查看: 2691|回复: 1
[Allegro16.6以下] FRDMPKPT2000EVM 带S32K144 MCU的346缸PT2000评估套件C版原理图PCB
终身成就奖原创先锋奖特殊贡献奖优秀斑竹奖金点子奖
发表于 2018-12-8 17:24:13 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
SYM_NAME
COMP_DEVICE_TYPE
COMP_VALUE
COMP_TOL
COMP_CLASS
REFDES
CC0603_OV
CAP_NP_CC0603_OV_DISCRETE_0.9 M
0.1uF
DISCRETE
C1
CC1206_OV
CAP_NP_CC1206_OV_DISCRETE_1.27M
1.0UF
10%
DISCRETE
C14
CC0805_OV
CAP_NP_CC0805_OV_DISCRETE_0.94M
330PF
DISCRETE
C24
TEST_LOOP
TESTLOOP_TEST_LOOP_IO_4.8 MM_21
TEST POINT WHITE
IO
CSB
CAP_13MM_RAD
CAP_POL_CAP_13MM_RAD_DISCRETE_2
620uF
DISCRETE
C_BATT1
CC1206_OV
CAP_NP_CC1206_OV_DISCRETE_1.8MM
0.1UF
DISCRETE
C_BATT2
CAP_13MM_RAD
620uF
DISCRETE
C_BATT3
CC1206_OV
0.1UF
DISCRETE
C_BATT4
CC0603_OV
0.1uF
DISCRETE
C_BATT5
CC0805_OV
CAP_NP_CC0805_OV_DISCRETE_1.35M
0.01UF
DISCRETE
C_BATT7
CC0805_OV
CAP_NP_CC0805_OV_DISCRETE_1.45M
2.2UF
DISCRETE
C_BATT_HS1
CC0805_OV
2.2UF
DISCRETE
C_BATT_HS3
CC0805_OV
2.2UF
DISCRETE
C_BATT_HS5
CC0805_OV
2.2UF
DISCRETE
C_BATT_HS7
CC0603_OV
CAP_NP_CC0603_OV_DISCRETE_0.9MM
0.33UF
DISCRETE
C_BHS1
CC0603_OV
0.33UF
DISCRETE
C_BHS2
CC0603_OV
0.33UF
DISCRETE
C_BHS3
CC0603_OV
0.33UF
DISCRETE
C_BHS4
CC0603_OV
0.33UF
DISCRETE
C_BHS5
CC0603_OV
0.33UF
DISCRETE
C_BHS6
CC0603_OV
0.33UF
DISCRETE
C_BHS7
CC0805_OV
CAP_NP_CC0805_OV_DISCRETE_1.3_1
0.022UF
DISCRETE
C_BOOST4
CC0805_OV
CAP_NP_CC0805_OV_DISCRETE_0.85M
0.22uF
DISCRETE
C_BOOST5
CAP_POL_7P5_18P5
CAP_POL_CAP_POL_7P5_18P5_DISCRE
1100uF
DISCRETE
C_BOOST6
CC0805_OV
CAP_NP_CC0805_OV_DISCRETE_1.4MM
2200PF
DISCRETE
C_GLS1
CC0805_OV
2200PF
DISCRETE
C_GLS2
CC0805_OV
2200PF
DISCRETE
C_GLS3
CC0805_OV
2200PF
DISCRETE
C_GLS4
CC0805_OV
2200PF
DISCRETE
C_GLS5
CC0805_OV
2200PF
DISCRETE
C_GLS6
CC0805_OV
2200PF
DISCRETE
C_GLS7
CC0805_OV
CAP_NP_CC0805_OV_DISCRETE_0.88M
4700pF
DISCRETE
C_GLS8
CC0805_OV
CAP_NP_CC0805_OV_DISCRETE_0.9_1
1000pF
DISCRETE
C_GSHS1
CC0805_OV
2200PF
DISCRETE
C_GSHS2
CC0805_OV
1000pF
DISCRETE
C_GSHS3
CC0805_OV
2200PF
DISCRETE
C_GSHS4
CC0805_OV
1000pF
DISCRETE
C_GSHS5
CC0805_OV
2200PF
DISCRETE
C_GSHS6
CC0805_OV
1000pF
DISCRETE
C_GSHS7
CC0805_OV
4700pF
DISCRETE
C_INJN1
CC0805_OV
4700pF
DISCRETE
C_INJN2
CC0805_OV
4700pF
DISCRETE
C_INJN3
CC0805_OV
4700pF
DISCRETE
C_INJN4
CC0805_OV
4700pF
DISCRETE
C_INJN5
CC0805_OV
4700pF
DISCRETE
C_INJN6
CC0805_OV
4700pF
DISCRETE
C_INJN7
CC0805_OV
4700pF
DISCRETE
C_INJP1
CC0805_OV
4700pF
DISCRETE
C_INJP2
CC0805_OV
4700pF
DISCRETE
C_INJP3
CC0805_OV
4700pF
DISCRETE
C_INJP4
CC0805_OV
4700pF
DISCRETE
C_INJP5
CC0805_OV
4700pF
DISCRETE
C_INJP6
CC0805_OV
4700pF
DISCRETE
C_INJP7
CC0603_OV
CAP_NP_CC0603_OV_DISCRETE_0.9_1
1000pF
DISCRETE
C_OA1
CC0603_OV
1000pF
DISCRETE
C_OA2
CC0603_OV
1000pF
DISCRETE
C_OA3
CC0603_OV
0.1uF
DISCRETE
C_VCC5
CC0603_OV
CAP_NP_CC0603_OV_DISCRETE_0.9_2
1UF
DISCRETE
C_VCC2P5_1
CC0603_OV
0.1uF
DISCRETE
C_VCC2P5_2
CC0603_OV
0.1uF
DISCRETE
C_VCCIO
CC0805_OV
CAP_NP_CC0805_OV_DISCRETE_1.4_2
4.7uF
DISCRETE
C_VCCP2
CC0603_OV
CAP_NP_CC0603_OV_DISCRETE_0.86M
330pF
DISCRETE
C_VSENSE1
CC0603_OV
330pF
DISCRETE
C_VSENSE2
CC0603_OV
330pF
DISCRETE
C_VSENSE3
CC0603_OV
330pF
DISCRETE
C_VSENSE5
CC0603_OV
330pF
DISCRETE
C_VSENSE6
SOD123
ZDIODE_SOD123_IC_1.35MM_480-776
MMSZ5245B
IC
D17
SMB_4P57X3P94MM
DIODE_SCHTKY_SMB_4P57X3P94MM_IC
STPS2H100UY
IC
D18
DO-214AA_A
DIODE_TVS_DO-214AA_A_IC_2.62MM_
SMBJ40
IC
D36
DPAK
DIODE_DUAL_DPAK_DPAK_IC_2.38MM_
BYQ28ED-200
IC
D37
DPAK
BYQ28ED-200
IC
D38
DPAK
BYQ28ED-200
IC
D39
DPAK
BYQ28ED-200
IC
D40
SOD-128
DIODE_SCHTKY_SOD-128_IC_1.1MM_4
PMEG10030ELP
IC
D41
SOD-128
PMEG10030ELP
IC
D42
SOD-128
PMEG10030ELP
IC
D43
SOD-128
PMEG10030ELP
IC
D44
SOD-128
PMEG10030ELP
IC
D45
SOD-128
PMEG10030ELP
IC
D46
SOD-128
PMEG10030ELP
IC
D47
SOD-128
DIODE_TVS_SOD-128_IC_1.1MM_480-
PTVS13VP1UP
IC
D48
TEST_LOOP
TEST POINT WHITE
IO
DBG
TEST_LOOP
TEST POINT WHITE
IO
FLAG0
TEST_LOOP
TEST POINT WHITE
IO
FLAG1
TEST_LOOP
TEST POINT WHITE
IO
FLAG2
TEST_LOOP
TEST POINT WHITE
IO
FLAG3
CON2_TB_5MM
TB2_CON2_TB_5MM_IO_10MM_210-776
CON_2_TB
IO
FP1
TEST_LOOP
TESTLOOP_TEST_LOOP_IO_4.8 MM__1
TEST POINT ORANGE
IO
G_HS1
TEST_LOOP
TEST POINT ORANGE
IO
G_HS2
TEST_LOOP
TEST POINT ORANGE
IO
G_HS7
TEST_LOOP
TEST POINT ORANGE
IO
G_LS1
TEST_LOOP
TEST POINT ORANGE
IO
G_LS2
TEST_LOOP
TEST POINT ORANGE
IO
G_LS7
TEST_LOOP
TEST POINT ORANGE
IO
G_LS8
CON2_TB_5MM
CON_2_TB
IO
INJ1
CON2_TB_5MM
CON_2_TB
IO
INJ2
CON2_TB_5MM
CON_2_TB
IO
INJ3
CON2_TB_5MM
CON_2_TB
IO
INJ4
CON2_TB_5MM
CON_2_TB
IO
INJ5
CON2_TB_5MM
CON_2_TB
IO
INJ6
TEST_LOOP
TEST POINT WHITE
IO
IRQB
JUMP1X8-6040
HDR-1X8_JUMP1X8-6040_IO_8.71MM_
TSW-108-07-T-S
IO
J1
HDR110
CONN_HDR_10X1_HDR110_IO_8.71MM_
TSW-110-07-T-S
IO
J2
JUMP1X8-6040
TSW-108-07-T-S
IO
J3
HDR110
TSW-110-07-T-S
IO
J6
JUMP1X8-6040
TSW-108-07-T-S
IO
J7
HDR102
CONN_HDR_2X1_HDR102_IO_8.71 MM_
HDR 1X2 TH
IO
JCLK
CON_TB_2F_197_TH
CONN_HDR_2X1_CON_TB_2F_197_TH_I
TB 1X2
IO
JVBAT
HDR102
HDR 1X2 TH
IO
JVCC5
HDR102
HDR 1X2 TH
IO
JVCCIO
IND_14X12P8
IND_IND_14X12P8_DISCRETE_5MM_18
10uH
20%
DISCRETE
L2
IND2_18MM_TH
INDUCTOR_IND2_18MM_TH_DISCRETE_
6uH
DISCRETE
L_BATTERY
TEST_LOOP
TEST POINT WHITE
IO
MISO
TEST_LOOP
TEST POINT WHITE
IO
MOSI
TEST_LOOP
TESTLOOP_TEST_LOOP_IO_4.8 MM__2
TEST POINT YELLOW
IO
OA1
TEST_LOOP
TEST POINT YELLOW
IO
OA2
TEST_LOOP
TEST POINT YELLOW
IO
OA3
TO252AA
P_MOS_TO252AA_IC_2.388MM_480-78
AOD4185
IC
Q0
LFPAK5_1P27_5X4
NMOS_5P_LFPAK5_1P27_5X4_IC_1.2M
BUK9Y38-100E
IC
Q8
LFPAK5_1P27_5X4
BUK9Y38-100E
IC
Q10
LFPAK5_1P27_5X4
BUK9Y38-100E
IC
Q11
LFPAK56_1P27_4P7X5P3
NMOS_DUAL_8P_LFPAK56_1P27_4P7X5
BUK9K29-100E
IC
Q12
LFPAK5_1P27_5X4
BUK9Y38-100E
IC
Q20
LFPAK5_1P27_5X4
BUK9Y38-100E
IC
Q21
BUK9K29-100E
IC
Q22
LFPAK5_1P27_5X4
BUK9Y38-100E
IC
Q30
LFPAK5_1P27_5X4
BUK9Y38-100E
IC
Q31
BUK9K29-100E
IC
Q32
LFPAK33_0P65_3P4X2P7
NMOS_5P_LFPAK33_0P65_3P4X2P7_IC
BUK9M24-60E
IC
Q40
BUK9M24-60E
IC
Q41
RC0603_OV
RES_RC0603_OV_DISCRETE_0.55 MM_
5.1
DISCRETE
R10
POT3_3224W
POT_POT3_3224W_DISCRETE_5.3MM_4
1K
10%
DISCRETE
R25
RC0805_OV
RES_RC0805_OV_DISCRETE_0.7 MM_4
240
1%
DISCRETE
R26
RC0805_OV
RES_RC0805_OV_DISCRETE_0.70 MM_
1.5K
5%
DISCRETE
R27
RC0603_OV
RES_RC0603_OV_DISCRETE_0.6MM_47
100K
DISCRETE
R37
RC0805_OV
RES_RC0805_OV_DISCRETE_470-8054
DISCRETE
RREG
RC0603_OV
RES_RC0603_OV_DISCRETE_0.6MM__1
DISCRETE
RRSTB
TEST_LOOP
TEST POINT WHITE
IO
RSTB
RC0805_OV
RES_RC0805_OV_DISCRETE_0.70 M_1
DISCRETE
R_GHSB1
RC0805_OV
DISCRETE
R_GHSB2
RC0805_OV
DISCRETE
R_GHSB3
RC0805_OV
DISCRETE
R_GHSB4
RC0805_OV
DISCRETE
R_GHSB5
RC0805_OV
DISCRETE
R_GHSB6
RC0805_OV
DISCRETE
R_GHSB7
RC0805_OV
DISCRETE
R_GLS7
RC0805_OV
RES_RC0805_OV_DISCRETE_470-7603
2.2
DISCRETE
R_GLS8A
RC0805_OV
DISCRETE
R_GLSB1
RC0805_OV
DISCRETE
R_GLSB2
RC0805_OV
DISCRETE
R_GLSB3
RC0805_OV
DISCRETE
R_GLSB4
RC0805_OV
DISCRETE
R_GLSB5
RC0805_OV
DISCRETE
R_GLSB6
RC0603_OV
RES_RC0603_OV_DISCRETE_0.6MM__2
DISCRETE
R_OA1
RC0603_OV
DISCRETE
R_OA2
RC0603_OV
DISCRETE
R_OA3
RL3264
RES_RL3264_DISCRETE_0.62MM_470-
0.015
DISCRETE
R_VSENSE1
RL3264
0.015
DISCRETE
R_VSENSE2
RL3264
0.015
DISCRETE
R_VSENSE3
RL3264
0.015
DISCRETE
R_VSENSE5
RC2512
RES_RC2512_DISCRETE_1.016 MM_47
0.01
DISCRETE
R_VSENSE6
TEST_LOOP
TEST POINT WHITE
IO
SCLK
SH0603
RES_SHORT-2_SH0603_DISCRETE_0.1
DISCRETE
SH1
SH0603
DISCRETE
SH2
SH0603
DISCRETE
SH3
SH0603
DISCRETE
SH6
SH0603
DISCRETE
SH11
SH0603
DISCRETE
SH12
SH0603
DISCRETE
SH13
SH0603
DISCRETE
SH14
SH0603
DISCRETE
SH15
SH0603
DISCRETE
SH16
TEST_LOOP
TEST POINT WHITE
IO
START1
TEST_LOOP
TEST POINT WHITE
IO
START2
TEST_LOOP
TEST POINT WHITE
IO
START3
TEST_LOOP
TEST POINT WHITE
IO
START4
TEST_LOOP
TEST POINT WHITE
IO
START5
TEST_LOOP
TEST POINT WHITE
IO
START6
TEST_LOOP
TEST POINT WHITE
IO
START7
TP_TH_063
TEST_POINT_TP_TH_063_IC_5.6MM_2
5006
IC
TP32
TP_TH_063
5006
IC
TP33
TP_TH_063
5006
IC
TP34
TP_TH_063
5006
IC
TP35
TP_TH_063
5006
IC
TP36
LQFP80_0P5_12X12_EP250
PC900715AE_LQFP_80P_LQFP80_0P5_
MC33PT2000
IC
U1
D2PAK_D2T
LM317D2T_D2PAK_D2T_IC_4.57MM_31
LM317D2T
IC
U8
TEST_LOOP
TESTLOOP_TEST_LOOP_IO_4.8 MM__3
TEST POINT RED
IO
VBAT
TEST_LOOP
TEST POINT RED
IO
VBOOST
TEST_LOOP
TEST POINT RED
IO
VCC5
TEST_LOOP
TEST POINT RED
IO
VCCIO
TEST_LOOP
TEST POINT RED
IO
VCCP
TEST_LOOP
TEST POINT ORANGE
IO
VSENSEN1
TEST_LOOP
TEST POINT ORANGE
IO
VSENSEP1
重要提示:PCB作品文件展下载说明
 楼主| 发表于 2018-12-8 17:25:03 | 显示全部楼层
SCH-29064_C.rar (84 KB, 下载次数: 2) LAY-29064_C.rar (1.57 MB, 下载次数: 2)
