查看: 4359|回复: 4
[Allegro16.6以下] LS1088A-RDB QorIQ® LS1088A-RDB参考设计LS1088ARDB-RevC版原理图PCB
终身成就奖原创先锋奖特殊贡献奖优秀斑竹奖金点子奖
发表于 2018-12-8 18:56:37 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
BOM表太大了,网页容量不够,只贴上U姓件。完整器件表和PCB原理图一起附件上传。
SW_DIP16_8POS_SM
SW_DIP_8_SW_DIP16_8POS_SM_2.65M
218-8LPST
IC
SW1
SW_DIP16_8POS_SM
218-8LPST
IC
SW2
SW_DIP16_8POS_SM
218-8LPST
IC
SW3
SW_DIP16_8POS_SM
218-8LPST
IC
SW4
SW_DIP16_8POS_SM
218-8LPST
IC
SW5
SW_ELTSA-66_TH
SW_PB_SPST_4P_SW_ELTSA-66_TH_IC
ELTSA-66N-H
IC
SW18
SW6_TACT_LED_TH
SPL6BL_SW6_TACT_SW6_TACT_LED_TH
SPL6BLH
IC
SW19
H5008
H5008_ALT_H5008_IC_5.72MM_312-7
H5008
IC
T4
H5008
H5008
IC
T5
H5008
H5008
IC
T6
H5008
H5008
IC
T7
H5008
H5008
IC
T8
H5008
H5008
IC
T9
H5008
H5008
IC
T10
H5008
H5008
IC
T11
TP_PTH
T POINT TH_TP_PTH_IC_0.1 MM_210
TP_PTH
IC
TP9
TP_PTH
TP_PTH
IC
TP10
TP_PTH
TP_PTH
IC
TP11
TP_PTH
TP_PTH
IC
TP16
TP_PTH
TP_PTH
IC
TP30
TP_PTH
TP_PTH
IC
TP31
TP_PTH
TP_PTH
IC
TP32
TESTPOINT_35MIL
TEST PAD_TESTPOINT_35MIL_IC_0.1
35 MIL
IC
TP58
TP_PTH
TP_PTH
IC
TP82
TPAD_020
TESTLOOP_TPAD_020_IO_0.1MM_211-
TPAD_020
IO
TP166
TESTPOINT_100_050MIL
TESTLOOP_TESTPOINT_100_050MIL_I
WHITE
IO
TP175
TPAD_030
TESTLOOP_TPAD_030_IO_0.1MM_211-
TPAD_030
IO
TP176
WHITE
IO
TP177
WHITE
IO
TP178
TP_TH_063
TEST_POINT_TP_TH_063_IC_5.6MM_2
5006
IC
TP185
TP_PTH
TP_PTH
IC
TP190
TP_PTH
TP_PTH
IC
TP191
TP_PTH
TP_PTH
IC
TP192
TP_PTH
TP_PTH
IC
TP193
TP_PTH
TP_PTH
IC
TP194
TP_PTH
TP_PTH
IC
TP195
TP_PTH
TP_PTH
IC
TP196
TP_PTH
TP_PTH
IC
TP197
TESTPOINT_35MIL
35 MIL
IC
TP198
TP_PTH
TP_PTH
IC
TP199
TP_PTH
TP_PTH
IC
TP200
TP_PTH
TP_PTH
IC
TP201
TP_PTH
TP_PTH
IC
TP206
TP_PTH
TP_PTH
IC
TP207
TP_PTH
TP_PTH
IC
TP208
TP_PTH
TP_PTH
IC
TP209
TP_PTH
TP_PTH
IC
TP210
TP_PTH
TP_PTH
IC
TP211
TP_PTH
TP_PTH
IC
TP215
TP_PTH
TP_PTH
IC
TP217
TP_PTH
TP_PTH
IC
TP218
TP_PTH
TP_PTH
IC
TP219
TP_PTH
TP_PTH
IC
TP220
TP_TH_063
5006
IC
TP221
TP_TH_063
5006
IC
TP222
TP_TH_063
5006
IC
TP223
TP_PTH
TP_PTH
IC
TP224
TP_PTH
TP_PTH
IC
TP225
TP_PTH
TP_PTH
IC
TP226
TP_PTH
TP_PTH
IC
TP227
TP_PTH
TP_PTH
IC
TP228
TP_PTH
TP_PTH
IC
TP229
TP_PTH
TP_PTH
IC
TP230
TP_PTH
TP_PTH
IC
TP231
TP_PTH
TP_PTH
IC
TP232
TP_PTH
TP_PTH
IC
TP233
SKT_BGA780_0P8_61X61
LS1088A_SS_LS1043A_SKT_BGA780_0
PLS1088ASE7Q1A + INTERPOSER + HEATSINK
IC
U1
SSOT6_1P7X3
FDC6330_SSOT_6P_SSOT6_1P7X3_IC_
FDC6330L
IC
U3
CON12_SHRD_2MM_TH
CON12_98414_PMBUS_CON12_SHRD_2M
CON_2X6 TH
IC
U4
PQFN31_0P5_5X5
FDMF5820DC_PQFN31_0P5_5X5_IC_0.
FDMF5820DC
IC
U5
QFN40_0P5_6P1X6P1
LTC3882_40P_EP_QFN40_0P5_6P1X6P
LTC3882
IC
U6
PQFN31_0P5_5X5
FDMF5820DC
IC
U7
SOT363_A
74LVC2G17_SOT363_A_IC_1.1MM_312
74LVC2G17
IC
U8
SOT363_A
74LVC2G17
IC
U9
MSOP10_0P5_3P1X3P1_EP
LTC3026_MSOP_10P_MSOP10_0P5_3P1
LTC3026EMSE
IC
U12
TDFN8_1P98_2P10X2P10
MAX8902B_TDFN8_1P98_2P10X2P10_I
MAX8902B
IC
U13
BGA68_1P27_9X15MM
LTM4649EY-BGA68_BGA68_1P27_9X15
LTM4649
IC
U17
SOT363_A
74AUP2G06GW_SOT363_A_IC_1.1MM_3
74AUP2G06GW
IC
U29
CON_DDR4_288_0P85_TH
DIMM_MODULE_CON_DDR4_288_0P85_T
78726-1004
IO
U30
BGA6_0P5_0P92X1P42_NSP
NX5P2924BUK_BGA6_0P5_0P92X1P42_
NX5P2924BUK
IC
U32
WLCSP6_0P5_0P98X1P48
FPF1321_6P_WLCSP6_0P5_0P98X1P48
FPF1321UCX
IC
U36
QFN64_0P5_9X9C
SI5341B_64P_EP_A_QFN64_0P5_9X9C
Si5341B-B04862-GM
IC
U44
QFN28_3X6_0P5
LT8612_28P_QFN_EP_QFN28_3X6_0P5
LT8612
IC
U45
AQFN138_0P65_12X12_EP
VSC8514_QFN_138P_A_AQFN138_0P65
VSC8514_QFN
IC
U51
TSSOP24_0P65_7P9X4P5
PCA9547_24P_TSSOP24_0P65_7P9X4P
PCA9547PW
IC
U87
UQFN10_0P4_1P45X1P85
NX3DV42GU_XQFN_10P_UQFN10_0P4_1
NX3DV42GU
IC
U91
NX3DV42GU
IC
U92
NX3DV42GU
IC
U94
NX3DV42GU
IC
U95
TSSOP8
AT24CXX_TSSOP8_IC_1.2MM_334-756
AT24C512C-XHD-B
IC
U97
TSSOP8
ATMEL_SERIAL_EEPROM_64K-1_TSSOP
AT24C02C-XHM-B
IC
U98
SO20_1P27_7P6X12P95
PCF2129AT_SO_20P_SO20_1P27_7P6X
PCF2129AT
IC
U99
NX3DV42GU
IC
U100
BGA324_1MM_19X19MM_C019S
AQR105_BGA324_BGA324_1MM_19X19M
AQR105-B1
IC
U101
SO8_1P27_4X5
MX25V4006E_8P_SO8_1P27_4X5_IC_1
MX25V4006E
IC
U102
NX3DV42GU
IC
U103
MSOP_10_0P5_3X3
INA220AIDGST_MSOP_10_0P5_3X3_IC
INA220AIDGST
IC
U104
SO8
ADT7461_SO8_IC_1.75MM_315-76826
ADT7461
IC
U106
XSON8_0P5_3P1X2P1
NTSX2102GD_XSON8_0P5_3P1X2P1_IC
NTSX2102GD
IC
U107
TSSOP8
AT24C02C-XHM-B
IC
U108
PCA9547PW
IC
U109
XSON8_0P5_3P1X2P1
NTSX2102GD
IC
U110
NX3DV42GU_XQFN_10P_A_UQFN10_0P4
NX3DV42GU
IC
U111
TSSOP8_A
NTB0102_8P_TSSOP8_A_IC_1.1MM_31
NTS0102
IC
U112
SSOP16_4P8X3P8MM
LTC2804_SSOP16_SSOP16_4P8X3P8MM
LTC2804-1
IC
U113
TSSOP8_A
NTS0102
IC
U115
SSOP16_4P8X3P8MM
LTC2804-1
IC
U120
NX3DV42GU
IC
U121
XSON7_0P5_2P2X1P2
PUSB3AB6_XSON7_0P5_2P2X1P2_IC_0
PUSB3AB6
IC
U131
WLCSP12_0P4_1P38X1P68MM_SMDP
NX5P3090UK_WLCSP12_WLCSP12_0P4_
NX5P3090UK
IC
U132
SOT143-25X60
PRTR5V0U2AX_SOT143-25X60_IC_1.1
PRTR5V0U2AX
IC
U133
XSON7_0P5_2P2X1P2
PUSB3AB6
IC
U134
NX5P3090UK
IC
U135
XSON7_0P5_2P2X1P2
PUSB3AB6
IC
U136
SOT143-25X60
PRTR5V0U2AX
IC
U137
QFN24_0P5_4P15SQ_EP2P6
DS125DF111_QFN24_0P5_4P15SQ_EP2
DS125DF111
IC
U144
XSON7_0P5_2P2X1P2
PUSB3AB6
IC
U145
NX3DV42GU
IC
U146
XSON7_0P5_2P2X1P2
PUSB3AB6
IC
U147
NX3DV42GU
IC
U148
NX3DV42GU
IC
U150
SOT-363_0P65_SMT
74AUP2G07GW_SOT-363_0P65_SMT_IC
74AUP2G07GW
IC
U164
SOT143-25X60
MAX811_SOT143-25X60_IC_1.22 MM_
MAX811
IC
U168
SC70-5
74AUP1T34GW_SC70-5_IC_1.1MM_312
74AUP1T34GW
IC
U169
SOT143-25X60
MAX811
IC
U170
SC70-5
74AUP1T34GW
IC
U172
SOIC16_1P27_7P5X10P3
S25FS512SAGMFI011_SOIC16_1P27_7
S25FS512SDSMFI011
IC
U182
TDFN10_0P5_3P1X3P1
NX3DV221TK_10P_B_TDFN10_0P5_3P1
NX3DV221TK
IC
U183
S25FS512SDSMFI011
IC
U185
VFBGA63_0P8_9X11
MT29F4G08ABBDAH4_VFBGA63_0P8_9X
MT29F4G08ABBDAH4
IC
U187
TDFN10_0P5_3P1X3P1
NX3DV221TK
IC
U188
TDFN10_0P5_3P1X3P1
NX3DV221TK
IC
U189
SC70-5
74AUP1T34GW
IC
U196
TSSOP8_A
NTS0102
IC
U201
VSC8514_QFN
IC
U205
BGA256_1MM_17X17
EPM2210F256C5N_256BGA_BGA256_1M
EPM2210F256C5N
IC
U207
SOT23-5_A
74AUP1G04GV_SOT23-5_A_IC_1.1MM_
74AUP1G04GV
IC
U209
SOT23-5_A
74AUP1G04GV
IC
U212
QFN24_4X4MM_SLUG
MC34712_QFN24_4X4MM_SLUG_IC_1MM
MC34712EP
IC
U213
QFN26_0P5_5X5_EP_3P75
MC34717_C_QFN26_0P5_5X5_EP_3P75
MC34717EP
IC
U214
MC34717EP
IC
U215
MC34717EP
IC
U216
MC34717EP
IC
U217
DQFN14_3X2P5MM
NTB0104BQ_DQFN14_3X2P5MM_IC_1MM
NTB0104BQ
IC
U218
QFN40_0P4_5P1X5P1
9FGV0641AK_40P_EP_A_QFN40_0P4_5
9FGV0641AKLF
IC
U220
MC34717EP
IC
U221
SC70-5
74AUP1T34GW
IC
U222
QFN10_0P5_3X3_A
NX3L4684TK_QFN10_0P5_3X3_A_IC_1
NX3L4684TK
IC
U224
TBGA100_1MM_14X18
MTFC32GJDDQ_LBGA_100P_TBGA100_1
MTFC4GACAANA-4M IT
IC
U225
SOT23-5
SN74CBTLV1G125_SOT23-5_IC_1.45M
SN74CBTLV1G125DBVR
IC
U226
QFN28_3X6_0P5
LT8612
IC
U227
SOT363_A
74LVC2G17
IC
U228
XSON8_0P5_3P1X2P1
NTSX2102GD
IC
U229
TSSOP8_A
NTS0102
IC
U230
SOT23-5
SN74CBTLV1G125DBVR
IC
U231
XTAL_4_3P3X2P6MM
XTAL_13Y_XTAL_4_3P3X2P6MM_IC_0.
7M48072002
IC
X1
XTAL_4P_6P2X3P9
CRYSTAL13_XTAL_4P_6P2X3P9_IC__1
50MHz
IC
Y7
XTAL_4P_6P2X3P9
CRYSTAL13_XTAL_4P_6P2X3P9_IC_1.
25 MHz
IC
Y10
OSC4_2P6X2P1_SM
SG8002_OSC4_2P6X2P1_SM_IC_0.9MM
25MHz
IC
Y11
重要提示:PCB作品文件展下载说明
 楼主| 发表于 2018-12-8 18:59:14 | 显示全部楼层
[sell=10,2] BOM.rar (65 KB, 下载次数: 2) SCH-28869.DSN.rar (756 KB, 下载次数: 2) 28869_C.brd.rar (13.1 MB, 下载次数: 2)
PADS-2020国庆特训班
发表于 2018-12-8 22:18:10 | 显示全部楼层
发表于 2021-10-20 23:12:55 | 显示全部楼层
发表于 2021-10-20 23:14:12 | 显示全部楼层
