[Allegro16.6以下] MAX10_10M50_EVAL_A1 FPGA MIPI影像测试板6层pcb,原理图
查看8873 | 回复48 | 2018-12-8 08:56:12 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
6层pcb,2497pins
C109CAP 0.1UF +/-10% 10V0402_0402_0.1uF402
C111CAP 0.1UF +/-10% 10V0402_0805_22uF805
C112CAP_0402_15PF15pF402
D182401646_WURTH_MSOP8_8240164682401646WURTH_MSOP8
D282401646_WURTH_MSOP8_8240164682401646WURTH_MSOP8
D3LED_WURTH_1_LED_0603_GREEN_LEDGREEN_LEDLED_0603
D4LED_WURTH_1_LED_0603_GREEN_LEDGREEN_LEDLED_0603
D5LED_WURTH_1_LED_0603_GREEN_LEDGREEN_LEDLED_0603
D6LED_WURTH_1_LED_0603_GREEN_LEDGREEN_LEDLED_0603
D7LED_WURTH_1_LED_0603_GREEN_LEDGREEN_LEDLED_0603
D8LED_WURTH_1_LED_0603_GREEN_LEDGREEN_LEDLED_0603
D9LED_WURTH_1_LED_0603_YELLOW_LEDYELLOW_LEDLED_0603
D10LED_WURTH_1_LED_0603_YELLOW_LEDYELLOW_LEDLED_0603
D11LED_WURTH_1_LED_0603_YELLOW_LEDYELLOW_LEDLED_0603
J1FCCCONN_1_52559-3652_FFC_CONN_FFC_CONN_1x3652559-3652
J2FCCCONN_1_52559-3652_FFC_CONN_FFC_CONN_1x3652559-3652
J3FFC_CONN_0_68711614522_FFCCONNFFC CONN 1x1668711614522
J4HDMI 19-PINRECEPTACLE_HDMI-19P6.85119E+11HDMI-19PIN
J5USBMINI-B_WURTH_USB_MINI-B_USBUSB MINI-BWURTH_USB_MINI-B
J62X5_HDR2X5_100MIL_SMT_DNIDNIHDR2X5_100MIL_SMT
J72X5_HDR2X5_100MIL_SMT_2X5_100MI2X5_100milHDR2X5_100MIL_SMT
J82X6PMOD_HDR2X6_100MIL_2X6 PMOD2x6 PMOD ConnectorHDR2X6_100MIL
J92X6PMOD_HDR2X6_100MIL_2X6 PMOD2x6 PMOD ConnectorHDR2X6_100MIL
J10JACK-DC_JACK-DC_2MM_DCINPUT JADC Input Jack 2.0 mmJACK-DC_2MM
J11HEADER,1X3-PIN_CONN_TSW_103_07HEADER, 1x3-PINCONN_TSW_103_07_L_S
J122X10_10-89-1201_HEADER2X10 (DNHeader 2x10 (DNI)10-89-1201
J132X10_10-89-1201_HEADER2X10 (DNHeader 2x10 (DNI)10-89-1201
J14HEADER_3_10-89-1141_HEADER2X7Header 2x7 (DNI)10-89-1141
L1IND 10UH 245MA0.82OHM 0806 SMD10uH806
L2IND 10UH 245MA0.82OHM 0806 SMD10uH806
L3IND 10UH 245MA0.82OHM 0806 SMD10uH806
L4IND 10UH 245MA0.82OHM 0806 SMD10uH806
L5IND FERRITE 0402300MA/220_0402BLM15AG221SN1402
L6IND FERRITE 0402300MA/220_0402BLM15AG221SN1402
L7INDUCTOR_0805_742792022742792022805
L8INDUCTOR_0805_742792022742792022805
L9IND FERRITE 0402300MA/220_0402BLM15AG221SN1402
R41R_0402_150150402
R313RESISTOR_0402_DNIDNI402
R314RESISTOR_0402_22.022402
R315RESISTOR_0603_5151603
S1TS-A02SA-2-S100_PUSHBUTTON_SMT_PB SwitchPUSHBUTTON_SMT
S2TS-A02SA-2-S100_PUSHBUTTON_SMT_PB SwitchPUSHBUTTON_SMT
S3TS-A02SA-2-S100_PUSHBUTTON_SMT_PB SwitchPUSHBUTTON_SMT
S4TS-A02SA-2-S100_PUSHBUTTON_SMT_PB SwitchPUSHBUTTON_SMT
S6TS-A02SA-2-S100_PUSHBUTTON_SMT_PB SwitchPUSHBUTTON_SMT
S7TS-A02SA-2-S100_PUSHBUTTON_SMT_PB SwitchPUSHBUTTON_SMT
SW1SPST4_DIPSWITCH_SMT_QUAD_DIPSWIDIPSWITCH4DIPSWITCH_SMT_QUAD
SW2SPST4_DIPSWITCH_SMT_QUAD_DIPSWIDIPSWITCH4DIPSWITCH_SMT_QUAD
SW3SW-PUSH_3_SW-PUSH-8X8_POWERSWPOWER SWSW-PUSH-8X8
TP1T POINTR_TEST_PAD_SMT_T POINTT POINT RTEST_PAD_SMT
TP2T POINTR_TEST_PAD_SMT_T POINTT POINT RTEST_PAD_SMT
TP3T POINTR_TEST_PAD_SMT_T POINTT POINT RTEST_PAD_SMT
TP4T POINTR_TEST_PAD_SMT_T POINTT POINT RTEST_PAD_SMT
TP5T POINTR_TEST_PAD_SMT_T POINTT POINT RTEST_PAD_SMT
TP6T POINTR_TEST_PAD_SMT_T POINTT POINT RTEST_PAD_SMT
TP7T POINTR_TEST_PAD_SMT_10MIL_TT POINT RTEST_PAD_SMT_10MIL
TP8T POINTR_TEST_PAD_SMT_10MIL_TT POINT RTEST_PAD_SMT_10MIL
TP10T POINTR_TEST_PAD_SMT_10MIL_TT POINT RTEST_PAD_SMT_10MIL
TP11T POINTR_TEST_PAD_SMT_10MIL_TT POINT RTEST_PAD_SMT_10MIL
TP13T POINTR_TEST_PAD_SMT_10MIL_TT POINT RTEST_PAD_SMT_10MIL
TP14T POINTR_TEST_PAD_SMT_10MIL_TT POINT RTEST_PAD_SMT_10MIL
TP15T POINTR_TEST_PAD_SMT_10MIL_TT POINT RTEST_PAD_SMT_10MIL
TP16T POINTR_TEST_PAD_SMT_10MIL_TT POINT RTEST_PAD_SMT_10MIL
TP19T POINTR_TEST_PAD_SMT_10MIL_TT POINT RTEST_PAD_SMT_10MIL
TP20T POINTR_TEST_PAD_SMT_10MIL_TT POINT RTEST_PAD_SMT_10MIL
TP21T POINTR_TEST_PAD_SMT_10MIL_TT POINT RTEST_PAD_SMT_10MIL
TP22T POINTR_TEST_PAD_SMT_10MIL_TT POINT RTEST_PAD_SMT_10MIL
TP25T POINTR_TEST_PAD_SMT_10MIL_TT POINT RTEST_PAD_SMT_10MIL
TP68T POINTR_TEST_PAD_SMT_10MIL_TT POINT RTEST_PAD_SMT_10MIL
U110M50DAF484_V2.0_4.5_F484_(S1+S10M50DAF484F484
U2LPDDR2_IS43LD16640A-3BL_2_FBGA1LPDDR2_IS43LD16640A-3BLFBGA134
U3ADV7513BSWZ_LQFP-64_ADV7513BSWZADV7513BSWZLQFP-64
U4EPM1270M256_2_M256_(S1+S4),(S2+EPM1270_M256FBGAM256
U5MAX811_SOT-143_MAX811MAX811SOT-143
U6TPD2EUSB30_DRT_TPD2EUSB30TPD2EUSB30DRT
U7CY7C68013A_56QFN_QFN56_CY7C6801CY7C68013A_QFNQFN56
U8824013_SOT23-6L_824013824013SOT23-6L
U9824013_SOT23-6L_824013824013SOT23-6L
U10824013_SOT23-6L_824013824013SOT23-6L
U11824013_SOT23-6L_824013824013SOT23-6L
U14CLOCK GEN,SI5338A_CUSTOM, A5SKSi5338C-CUSTOMQFN24
U15SI510-DUALCMOS_SI510_510MCA50M0510MCA50M0000AAGRSI510
U16FDMC8878_VER2_FDMC8878_VER2_FDMFDMC8878FDMC8878_VER2
U17EN5329/5339QI_0_EN5339QI_EN5329EN5329QIEN5339QI
U18LTC4218CGN_16-LEAD_PLASTIC_SSOPLTC4218CGN16-LEAD_PLASTIC_SSOP
U19EP5348UI_0_EP5348UI_EP5348UIEP5348UIEP5348UI
U20EP5358XUI_UQFN16_EP5358HUIEP5358HUIUQFN16
U21EN5329/5339QI_0_EN5339QI_EN5339EN5339QIEN5339QI
U22EP5348UI_0_EP5348UI_EP5348UIEP5348UIEP5348UI
U23N25Q00AA13GSF40F_1_SO16_WIDE_N2N25Q512A83GSF40FSO16_WIDE
V1SENSE_PAD_SENSE_SENSE_PADSENSE_PADSENSE
V2SENSE_PAD_SENSE_SENSE_PADSENSE_PADSENSE
Y1CRYSTAL_SM_13_XTAL_FA-128_24.0024.00MHzXTAL_FA-128
Y2XTAL 25MHZ 30PPM 18PFMINI_XTAL25.00MHzXTAL_FA-128
max10_10m50_eval_a1.1-pcb.zip (2.52 MB, 下载次数: 19)
重要提示:PCB作品文件展下载说明
pads008 | 2018-12-8 08:56:57 | 显示全部楼层
yang111 | 2018-12-8 08:59:52 | 显示全部楼层
shenchengan | 2018-12-8 09:01:49 | 显示全部楼层
fxliuqq | 2018-12-8 09:18:27 | 显示全部楼层
谢谢分享谢谢分享谢谢分享
似水流年 | 2018-12-8 09:19:43 | 显示全部楼层
fxliuqq | 2018-12-8 09:25:52 | 显示全部楼层
谢谢分享谢谢分享谢谢分享
topdenzengzhi | 2018-12-8 10:10:33 | 显示全部楼层
生活就是油盐酱醋再加一点糖,快活就是一天到晚乐呵呵的忙!
lbmone | 2018-12-8 11:12:36 | 显示全部楼层
wuzf | 2018-12-9 18:39:38 | 显示全部楼层
