查看: 2471|回复: 0
[AD格式] Value Line MSP430 LaunchPad  Development Kit 开发板原理图 PCB
发表于 2018-12-9 12:52:04 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
slar153.zip (4.89 MB, 下载次数: 4)
Bill of Material for
On 2018/12/8/周六 at 13:28:59
Comment             Pattern     Quantity  Components
0.01uF              0402             4    C7, C9, C102, C142           CAP, CERM, 0.01 礔, 16 V,+/- 10%, X7R, 0402
0.047               0603             1    R123                         RES, 0.047, 1%, 0.1 W, 0603
0.1uF               0402            15    C1, C4, C5, C101, C105, C113 CAP, CERM, 0.1 礔, 10 V,+/- 10%, X5R, 0402
                                           C114, C116, C118, C122, C126
                                           C129, C131, C133, C141
0.2                 0603             1    R102                         RES, 0.2, 1%, 0.125 W, 0603
0.22uF              0402             3    C108, C110, C125             CAP, CERM, 0.22 礔, 10 V,+/- 10%, X5R, 0402
0.47uF              0402             1    C109                         CAP, CERM, 0.47 礔, 16 V,+/- 10%, X5R, 0402
0                   0402             1    R124                         RES, 0, 5%, 0.063 W, 0402
0                   0603             4    R3, R5, R7, R9               RES, 0, 5%, 0.1 W, 0603
0                   1206             2    R110, R112                   RES, 0, 5%, 0.25 W, 1206
1.00Meg             0402             1    R122                         RES, 1.00 M, 1%, 0.063 W, 0402
1.0Meg              0402             1    R116                         RES, 1.0 M, 5%, 0.063 W, 0402
1.40k               0402             1    R115                         RES, 1.40 k, 1%, 0.063 W, 0402
10.0                0402             6    R104, R105, R106, R107, R109 RES, 10.0, 1%, 0.063 W, 0402
                                           R111
1000pF              0402             4    C13, C14, C117, C120         CAP, CERM, 1000 pF, 50 V,+/- 10%, X7R, 0402
1000pF              0603             1    C12                          CAP, CERM, 1000 pF, 50 V,+/- 5%, X7R, 0603
1051640001          Molex_1051640001    1    J102                         Receptacle, USB 2.0, Micro B, 5 Position, R/A, SMT
10pF                0402             5    C106, C107, C119, C123, C124 CAP, CERM, 10 pF, 50 V,+/- 1%, C0G/NP0, 0402
10uF                3216-18          1    C2                           CAP, TA, 10 礔, 10 V, +/- 20%, 3.4 ohm, SMD
110                 0402             1    R12                          RES, 110, 1%, 0.063 W, 0402
110-44-320-41-001000 Mill-Max_110-xx-320-41-001000    1    XU1                          Socket, DIP-20, Sleeve Pin, 2.54 mm Pitch
1188E-1K2-V-TR      SW_1188E         2    S1, S2                       Switch, SPST, 0.05 A, 12 VDC, SMD
12pF                0402             2    C10, C11                     CAP, CERM, 12 pF, 50 V,+/- 5%, C0G/NP0, 0402
150 ohm             0603             2    L100, L101                   Ferrite Bead, 150 ohm @ 100 MHz, 0.7 A, 0603
150060RS75000       WL-SMCW_RED      2    D2, D100                     LED, Red, SMD
150060VS75000       WL-SMCW_GREEN    2    D1, D101                     LED, Green, SMD
150060YS75000       WL-SMCW_YELLOW    1    D102                         LED, Yellow, SMD
150k                0402             1    R130                         RES, 150 k, 1%, 0.063 W, 0402
16                  0402             1    R13                          RES, 16, 5%, 0.063 W, 0402
19-337/R6GHBHC-A01/2T 19-337_RGB       1    D3                           LED, RGB, SMD
1uF                 0402             5    C3, C100, C104, C112, C140   CAP, CERM, 1 礔, 10 V,+/- 10%, X5R, 0402
2.20k               0402             1    R133                         RES, 2.20 k, 0.1%, 0.0625 W, AEC-Q200 Grade 0, 0402
2.2uF               0402             1    C103                         CAP, CERM, 2.2 uF, 16 V, +/- 10%, X5R, 0402
2.2uF               3216-18          3    C6, C8, C127                 CAP, TA, 2.2 礔, 25 V, +/- 10%, 6.3 ohm, SMD
2.2uH               CBC2518          1    L102                         Inductor, Wirewound, Ceramic, 2.2 礖, 0.89 A, 0.13 ohm, SMD
220k                0402             2    R125, R129                   RES, 220 k, 1%, 0.0625 W, 0402
220k                0603             4    R127, R128, R131, R132       RES, 220 k, 0.1%, 0.063 W, 0603
24                  0402             1    R11                          RES, 24, 5%, 0.063 W, 0402
240k                0402             1    R126                         RES, 240 k, 1%, 0.063 W, 0402
27                  0402             2    R113, R114                   RES, 27, 5%, 0.063 W, 0402
3.30k               0402             1    R134                         RES, 3.30 k, 0.1%, 0.0625 W, AEC-Q200 Grade 0, 0402
33k                 0402             1    R117                         RES, 33 k, 5%, 0.063 W, 0402
33pF                0402             6    C134, C135, C136, C137, C138 CAP, CERM, 33 pF, 50 V,+/- 5%, C0G/NP0, 0402
                                           C139
390                 0402             3    R4, R101, R103               RES, 390, 5%, 0.063 W, 0402
4.7k                0402             4    R1, R2, R118, R119           RES, 4.7 k, 5%, 0.063 W, 0402
4.7uF               0402             1    C115                         CAP, CERM, 4.7 礔, 6.3 V,+/- 20%, X5R, 0402
4.7uF               0603             1    C132                         CAP, CERM, 4.7 礔, 10 V,+/- 10%, X5R, 0603
4.7uF               0805_HV          2    C121, C128                   CAP, CERM, 4.7 礔, 10 V,+/- 10%, X5R, 0805
4.7uF               3216-18          2    C111, C130                   CAP, TA, 4.7 礔, 10 V, +/- 10%, 5 ohm, SMD
47.0k               0603             1    R6                           RES, 47.0 k, 1%, 0.1 W, AEC-Q200 Grade 0, 0603
470                 0402             3    R8, R100, R120               RES, 470, 5%, 0.063 W, 0402
47k                 0402             4    R10, R108, R135, R136        RES, 47 k, 5%, 0.063 W, 0402
6.81k               0402             1    R137                         RES, 6.81 k, 0.1%, 0.0625 W, AEC-Q200 Grade 0, 0402
820                 0402             1    R121                         RES, 820, 1%, 0.063 W, 0402
B0530W-7-F          SOD-123          1    D103                         Diode, Schottky, 30 V, 0.5 A, SOD-123
BAS40-05,215        SOT-23           2    D104, D105                   Diode, Schottky, 40 V, 0.12 A, AEC-Q101, SOT-23
BC850CW,115         SOT-323          1    Q101                         Transistor, NPN, 45 V, 0.1 A, SOT-323
CSTCR4M00G15L99-R0  Murata_CSTCR     1    Y100                         Resonator, 4 MHz, 39pF SMD
DMG1013UW-7         SOT-323          1    Q100                         MOSFET, P-CH, -20 V, -0.82 A, SOT-323
ECS-.327-12.5-34B-TR ECS_ECX_31B      1    Y1                           Crystal, 32.768 KHz, 20 ppm, SMD
Fiducial            Fiducial6.4-20    3    FID1, FID2, FID3             Fiducial mark.  There is nothing to buy or mount.
INA214AIDCKR        DCK0006A_N       1    U102                         Voltage Output, High or Low Side Measurement, Bi-Directional Zer?Drift Series Current-Shunt Monitor, DCK0006A (SOT-SC70-6)
MAE-10              KY_MAE-10        2    H1, H2                       Spacer Support, Nylon 66
MSP430F5528IRGCT    RGC0064B         1    U100                         25 MHz Mixed Signal Microcontroller with 128 KB Flash, 8192 B SRAM and 47 GPIOs, -40 to 85 degC, 64-pin QFN (RGC), Green (RoHS & no Sb/Br)
MSP430G2452IRSA16R  RSA0016B         1    U104                         16 MHz Mixed Signal Microcontroller with 8 KB Flash, 256 B SRAM and 16 GPIOs, 16-pin QFN (RSA), Green (RoHS & no Sb/Br)
PEC03SAAN           PEC03SAAN_Launchpad_3V3    1    J4                           Header, 100mil, 3x1, Tin, TH
PEC03SAAN           PEC03SAAN_Launchpad_5V0    1    J5                           Header, 100mil, 3x1, Tin, TH
PEC07DAAN           PEC07DAAN_Launchpad_EZ-FET    1    J101                         Header, 100mil, 7x2, Tin, TH
Place J101: 11-12   SNT-100-BK-G     1    SH-J101-6                    Shunt, 100mil, Gold plated, Black
Place J101: 1-2     SNT-100-BK-G     1    SH-J101-1                    Shunt, 100mil, Gold plated, Black
Place J101: 13-14   SNT-100-BK-G     1    SH-J101-7                    Shunt, 100mil, Gold plated, Black
Place J101: 3-4     SNT-100-BK-G     1    SH-J101-2                    Shunt, 100mil, Gold plated, Black
Place J101: 5-6     SNT-100-BK-G     1    SH-J101-3                    Shunt, 100mil, Gold plated, Black
Place J101: 7-8     SNT-100-BK-G     1    SH-J101-4                    Shunt, 100mil, Gold plated, Black
Place J101: 9-10    SNT-100-BK-G     1    SH-J101-5                    Shunt, 100mil, Gold plated, Black
Place J6: 1-2       SNT-100-BK-G     1    SH-J6                        Shunt, 100mil, Gold plated, Black
Place J7: 1-2       SNT-100-BK-G     1    SH-J7                        Shunt, 100mil, Gold plated, Black
Place on Pin 2 only SNT-100-BK-G     1    SH-J8-1                      Shunt, 100mil, Gold plated, Black
Place on Pin 4 only SNT-100-BK-G     1    SH-J8-2                      Shunt, 100mil, Gold plated, Black
Place on Pin 6 only SNT-100-BK-G     1    SH-J8-3                      Shunt, 100mil, Gold plated, Black
SSQ-102-03-F-S      BoosterPack_20pin_J3    1    J3                           Receptacle, 2.54mm, 2x1, Gold, TH
SSQ-110-03-F-S      BoosterPack_20pin_J1    1    J1                           Receptacle, 2.54mm, 10x1, Gold, TH
SSQ-110-03-F-S      BoosterPack_20pin_J2    1    J2                           Receptacle, 2.54mm, 10x1, Gold, TH
TPD2E001DRLR        DRL0005A         1    U103                         Low-Capacitance + / - 15 kV ESD-Protection Array for High-Speed Data Interfaces, 2 Channels, -40 to +85 degC, 5-pin SOT (DRL), Green (RoHS & no Sb/Br)
TPS22968NDPUR       DPU0014A         1    U105                         5.5V, 4A, 25mO, 2-Channel Load Switch With Quick Output Discharge and Adjustable Rise Time, DPU0014A (WSON-14)
TPS73533DRVR        DRV0006A         1    U101                         Single Output High PSRR LDO, 500 mA, Fixed 3.3 V Output, 2.7 to 6.5 V Input, with Low IQ, 6-pin SON (DRV), -40 to 125 degC, Green (RoHS & no Sb/Br)
TSW-102-07-G-S      TSW-102-07-G-S    2    J6, J7                       Header, 100mil, 2x1, Gold, TH
TSW-103-07-G-D      TSW-103-07-G-D    1    J8                           Header, 100mil, 3x2, Gold, TH
[/hide]
重要提示:PCB作品文件展下载说明
