?6#won SYM_NAME | <n"BPXF~ COMP_DEVICE_TYPE | +6m.f,14q COMP_VALUE | bz>X~
COMP_TOL | em$pU*`P COMP_CLASS | O] _4pP REFDES |
mkl{Tp* CC0603_OV | g?C;b>4 CAP_NP_CC0603_OV_DISCRETE_0.965 | ny={OhP- 470PF | r~w.J+W | ~(5r+Z}*` DISCRETE | NW3c_]`= C1 |
GK(CuwJe CC0603_OV | (~T*yH ~ CAP_NP_CC0603_OV_DISCRETE_0.965 | bS.w<V
Ew 470PF | ZzT=m*tQ& | d_RgKdR )k DISCRETE | 7*/{m K) C2 |
rr<E#w CC0805_OV | k$EVr([ CAP_NP_CC0805_OV_DISCRETE_1.4_1 | ab0Sx 2.2uF | Mf}M/Fh 10% | :Mf" DISCRETE | :FyF:=
C3 |
NE995; CC0603_OV | WWT1= #" CAP_NP_CC0603_OV_DISCRETE_0.9 M | f0<zK! 0.1uF | f)I5=Ijy( | _KT!OYH DISCRETE | IG-\& C4 |
#;!&8iH CC0603_OV | ,Z.sGv CAP_NP_CC0603_OV_DISCRETE_0.965 | (!j#u)O 470PF | ~j0rORy] | 3} A$+PX DISCRETE | K*6 "c.D C5 |
/--p#G h' CC0805_OV | ~%{2Z_t$ CAP_NP_CC0805_OV_DISCRETE_1.4_1 | O&`.R|v 2.2uF |
%H{p&ms 10% | 'U@o!\=a DISCRETE | h}bfZL C6 |
YJi%vQ*] CC0603_OV | }D/+YG CAP_NP_CC0603_OV_DISCRETE_0.9 M | L`NIYH<^ 0.1uF | _ k-_&PR | Cj5mM[:s DISCRETE | O*yxOb* C7 |
>rG>Bz^Pu CCE63X55 | zF&VzNR2 CAP_POL_CCE63X55_DISCRETE_6.1MM | 5&Oc`5QD 47UF | :yay:3qv | ^xo<$zn DISCRETE | =:W2NN' C8 |
V35Vi6*p CC0603_OV | qsj{0 Go CAP_NP_CC0603_OV_DISCRETE_0.9 M | jU,Xlgz(A 0.1uF | 3? {AGJ1 | <,d550GSm DISCRETE | a6p0_-MF C9 |
jW/WG tz CC0603_OV | yTm
\OUD CAP_NP_CC0603_OV_DISCRETE_0.9 M | Uj@th 0.1uF | "> uN={Iy | OG\i?N DISCRETE | y@P%t9l C10 |
.6?"<zdPU CC0603_OV | _0/unJl` CAP_NP_CC0603_OV_DISCRETE_0.91M | tjdPia 47PF | $:ush"=f8^ | [g}Cve#i DISCRETE | ,5DJ54B! C11 |
4WT[( CC0805_OV | OV>&`puL CAP_NP_CC0805_OV_DISCRETE_1.45M | |OQ]F 2.2uF | U,<m%C" | CK* *RZ DISCRETE | Y$'j9bUJ C12 |
n.%QWhUB CC0603_OV | oOFTQB_6 CAP_NP_CC0603_OV_DISCRETE_0.9 M | m*0YMS>Y | 0.1uF | >CB-a : | "~KDm(D DISCRETE | 6jE.X C13 |
;Iu _*U9) CC0603_OV | 1v@#b@NXM7 CAP_NP_CC0603_OV_DISCRETE_0.91M | uU
d"l,V 47PF | Pk?$\ | N:j7J DISCRETE | y:G%p3h)[ C14 |
!V|{(>+< CC0603_OV | ~(kEGEF CAP_NP_CC0603_OV_DISCRETE_0.9_1 | .#EU@Hc 82pF | yi7.9/;a | K:Z$V DISCRETE | i'Y8-}) C15 |
;0DoZ CC0603_OV | ly0R'4j \ CAP_NP_CC0603_OV_DISCRETE_0.965 | 1M ?BSH{ 470PF |
]jT}]9Q$ | NAYLlW}A DISCRETE | l4C{LZ C16 |
2>z YJqG| CC0603_OV | 8ud12^s$ CAP_NP_CC0603_OV_DISCRETE_0.9_1 | &/@V$'G= 82pF | WfPb7T | +eVYy_bL- DISCRETE | OB>Hiy
C18 |
RpdUR*K9x CC0603_OV | 41
F;X{Br CAP_NP_CC0603_OV_DISCRETE_0.91M | f*k7 @[rSv 47PF | x&B&lFmo8 | y-<.l=6A DISCRETE | R hWQ:l] C19 |
{}$9
70y CC0603_OV | :Cq73:1\B CAP_NP_CC0603_OV_DISCRETE_0.91M | Yf0 KG 47PF | *85N_+Wv! | OGZD$j DISCRETE | I0XJ&P% C20 |
m*^)# CC0603_OV | <kB:`&X<\ CAP_NP_CC0603_OV_DISCRETE_0.9_1 | d$IROZK-D 82pF | A?R`~*Q5 | C% -Tw]T$_ DISCRETE | Ak[X`e T C21 |
b{0a/&&1O CC0603_OV | c^}G=Z1@ CAP_NP_CC0603_OV_DISCRETE_0.9 M | RZ6y5 0.1uF | (p]FI# y | "i&)+dr- DISCRETE | TzL|{9 C22 |
R"ON5,E CC0603_OV | EN m%(G$ CAP_NP_CC0603_OV_DISCRETE_0.91M | 5lsslE+:J 47PF | zx@!8Z | 9f~qD&~ DISCRETE | WNR]GI C23 |
9xA4;)36 CC0603_OV | 0ix(1`Z CAP_NP_CC0603_OV_DISCRETE_0.9_2 | Jr!^9i2j' 220PF | L0w6K0J4 | BN*:*cmUl DISCRETE | V?XQjH1X C24 |
[?K>s>it CC0603_OV | w=KfkdAJ*/ CAP_NP_CC0603_OV_DISCRETE_0.91M | (%_X{R' 47PF | 8D.c."q | KL \>-
DISCRETE | sL@\,]Y C25 |
=.`\V] CC0603_OV | |>Q>d8|k CAP_NP_CC0603_OV_DISCRETE_0.9_1 | aM5]cc% 82pF | i1evB9FZ1z | @=kgK[t
9 DISCRETE | @a9.s C26 |
nJI2IPZ CC0603_OV | 're:_;lG CAP_NP_CC0603_OV_DISCRETE_0.9_1 | ('x]@ 82pF | $RDlM | !Yof%%m$; DISCRETE | /8;m.J>bf C27 |
h$5[04.Q CASE_G_AL |
wra0bS)4 CAP_POL_CASE_G_AL_DISCRETE_10.8 | }
=OE.cf@ 330UF | tW/k | *JK0X DISCRETE | |_?e.}K C28 |
sVx}(J CC0603_OV | 88HqP!m%P: CAP_NP_CC0603_OV_DISCRETE_0.9 M | 97liSd 0.1uF | L[<#>/NPy | :
UeK0 DISCRETE | SKC;@? C29 |
pU_3Z3CeE CC0805_OV | :#:|:q.] CAP_NP_CC0805_OV_DISCRETE_1.45M | 9a*#r;R 2.2uF | L{1sYR%s\ | FKO2UY#&7 DISCRETE | v,i|:;G C30 |
/8Tth86 CC0603_OV | M5{#!d}^D CAP_NP_CC0603_OV_DISCRETE_0.9 M | "Not /8J 0.1uF | }AS?q?4? | #@FA=p[% DISCRETE | SIp)& C31 |
<Yki8 CC0603_OV | R;DU68R CAP_NP_CC0603_OV_DISCRETE_0.9 M | Ki><~!L 0.1uF | lpG%rN! | v+LJx DISCRETE | ;VE y{%nF C32 |
rZ?:$],U! CC0603_OV | JP8}+ CAP_NP_CC0603_OV_DISCRETE_0.9 M | -rO34l 0.1uF | d-b04Q7DQ | Y,s EM% DISCRETE | JmCMFqB9 C33 |
3en9TB CC1206_OV | oPi>]#X CAP_NP_CC1206_OV_DISCRETE_1.8MM | [v~,|N>w 4.7uF | nJe}U# | ,;,B7g DISCRETE | SES.&e|!6 C34 |
xFF!)k # CC1206_OV | )R7Sh51P CAP_NP_CC1206_OV_DISCRETE_1.8MM | BAQ-1kSz 4.7uF | %jHm9{|X | X%b1KG|#( DISCRETE | }xsO^K C35 |
JY CC1206_OV | DMUirA; CAP_NP_CC1206_OV_DISCRETE_1.8MM | ^Wld6:L{I 4.7uF | '?C6P5fm | <IR#W$[ DISCRETE | h]<S0/ C36 |
F
CYGXtc CC0603_OV | kGD_w CAP_NP_CC0603_OV_DISCRETE_0.9 M | "'CvB0> 0.1uF | E`TZ:W]r, | p{Q6g>?[ DISCRETE | !@& 3q| C37 |
LSta]81B4L CC0805_OV | %O`@}Tg CAP_NP_CC0805_OV_DISCRETE_1.45M | g`pq*D 2.2uF | gBqDx|G | h:fiUCw DISCRETE | egu{}5 C38 |
D_lRYLA+ CC0603_OV | :UdW4N- CAP_NP_CC0603_OV_DISCRETE_0.9 M | ?TA7i b_ 0.1uF | ]q"&V\b | &ZD@-"@ DISCRETE | 7wj2-BWa C39 |
lgews" CC0805_OV | ZO/e!yju CAP_NP_CC0805_OV_DISCRETE_1.45M | v*.R<-X: 2.2uF | ob>)F^.iS | 7$<pdayd DISCRETE | OQumAj C40 |
9\ "\7S/Z CC0603_OV | )|*Qs${tF CAP_NP_CC0603_OV_DISCRETE_0.9 M | CA#g(SiZ 0.1uF | {($bzT7c | ZuGSR GX' DISCRETE | qe.QF."y C41 |
PMP{|yEx" CC0805_OV | ;^/ruf[t CAP_NP_CC0805_OV_DISCRETE_1.45M | *}vvS^ c0 2.2uF | 4<[?qd3v= | 1]If<
< DISCRETE | 7RT{RE C42 |
c=u+X`
Q CC0603_OV | lfAy$qP"} CAP_NP_CC0603_OV_DISCRETE_0.9_3 | <.)=CK 1uF | Yh95W | Ubu&$4a DISCRETE | s:_hsmc" C43 |
W|2^yO,dX CC0603_OV | *fm?"0M5 CAP_NP_CC0603_OV_DISCRETE_0.9 M | w"0$cL3 0.1uF | XKGiw 2
C | =OK#5r[UV DISCRETE | F/2cQ.u2 C44 |
P8c_GEna CC0603_OV | ~k34#j:J65 CAP_NP_CC0603_OV_DISCRETE_0.9 M | q.J6'v lj/ 0.1uF | h.tj8O1 | _-f LD DISCRETE | IX+Jf? &^ C45 |
)?[2Y%P CC0805_OV | OD'~t,St CAP_NP_CC0805_OV_DISCRETE_1.45M | n@`3O'S 2.2uF | #)S }z+I | #<Y.+: DISCRETE | B<s+I# C46 |
lB27Z} CC0603_OV | gp9O%g3' CAP_NP_CC0603_OV_DISCRETE_0.9 M | DAq
H 0.1uF | #w L(<nE | 6teu_FS DISCRETE | b#I,Z+0ry C48 |
&3/`cl[+ CC0603_OV | 9-n]_AF`0 CAP_NP_CC0603_OV_DISCRETE_0.9_3 | Mzg3i* 1uF | 9]3l' | ?e-rwaW DISCRETE | ANPG3^w C49 |
)%jS9e{d SOD123LF | f #h0O3 DIODE_SCHTKY_SOD123LF_IC_1.2MM_ | HV!P]82Pa PMEG3020EH | `x=kb; | TJNE2 IC | ;s3@(OnjZ D1 |
u&p8S#e HSMX-C170 | PE7V1U#$o, LED_HSMX-C170_IC_0.9 MM_370-300 | TJP;!uX HSMG-C170 | 5 n 4/}s | +PYR IC | 4`~OxL D2 |
"Io-%Su+ SOD123LF | C|}yE;*a DIODE_SCHTKY_SOD123LF_IC_1.2MM_ | ip'v<%,Q3" PMEG3020EH | 8;=?F>]xn | crd|r." IC | =SJ[)| D3 |
@uC-dXA" SOD323 | F4(;O7j9 DIODE_SOD323_IC_1.1MM_480-78885 | .~'q
yD2V BAS316 | _6FDuCVD- | Nt+UL/1] IC | W(ZEqH2 D4 |
:%Z)u:~': SOD323 | Wm8BhO DIODE_SOD323_IC_1.1MM_480-78885 | 'PMzm/;8st BAS316 | >VjtKSN | lItr*,A] IC | |RpZr!3V D5 |
^R\5'9K! SOD123LF | unL1/JY z DIODE_SCHTKY_SOD123LF_IC_1.2M_1 | JmF`5 PMEG2005EH | avS9 "e | -NG9?sI\U IC | -eSI"To L< D6 |
yyR@kOGga SOD-128 | YVHDk7s DIODE_SCHTKY_SOD-128_IC_1.1 MM_ | +&AU&2As PMEG4050EP | r~;.8qs | Vfw +m1sS IC | fZd~},X D7 |
:Z
]E:f0P SOD-128 | [0+5 Gx DIODE_SCHTKY_SOD-128_IC_1.1 MM_ | Z?",+|4 PMEG4050EP | "2"*3R<Y | BcGQpv&x IC | `0ju=FP'u5 D8 |
=7P; /EV SOD123LF | Qe/=(P< DIODE_SCHTKY_SOD123LF_IC_1.2M_1 | U|h@Pw z PMEG2005EH | _Q;M$.[zyR | \b88=^ IC | \t&6$"n(B6 D9 |
6ud<B SOD123LF | gk6j5 $Y"< DIODE_SCHTKY_SOD123LF_IC_1.2M_1 | =TI|uD6T PMEG2005EH | dR/UXzrc | **YNR:#Y IC | w1A&p D10 |
T{K+1SPy4 CON2X8_2P54_TH | ;v+CQx CONN_HDR_8X2_CON2X8_2P54_TH_IO_ | >-y&k^a= CON_2X8 |
?Ve5}N | &<i>)Ss IO | 8CSvg{B J1 |
f<'&_*7,|t CON20_2P54_TH | zsRN\U CONN_HDR_10X2_CON20_2P54_TH_IO_ | j'0*|f ^z CON_2X10 |
vrW9<{ | tT#Q`cB IO | ow`c B J2 |
s9:2aLZ{ CON2X8_2P54_TH | z06pX$Q.< CONN_HDR_8X2_CON2X8_2P54_TH_IO_ | 2Nl("e^kJr CON_2X8 | \&qVr1| | TuCOoz@d IO | IA!ixabG J3 |
$kz5)vj " CON2X8_2P54_TH | /s*>V@Q CONN_HDR_8X2_CON2X8_2P54_TH_IO_ | /~tfP CON_2X8 | x}>tX | '}YXpB IO | >a-+7{}; J4 |
ez5`B$$ CON20_2P54_TH | 80]TKf> CONN_HDR_10X2_CON20_2P54_TH_IO_ | yRi/YR# CON_2X10 | >`\*{] | =nL*/ IO | -MEz`7c~ J5 |
+@qk=]3a CON20_2P54_TH | fY"28# CONN_HDR_10X2_CON20_2P54_TH_IO_ | q(p0#Mk,E CON_2X10 | \+~4t | v!U# C[a^ IO | <d5vVn J6 |
PrKlwhi# CON3_PWR_JACK_TH_PJ051A | 8k`zMT DC_POWER_JACK_SHD_CON3_PWR_JACK | Y-c~"# PJ-051AH | 5)oIPHXw | qtH&]Suu, IO | 4F4u1r+ J7 |
:4Kk
4g1 HDR102 | rlIEch^wZ CONN_HDR_2X1_HDR102_IO_8.58MM_2 | 2!3&Ub#FO HDR 1X2 | G([vy#p | l9ihW^ IO | ">QY'r J8 |
*pD;AU HDR103 | >oNk(.
% CONN_HDR_3X1_HDR103_IO_8.38 MM_ | ck~xj0 HDR_1X3 | %UJ4wm | _z 5CplO IO | yrs3`/ J9 |
G0Eq}MyF HDR103 | V6{xX0'b*m CONN_HDR_3X1_HDR103_IO_8.38 MM_ | k0IU~y% HDR_1X3 | JAz;_wS(k | Wu&Di8GhP IO | Zn0fgQd J10 |
*a%PA(%6 HDR103 | r*wKYb CONN_HDR_3X1_HDR103_IO_8.38 MM_ | U}0/V
c26 HDR_1X3 | Wd5t,8*8 | EG.C2]Fi IO | 6 {Z\cwP)c J11 |
n_Y]iAoc` CON2_TB_5MM_TH | j[`?`RyU TB2_CON2_TB_5MM_TH_IO_10.2MM_21 | [alXD_ CON_2_TB | +3>4 ?,^g | swFOh5z IO | \^4$}@*] J12 |
ix+x-G CON4_TB_5MM | (d#Z-w- 282836-4_CON4_TB_5MM_IO_10MM_21 | ;alFK*K6 CON_4_TB | >2
qP | [;AcV73 IO | UYOn
p7R< J13 |
_[o^23Hj HDR106_100_TH | |u;PU`^-z CONN_HDR_6X1_HDR106_100_TH_IO_1 | q)b?X
^ HEADER 1X6 | 3= zQ
U | Zwns|23n IO | yo,!u\^x JP1 |
& }}WP:U LFPAK56_1P27_4P7X5P3 | *$C[![ NMOS_DUAL_8P_B_LFPAK56_1P27_4P7 | ji
-1yX BUK7K52-60E | PZJ
4:h | .boizW1+ IC | )"uG*}\?b Q2 |
xN8JrZE& LFPAK56_1P27_4P7X5P3 | !cwVJe NMOS_DUAL_8P_B_LFPAK56_1P27_4P7 | iBC>w+t14 BUK7K52-60E | "@w%TcA | b_Jq=Gk` IC | arKmc@"X Q3 |
y?#J`o-
O LFPAK56_1P27_4P7X5P3 | A i){,nh`0 NMOS_DUAL_8P_B_LFPAK56_1P27_4P7 | /t)c fFM BUK7K52-60E | b|o!&9Yyr | zN)\2 IC | lY*]&8/= Q4 |
;OU>AnWr(& SOT23_A | 'A!/pUML NMOSFET_PMV130ENEA_SOT23_A_IC_1 | 2\B9o `Y PMV130ENEA | 6n\z53Mk | M.N~fSJ IC | l)*,18n Q5 |
u7P+^A97L_ RC0603_OV | RLOQ>vYY RES_RC0603_OV_DISCRETE_0.55 MM_ | 0(/D| 33 | etMh=/NFV | \R\@t]>Y DISCRETE | 0&IXzEOr R1 |
Pph8"`mv.m RC0805_OV | xTFrrmxOf RES_RC0805_OV_DISCRETE_0.60 MM_ | ~uR6z//% 4.7 | A
a} o* | @@3,+7%1 DISCRETE | l()MYuLNV R3 |
L\wpS1L( RC0603_OV | h`h>H
X RES_RC0603_OV_DISCRETE_0.55MM_1 | 9_WPWFO 1K | s7nX\:Bw: | Z<|_+7T DISCRETE | R =9~*9 R4 |
+i@yZfT RC0603_OV | v;]I^Kq RES_RC0603_OV_DISCRETE_0.55MM_1 | 1m<?Q&|m$ 1K | 3R%UPT0> | Hn9F
gul& DISCRETE | Jhsv2,8
{ R5 |
zP(=,)d RC0603_OV | nOal7BNN RES_RC0603_OV_DISCRETE_0.55MM_1 | cP@F
#!2 1K | '*N9"C | mDF"&.(j DISCRETE | iQ|,&K0d] R6 |
me:|!lI7YU RC0603_OV | nJ*mEB RES_RC0603_OV_DISCRETE_0.55 MM_ | v=.z|QD^1 33 | @9uYmkcV | OVUs]uK DISCRETE | RHx+HBZ R7 |
0i*'N ch#i RC0603_OV | EN-H4F RES_RC0603_OV_DISCRETE_0.55 MM_ | o\]:!#r{T 33 | d]7|v
r] | \7t5U7v8U DISCRETE | i,'Ka[6
R9 |
wAu[pWD'6; RC0603_OV | \U!@OX.R'M RES_RC0603_OV_DISCRETE_0.55 M_1 | [EmOA.6 330 | ^5;vx | lP@) DISCRETE | 3_L1Wm R11 |
Cgz&@@j,] RC0603_OV | &gA6+b' RES_RC0603_OV_DISCRETE_0.55MM_4 | 'n^2|"$sH 1.2K | Z(Eke | =|E
09 DISCRETE | >lraYMc<rZ R12 |
oI_oz0nHk RC0603_OV | DIG0:)4R. RES_RC0603_OV_DISCRETE_0.55MM_1 | KbwTj*k[ 1K | jcEs10y | OB?S kR DISCRETE | 6.U"_% R13 |
ShWHHU(QQ RC0603_OV | (!ZQ RES_RC0603_OV_DISCRETE_0.55MM_1 | ?{
B[^ 1K | @PPR$4 | |;A9A's DISCRETE | Qj
6gg R14 |
cxXbo a RC0603_OV | <I7(eh6d RES_RC0603_OV_DISCRETE_0.55 M_2 | Yzj%{fkh 1.50K | IjG5X[@ | p-5Pas DISCRETE | `E3:;| R15 |
kqVg2#<@M RC0603_OV | ^oQekga\l RES_RC0603_OV_DISCRETE_0.55 M_3 | F8{ldzh 24K | 45x,|h[F{5 | j|VXC(6P, DISCRETE | ta&Q4v&- R16 |
l60ikc4$I RC0603_OV | e7@li<3>d RES_RC0603_OV_DISCRETE_0.55MM_2 | jrm0@K+<IA 120.0 | 5oz>1 | =
:Po%Z%{ DISCRETE | {UB%(E[Mr R17 |
wL'oImE RC0603_OV | =m`l%V[ RES_RC0603_OV_DISCRETE_0.55 M_2 | \s=QiPK 1.50K | `FUFK/7
w\ | f;.SSiT DISCRETE | QF\kPk(CtD R18 |
L)q`D2|' RC0603_OV | A)8rk_92Q RES_RC0603_OV_DISCRETE_0.55 M_3 | !L4dUMo 24K | 0/ut:RV0 | l<:`~\# DISCRETE | #hIEEkCp + R19 |
aSRjFL^ RC0603_OV | 7egq4gN]2Y RES_RC0603_OV_DISCRETE_0.55MM_1 | xb%/sz(4 1K | csYy7uzi | e\`wlaP, DISCRETE | t-_#Q bzE{ R20 |
Q}=fVY RC0603_OV | g{e/X~ RES_RC0603_OV_DISCRETE_0.6MM_47 | <BSSa`N` 10.0K | sTiYf | D>P;Izb DISCRETE | fTBVvY4( R21 |
k=e`*LB\ RC0603_OV | C?/r; RES_RC0603_OV_DISCRETE_0.55MM_2 |
/^Y[*5 120.0 | YNI;h%w | :i.t)ES DISCRETE | EOhC6>ATh R22 |
w^ 3|(F RC0603_OV | sJOV2#r RES_RC0603_OV_DISCRETE_0.55 M_2 | mB~~_]M
N 1.50K | )Bo]=ZTJ^ | R }1W DISCRETE | t ^m~ R23 |
$%=G[/i' RC0603_OV | (Ux[[ RES_RC0603_OV_DISCRETE_0.55 M_3 | ZNi
+Aw$u 24K | B_hPcmB | J smB^ DISCRETE | =5?.'XMk R24 |
E:)Cp RC0603_OV | G{+2xN
a( RES_RC0603_OV_DISCRETE_0.55MM_1 | P].eAAXnP 1K | +Juh:1H | <6/= y1QC) DISCRETE | ~cIl$b R25 |
.%IslLZ RC0603_OV | >OK#n)U` RES_RC0603_OV_DISCRETE_0.6MM_47 | Kk=LXmL2 10.0K | ;g+]klR! | W&YU^&`Yr DISCRETE | &pL/
@2+ R26 |
nM8[ RC0603_OV | s9i|mVtm8 RES_RC0603_OV_DISCRETE_0.55MM_2 | RJhK$\ 120.0 | <UT>PCNG | q(H ip<6p DISCRETE | !p',Za R27 |
p?JQ[K7i RC0603_OV | dw9T f ^V RES_RC0603_OV_DISCRETE_0.55 M_2 | L=]p_2+ 1.50K | R&*@@F-dx | O%&cE*eX DISCRETE | n'M>xq_ R28 |
JhP\u3 QE RC0603_OV | ezUQ>
e RES_RC0603_OV_DISCRETE_0.55 M_3 | 8vSIf+ 24K |
bq NP#C | ,F9nDF@) DISCRETE | D"^'.DL@wG R29 |
Xb,T{.3@ RC0603_OV | to`mnp9Z RES_RC0603_OV_DISCRETE_0.55 M_3 | +rc SL8C 24K | +D`*\d1 |
X{\jK]O DISCRETE | Skxd<gv R30 |
Qnt5HSSt RC0603_OV | :h*a
rT4{ RES_RC0603_OV_DISCRETE_0.55 M_2 | t,HFz6 1.50K | Ee)xnY%( | d:rGyA] DISCRETE | p!DP`Ouc3\ R31 |
"r$/
RC0603_OV | 5FOqv=6S RES_RC0603_OV_DISCRETE_0.55 M_3 | t,<UohL|z 24K | {v,)G)obWw | "@yyXS
r DISCRETE | +~35G:&: R32 |
D(\$i.,b2 RC0603_OV | `q_<Im%I RES_RC0603_OV_DISCRETE_0.55 M_3 | #|f~s 24K | =J/ FJb | r4Q|5kT*i DISCRETE | L'E^c,-x~ R33 |
Ll}yJ#3, RC0603_OV | tJU-<{8 RES_RC0603_OV_DISCRETE_0.55MM_2 | ^ R~~L 120.0 | Z
a(|(M H | <]U1\~j DISCRETE | _A'{la~k R34 |
#ekM"p RC0603_OV | 6N" l{! RES_RC0603_OV_DISCRETE_0.55 M_2 | eR;!(Oy=A 1.50K | *y]+dK&- | ~ap2m DISCRETE | "pvH0"Q* R35 |
[Qj;/ RC0603_OV | 5o0Ch RES_RC0603_OV_DISCRETE_0.55 M_3 | Mvcfk$pA 24K | D/ Dt | s([dGD$i DISCRETE | wT_h!W R36 |
\#Up|u: RC0603_OV | =.Tv)/ea RES_RC0603_OV_DISCRETE_0.55 M_3 | /,tAoa~FA 24K | 1cC1*c0Z | 46No%cSiG DISCRETE | vhgLcrn R37 |
:dnJY%/q RC0603_OV | 8@\7&C(g17 RES_RC0603_OV_DISCRETE_0.55 M_3 | [hh/1[ 24K | EgM*d)X | `dW]4>`O DISCRETE | |i7a@'0) R38 |
eJ@~o{,?> RC0603_OV | A :e;k{J RES_RC0603_OV_DISCRETE_0.55 M_3 | 8P: spD0 24K | Z-X?JA\& | iK;opA" DISCRETE | I'!/[\_ R39 |
diT=x52 RC0603_OV | V5mTu)tp5 RES_RC0603_OV_DISCRETE_0.55 M_3 | ^ c%N/V
\ 24K | '%;\YD9 | G|
m4m. DISCRETE | 5M_Wj*a}7 R40 |
m$2<`C= RC0603_OV | dcfe_EuT RES_RC0603_OV_DISCRETE_0.55MM_2 | E6MA?Ax&= 120.0 | N{Qxq>6 G | wdas1 DISCRETE | S4o$t-9l R41 |
1KE:[YQ1 RC0603_OV | g P}+wbk RES_RC0603_OV_DISCRETE_0.6MM__1 | aX6}6zubr 3.0K | 7jG(<!, | CNrIIsJ DISCRETE | sM2MLh 'D R42 |
_}6q{}jn:c RC0603_OV | dp5cDF}l RES_RC0603_OV_DISCRETE_0.6MM__1 | [.,>wo~ 3.0K | j}J Z
| l.=p8-/$'7 DISCRETE | ^QXbJJ R43 |
au@a8MP RC0603_OV | r6.d s^ RES_RC0603_OV_DISCRETE_0.6MM__1 | {]N3f[w 3.0K | PAF8Wlg | N"7]R[* DISCRETE | Dl\` R44 |
!nf-}ze{ RC0603_OV | *f+: <=i RES_RC0603_OV_DISCRETE_0.6MM__1 | M[]A2'fS 3.0K | Sv[ 5NZn0& | ]+Ixi o DISCRETE | KLWDo%%u R45 |
Sm{>rR RC0603_OV | ef"?|sn RES_RC0603_OV_DISCRETE_0.6MM__1 | Gu0 ,)jy\ 3.0K | bZwnaM4"F | ps|)cW3` DISCRETE | VR?^HA9 R46 |
y'C-[nk RC0603_OV | $&I'o RES_RC0603_OV_DISCRETE_0.55MM_3 | }Fb!?['G5 100 | <yUstz,Xu^ | JCniN";r[ DISCRETE | k ]a*&me R47 |
kAYb!h[` RC0603_OV | ib6^x:HGU RES_RC0603_OV_DISCRETE_0.55MM_3 | ?\=/$Gt 100 | 15\Ph[6g | cI0 ]}S DISCRETE | j Ch=@<9 R48 |
:;]Oc RC0603_OV | +>f<EPGn RES_RC0603_OV_DISCRETE_0.55MM_3 | ~%k ?L4% 100 | VyLH"cCv | J;Rv ~<7 DISCRETE | I27,mS+] R49 |
,L>
ar)B RC0805_OV | PXKJ^fa RES_RC0805_OV_DISCRETE_0.60 MM_ | YPDf
Y<?v 4.7 | dI'SwnR | F'RUel_% DISCRETE | D=f7NVc >Q R50 |
o89(
h! RC0805_OV | _u0$,Y?& |
