SYM_NAME |
COMP_DEVICE_TYPE |
COMP_VALUE |
COMP_TOL |
COMP_CLASS |
REFDES |
SHORTBAR_1206 |
SHORTBAR1206_SHORTBAR_1206_IC_0 |
ShortingBar1206 |
IC |
BAR1 |
PLATED_HOLE_3_5MM |
MOUNT_HOLE_PLATED_HOLE_3_5MM_IC |
MOUNTING HOLE |
IC |
BH1 |
CC0805_OV |
CAP_NP_CC0805_OV_DISCRETE_1.4 M |
47PF |
5% |
DISCRETE |
C1 |
CC0805_OV |
CAP_NP_CC0805_OV_DISCRETE_1.35 |
0.1UF |
DISCRETE |
C2 |
CC0805_OV |
0.1UF |
DISCRETE |
C3 |
CC0805_OV |
47PF |
5% |
DISCRETE |
C4 |
CC0805_OV |
CAP_NP_CC0805_OV_DISCRETE_1.3_1 |
0.1UF |
10% |
DISCRETE |
C5 |
CC0805 |
CAP_NP_CC0805_DISCRETE_1.27MM_1 |
2.2UF |
DISCRETE |
C6 |
CC0805_OV |
CAP_NP_CC0805_OV_DISCRETE_1.4_2 |
4.7UF |
DISCRETE |
C7 |
CC0805_OV |
0.1UF |
DISCRETE |
C8 |
CC0805 |
2.2UF |
DISCRETE |
C9 |
CC0805_OV |
0.1UF |
DISCRETE |
C10 |
CC0805_OV |
0.1UF |
DISCRETE |
C11 |
CC0805_OV |
CAP_NP_CC0805_OV_DISCRETE_1.45M |
1.0uF |
DISCRETE |
C12 |
CC0805_OV |
0.1UF |
DISCRETE |
C13 |
CC0805_OV |
47PF |
5% |
DISCRETE |
C14 |
CC0805_OV |
47PF |
5% |
DISCRETE |
C15 |
CC0805_OV |
CAP_NP_CC0805_OV_DISCRETE_0.88M |
0.01UF |
DISCRETE |
C16 |
CAP_METPLY_15MM_18P2X6P9 |
CAP_NP_CAP_METPLY_15MM_18P2X6P9 |
0.68uF |
DISCRETE |
C17 |
CC0805_OV |
47PF |
5% |
DISCRETE |
C18 |
C402_520_154_35 |
CAP_NP_C402_520_154_35_DISCRETE |
2200PF |
DISCRETE |
C19 |
C402_520_154_35 |
2200PF |
DISCRETE |
C20 |
CC0805_OV |
0.1UF |
DISCRETE |
C21 |
CC0805_OV |
0.1UF |
DISCRETE |
C22 |
CCE50X54 |
CAP_POL_CCE50X54_DISCRETE_5.4MM |
47UF |
DISCRETE |
C23 |
CCE50X54 |
CAP_POL_CCE50X54_DISCRETE_5.5MM |
47UF |
DISCRETE |
C24 |
CC0805_OV |
0.1UF |
DISCRETE |
C25 |
CC0805_OV |
CAP_NP_CC0805_OV_DISCRETE_1.4MM |
1000PF |
DISCRETE |
C26 |
CC0805_OV |
1.0uF |
DISCRETE |
C27 |
CC0805_OV |
0.1UF |
DISCRETE |
C28 |
CR1653_1220_POL |
CAP_POL_CR1653_1220_POL_DISCRET |
330uF |
DISCRETE |
C29 |
CC0805_OV |
1000PF |
DISCRETE |
C30 |
CC0805_OV |
0.1UF |
DISCRETE |
C31 |
CCE50X54 |
47UF |
DISCRETE |
C32 |
CC0805_OV |
1000PF |
DISCRETE |
C33 |
CC0805_OV |
0.1UF |
DISCRETE |
C34 |
CC0805_OV |
0.1UF |
DISCRETE |
C35 |
CC0805_OV |
1000PF |
DISCRETE |
C36 |
CC0805_OV |
1000PF |
DISCRETE |
C37 |
CC0805_OV |
1000PF |
DISCRETE |
C38 |
CC0805_OV |
1000PF |
DISCRETE |
C39 |
CC0805_OV |
1.0uF |
DISCRETE |
C40 |
CC0805_OV |
0.1UF |
DISCRETE |
C41 |
CC0805_OV |
0.1UF |
DISCRETE |
C42 |
CC0805_OV |
0.1UF |
DISCRETE |
C43 |
CC0805_OV |
1000PF |
DISCRETE |
C44 |
CAP_10P5_RAD |
CAP_POL_CAP_10P5_RAD_DISCRETE_2 |
4.7uF |
DISCRETE |
C45 |
CAP_MET_PLY_18X6MM |
CAP_NP_CAP_MET_PLY_18X6MM_DISCR |
0.15UF |
DISCRETE |
C46 |
CC0805_OV |
0.1UF |
DISCRETE |
C47 |
CC0805_OV |
CAP_NP_CC0805_OV_DISCRETE_1.4_1 |
10UF |
DISCRETE |
C48 |
CC0805_OV |
1000PF |
DISCRETE |
C49 |
CC0805_OV |
1000PF |
DISCRETE |
C50 |
CC0805_OV |
1000PF |
DISCRETE |
C51 |
CC0805_OV |
0.1UF |
DISCRETE |
C52 |
CC0805_OV |
10UF |
DISCRETE |
C53 |
CCE50X54 |
CAP_POL_CCE50X54_DISCRETE_5.5 M |
10UF |
DISCRETE |
C54 |
CCE50X54 |
10UF |
DISCRETE |
C55 |
CCE50X54 |
10UF |
DISCRETE |
C56 |
CCE8P3X8P3 |
CAP_POL_CCE8P3X8P3_DISCRETE_10. |
100uF |
DISCRETE |
C57 |
CC0805_OV |
47PF |
5% |
DISCRETE |
C58 |
CC1812 |
CAP_NP_CC1812_DISCRETE_2 MM_150 |
0.1uF |
DISCRETE |
C59 |
CCE50X54 |
10UF |
DISCRETE |
C60 |
CC0805_OV |
47PF |
5% |
DISCRETE |
C61 |
CC0805_OV |
0.1UF |
10% |
DISCRETE |
C62 |
CR1653_1220_POL |
330uF |
DISCRETE |
C63 |
CCE10_3X10_3 |
CAP_POL_CCE10_3X10_3_DISCRETE_1 |
150uF |
DISCRETE |
C64 |
CC0805_OV |
47PF |
5% |
DISCRETE |
C65 |
CC0805_OV |
0.1UF |
10% |
DISCRETE |
C66 |
CC0805_OV |
0.1UF |
10% |
DISCRETE |
C67 |
CC0805_OV |
0.1UF |
DISCRETE |
C68 |
CC0805_OV |
0.1UF |
DISCRETE |
C69 |
CC0805_OV |
0.1UF |
DISCRETE |
C70 |
CC0805_OV |
0.1UF |
DISCRETE |
C71 |
CC0805_OV |
0.1UF |
10% |
DISCRETE |
C72 |
CC0805_OV |
10UF |
DISCRETE |
C73 |
CCE50X54 |
10UF |
DISCRETE |
C74 |
CC0805_OV |
47PF |
5% |
DISCRETE |
C75 |
CC0805_OV |
0.1UF |
10% |
DISCRETE |
C76 |
CC0805_OV |
47PF |
5% |
DISCRETE |
C77 |
CC0805_OV |
CAP_NP_CC0805_OV_DISCRETE_1.473 |
0.01UF |
DISCRETE |
C78 |
CC0805_OV |
0.1UF |
10% |
DISCRETE |
C79 |
CC0805_OV |
0.01UF |
DISCRETE |
C80 |
CC0805_OV |
0.01UF |
DISCRETE |
C81 |
CC0805_OV |
0.1UF |
DISCRETE |
C82 |
CC1812 |
0.1uF |
DISCRETE |
C83 |
CC0805_OV |
0.01UF |
DISCRETE |
C84 |
HSMX-C170 |
LED_HSMX-C170_IC_0.9 MM_370-300 |
HSMG-C170 |
IC |
D1 |
HSMX-C170 |
LED_HSMX-C170_IC_0.8MM_370-7578 |
HSMY-C170 |
IC |
D2 |
TO-220AC_VERT_2P |
DIODE_SCHTKY_TO-220AC_VERT_2P_I |
C3D10060A |
IC |
D3 |
TO-220AC_VERT_2P |
C3D10060A |
IC |
D4 |
TO-220AC_VERT |
DIODE_TO-220AC_VERT_IC_19.07 MM |
VS-15ETL06P |
IC |
D5 |
BRIDGE_DFB20_TH |
BRIDGE_RECTIFIER_BRIDGE_DFB20_T |
DFB2060 |
IC |
D6 |
SOD123 |
ZDIODE_SOD123_IC_1.35MM_480-780 |
MMSZ5248ET1 |
IC |
D7 |
DO214AC_4P06 |
DIODE_DO214AC_4P06_IC_2.64MM_48 |
ES1J-LTP |
IC |
D8 |
DO214AC_4P06 |
ES1J-LTP |
IC |
D9 |
SOD123 |
MMSZ5248ET1 |
IC |
D10 |
SOD-123 |
DIODE_SOD-123_IC_1.35MM_480-760 |
MMSD4148T1G |
IC |
D11 |
SOD-123 |
MMSD4148T1G |
IC |
D12 |
SOD-123 |
MMSD4148T1G |
IC |
D13 |
SOD123 |
DIODE_SCHTKY_SOD123_IC_1.45MM_4 |
MBR0520LT1G |
IC |
D14 |
SOD123 |
MBR0520LT1G |
IC |
D15 |
SMA |
ZDIODE_SMA_IC_2.41MM_480-77778_ |
1SMA5936BT3G |
IC |
D16 |
CASE403D_02 |
DIODE_CASE403D_02_IC_2.41MM_480 |
MURA160T3G |
IC |
D17 |
CASE403D_02 |
MURA160T3G |
IC |
D18 |
LED_2P_0805 |
LED_LED_2P_0805_IC_0.9MM_370-76 |
RED |
IC |
D19 |
HSMX-C170 |
HSMG-C170 |
IC |
D20 |
SMC_CASE403 |
DIODE_SMC_CASE403_IC_2.616MM_48 |
ES3J |
IC |
D21 |
LED0805 |
LED_LED0805_IC_1.2MM_370-76452_ |
BLUE |
IC |
D22 |
CASE403D_02 |
MURA160T3G |
IC |
D23 |
SOT23-3 |
DUALDIODE_CC_SOT23_SOT23-3_IC_1 |
BAS70-05 |
IC |
D24 |
SOT23-3 |
LM4041_SOT23-3_IC_1.12MM_315-78 |
LM4041 |
IC |
D25 |
SOD123 |
MBR0520LT1G |
IC |
D26 |
SOD123 |
MBR0520LT1G |
IC |
D27 |
SOD123 |
MBR0520LT1G |
IC |
D28 |
JUMP1X4-6040 |
CONN_HDR_4X1_JUMP1X4-6040_IO_8. |
HDR_1X4 |
IO |
J1 |
JUMP1X4-6040 |
HDR_1X4 |
IO |
J2 |
JUMP1X4-6040 |
HDR_1X4 |
IO |
J3 |
CON_USB_RA |
USB_B_RCPT_CON_USB_RA_IO_11.50M |
USB_TYPE_B |
IO |
J4 |
HDR102 |
CONN_HDR_2X1_HDR102_IO_8.6MM_21 |
HDR 1X2 |
IO |
J5 |
CON3_TB_5P08_TH |
CONN_HDR_3X1_CON3_TB_5P08_TH_IO |
MC000049 |
IO |
J8 |
CON_5M_100_TH |
CONN_HDR_5X1_CON_5M_100_TH_IO_1 |
CON_1X5 |
IO |
J9 |
CONN_2X32_THRUHOLE |
CONN_PCIEXP_64P_CUST_CONN_2X32_ |
CONN PCI EXP 64 |
IO |
J11 |
CON_2_TB_5P08_TH |
CONN_HDR_2X1_CON_2_TB_5P08_TH_I |
MC000048 |
IO |
J12 |
CON3_TB_5P08_TH |
MC000049 |
IO |
J13 |
RELAY_4P_19P8X15P8 |
G5LA-1A4-DC12_RELAY_4P_19P8X15P |
G5LA-1A4 DC12 |
IC |
K1 |
IND_2012 |
INDUCTOR_IND_2012_DISCRETE_0.85 |
1uH |
DISCRETE |
L1 |
IND_12P_45P5X42P4 |
GA3199_12P_IND_12P_45P5X42P4_DI |
650uH |
DISCRETE |
L2 |
IND_12P_45P5X42P4 |
650uH |
DISCRETE |
L3 |
IND12X12 |
INDUCTOR_IND12X12_DISCRETE_8.0M |
1000UH |
DISCRETE |
L4 |
TO-220AB_NSP |
MOSFET_N3_TO-220AB_NSP_IC_19.62 |
SIHF22N60E-E3 |
IC |
Q1 |
TO-220AB_NSP |
SIHF22N60E-E3 |
IC |
Q2 |
SOT-23 |
MOSFET_EN_SOT-23_IC_1.11 MM_480 |
BSS138LT1G |
IC |
Q3 |
D2PAK_B |
MOSFET_N_D4_D2PAK_B_IC_4.82 MM_ |
600V 20.2A |
IC |
Q4 |
RC0805_OV |
RES_RC0805_OV_DISCRETE_470-7546 |
15.0K |
DISCRETE |
R1 |
RC0805_OV |
RES_RC0805_OV_DISCRETE_0.55MM_4 |
1.6K |
1% |
DISCRETE |
R2 |
RC0805_OV |
RES_RC0805_OV_DISCRETE_0.6MM_47 |
220 |
1% |
DISCRETE |
R3 |
RC0805_OV |
RES_RC0805_OV_DISCRETE_470-7557 |
470 |
DISCRETE |
R4 |
RC0805_OV |
470 |
DISCRETE |
R5 |
RC2512_B |
RES_RC2512_B_DISCRETE_470-80263 |
0.05 |
DISCRETE |
R6 |
RC0805_OV |
220 |
1% |
DISCRETE |
R7 |
RC0805_OV |
1.6K |
1% |
DISCRETE |
R8 |
RC0805_OV |
RES_RC0805_OV_DISCRETE_470-7842 |
82K |
DISCRETE |
R9 |
RC0805_OV |
82K |
DISCRETE |
R10 |
RC0805_OV |
82K |
DISCRETE |
R11 |
RC0805_OV |
1.6K |
1% |
DISCRETE |
R12 |
RC0805_OV |
220 |
1% |
DISCRETE |
R13 |
RC0805_OV |
RES_RC0805_OV_DISCRETE_0.6 MM_4 |
24 |
5% |
DISCRETE |
R14 |
RC0805_OV |
RES_RC0805_OV_DISCRETE_470-75_1 |
10.0K |
DISCRETE |
R15 |
RC0805_OV |
1.6K |
1% |
DISCRETE |
R16 |
RC0805_OV |
220 |
1% |
DISCRETE |
R17 |
RC0805_OV |
RES_RC0805_OV_DISCRETE_470-7590 |
4.7K |
DISCRETE |
R18 |
RC2512_B |
0.05 |
DISCRETE |
R19 |
RC0805_OV |
15.0K |
DISCRETE |
R20 |
RC0805_OV |
RES_RC0805_OV_DISCRETE_470-75_2 |
560K |
DISCRETE |
R21 |
RC0805_OV |
4.7K |
DISCRETE |
R22 |
RC0805_OV |
4.7K |
DISCRETE |
R23 |
RC0805_OV |
24 |
5% |
DISCRETE |
R24 |
RC0805_OV |
4.7K |
DISCRETE |
R25 |
RC0805_OV |
1.6K |
1% |
DISCRETE |
R26 |
RC0805_OV |
1.6K |
1% |
DISCRETE |
R27 |
RC0805_OV |
RES_RC0805_OV_DISCRETE_470-75_3 |
1.0K |
DISCRETE |
R28 |
RC0805_OV |
1.6K |
1% |
DISCRETE |
R29 |
RC0805_OV |
1.6K |
1% |
DISCRETE |
R30 |
RC1206_OV |
RES_RC1206_OV_DISCRETE_470-8065 |
130K |
DISCRETE |
R31 |
RC1206_OV |
130K |
DISCRETE |
R32 |
RC1206_OV |
130K |
DISCRETE |
R33 |
RC0805_OV |
1.6K |
1% |
DISCRETE |
R34 |
RC0805_OV |
1.6K |
1% |
DISCRETE |
R35 |
RC0805_OV |
RES_RC0805_OV_DISCRETE_470-7881 |
120 |
DISCRETE |
R36 |
RC0805_OV |
RES_RC0805_OV_DISCRETE_470-7544 |
0 |
DISCRETE |
R37 |
RC0805_OV |
4.7K |
DISCRETE |
R38 |
RC0805_OV |
120 |
DISCRETE |
R39 |
RC0805_OV |
120 |
DISCRETE |
R40 |
RC0805_OV |
0 |
DISCRETE |
R41 |
RC0805_OV |
4.7K |
DISCRETE |
R42 |
RC0805_OV |
120 |
DISCRETE |
R43 |
RC0805_OV |
120 |
DISCRETE |
R44 |
RC0805_OV |
4.7K |
DISCRETE |
R45 |
RC0805_OV |
120 |
DISCRETE |
R46 |
RC0805_OV |
4.7K |
DISCRETE |
R47 |
RC0805_OV |
120 |
DISCRETE |
R48 |
RC0805_OV |
RES_RC0805_OV_DISCRETE_470-7877 |
22.0K |
DISCRETE |
R49 |
RC1206_OV |
130K |
DISCRETE |
R50 |
RC2512_B |
0.05 |
DISCRETE |
R51 |
RC0805_OV |
1.0K |
DISCRETE |
R52 |
RC1206_OV |
130K |
DISCRETE |
R53 |
RC1206_OV |
RES_RC1206_OV_DISCRETE_470-7868 |
3.01K |
DISCRETE |
R54 |
RC1206_OV |
130K |
DISCRETE |
R55 |
RC1206_OV |
130K |
DISCRETE |
R56 |
RC1206_OV |
130K |
DISCRETE |
R57 |
RC1206_OV |
130K |
DISCRETE |
R58 |
RC1206_OV |
RES_RC1206_OV_DISCRETE_470-3006 |
1.5K |
DISCRETE |
R59 |
RC2512_B |
0.05 |
DISCRETE |
R60 |
RC2512_B |
0.05 |
DISCRETE |
R61 |
RC2512_B |
0.05 |
DISCRETE |
R62 |
RC1206_OV |
1.5K |
DISCRETE |
R63 |
RC0805_OV |
24 |
5% |
DISCRETE |
R64 |
RC0805_OV |
RES_RC0805_OV_DISCRETE_0.55MM_1 |
7.5K |
1% |
DISCRETE |
R65 |
RC0805_OV |
1.6K |
1% |
DISCRETE |
R66 |
RC0805_OV |
220 |
1% |
DISCRETE |
R67 |
RC0805_OV |
1.6K |
1% |
DISCRETE |
R68 |
RC0805_OV |
220 |
1% |
DISCRETE |
R69 |
RC0805_OV |
RES_RC0805_OV_DISCRETE_470-7634 |
2K |
DISCRETE |
R70 |
RC0805_OV |
2K |
DISCRETE |
R71 |
RC0805_OV |
1.6K |
1% |
DISCRETE |
R72 |
RC0805_OV |
220 |
1% |
DISCRETE |
R73 |
RC0805_OV |
22.0K |
DISCRETE |
R74 |
RC0805_OV |
1.6K |
1% |
DISCRETE |
R75 |
RC0805_OV |
220 |
1% |
DISCRETE |
R76 |
RC0805_OV |
7.5K |
1% |
DISCRETE |
R77 |
RC0805_OV |
RES_RC0805_OV_DISCRETE_470-7595 |
16.5K |
DISCRETE |
R78 |
RC0805_OV |
4.7K |
DISCRETE |
R79 |
RC0805_OV |
10.0K |
DISCRETE |
R80 |
RC0805_OV |
RES_RC0805_OV_DISCRETE_470-7968 |
30K |
DISCRETE |
R81 |
RC0805_OV |
7.5K |
1% |
DISCRETE |
R82 |
RC0805_OV |
7.5K |
1% |
DISCRETE |
R83 |
RC0805_OV |
120 |
DISCRETE |
R84 |
RC0805_OV |
7.5K |
1% |
DISCRETE |
R85 |
RC0805_OV |
4.7K |
DISCRETE |
R86 |
RC0805_OV |
4.7K |
DISCRETE |
R87 |
RC0805_OV |
2K |
DISCRETE |
R88 |
RC0805_OV |
7.5K |
1% |
DISCRETE |
R89 |
RC1206_OV |
130K |
DISCRETE |
R90 |
RC1206_OV |
130K |
DISCRETE |
R91 |
RC1206_OV |
130K |
DISCRETE |
R92 |
RC0805_OV |
7.5K |
1% |
DISCRETE |
R93 |
RC0805_OV |
7.5K |
1% |
DISCRETE |
R95 |
RC1206_OV |
3.01K |
DISCRETE |
R96 |
RC0805_OV |
1.6K |
1% |
DISCRETE |
R97 |
RC0805_OV |
220 |
1% |
DISCRETE |
R98 |
RC1206_OV |
130K |
DISCRETE |
R99 |
RC1206_OV |
130K |
DISCRETE |
R100 |
RC1206_OV |
130K |
DISCRETE |
R101 |
RC0805_OV |
120 |
DISCRETE |
R102 |
RC0805_OV |
1.6K |
1% |
DISCRETE |
R103 |
RC0805_OV |
220 |
1% |
DISCRETE |
R104 |
RC1206_OV |
3.01K |
DISCRETE |
R105 |
RC1206_OV |
130K |
DISCRETE |
R106 |
RC1206_OV |
130K |
DISCRETE |
R107 |
RC1206_OV |
130K |
DISCRETE |
R108 |
RC0805_OV |
1.6K |
1% |
DISCRETE |
R109 |
RC0805_OV |
220 |
1% |
DISCRETE |
R110 |
RC1206_OV |
3.01K |
DISCRETE |
R111 |
RC0805_OV |
1.6K |
1% |
DISCRETE |
R112 |
RC0805_OV |
220 |
1% |
DISCRETE |
R113 |
RC0805_OV |
7.5K |
1% |
DISCRETE |
R114 |
RC0805_OV |
4.7K |
DISCRETE |
R115 |
RC1206_OV |
1.5K |
DISCRETE |
R116 |
RC0805_OV |
15.0K |
DISCRETE |
R117 |
RC0805_OV |
15.0K |
DISCRETE |
R118 |
RC0805_OV |
82K |
DISCRETE |
R119 |
RC0805_OV |
10.0K |
DISCRETE |
R121 |
RC0805_OV |
1.6K |
1% |
DISCRETE |
R122 |
RC0805_OV |
2K |
DISCRETE |
R123 |
RC0805_OV |
120 |
DISCRETE |
R124 |
RC0805_OV |
24 |
5% |
DISCRETE |
R125 |
RC0805_OV |
470 |
DISCRETE |
R126 |
RC0805_OV |
4.7K |
DISCRETE |
R127 |
RC0805_OV |
120 |
DISCRETE |
R128 |
RC0805_OV |
470 |
DISCRETE |
R137 |
THERMISTOR_328_770X220_TH |
THERMISTOR_THERMISTOR_328_770X2 |
16 OHM |
DISCRETE |
RT1 |
VARISTOR_7P5_17X5P6_TH |
VARISTOR_VARISTOR_7P5_17X5P6_TH |
V14E275P |
DISCRETE |
RV1 |
TESTPOINT_060_039MIL |
T POINT TH_TESTPOINT_060_039MIL |
TEST_POINT |
IC |
TP1 |
TEST_POINT |
IC |
TP2 |
TEST_POINT |
IC |
TP3 |
TEST_POINT |
IC |
TP4 |
TEST_POINT |
IC |
TP5 |
TEST_POINT |
IC |
TP6 |
TEST_POINT |
IC |
TP7 |
TEST_POINT |
IC |
TP8 |
TEST_POINT |
IC |
TP9 |
TEST_POINT |
IC |
TP10 |
TEST_POINT |
IC |
TP11 |
TEST_POINT |
IC |
TP12 |
TEST_POINT |
IC |
TP13 |
TEST_POINT |
IC |
TP14 |
TEST_POINT |
IC |
TP15 |
TEST_POINT |
IC |
TP16 |
TEST_POINT |
IC |
TP17 |
TEST_POINT |
IC |
TP18 |
TEST_POINT |
IC |
TP19 |
TEST_POINT |
IC |
TP20 |
TEST_POINT |
IC |
TP21 |
TEST_POINT |
IC |
TP22 |
TEST_POINT |
IC |
TP23 |
TEST_POINT |
IC |
TP24 |
TEST_POINT |
IC |
TP25 |
TEST_POINT |
IC |
TP26 |
TEST_POINT |
IC |
TP27 |
TEST_POINT |
IC |
TP28 |
TEST_POINT |
IC |
TP29 |
TEST_POINT |
IC |
TP30 |
TEST_POINT |
IC |
TP31 |
TEST_POINT |
IC |
TP32 |
TEST_POINT |
IC |
TP33 |
TEST_POINT |
IC |
TP34 |
TEST_POINT |
IC |
TP35 |
TEST_POINT |
IC |
TP36 |
TEST_POINT |
IC |
TP37 |
TEST_POINT |
IC |
TP38 |
TEST_POINT |
IC |
TP39 |
TEST_POINT |
IC |
TP40 |
TEST_POINT |
IC |
TP41 |
TEST_POINT |
IC |
TP42 |
TEST_POINT |
IC |
TP43 |
TEST_POINT |
IC |
TP44 |
TEST_POINT |
IC |
TP45 |
TEST_POINT |
IC |
TP46 |
SO16W |
SI8622BD_16P_SO16W_IC_2.65MM_31 |
SI8622BD-B-IS |
IC |
U1 |
SO8_1P27_4X5 |
MC33502D_SO8_1P27_4X5_IC_1.75MM |
MC33502DG |
IC |
U2 |
QFN28_5X5MM_3P3_EP |
CP2102_QFN28_5X5MM_3P3_EP_IC_1M |
CP2102 |
IC |
U3 |
DPAK_MC33269 |
MC33269_DPAK_DPAK_MC33269_IC_2. |
MC33269DT-3.3G |
IC |
U5 |
SIP3_2P54_12X8P6_TH |
MC78XXCT_SIP3_2P54_12X8P6_TH_IC |
R-78E5.0-0.5 |
IC |
U6 |
SMD-8B |
LNK306G_SMD-8B_IC_3.98MM_312-79 |
LNK306G |
IC |
U7 |
SO8_1P27_4X5 |
MC33502DG |
IC |
U8 |
S08_1P27_4X5 |
MC33152D_S08_1P27_4X5_IC_1.75MM |
MC33152 |
IC |
U9 |
SOT-23-5 |
LMV7271MF_SOT-23-5_IC_1.22MM_31 |
LMV7271MF |
IC |
U10 |
SO8_1P27_4X5 |
MC33502DG |
IC |
U11 |
DIP_26P_39P5X23P5_SPMAA-C26_TH |
FNB41560_26P_DIP_26P_39P5X23P5_ |
FNB41560 |
IC |
U12 |
SOT-23-5 |
LMV7271MF |
IC |
U13 |
SO8_1P27_4X5 |
FAN3224_SO_8P_SO8_1P27_4X5_IC_1 |
FAN3224 |
IC |
U14 |
