DK-S124-v2.0-Design-Files.zip
(24.61 MB, 下载次数: 2)
Comment Pattern Quantity Components
CAP-000013-01 CAPC0603-01 3 C28, C31, C59 Ceramic Chip Capacitor 0603 10uF 6.3V
CAP-000057-01 CAPC0201-01 35 C1, C3, C6, C9, C10, C11, C16 Ceramic Chip Capacitor 0201 0.1uF 10V
C18, C19, C20, C21, C22, C23
C24, C25, C26, C27, C29, C32
C33, C34, C36, C40, C44, C45
C46, C47, C48, C49, C50, C54
C57, C58, C61, C62
CAP-000059-01 CAPC0402-01 2 C14, C15 Ceramic Chip Capacitor 0402 12pF 50V
CAP-000062-01 CAPC0402-01 1 C17 Ceramic Chip Capacitor 0402 0.01uF 50V
CAP-000063-01 CAPC0402-01 6 C7, C8, C30, C39, C42, C43 Ceramic Chip Capacitor 0402 1uF 16V
CAP-000064-01 CAPC0402-01 1 C60 Ceramic Chip Capacitor 0402 4.7uF 6.3V
CAP-000067-01 CAPC0402-01 1 C38 Ceramic Chip Capacitor 0402 2.2uF 10V
CAP-000072-01 CAPC0603-01 2 C4, C5 Ceramic Chip Capacitor 0603 22uF 6.3V
CAP-000081-01 CAPC0201-01 4 C12, C13, C55, C56 Ceramic Chip Capacitor 0201 10pF 25V
CAP-000086-01 CAPC0805-01 1 C2 Ceramic Chip Capacitor 0805 22uF 25V
CAP-000088-01 CAPC0402-01 1 C51 Ceramic Chip Capacitor 0402 33pF
CAP-000092-01 CAPC0201-01 2 C52, C53 Ceramic Chip Capacitor 0201 15pF 25V
CAP-000101-01 CAPC0402-01 1 C37 Ceramic Chip Capacitor 0402 22nF 50V
CAP-000114-01 CAPC0402-01 2 C35, C41 Ceramic Chip Capacitor 0402 0.47uF 10V
CON-000031-01 KEYSTONE_3002 1 BAT1 Keystone CR2032 Battery Coin Cell holder
CON-000047-01 KEYSTONE_5015 3 TP1, TP2, TP3 Keystone SMT Test Point
CON-000056-01 FCI_6800-x03 1 J18 FCI Header 0.1" pitch 3pos 1x3
CON-000080-01 FCI_20020110-C081 1 J4 FCI Terminal Block 3.5mm pitch 8pos Right Angle
CON-000116-01 FCI_10118192 2 J10, J14 USB Micro 2.0 Female 5 Pin Right Angle
CON-000153-01 HARWIN_M20-9960345 1 J8 Header 0.1" pitch 3pos 1x3 Right Angle
CON-000171-01 SAMTEC_FTSH-105-01-DV-007-K 1 J13 10 Position Shrouded Header 1.27mm Pitch Pin #7 Removed
CON-000176-01 FCI_67966-X02 4 J3, J17, J19, J20 FCI Header 0.1" pitch 2pos 1x2
CON-000184-01 FCI_77313-801-06LF 1 J2 FCI Header 0.1" pitch 6pos 2x3
CON-000185-01 FCI_77311-818-08LF 1 J9 FCI Header 0.1" pitch 8pos 1x8
CON-000189-01 CUI_SJ1-3523N 1 J11 CUI 3.5mm Audio Jack TH no switch
CON-000190-01 SULLINS_PPTC062LJBN-RC-PMOD 1 J7 Samtec Female Header 0.1" pitch PMOD 2x6 Right Angle
CON-000191-01 KOBICON_163-7620E 1 J1 Kobicon DC Jack 2.0mm TH
CON-000197-01 FCI_77311-818-22LF 2 J5, J6 FCI Header 0.1" pitch 22pos 1x22
CON-000211-01 SEEED_GROVE-1125S=4P 1 J16 SEEED Vertical 2mm Grove System 4-pin
DIO-000022-01 SOT-23 1 D3 Dual Line CAN Bus Protector 350W
DIO-000026-01 MCC_DO-214AA 2 D1, D2 Schottky Diode 30V 2A DO214AA
FET-000002-02 SC-70-6 1 Q1 N-FET 30V 4A
ICN-000022-01 TI_SOIC8 1 U6 Infineon CAN Transceiver 1MBaud
ICN-000108-01 INTERSIL_QFN40-6X6 1 U5 Intersil ISL41387 RS232/RS485 Transceiver
ICN-000117-01 TI_DSE-PWSON-N6 1 U4 LDO Regulator 3.3V 200mA
ICN-000126-01 MICRON_V-PDFN-8 1 U7 Micron 256Mbit Serial FLASH QSPI
ICN-000158-01 RENESAS_PLQP0100KB-A_N 1 U12 Renesas RX621 32-bit 100MHz MCU LQFP100
ICN-000166-01 INTERSIL_WLCSP 1 U2 DC-DC Buck Boost Switcher 3.3V 2A
ICN-000168-01 MAXIM_TDFN-EP-14 1 U10 Maxim Microphone Preamp
ICN-000177-01 MSOP10_N 1 U11 Stereo Headphone Amp 135mW
ICN-000186-01 SC-70-8 1 U3 LTC 5.5V Voltage Protection Controller
ICN-000189-01 AVAGO_ADPS-9005 1 U8 Avago ADPS-9005 Ambient Light Sensor
ICN-000202-01 RENESAS_PLQP0064KB-A_N 1 U1 Renesas S124 TBD LQFP64
ICN-000209-01 SOT23-5 1 U9 Analog Temperature Sensor
ICN-0002229-01 BOSCH_BMA250-LGA12 1 U13 BOSCH 3-Axis Digital ACcelerometer
IND-000005-01 FB_0805 1 FB1 Chip Ferrite Bead 0805 120 800mA 25%
IND-000021-01 SUMIDA_252012 1 L1 Sumida Power Inductor 1uH 3.1A
LED-000001-01 LED_DIALIGHT-598-8610 1 LED4 Dialight Bicolor LED Red/Green 1210
LED-000004-01 LED_0603-GRN 1 LED3 Lite-On LED Green Clear 0603
LED-000005-01 LED_0603-RED 1 LED1 Lite-On LED Red Clear 0603
LED-000006-01 LED_0603-YLW 1 LED2 Lite-On LED Yellow Clear 0603
MIC-000002-01 KNOWLES_5P1H_4x3x1mm 1 MK1 SMT MEMS Analog Microphone
OEM-000013-01 CMAX_9301-V4.4 1 RF1 C-Max BLE Module V4.4
POT-000001-02 BOURNS_3352T 1 POT1 Bourns Single Turn Trimmer 10K0
RES-000106-01 RESCAF0804 2 RA4, RA8 Chip Resistor Array 0804 100K0 5% 1/16W 4 x 0402
RES-000108-01 RESCAF0804 3 RA1, RA2, RA11 Chip Resistor Array 0804 4K70 5% 1/16W 4 x 0402
RES-000111-01 RESCAF0804 2 RA5, RA12 Chip Resistor Array 0804 10K0 5% 1/16W 4 x 0402
RES-000112-01 RESCAF0804 1 RA10 Chip Resistor Array 0804 22R0 5% 1/16W 4 x 0402
RES-000116-01 RESCAF0804 1 RA7 Chip Resistor Array 0804 22K0 5% 1/16W 4 x 0402
RES-000117-01 RESCAF0804 1 RA6 Chip Resistor Array 0804 30K0 5% 1/16W 4 x 0402
RES-000124-01 RESC0402-01 1 R2 Chip Resistor Thick Film 0402 470R 0.5% 1/16W
RES-000125-01 RESC0402-01 1 R17 Chip Resistor Thick Film 0402 1K00 0.5% 1/16W
RES-000132-01 RESC0805-01 4 R27, R28, R29, R30 Chip Resistor Thick Film 0805 0R00 1% 1/8W
RES-000137-01 RESC0402-01 2 R20, R21 Chip Resistor Thick Film 0402 10K0 0.5% 1/16W
RES-000139-01 RESC0402-01 5 R1, R13, R22, R23, R31 Chip Resistor Thick Film 0402 100K0 0.5% 1/16W
RES-000140-01 RESC0402-01 2 R3, R26 Chip Resistor Thick Film 0402 1K50 0.5% 1/16W
RES-000141-01 RESC0402-01 2 R24, R25 Chip Resistor Thick Film 0402 0R00 1% 1/16W
RES-000171-01 RESC0402-01 2 R15, R16 Chip Resistor Thick Film 0402 27R0 1% 1/10W
RES-000193-01 RESC0402-01 1 R19 Chip Resistor Thick Film 0402 143K0 1% 1/16W
RES-000198-01 RESCAF0804 2 RA3, RA9 Chip Resistor Array 0804 150R 5% 1/16W 4 x 0402
RES-000199-01 RESC0805-01 1 R14 Chip Resistor Thick Film 0805 10K0 1% 1/8W
RES-000205-01 RESC0805-01 1 R4 Current Sense Resitor 0805 50mOhm 1%
RES-000206-01 RESC0603-01 7 R6, R7, R8, R9, R10, R11, R12 Chip Resistor Thick Film 0603 560R0 1% 1/10W
SWT-000007-01 SW_CTS_219-4LPST 1 S4 SMD DIP Switch 4 Position 2.54mm
SWT-000013-01 SW_C&K_PTS645_43 3 S1, S2, S3 Push Button Switch 6 x 6mm 4.3mm High
XTL-000006-01 ABRACON_ABS07 1 X2 Crystal 32.769KHz 12.5pF SMT
XTL-000011-01 TXC_7V 1 X3 TXC 7V Crystal 12MHz 10pF
XTL-000012-01 TXC_7V 1 X1 TXC 7V Crystal 16MHz 10pF
[/hide][/hide] |
