SYM_NAME |
COMP_DEVICE_TYPE |
COMP_VALUE |
COMP_TOL |
COMP_CLASS |
REFDES |
0201_CC |
CAP_NP_0201_CC_DISCRETE_0.33MM_ |
20pF |
DISCRETE |
C330 |
0201_CC |
20pF |
DISCRETE |
C331 |
0201_CC |
CAP_NP_0201_CC_DISCRETE_0.33M_1 |
0.1UF |
DISCRETE |
C340 |
0402_CC |
CAP_NP_0402_CC_DISCRETE_0.55MM_ |
2.2uF |
DISCRETE |
C345 |
0201_CC |
0.1UF |
DISCRETE |
C347 |
0201_CC |
CAP_NP_0201_CC_DISCRETE_0.33M_2 |
18pF |
DISCRETE |
C350 |
0201_CC |
18pF |
DISCRETE |
C351 |
CC0201 |
CAP_NP_CC0201_DISCRETE_0.33MM_1 |
0.1uF |
DISCRETE |
C352 |
CC0402_25 |
CAP_NP_CC0402_25_DISCRETE_0.65M |
4.7UF |
DISCRETE |
C353 |
CC0201 |
CAP_NP_CC0201_DISCRETE_0.33MM_2 |
0.01uF |
DISCRETE |
C354 |
CC0201 |
0.01uF |
DISCRETE |
C355 |
CC0201 |
0.01uF |
DISCRETE |
C356 |
CC0201 |
0.1uF |
DISCRETE |
C357 |
CC0201 |
0.1uF |
DISCRETE |
C358 |
CC0201 |
0.1uF |
DISCRETE |
C359 |
CC0201 |
0.1uF |
DISCRETE |
C360 |
CC0201 |
0.01uF |
DISCRETE |
C361 |
0402_CC |
CAP_NP_0402_CC_DISCRETE_0.65MM_ |
4.7UF |
DISCRETE |
C362 |
CC0201 |
0.01uF |
DISCRETE |
C363 |
CC0201 |
0.1uF |
DISCRETE |
C364 |
0402_CC |
CAP_NP_0402_CC_DISCRETE_0.7MM_1 |
10uF |
DISCRETE |
C365 |
CC0402_25 |
4.7UF |
DISCRETE |
C366 |
CC0402_25 |
4.7UF |
DISCRETE |
C367 |
CC0201 |
0.1uF |
DISCRETE |
C369 |
CC0402_25 |
4.7UF |
DISCRETE |
C370 |
0201_CC |
0.1UF |
DISCRETE |
C371 |
0603_CC |
CAP_NP_0603_CC_DISCRETE_1.0MM_1 |
10UF |
DISCRETE |
C372 |
LED_0603 |
LED_LED_0603_IC_0.67 MM_370-766 |
LED_RED_NRND |
IC |
D1 |
SOD123W |
DIODE_SCHTKY_SOD123W_IC_1.1MM_4 |
PMEG3010ER |
IC |
D2 |
CON100_0P4_22P8X3P1_SM |
HDR_2X50_M_CON100_0P4_22P8X3P1_ |
DF40C-100DS-0.4V(51) |
IO |
J3 |
IO |
J4 |
HDR_2X5_6X3_1P27MM_TH |
CONN_HDR_5X2_HDR_2X5_6X3_1P27MM |
HDR 2X5 |
IO |
J7 |
CON_MICROUSBB_9F_0P65_SM_RA |
MICRO_USB_CONN_9PIN_CON_MICROUS |
1050170001 |
IO |
J8 |
IND_0402 |
INDUCTOR_IND_0402_DISCRETE_0.55 |
600OHM |
DISCRETE |
L37 |
IND_0402 |
600OHM |
DISCRETE |
L38 |
IND_0603 |
BEAD_IND_0603_DISCRETE_0.95MM_1 |
220Ohm |
DISCRETE |
L39 |
SOT23-40X40 |
MOSFET_P_SOT23-40X40_IC_1.1MM_4 |
ZXM61P03F |
IC |
Q1 |
0402_CC |
RES_0402_CC_DISCRETE_0.4 MM_470 |
12.1K |
DISCRETE |
R15 |
0201_CC |
RES_0201_CC_DISCRETE_0.26 MM__1 |
33 |
DISCRETE |
R28 |
RC0402_X2 |
RES_3PIN_RC0402_X2_DISCRETE_0.4 |
0 |
DISCRETE |
R29 |
0201_CC |
RES_0201_CC_DISCRETE_0.30 MM_47 |
0 |
DISCRETE |
R407 |
0201_CC |
0 |
DISCRETE |
R408 |
0201_CC |
RES_0201_CC_DISCRETE_0.26 MM_47 |
10K |
DISCRETE |
R414 |
0201_CC |
10K |
DISCRETE |
R423 |
0201_CC |
10K |
DISCRETE |
R425 |
0201_CC |
0 |
DISCRETE |
R427 |
0201_CC |
10K |
DISCRETE |
R430 |
0201_CC |
RES_0201_CC_DISCRETE_0.28 MM_47 |
100K |
DISCRETE |
R436 |
0201_CC |
RES_0201_CC_DISCRETE_0.26MM_470 |
2.2K |
DISCRETE |
R453 |
RC0402_X2 |
0 |
DISCRETE |
R455 |
0201_CC |
33 |
DISCRETE |
R456 |
0201_CC |
100K |
DISCRETE |
R459 |
0201_CC |
100K |
DISCRETE |
R460 |
0201_CC |
RES_0201_CC_DISCRETE_0.3 MM_470 |
470 ohms |
DISCRETE |
R464 |
0201_CC |
2.2K |
DISCRETE |
R465 |
0201_CC |
0 |
DISCRETE |
R466 |
SW2_TACT_4X3_SM |
SW2P_SW2_TACT_4X3_SM_IC_2 MM_51 |
KAN0444-0201E1 |
IC |
SW1 |
TPAD_030 |
TESTLOOP_TPAD_030_IO_0.1MM_211- |
TPAD_030 |
IO |
TP1 |
TPAD_030 |
TPAD_030 |
IO |
TP3 |
TPAD_030 |
TPAD_030 |
IO |
TP5 |
TPAD_030 |
TPAD_030 |
IO |
TP6 |
TPAD_030 |
TPAD_030 |
IO |
TP7 |
TPAD_030 |
TPAD_030 |
IO |
TP8 |
TPAD_030 |
TPAD_030 |
IO |
TP9 |
TPAD_030 |
TPAD_030 |
IO |
TP10 |
TPAD_030 |
TPAD_030 |
IO |
TP11 |
TPAD_030 |
TPAD_030 |
IO |
TP12 |
MODULE_34P_1P5_26X18 |
GT1216_MODULE_34P_MODULE_34P_1P |
GT1216 |
IC |
U1 |
SO8_W |
MX25R6435FM2IL0_SO8_W_IC_2.16MM |
MX25L12835FM2I-10G |
IC |
U20 |
BGA_180_0P8_12P1SQ |
LPC546XX_BGA_180P_BGA_180_0P8_1 |
LPC54018JET180 |
IC |
U22 |
DFN_8_0P5_3X3 |
ADM7172_8P_EP_DFN_8_0P5_3X3_IC_ |
ADM7172 |
IC |
U23 |
SOT143B |
PRTR5V0U2X_SOT143B_IC_1.1MM_315 |
PRTR5V0U2X |
IC |
U24 |
XTL4_2P5X2MM_SM |
XTAL_13_XTL4_2P5X2MM_SM_IC_0.55 |
12MHz |
IC |
Y2 |
XTAL_2_2X1P2_SM |
XTAL_XTAL_2_2X1P2_SM_IC_0.6 MM_ |
32.768 KHZ |
IC |
Y4 |
