slar147.zip
(6.45 MB, 下载次数: 5)
Bill of Material for
On 2018/12/8/周六 at 13:26:16
Comment Pattern Quantity Components
1051640001 Molex_1051640001 1 USB101 Receptacle, USB 2.0, Micro B, 5 Position, R/A, SMT
1188E-1K2-V-TR SW_1188E 4 RESET_SW1, USR_SW1, USR_SW2 Switch, SPST, 0.05 A, 12 VDC, SMD
Wake_SW4
1-406541-1 TEC_1-406541-1 1 U14 RJ-45, No LED, tab up, R/A, TH
1812GC472KAT1A 1812_254 1 C31 CAP, CERM, 4700 pF, 2000 V, +/- 10%, X7R, 1812
2.5V DCK0005A_N 1 IC6 Precision Micropower Shunt Voltage Reference, 0.2% accuracy, 2.5 V, 15 ppm / degC, 15 mA, -40 to 85 degC, 5-pin SC70 (DCK), Green (RoHS & no Sb/Br)
5001 Keystone5001 14 TP4, TP5, TP6, TP7, TP8, TP9 Test Point, Miniature, Black, TH
TP10, TP11, TP12, TP13, TP14
TP15, TP16, TP17
AWHW-10G-0202-T Assman_AWHW-10G-0x02-T 1 BSL Header(Shrouded), 2.54mm, 5x2, Gold, TH
C1210C102KGRACTU 1210_270 1 C1 CAP, CERM, 1000 pF, 2000 V, +/- 10%, X7R, 1210
CMR200T-32.768KDZY-UT CFM_CMR200T 1 Y3 Crystal, 32.768 MHz, SMD
CRCW0402100KJNED 0402 2 R26, R36 RES, 100 k, 5%, 0.063 W, 0402
CRCW0402100RJNED 0402 4 R18, R51, R120, R166 RES, 100, 5%, 0.063 W, 0402
CRCW040210K0JNED 0402 7 R1, R2, R35, R44, R50, R117 RES, 10 k, 5%, 0.063 W, 0402
R121
CRCW04021K00JNED 0402 5 R108, R109, R110, R111, R118 RES, 1.0 k, 5%, 0.063 W, 0402
CRCW04021M00FKED 0402 1 R132 RES, 1.00 M, 1%, 0.063 W, 0402
CRCW04021M00JNED 0402 1 R42 RES, 1.0 M, 5%, 0.063 W, 0402
CRCW04022K00JNED 0402 1 R49 RES, 2.0 k, 5%, 0.063 W, 0402
CRCW040230K0JNED 0402 1 R134 RES, 30 k, 5%, 0.063 W, 0402
CRCW0402390RJNED 0402 4 R27, R30, R31, R33 RES, 390, 5%, 0.063 W, 0402
CRCW04023K30JNED 0402 3 R13, R14, R158 RES, 3.3 k, 5%, 0.063 W, 0402
CRCW040249R9FKED 0402 4 R21, R22, R23, R24 RES, 49.9, 1%, 0.063 W, 0402
CRCW04024K87FKED 0402 2 R25, R128 RES, 4.87 k, 1%, 0.063 W, 0402
CRCW040251K0JNED 0402 1 R133 RES, 51 k, 5%, 0.063 W, 0402
CRCW040251R0JNED 0402 2 R38, R131 RES, 51, 5%, 0.063 W, 0402
CRCW040275R0JNED 0402 4 R32, R43, R45, R46 RES, 75, 5%, 0.063 W, 0402
CRCW06030000Z0EA 0603 2 R101, R102 RES, 0, 5%, 0.1 W, 0603
CRCW06031M00JNEA 0603 1 R52 RES, 1.0 M, 5%, 0.1 W, 0603
CRCW12061M00JNEA 1206 1 R47 RES, 1.0 M, 5%, 0.25 W, 1206
ERJ-2GE0R00X 0402 14 R3, R4, R5, R6, R7, R8, R9 RES, 0, 5%, 0.063 W, 0402
R10, R11, R12, R19, R20, R39
R41
ERJ-2RKF4700X 0402 2 R123, R125 RES, 470, 1%, 0.1 W, AEC-Q200 Grade 0, 0402
FTSH-105-01-F-DV-K Samtec_FTSH-105-01-x-DV-K 2 J11, J102 Header (Shrouded), 1.27mm, 5x2, Gold, SMT
GRM1555C1H120JA01D 0402 6 C44, C45, C47, C48, C133 CAP, CERM, 12 pF, 50 V, +/- 5%, C0G/NP0, 0402
C134
GRM1555C1H150JA01D 0402 1 C147 CAP, CERM, 15 pF, 50 V, +/- 5%, C0G/NP0, 0402
GRM155R60J225KE95D 0402 3 C145, C148, C149 CAP, CERM, 2.2 礔, 6.3 V, +/- 10%, X5R, 0402
GRM155R61A105KE15D 0402 4 C14, C140, C142, C144 CAP, CERM, 1 礔, 10 V, +/- 10%, X5R, 0402
GRM155R70J104KA01D 0402 5 C132, C138, C139, C143, C146 CAP, CERM, 0.1 礔, 6.3 V, +/- 10%, X7R, 0402
GRM155R71C104KA88D 0402 19 C3, C4, C16, C17, C18, C22 CAP, CERM, 0.1 礔, 16 V, +/- 10%, X7R, 0402
C23, C24, C25, C26, C27, C28
C29, C30, C40, C41, C42, C43
C46
GRM155R71E103KA01D 0402 6 C135, C136, C137, C141, C150 CAP, CERM, 0.01 礔, 25 V, +/- 10%, X7R, 0402
C159
GRM155R71H332KA01D 0402 1 C102 CAP, CERM, 3300 pF, 50 V, +/- 10%, X7R, 0402
GRM188R61C225KE15D 0603 1 C15 CAP, CERM, 2.2 礔, 16 V, +/- 10%, X5R, 0603
GRM188R71H332KA01D 0603 1 C32 CAP, CERM, 3300 pF, 50 V, +/- 10%, X7R, 0603
HX1198FNLT Pulse_HX1198FNLT 1 U10 Transformer, 350 uH, SMT
LTST-C190CKT LED_LTST-C190_Red 1 LED102 LED, Red, SMD
LTST-C190GKT LED_LTST-C190 5 D1, D2, D3, D4, LED101 LED, Green, SMD
MSP432E401YTPDTR PDT0128A 1 U1 IoT enabled High performance 32-bit ARM(R) Cortex(R)-M4F based MCU, PDT0128A (TQFP-128)
NX3225GA-16.000M-STD-CRG-1 NDK_NX3225GA 1 Q101 Crystal, 16MHz, 8pF, SMD
NX3225GA-25.000M-STD-CRG-2 NDK_NX3225GA 1 Y1 Crystal, 25 MHz, 8pF, SMD
PBC02DAAN Sullins_PxC02DAAN 2 JP4, JP5 Header, 2.54mm, 2x2, Gold, TH
PEC02SAAN CONN_PEC02SAAN 3 JP2, JP6, JP7 Header, 100mil, 2x1, Tin, TH
PEC03DAAN SULLINS_PEC03DAAN 1 JP1 Header, 100mil, 3x2, Tin, TH
PEC03SAAN PEC03SAAN_Launchpad_3V3 1 J12 Header, 100mil, 3x1, Tin, TH
PEC03SAAN PEC03SAAN_Launchpad_5V0 1 J13 Header, 100mil, 3x1, Tin, TH
PEC10DAAN SULLINS_PEC10DAAN 1 J101 Header, 2.54mm, 10x2, Tin, TH
RC0402FR-07220KL 0402 1 R124 RES, 220 k, 1%, 0.0625 W, 0402
RC0402FR-07330KL 0402 1 R122 RES, 330 k, 1%, 0.0625 W, 0402
SLVU2.8-4.TBT SOIC-8 1 U13 Diode, TVS, Uni, 2.8 V, 15 Vc, SOIC-8
SNT-100-BK-G SNT-100-BK-G 18 SH-J101A, SH-J101B, SH-J101C Shunt, 100mil, Gold plated, Black
SH-J101D, SH-J101E, SH-J101F
SH-J101G, SH-J101H, SH-J101I
SH-J101J, SH-JP1, SH-JP2
SH-JP4A, SH-JP4B, SH-JP5A
SH-JP5B, SH-JP6, SH-JP7
SSQ-110-03-T-D BoosterPack_40pin_J1J3 2 J1/J3, J5/J7 Receptacle, 2.54mm, 10x2, Tin, TH
SSQ-110-03-T-D BoosterPack_40pin_J2J4 2 J2/J4, J6/J8 Receptacle, 2.54mm, 10x2, Tin, TH
TM4C129ENCPDTI3R PDT0128A 1 IC106 IoT enabled High performance 32-bit ARM(R) Cortex(R)-M4F based MCU, PDT0128A (TQFP-128)
TPD4E004DRYR DRY0006A 1 IC102 ESD-Protection Array for High-Speed Data Interfaces, 4 Channels, -40 to +85 degC, 6-pin SON (DRY), Green (RoHS & no Sb/Br)
TPD4S012DRYR DRY0006A 1 U2 USB ESD Solution with Power Clamp, 4 Channels, -40 to +85 degC, 6-pin SON (DRY), Green (RoHS & no Sb/Br)
TPD6E004RSER RSE0008A 2 U8, U108 Low-Capacitance + / - 15 kV ESD Protection Array for High-Speed Data Interfaces, 6 Channels, -40 to +85 degC, 8-pin UQFN (RSE), Green (RoHS & no Sb/Br)
TPS2052BDRBR DRB0008B 1 U4 Current-Limited, Power-Distribution Switches, DRB0008B (VSON-8)
TPS79601DRBR DRB0008B 1 IC101 Single Output High PSRR LDO, 1 A, Adjustable 1.2 to 5.5 V Output, 2.7 to 5.5 V Input, 8-pin SON (DRB), -40 to 125 degC, Green (RoHS & no Sb/Br)
TSW-149-07-S-D Samtec_TSW-149-07-x-D 1 J10 Header, 2.54mm, 49x2, Gold, TH
ZX62D-AB-5P8 Hirose-ZX62D-AB-5P8 1 U7 Connector, Receptacle, Micro-USB Type AB, R/A, Bottom Mount SMT
[/hide] |
