查看: 3030|回复: 0
[AD格式] 23DK-S3A7开发套件 底板 原理图 PCB
发表于 2018-12-9 13:02:00 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
22.zip (5.54 MB, 下载次数: 4)
Comment             Pattern     Quantity  Components
CAP-000029-01       CAPC0603-01     13    C100, C102, C106, C117, C134 Ceramic Chip Capacitor 0603 0.1uF 50V
                                           C137, C138, C142, C143, C144
                                           C145, C146, C147
CAP-000043-01       CAPC0603-01      2    C135, C141                   Ceramic Chip Capacitor 0603 4.7uF 6.3V
CAP-000057-01       CAPC0201-01      2    C118, C124                   Ceramic Chip Capacitor 0201 0.1uF 10V
CAP-000063-01       CAPC0402-01      4    C120, C136, C148, C149       Ceramic Chip Capacitor 0402 1uF 16V
CAP-000066-01       CAPC0603-01      3    C101, C110, C122             Ceramic Chip Capacitor 0603 10uF 10V
CAP-000067-01       CAPC0402-01      1    C111                         Ceramic Chip Capacitor 0402 2.2uF 10V
CAP-000070-01       CAPMP7343-31-01    1    C105                         Tantalum Capacitor D 7343-31 150uF 16V
CAP-000072-01       CAPC0603-01      1    C103                         Ceramic Chip Capacitor 0603 22uF 6.3V
CAP-000073-01       CAPC0402-01      1    C130                         Ceramic Chip Capacitor 0402 10uF 6.3V
CAP-000074-01       CAPC0603-01      2    C107, C139                   Ceramic Chip Capacitor 0603 1uF 50V
CAP-000081-01       CAPC0201-01      5    C119, C121, C123, C125, C127 Ceramic Chip Capacitor 0201 10pF 25V
CAP-000084-01       CAPC0201-01     13    C108, C109, C112, C113, C114 Ceramic Chip Capacitor 0201 1uF 6.3V
                                           C115, C116, C126, C128, C129
                                           C131, C132, C133
CAP-000090-01       CAPC0603-01      1    C140                         Ceramic Chip Capacitor 0603 220nF 50V
CON-000036-01       SAMTEC_USB-A-S-F    1    J101                         USB Type A 2.0 Jack
CON-000047-01       KEYSTONE_5015   10    TP100, TP101, TP102, TP103   Keystone SMT Test Point
                                           TP104, TP105, TP106, TP107
                                           TP108, TP109
CON-000050-01       SAMTEC_SSW-106-02-F-D-RA-PMOD    2    J100, J111                   Samtec Female Header 0.1" pitch PMOD 2x6 Right Angle
CON-000074-01       FCI_100067847-01    1    SD100                        FCI SD Socket
CON-000076-01       FCI_10106813-061112LF    3    J105, J106, J108             FCI Board to Board M/F 60 Position 0.5mm Pitch 2mm
CON-000124-01       CUI_SJ-3524-GR    1    J110                         3.5mm SMT Audio Jack Green
CON-000130-01       CUI_SJ-3524-BE    1    J112                         3.5mm SMT Audio Jack Blue
CON-000153-01       HARWIN_M20-9960345    2    J102, J109                   Header 0.1" pitch 3pos 1x3 Right Angle
CON-000163-01       CUI_SJ-43516-SMT    1    J107                         3.5mm SMT Audio Jack
CON-000174-01       FCI_77313-801-04LF    1    JMP100                       FCI Header 0.1" pitch 14pos 2x7
CON-000184-01       FCI_77313-801-06LF    1    JMP101                       FCI Header 0.1" pitch 6pos 2x3
CON-013002-01       MOLEX_79107-7214    2    J103, J104                   Molex HT Female Header 2mm pitch 30pos 2x15
FAS-000018-01       PEM_SMTSO-M3-4    4    SO100, SO101, SO102, SO103   PEM SMT M3 4.0mm Standoff
FAS-000043-01       Keystone-1377    2    TOOL1, TOOL2
ICN-000010-01       MSOP8_N          1    U109                         NCT75 5.5V Digital Temperature Sensor I2C
ICN-000072-01       TI_PVSON-N10     1    U100                         TI Integrated USB Power switch with boost converter
ICN-000129-01       MAXIM_TQFN56     1    U104                         MAX98089 Audio Stereo Codec/Amplifier
ICN-000131-01       TI_DSE-PWSON-N6    1    U103                         LDO Regulator 1.8V 200mA
ICN-000165-01       TI PDSO-N5       1    U101                         Two channel 30kV ESD Dual Protection
ICN-000179-01       HONEYWELL_LCC-16    1    U107                         Digital I2C 3-Axis Compass
ICN-000180-01       ONSEMI_UDFN8     1    U108                         EEPROM 64kbit 8kx8 1.8/2.5/3.3/5V
ICN-000181-01       OSRAM_SFH7776    1    U105                         Ambient Light and Proximity Sensor, I2C
ICN-000182-01       MICRON_V-PDFN-8-6    1    U102                         Micron 2Mbit SPI Serial Flash
ICN-000184-01       KIONIX_KX022-LGA12    1    U106                         3-Axis Digital ACcelerometer
IND-000007-01       BOURNS_SRN3015    1    L100                         Bourns Semishielded Power Inductor 2.2uH 1.8A
IND-000011-01       FB_0402          2    FB100, FB102                 Chip Ferrite Bead 0402 600 300mA 25%
IND-000012-01       FB_0603          1    FB101                        Chip Ferrite Bead 0603 30 6A 25%
RES-000116-01       RESCAF0804       2    RA100, RA101                 Chip Resistor Array 0804 22K0 5% 1/16W 4 x 0402
RES-000137-01       RESC0402-01     11    R101, R103, R104, R106, R108 Chip Resistor Thick Film 0402 10K0 0.5% 1/16W
                                           R109, R110, R112, R113, R114
                                           R115
RES-000139-01       RESC0402-01      3    R102, R105, R116             Chip Resistor Thick Film 0402 100K0 0.5% 1/16W
RES-000144-01       RESC0402-01      1    R100                         Chip Resistor Thick Film 0402 180K0 1% 1/10W
RES-000155-01       RESC0402-01      1    R107                         Chip Resistor Thick Film 0402 22K0 0.5% 1/16W
[/hide][/hide]
重要提示:PCB作品文件展下载说明
