,SMD0402 |
12 |
16 |
C62,C214,C218,C219,C224, |
10uF | |
CAP,10UF,+/-20%,X5R,6.3V,SMD0603 | | |
C252,C307,C319,C323,C325, | | | | | | |
C328,C330,C332,C335,C337, | | | | | | |
C413 | | | | | | |
13 |
23 |
C102,C103,C105,C106,C197, |
18pF | |
CAP,18PF,+/-5%,C0G,50V,SMD0402 | | |
C243,C244,C349,C350,C366, | | | | | | |
C391,C397,C398,C399,C400, | | | | | | |
C401,C406,C420,C421,C422, | | | | | | |
C423,C434,C435 | | | | | |
14 |
4 |
C121,C123,C358,C375 |
10uF | |
CAP,10UF,+/-10%,X5R,10V,SMD0603 |
15 |
3 |
C195,C321,C416 |
47uF | |
CAP,47UF,+/-20%,X5R,6.3V,SMD0805 |
16 |
3 |
C226,C239,C298 |
4.7uF | |
CAP,4.7UF,+/-10%,X5R,16V,SMD0603 |
17 |
5 |
C242,C301,C302,C353,C395 |
100nF | |
CAP,100NF,+/-10%,X5R,25V,SMD0402 |
18 |
2 |
C281,C282 |
56pF | |
CAP,56PF,+/-1%,C0G,50V,SMD0402 |
1% | |
19 |
3 |
C283,C369,C370 |
1nF | |
CAP,1NF,+/-10%,X7R,50V,SMD0402 |
20 |
1 |
C299 |
100uF | |
TCAP,100UF,+/-20%,10V,SMD1210(B) |
21 |
1 |
C383 |
33nF | |
CAP,33NF,+/-10%,X7R,16V,SMD0402 |
22 |
2 |
C402,C403 |
10pF | |
CAP,10PF,+/-5%,C0G,50V,SMD0402 |
23 |
1 |
C454 |
2.2uF | |
CAP,2.2UF,+/-10%,X5R,50V,SMD0805 |
24 |
1 |
C455 |
100nF | |
CAP,100NF,+/-10%,X7R,50V,SMD0603 |
25 |
4 |
D1,D6,D9,D11 |
Green | |
LED,Brilliant Green,WaterClear,20mA,SMD0805 |
26 |
5 |
D2,D7,D8,D10,D23 |
RED | |
LED,Brilliant Red,WaterClear,20mA,SMD0805 |
27 |
6 |
D3,D4,D16,D20,D25,D26 |
1N5819HW-7-F |
Diode,SchottkyDiode,1N5819HW-7-F,40V,1A,SOD-123,SMD |
28 |
1 |
D5 |
ORG | |
LED,Brilliant Orange,WaterClear,20mA,SMD0805 |
29 |
2 |
D12,D13 |
LED | |
30 |
3 |
D14,D15,D24 |
BAT54A | |
Diode,SchottkyDiode,BAT54AWT1G,30V,200mA,SOT-323 |
31 |
1 |
D17 |
MM5Z5V1ST1G |
Diode,DIODE ZENER 5.1V 200MW SOD523 |
32 |
1 |
D22 |
BAT54S | |
Diode,Schottky Barrier(Double)Diodes,BAT54S,30V,200mA,SOT-23,SMD |
33 |
1 |
FL1 |
LFB182G45SG9A272 |
FILTER,BANDPASS 2.4GHZ WLAN,0603(5pads),SMD |
34 |
1 |
F1 |
FUSE | |
Fuse,F1206FA4000V032T,32V,4A,FastActing,0.022ohm,SMD1206 |
35 |
1 |
JP1 |
HTMS-103-02-G-S |
Connector,PinHeader,Straight,Male,1x3Pin,1.27MM pitch,2.54,3.05,Gold Flash 10u,black,DIP |
36 |
1 |
J1 |
CONN_DCPOWER |
Connector,DC Jack,Right Angle,3Pin,2.0MMCenter Pin,Tin Plated,Black,DIP |
37 |
1 |
J2 |
CONN_BATIN |
Connector,PH Series PCBHeader,Straight,Male,1x2Pin,2.0MM pitch,Tin Plated, white,DIP |
38 |
1 |
J3 |
CONN_BAT | |
Connector,Battery Holder forCR1220,brown,SMD |
39 |
3 |
J4,J5,J10 |
CONN_Coaxial |
Connector,CoaxialConnector,U.FL-R-SMT-1,6GHZ,SMD |
40 |
1 |
J6 |
CONN_SD | |
Connector,SD Card CONN with detectswitch, Gold Flash 3u,white,SMD |
41 |
1 |
J7 |
CONN_SIM | |
Connector,SIM Card CONN,Gold Flash1u,Black,16.35x15.7x2.6mm,SMD |
42 |
1 |
J8 |
CONN_PCIe |
Connector,MiniPCI Card CONN 2x26,GoldFlash 1u,Black,SMD |
43 |
1 |
J9 |
CONN_HDMI |
Connector,HDMI A port,FeMale,19Position,Right Angle,Gold Flash 3u,black,SMD |
44 |
2 |
J11,J25 |
CONN_USB | |
Connector,MicroUSB AB port,5Position,Right Angle,Gold Flash 1u, black,SMD |
45 |
1 |
J12 |
CONN_JTAG |
Connector,PinHeader,Straight,Male,2x5Pin,1.27MM pitch,2.9mm,,Gold Flash 1u,black,SMD |
46 |
1 |
J13 |
CONN_EPD |
SAMTEC |
Connector,Board to Baord, Female120Pin,0.8MM Pitch, Gold Flash 10u,black,SMD |
QSH-060-01-L-D-A | |
47 |
1 |
J14 |
CONN_LCD | |
Connector,FPC Connector,RightAngle,50Pin,0.5MM Pitch,Flip-Lock Type,Bottom Contact,2.0MM Height,TinPlated, white,SMD |
48 |
1 |
J15 |
CONN_HP | |
Connector,Audio Jack,Right Angle,3.5MMPlug Diameter,Gold Flash 1u,Green,DIP |
49 |
1 |
J16 |
CONN_MIC | |
Connector,Audio Jack,Right Angle,3.5MMPlug Diameter,Gold Flash 1u,Pink,DIP |
50 |
1 |
J17 |
CONN_SPEAKER |
Townes |
Connector,PinHeader,Straight,Male,1x4Pin,2.54MM pitch,6.06,3.00,Gold Flash 1u,black,DIP |
P101-1*04SGF-116A-NG |
51 |
1 |
J18 |
CONN_SMARTCARD |
Connector,FPC Connector,RightAngle,14Pin,0.5MM Pitch,Flip-Lock Type,Bottom Contact,1.2MM Height,TinPlated, white,SMD |
52 |
1 |
J19 |
CONN_CAN | |
Connector,D-SUB with screwlock,Male,9Position,Right Angle,Gold Flash,black,DIP |
53 |
1 |
J20 |
CONN_MFI | |
Connector,PinSocket,Straight,Female,2x5Pin,2.54MM pitch,8.5,3.00,Gold Flash 1u, black,DIP |
54 |
1 |
J22 |
CONN_ADC | |
Connector,PinHeader,Straight,Male,2x4Pin,2.54MM pitch,5.80,,Gold Flash 1u, black,SMD |
55 |
1 |
J26 |
CONN_USB | |
Connector,USB A port,4 Position,RightAngle Flag,Gold Flash 1u,white,DIP |
56 |
2 |
J27,J28 |
CONN_RJ45 |
Connector,RJ45 Jack with integratedmagnetics and G/Y leds,Right Angle,1000M,Top contact,Gold Flash |
57 |
1 |
J29 |
CONN_CSI | |
BTBConnector,Socket,AXT530124,30Pin,0.4MM Pitch,without bosses,Height1.0mm,Ni+Au,panasonic,SMD |
58 |
1 |
J30 |
CONN_DSI | |
BTB Connector,socket,Right Angle,24Pin,0.4MMPitch,1.5MM Height,Au,Black,SMD |
59 |
1 |
J31 |
CONN_TAMPER |
Connector,PinHeader,Straight,Male,2x10Pin,1.27MM pitch,Gold Flash 30u,black,SMD |
60 |
2 |
J32,J33 |
CONN_MikroBUS |
Connector,PinSocket,Straight,Female,1x8Pin,2.54MM pitch,8.5,3.2,Gold Flash 1u, black,DIP |
61 |
6 |
J36,J37,J38,J39,J40,J41 |
CONN_JUMPER |
Connector,PinHeader,Straight,Male,1x2Pin,1.27MM pitch,3,2,Gold Flash 1u, black,DIP |
62 |
2 |
L1,L2 |
2.2uH | |
Power Inductor,Magneticshielded,2.2uH,IRMS=7A,ISAT=14A,0.02ohms,7.3x6.6x3mm,SMD |
63 |
4 |
L3,L4,L5,L7 |
1.5uH | |
Inductor ,1.5uH,60mOhms,3.5A +/-20%2.5x2.0x1.2mm OPNFE252012P-1R5M=P2 |
64 |
1 |
L6 |
2.2uH | |
Inductor,2.2uH 84mOhms3.0A +/-20%2.5x2.0x1.2mm OPNFE252012P-2R2M=P2 |
65 |
12 |
L8,L11,L12,L13,L50,L51, |
120 OHM@100MHZ |
FerriteBead,120ohm@100MHz,+/-25%,1300mA,90mohm,SMD0402 | | |
L52,L63,L64,L65,L66,L68 | | | | |
66 |
7 |
L10,L40,L41,L59,L60,L61, |
WCM-2012-900T |
Common Choke,90ohm@100MHz/20°C,±25%,450mA,0.3ohm,SMD0508 | | |
L62 | | | | | | |
67 |
24 |
L14,L15,L19,L20,L21,L22, |
120 OHM@100MHZ |
L25,L26,L27,L28,L29,L30, | | | | | | |
L31,L39,L42,L43,L45,L46, | | | | | | |
L47,L48,L49,L53,L57,L58 | | | | |
68 |
4 |
L16,L17,L55,L56 |
1nH | |
Inductor,1nH,Ir=400mA,RF=6GHz,Rdc=0.1ohm,SMD0402 |
69 |
2 |
L18,L67 |
2.2uH | |
Inductor,2.2uH,Ir=1.3A,RF=40MHz,Rdc=100mohm,SMD1008 |
70 |
2 |
L44,L54 |
4.7uH | |
Inductor,4.7uH,Ir=120mA,+/-20%,0.455ohm,SMD0805 |
71 |
4 |
MG1,MG2,MG3,MG4 |
MGX | |
STANDOFF,PHILIP FEMALE, ROUNDHEAD,M2-0.4*5,COPPER ALLOY |
72 |
3 |
Q2,Q32,Q34 |
AON3419 | |
Mosfet,P-Channel,AON3419,-30V,-10A,SOIC-8,SMD |
73 |
8 |
Q5,Q7,Q16,Q22,Q25,Q29, |
2N7002 | |
Mosfet,N-Channel,2N7002,60V,115mA,SOT-23,SMD | | |
Q30,Q31 | | | | | | |
74 |
5 |
Q6,Q10,Q13,Q21,Q24 |
AO3407A | |
Mosfet,P-Channel,AO3407A,-30V,-4.3A,SOT-23,SMD |
75 |
1 |
Q8 |
MMBT3904 | |
Transistor,NPN,MMBT3904,40V,200MA,SOT-23,SMD |
76 |
1 |
Q17 |
MMBT2907 | |
Transistor,PNP,MMBT2907A-7-F,60V,600MA,SOT-23,SMD |
77 |
1 |
Q35 |
BCM857BS | |
Transistor,DUALPNP,BCM857BS,45V,100MA,SOT-363,SMD |
78 |
1 |
Q36 |
DMN2005K-7 |
79 |
6 |
RN13,RN14,RN15,RN16,RN17, |
33R | |
RES 4 arrays,33R, +/-5%,1/16W,SMD0408 | | |
RN18 | | | | | | |
80 |
5 |
RN19,RN20,RN21,RN22,RN23 |
10K | |
RES 4 Arrays,10K,+/-5%,1/16W,SMD0408 |
81 |
13 |
R1,R4,R134,R161,R162, |
1K | |
RES,1K,+/-5%,1/16W,SMD0402 | | | |
R166,R167,R295,R296,R309, | | | | | | |
R310,R347,R623 | | | | | |
82 |
26 |
R6,R8,R15,R18,R35,R75, |
100K | |
RES,100K,+/-1%,1/16W,SMD0402 | | |
R152,R153,R154,R155,R156, | | | | | | |
R254,R256,R280,R348,R354, | | | | | | |
R539,R547,R549,R550,R551, | | | | | | |
R561,R570,R584,R611,R614 | | | | |
83 |
89 |
R9,R11,R28,R68,R87,R88, |
10K | |
RES,10K,+/-5%,1/16W,SMD0402 | | |
R89,R92,R93,R94,R97,R98, | | | | | | |
R99,R100,R101,R104,R105, | | | | | | |
R108,R135,R138,R139,R148, | | | | | | |
R165,R168,R169,R170,R225, | | | | | | |
R226,R228,R230,R232,R234, | | | | | | |
R236,R239,R241,R242,R244, | | | | | | |
R252,R253,R255,R257,R262, | | | | | | |
R263,R275,R282,R294,R327, | | | | | | |
R330,R331,R332,R333,R334, | | | | | | |
R335,R336,R351,R353,R361, | | | | | | |
R362,R363,R364,R367,R386, | | | | | | |
R387,R472,R477,R489,R490, | | | | | | |
R493,R498,R537,R543,R548, | | | | | | |
R553,R602,R603,R604,R609, | | | | | | |
R610,R612,R613,R615,R621, | | | | | | |
R622,R628,R630,R631,R636, | | | | | | |
R637,R640 | | | | | |
84 |
1 |
R10 |
75K | |
RES,75K,+/-1%,1/16W,SMD0402 |
1% | |
85 |
2 |
R12,R16 |
12K7 | |
RES,12K7,+/-1%,1/16W,SMD0402 |
86 |
2 |
R13,R17 |
24K | |
RES,24K,+/-1%,1/16W,SMD0402 |
1% | |
87 |
1 |
R14 |
88K7 | |
RES,88K7,+/-1%,1/16W,SMD0402 |
1% | |
88 |
14 |
R19,R90,R91,R127,R128, |
470R | |
RES,470R,+/-1%,1/16W,SMD0402 | | |
R129,R157,R264,R266,R267, | | | | | | |
R268,R269,R270,R556 | | | | |
89 |
2 |
R20,R24 |
0R | |
RES,0R,+/-5%,1/2W,SMD1206 | |
90 |
189 |
R23,R30,R31,R32,R45,R46, |
0R | |
RES,0R,+/-5%,1/16W,SMD0402 | | | |
R65,R69,R76,R85,R102, | | | | | | |
R117,R118,R119,R120,R124, | | | | | | |
R125,R136,R147,R163,R171, | | | | | | |
R172,R180,R181,R183,R184, | | | | | | |
R185,R186,R187,R188,R189, | | | | | | |
R190,R191,R192,R193,R194, | | | | | | |
R243,R250,R251,R258,R261, | | | | | | |
R265,R281,R283,R284,R285, | | | | | | |
R299,R300,R301,R302,R303, | | | | | | |
R307,R311,R312,R313,R314, | | | | | | |
R315,R316,R317,R318,R319, | | | | | | |
R320,R321,R325,R326,R329, | | | | | | |
R339,R340,R341,R350,R352, | | | | | | |
R355,R365,R368,R369,R370, | | | | | | |
R371,R372,R373,R374,R375, | | | | | | |
R388,R389,R390,R391,R392, | | | | | | |
R393,R394,R395,R396,R397, | | | | | | |
R398,R399,R400,R401,R402, | | | | | | |
R403,R404,R405,R406,R407, | | | | | | |
R408,R409,R410,R411,R412, | | | | | | |
R413,R415,R416,R417,R419, | | | | | | |
R420,R421,R422,R423,R424, | | | | | | |
R425,R426,R427,R428,R429, | | | | | | |
R430,R431,R432,R433,R434, | | | | | | |
R435,R476,R478,R479,R480, | | | | | | |
R481,R482,R483,R484,R485, | | | | | | |
R486,R487,R488,R496,R497, | | | | | | |
R499,R500,R501,R502,R503, | | | | | | |
R504,R505,R506,R507,R508, | | | | | | |
R509,R510,R512,R514,R515, | | | | | | |
R516,R518,R519,R520,R521, | | | | | | |
R523,R524,R554,R555,R557, | | | | | | |
R558,R559,R560,R565,R566, | | | | | | |
R567,R568,R569,R571,R582, | | | | | | |
R583,R595,R596,R617,R618, | | | | | | |
R619,R620,R629,R632,R633, | | | | | | |
R641,R642,R643 | | | | | |
91 |
6 |
R27,R132,R142,R143,R249, |
47K | |
RES,47K,+/-1%,1/16W,SMD0402 | | |
R616 | | | | | | |
92 |
14 |
R33,R34,R59,R60,R61,R62, |
2K2 | |
RES,2K2,+/-5%,1/16W,SMD0402 | | |
R63,R64,R107,R182,R491, | | | | | | |
R538,R580,R581 | | | | | |
93 |
1 |
R36 |
4.75M | |
RES, 4.75 M, 1%, 1/16 W,0402,SMD |
94 |
3 |
R38,R164,R349 |
1M | |
RES,1M,+/-5%,1/16W,SMD0402 | |
95 |
47 |
R39,R40,R41,R42,R43,R44, |
22R | |
RES,22R,+/-5%,1/16W,SMD0402 | | |
R112,R158,R160,R286,R287, | | | | | | |
R288,R289,R290,R291,R342, | | | | | | |
R436,R437,R438,R439,R440, | | | | | | |
R441,R442,R443,R444,R445, | | | | | | |
R446,R447,R448,R449,R450, | | | | | | |
R451,R452,R453,R454,R455, | | | | | | |
R456,R457,R458,R459,R468, | | | | | | |
R469,R470,R471,R473,R474, | | | | | | |
R475 | | | | | | |
96 |
2 |
R66,R70 |
200R | |
RES,200R,+/-1%,1/16W,SMD0402 |
1% | |
97 |
2 |
R67,R71 |
470K | |
RES,470K,+/-5%,1/16W,SMD0402 |
98 |
3 |
R80,R279,R540 |
4K7 | |
RES,4K7,+/-1%,1/16W,SMD0402 |
1% | |
99 |
5 |
R81,R82,R83,R84,R86 |
240R | |
RES,240R,+/-1%,1/16W,SMD0402 |
1% | |
100 |
25 |
R95,R96,R106,R110,R111, |
33R | |
RES,33R,+/-5%,1/16W,SMD0402 | | |
R137,R151,R177,R178,R179, | | | | | | |
R337,R338,R356,R357,R358, | | | | | | |
R359,R360,R492,R590,R591, | | | | | | |
R592,R593,R597,R598,R601 | | | | |
101 |
3 |
R103,R245,R246 |
60R4 | |
RES,60R4,+/-1%,1/8W,SMD0805 |
102 |
1 |
R133 |
5K1 | |
RES,5K1,+/-1%,1/16W,SMD0402 |
103 |
33 |
R140,R141,R144,R145,R174, |
4K7 | |
RES,4K7,+/-1%,1/16W,SMD0402 | | |
R175,R195,R196,R197,R199, | | | | | | |
R203,R204,R205,R206,R207, | | | | | | |
R208,R209,R210,R211,R212, | | | | | | |
R213,R214,R215,R216,R217, | | | | | | |
R218,R272,R273,R276,R277, | | | | | | |
R278,R638,R639 | | | | | |
104 |
1 |
R146 |
15K | |
RES,15K,+/-5%,1/16W,SMD0402 |
105 |
2 |
R159,R271 |
1K5 | |
RES,1K5,+/-1%,1/16W,SMD0402 |
1% | |
106 |
1 |
R176 |
10R | |
RES,10R,+/-5%,1/16W,SMD0402 |
107 |
1 |
R274 |
6K04 | |
RES,6K04,+/-1%,1/16W,SMD0402 |
108 |
1 |
R323 |
52K3 | |
RES,52K3,+/-1%,1/16W,SMD0402 |
109 |
1 |
R324 |
30K1 | |
RES,30K1,+/-1%,1/16W,SMD0402 |
110 |
25 |
R343,R344,R345,R346,R460, |
49R9 | |
RES,49R9,+/-1%,1/16W,SMD0402 | | |
R461,R462,R463,R464,R465, | | | | | | |
R466,R467,R495,R525,R526, | | | | | | |
R527,R528,R529,R530,R531, | | | | | | |
R532,R533,R534,R535,R536 | | | | |
111 |
1 |
R366 |
33K | |
RES,33K,+/-5%,1/16W,SMD0402 |
112 |
1 |
R494 |
560R | |
RES,560R,+/-1%,1/16W,SMD0402 |
1% | |
113 |
2 |
R605,R607 |
140R | |
RES,140R,+/-1%,1/16W,SMD0402 |
1% | |
114 |
2 |
R606,R608 |
75R | |
RES,75R,+/-1%,1/16W,SMD0402 |
1% | |
115 |
1 |
R624 |
374K | |
RES,374K,+/-1%,1/16W,SMD0402 |
116 |
1 |
R625 |
12K | |
RES,12K,+/-1%,1/16W,SMD0402 |
117 |
1 |
R626 |
30R | |
RES,30R, +/-1%,1/10W,SMD0603 |
118 |
2 |
R634,R635 |
49.9R 1% | |
119 |
1 |
SW1 |
SS-12D01VG2-566 |
Switch, Slide SwitchesSPDT,Straight,black housing,black plunger,8.6*4.3*4.7MM,DIP |
120 |
1 |
SW2 |
DSHP08TSGER |
Switch, DIP Switches SPST 8 switchsections,8 Position,1.27MM Pitch,black housing,white plunger,SMD |
121 |
1 |
SW3 |
GDH02S04 | |
Switch, DIP Switches,2 Position,1.27MMPitch,black housing,white plunger,SMD |
122 |
4 |
S1,S2,S3,S4 |
B3S-1000 | |
Switch,Tacticle,160gf,Metal housing,whiteplunger, 6*6*4.3MM,SMD |
123 |
64 |
TP1,TP2,TP3,TP4,TP5,TP6, |
tp30 | |
TEST POINT PAD 0.5MM DIA SMT, NO PART TOORDER |
DNP | | |
TP7,TP8,TP9,TP10,TP11, | | | | | | |
TP12,TP13,TP14,TP15,TP16, | | | | | | |
TP17,TP18,TP19,TP20,TP21, | | | | | | |
TP22,TP23,TP24,TP25,TP26, | | | | | | |
TP27,TP29,TP30,TP31,TP32, | | | | | | |
TP33,TP34,TP35,TP36,TP37, | | | | | | |
TP39,TP40,TP41,TP42,TP43, | | | | | | |
TP44,TP45,TP46,TP47,TP48, | | | | | | |
TP49,TP50,TP51,TP52,TP53, | | | | | | |
TP54,TP55,TP56,TP57,TP67, | | | | | | |
TP68,TP69,TP70,TP71,TP72, | | | | | | |
TP73,TP74,TP75 | | | | | |
124 |
8 |
TP58,TP60,TP61,TP62,TP63, |
tp30 | |
Connector,Test Point,5016,PAD:4.7*3.4mm,SMD |
DNP | | |
TP64,TP65,TP66 | | | | | |
125 |
6 |
TVS1,TVS2,TVS3,TVS4,TVS5, |
B72590D0050H160 |
On Semiconductor |
Diode,TVS,B72590D0050H160,5.6V,0402,SMD |
ESD9B3.3ST5G | | | |
TVS6 | | | | | | |
126 |
2 |
U2,U3 |
RT8070ZSP |
IC,4A, 2MHz, Synchronous Step-DownConverter,RT8070ZSP,SO-8,SMD |
127 |
1 |
U4 |
PC32PF3000A1EP |
IC,PMIC design for imx7,QFN48 |
128 |
1 |
U7 |
PCIMX7D7DVM10SA_541BGA_V2 |
ARM Cortex A7 MPCore? Processor |
129 |
2 |
U8,U9 |
MT41K256M16HA-125 |
MICRON |
IC,DDR3L 4Gb(256Mbx16)SDRAM,MT41K256M16HA-125:E,FPGA96,SMD |
MT41K128M16JT-125:K |
130 |
1 |
U10 |
MTFC8GACAEAM-1M WT |
IC,8GB MultiMediaCard (MMC) controllerand NAND Flash,MTFC8GACAEAM-1M WT,153-ball VFBGA,SMD |
131 |
1 |
U11 |
MX25L51245GZ2I-10G |
IC,Quad Serial NOR Flash Memory512Mb,MX25L51245G,SOIC-8,SMD |
132 |
1 |
U12 |
MT29F32G08CBADB |
IC,32Gb Asynchronous/SynchronousNAND,TSOP48 |
133 |
1 |
U13 |
SiI9022ACNU |
HDMI Transmitter supports the HighDefinition Multimedia Interface (HDMI) |
134 |
1 |
U14 |
ME6211C12M5G |
IC,High Speed LDO Regulators, Low ESRCap. Compatible, ME6211 Series,ME6211C12M5G,SOT-23-5,SMD |
135 |
1 |
U15 |
CM2020-00TR |
HDMI transmitter port protection andinterface device,TSSOP38,ON |
136 |
1 |
U16 |
LBEH5HMZPC-TEMP |
IC,W-LAN+Bluetooth+FM ComboModule,LBEH5HMZPC-TEMP,SMD |
137 |
2 |
U17,U19 |
SN74LVC2G126DCUT |
IC,Dual bus buffer gate with 3-stateoutputs,DCU,SMD |
138 |
1 |
U18 |
FT2232D | |
IC,Dual USB to SerialUART/FIFO,FT2232D,48-Pin LQFP,SMD |
139 |
1 |
U20 |
FXAS21002CQR1 |
IC,Xtrinsic 3-Axis Digital Angular RateGyroscope,FXAS21002CQR1,QFN24,SMD |
140 |
1 |
U21 |
FXOS8700CQR1 |
IC,6-Axis Sensor with Integrated LinearAccelerometer and Magnetometer,FXOS8700CQR1,QFN16,SMD |
141 |
1 |
U22 |
MPL3115A2 |
IC,PRESSURE SENSOR,20-110KPA,MPL3115A2,LGA,,SMD |
142 |
1 |
U23 |
TSC2046IPWR |
IC,Low-Voltage I/O TOUCH SCREENCONTROLLER,TSC2046IPWR,TSSOP-16,SMD |
143 |
1 |
U24 |
WM8960CGEFL/V |
IC,Stereo CODEC with Speaker Drivers andHeadphone Drivers,QFN32,SMD |
144 |
1 |
U25 |
MC33901WEF |
IC,high speed CAN transceivers,Automaticadaptation to 3.3 or 5.0 V MCU communication,SOIC8 |
145 |
2 |
U27,U28 |
USBLC6-2SC6Y |
Diode,TVS,USBLC6-2SC6Y,5.25V,SOT23-6L,SMD |
146 |
1 |
U30 |
SP2526A-1EN-L |
IC,Power Switch ICs - USB 2-CH ActiveHigh,SP2526A-1EN-L,NSOIC-8,SMD |
147 |
1 |
U31 |
BCM54220B0KFBG |
IC,Dual lan phy,FPGA-144,SMD |
148 |
1 |
U33 |
ME6211C18M5G |
IC,500mA High Speed LDO Regulators, LowESR Cap. low noise,ME6211C18M5G,SOT23-5,SMD |
149 |
1 |
U35 |
TPS73701DRB |
IC,Single Output LDO, 1A, Adj. (1.2 to5.0V), Reverse Current Protection,TPS73701DRB,SON8,SMD |
150 |
1 |
U36 |
SN74AVC16T245DGGR |
IC, 16-BIT DUAL-SUPPLY BUS TRANSCEIVERWITH CONFIGURABLE VOLTAGE TRANSLATION AND 3-STATE OUTPUTS, SN74AVC16T245DGGR,TSSOP-48, SMD |
151 |
1 |
U37 |
TPS3808G30DBVT |
IC,Low Quiescent Current,Programmable-Delay Supervisory Circuit,TPS3808G30DBVT,SOT-23,SMD |
152 |
1 |
U38 |
74LV595PW |
IC,8-bit serial-in/serial-out orparallel-out shift register; 3-state;NXP |
153 |
1 |
U39 |
SN74LV1T126DCKR |
IC,Single Power Supply Single Buffer Gatewith 3-State Output CMOS Logic Level Shifter;TI |
154 |
1 |
U40 |
LMV358MX | |
IC,Rail-to-Rail Output OperationalAmplifiers,LMV358MX,SOIC-8,SMD |
155 |
1 |
U41 |
24AA512-I/SN |
EEPROM,64KB,1.8V,SOIC-8,SMD |
156 |
1 |
U42 |
PI6CFGL201BZDIEX |
Clock,2-Output Low Power PCIE Gen 1-2-3Clock Generator,TQFN-24,SMD |
157 |
1 |
U43 |
AAT1239ITP-1-T1 |
IC,40V Step-Up Converter for 4 to 10White LEDs,AAT1239ITP-1-T1,TSOPJW-12,SMD |
158 |
1 |
U44 |
TLV73310PDBVT | | | | |
159 |
1 |
U45 |
TXS0102DCUR |
IC,2-BIT BIDIRECTIONAL VOLTAGE-LEVELTRANSLATO,TXS0102DCUR,8-X2SON,SMD |
160 |
3 |
X1,X2,X3 |
32.768KHz |
Oscillator,1631-L3275-BTGQYA,32.768KHz,50ppm,1.8V,3225,SMD |
161 |
1 |
X4 |
24MHz | |
Oscillator,ASTMLPE-18-24.000MHz-LJ-E-T,24MHz, |
+/-20ppm,1.8V,3225,SMD | | | | | | |
162 |
1 |
Y1 |
CM7V-T1A | |
Crystal,CM7V-T1A,32.768KHz,+/-20PPM,12.5PF,3.2x1.5MM,SMD |
163 |
1 |
Y2 |
5XBB24000202TF50Q3 |
Crystal,5XBB24000202TF50Q3,24MHz,+/-20PPM,20PF,5032-2pads,SMD |
164 |
1 |
Y3 |
25MHZ | |
Crystal,S,25MHz,30ppm,18PF,3225-4,SMD |
165 |
1 |
Y4 |
7D06000202BTAF70Q3 |
Crystal,7D06000202BTAF70Q3,6MHz,+/-20PPM,20PF,HC-49SMD,SMD |
166 |
1 |
Y8 |
5XBB25000202TF40Q3 |
Crystal,5XBB25000202TF40Q3,25MHz,+/-20PPM,20PF,5032-2pads,SMD |
167 |
7 |
Z31,Z36,Z37,Z38,Z39,Z40, |
CONN_Shunt |
SHUNT,1.27mm,SP JUMPER,118H,AU,DIP | | |
Z41 | | | | | | |
