30.zip
(10.19 MB, 下载次数: 9)
Comment Pattern Quantity Components
CAP-000013-01 CAPC0603-01 1 C9 Ceramic Chip Capacitor 0603 10uF 6.3V
CAP-000019-01 CAPC1206-01 1 C52 Ceramic Chip Capacitor 1206 47uF 10V
CAP-000031-01 CAPC0402-01 1 C14 Ceramic Chip Capacitor 0402 0.1uF 16V
CAP-000041-01 CAPC0603-01 1 C71 Ceramic Chip Capacitor 0603 100pF 50V
CAP-000042-01 CAPC1206-01 1 C12 Ceramic Chip Capacitor 1206 1uF 50V
CAP-000051-01 CAPC1206-01 2 C62, C63 Ceramic Chip Capacitor 1206 47uF 10V
CAP-000057-01 CAPC0201-01 62 C1, C2, C4, C7, C8, C11, C17 Ceramic Chip Capacitor 0201 0.1uF 10V
C18, C20, C21, C25, C26, C27
C28, C29, C30, C31, C32, C33
C37, C40, C45, C48, C49, C51
C53, C54, C75, C76, C77, C78
C79, C81, C83, C85, C86, C87
C88, C90, C91, C98, C100
C101, C102, C103, C104, C105
C106, C107, C108, C109, C110
C112, C113, C114, C115, C116
C122, C123, C124, C125, C126
CAP-000059-01 CAPC0402-01 2 C38, C39 Ceramic Chip Capacitor 0402 12pF 50V
CAP-000063-01 CAPC0402-01 10 C19, C35, C73, C74, C80, C82 Ceramic Chip Capacitor 0402 1uF 16V
C84, C89, C97, C111
CAP-000064-01 CAPC0402-01 3 C46, C92, C93 Ceramic Chip Capacitor 0402 4.7uF 6.3V
CAP-000066-01 CAPC0603-01 3 C10, C13, C94 Ceramic Chip Capacitor 0603 10uF 10V
CAP-000067-01 CAPC0402-01 4 C47, C96, C127, C128 Ceramic Chip Capacitor 0402 2.2uF 10V
CAP-000070-01 CAPMP7343-31-01 1 C36 Tantalum Capacitor D 7343-31 150uF 16V
CAP-000072-01 CAPC0603-01 4 C5, C6, C15, C50 Ceramic Chip Capacitor 0603 22uF 6.3V
CAP-000073-01 CAPC0402-01 2 C16, C34 Ceramic Chip Capacitor 0402 10uF 6.3V
CAP-000077-01 CAPC0402-01 4 C22, C23, C24, C68 Ceramic Chip Capacitor 0402 0.1uF 50V
CAP-000083-01 CAPC0201-01 5 C117, C118, C119, C120, C121 Ceramic Chip Capacitor 0201 10nF 25V
CAP-000086-01 CAPC0805-01 1 C3 Ceramic Chip Capacitor 0805 22uF 25V
CAP-000090-01 CAPC0603-01 1 C65 Ceramic Chip Capacitor 0603 220nF 50V
CAP-000093-01 CAPC1206-01 1 C55 Ceramic Chip Capacitor 1206 1000pF 2KV
CAP-000095-01 CAPC0402-01 4 C41, C42, C43, C44 Ceramic Chip Capacitor 0402 0.01uF 100V
CAP-000097-01 CAPC0402-01 1 C72 Ceramic Chip Capacitor 0402 8.2nF 50V
CAP-000098-01 CAPC0402-01 1 C57 Ceramic Chip Capacitor 0402 680pF 50V
CAP-000099-01 CAPC0805-01 1 C67 Ceramic Chip Capacitor 0805 1nF 100V
CAP-000100-01 CAPC0603-01 1 C69 Ceramic Chip Capacitor 0603 330pF 200V
CAP-000101-01 CAPC0402-01 2 C70, C95 Ceramic Chip Capacitor 0402 22nF 50V
CAP-000102-01 CAPC1206-01 2 C58, C60 Ceramic Chip Capacitor 1206 1uF 100V
CAP-000103-01 CAPC0805-01 1 C66 Ceramic Chip Capacitor 0805 0.1uF 100V
CAP-000104-01 CAPEL_B 1 C61 Aluminum Capacitor 47uF 6.3V 4x5.8
CAP-000105-01 CAPEL_F 1 C59 Aluminum Capacitor 22uF 100V 8x10.2
CAP-000106-01 CAPC1210-01 1 C56 Ceramic Chip Capacitor 1210 2200pF 2KV
CAP-000107-01 CAPEL_B 1 C64 Aluminum Capacitor 10uF 25V 4x5.8
CAP-000114-01 CAPC0402-01 1 C99 Ceramic Chip Capacitor 0402 0.47uF 10V
CON-000036-01 SAMTEC_USB-A-S-F 1 J3 USB Type A 2.0 Jack
CON-000047-01 KEYSTONE_5015 8 TP1, TP2, TP3, TP4, TP5, TP6 Keystone SMT Test Point
TP7, TP8
CON-000049-01 KEYSTONE_3000 1 BAT1 Keystone CR1220 Battery Coin Cell holder
CON-000050-01 SAMTEC_SSW-106-02-F-D-RA-PMOD 1 J9 Samtec Female Header 0.1" pitch PMOD 2x6 Right Angle
CON-000080-01 FCI_20020110-C081 1 J10 FCI Terminal Block 3.5mm pitch 8pos Right Angle
CON-000107-01 OMRON_XF2W-4015 1 J5 Omron FPC/FFC Connector 40pos Pitch 0.5mm
CON-000116-01 FCI_10118192 1 J2 USB Micro 2.0 Female 5 Pin Right Angle
CON-000126-01 JST_SM02B-GHS 2 J7, J8 JST PH Connector 2 Position Right Angle 2mm Pitch
CON-000129-01 OMRON_XF2W-0815 1 J6 Omron FPC/FFC Connector 8pos Pitch 0.5mm
CON-000144-01 AMPHENOL_RJSSE-5381 1 J4 Amphenol RJ345 8pos SMT w/light pipes
CON-000145-01 MOLEX_503471-0200 1 J1 Molex Flexi-Mate Receptacle 2pos
CON-000148-01 SAMTEC_SSW-106-02-F-S-RA 1 J11 Samtec Female Header 0.1" pitch 6pos 1x6 Right Angle
CON-000153-01 HARWIN_M20-9960345 2 J13, J14 Header 0.1" pitch 3pos 1x3 Right Angle
CON-000172-01 SAMTEC_FTSH-110-01-X-DV-007-K 1 J12 20 Position Shrouded Header 1.27mm Pitch Pin #7 Removed
DIO-000011-01 SOT-23 1 D4 OnSemi Schottky Power Rectifier 40V 120mA
DIO-000014-01 SOT-23 1 D10 Dual switching diode 100V 200mA
DIO-000015-01 DIODES_POWERDI123 1 D3 Schottky Diode 30V 1A PowerDI 123
DIO-000018-01 SOD-323 1 D7 Diodes Schottky Switching 500mA 100V
DIO-000019-01 DO-221AC 1 D5 Diodes Schottky 5A 40V
DIO-000020-01 SMD_4P-MINI-DIP 2 D6, D9 Diodes Bridge Rectifier 100V 0.8A MiniDIP
DIO-000021-01 DIODES_SMA 1 D8 Diodes TVS 58V 1W
DIO-000022-01 SOT-23 1 D12 Dual Line CAN Bus Protector 350W
DIO-000027-01 DIODES_POWERDI123 2 D1, D2 Schottky Diode 30V 2A PowerDI 123
FAS-000020-01 PEM_SMTSO-M3-6 4 SO1, SO2, SO3, SO4 PEM SMT M3 6.0mm Standoff
FET-000001-01 SSOT-6 1 Q1 N-FET 150V 1.4A
ICN-000012-01 SOT-23 1 U2 Low power reset circuit
ICN-000017-01 SOT23-5 1 U5 22V High Current Boost White LED Driver
ICN-000022-01 TI_SOIC8 1 U21 Infineon CAN Transceiver 1MBaud
ICN-000072-01 TI_PVSON-N10 1 U6 TI Integrated USB Power switch with boost converter
ICN-000101-01 MICRON_WFBGA153 1 U22 Micron 2GByte eMMC 3v3
ICN-000108-01 INTERSIL_QFN40-6X6 1 U20 Intersil ISL41387 RS232/RS485 Transceiver
ICN-000121-01 SILABS_DFN2025-4 1 U8 SiLabs MEMS Oscillator 24.000MHz
ICN-000131-01 TI_DSE-PWSON-N6 1 U15 LDO Regulator 1.8V 200mA
ICN-000146-01 SILABS_DFN2025-4 1 U11 SiLabs MEMS Oscillator 50.000MHz
ICN-000148-01 INTERSIL_DFN8 1 U3 DC-DC Single Step Down 3.3V 1.5A
ICN-000149-01 MICREL_QFN55-32 1 U10 10/100Base-TX Ehternet PHY EEE
ICN-000150-01 TI_TSSOP14 1 U12 TI PoE Interface & Converter Controller
ICN-000152-01 SOT-23 1 D11 Low Voltage Adjustable Shunt Regulator
ICN-000153-01 QFN16-3X3 1 U19 Wolfson 1W Mono Speaker Driver
ICN-000154-01 NXP_DHVQFN-16 1 U16 Bidirectional Level Translator 6-bit
ICN-000155-01 SILABS_DFN2025-4 1 U17 SiLabs MEMS Oscillator 32.768KHz
ICN-000165-01 TI PDSO-N5 2 U7, U9 Two channel 30kV ESD Dual Protection
ICN-000168-01 MAXIM_TDFN-EP-14 1 U18 Maxim Microphone Preamp
ICN-000169-01 MICRON_VFBGA54 1 U23 Micron SDRAM 256M-Bit 16Mx16 3.3V
ICN-000189-01 AVAGO_ADPS-9005 1 U4 Avago ADPS-9005 Ambient Light Sensor
ICN-000198-01 RENESAS_FBGA224 1 U1 Renesas S7G2 240MHz 32-bit Cortex M4 MCU FBGA-224 WS2
IND-000005-01 FB_0805 1 FB2 Chip Ferrite Bead 0805 120 800mA 25%
IND-000007-01 BOURNS_SRN3015 2 L1, L3 Bourns Semishielded Power Inductor 2.2uH 1.8A
IND-000008-01 BOURNS_SRR5028 1 L2 Bourns Semishielded Power Inductor 22uH 2.2A
IND-000011-01 FB_0402 1 FB1 Chip Ferrite Bead 0402 600 300mA 25%
IND-000015-02 BOURNS_SM51108PEL 1 L4 Bourns Ethernet Transformer PoE 10/100
IND-000016-01 FB_0805 2 FB3, FB4 Chip Ferrite Bead 0805 15R0 1.5A
IND-000017-01 BOURNS_SRN4018 1 L5 Murata Semishielded Power Inductor 4.7uH 1.7A
IND-000018-01 PULSE_PA1283 1 T1 Pulse PoE Flyback Transformer 5V 7W
LED-000001-01 LED_DIALIGHT-598-8610 2 LED1, LED2 Dialight Bicolor LED Red/Green 1210
LED-000002-01 LED_0603-ORG 1 LED3 Avago LED Orange 0603
LED-000003-01 LED_0603-GRN 1 LED4 Avago LED Green 0603
OEM-000007-01 NETCOM_GT202 1 RF1 Netcom GT202 WiFi Module Ext Antenna
OEM-000011-01 PANASONIC_PAN132X 1 RF2 Panasonic PAN1326 Bluetooth Module
OPT-000001-01 OPTO_DIP4 2 U13, U14 Opto Coupler 80V 5KV DIP4
RES-000106-01 RESCAF0804 2 RA16, RA17 Chip Resistor Array 0804 100K0 5% 1/16W 4 x 0402
RES-000108-01 RESCAF0804 9 RA2, RA3, RA4, RA5, RA6, RA7 Chip Resistor Array 0804 4K70 5% 1/16W 4 x 0402
RA8, RA10, RA14
RES-000109-01 RESC0402-01 1 R5 Chip Resistor Thick Film 0402 1.1K 1% 1/16W
RES-000113-01 RESCAF0804 1 RA13 Chip Resistor Array 0804 470R 5% 1/16W 4 x 0402
RES-000118-01 RESCAF0804 2 RA9, RA15 Chip Resistor Array 0804 47K0 5% 1/16W 4 x 0402
RES-000123-01 RESC0402-01 1 R15 Chip Resistor Thick Film 0402 100R 0.5% 1/16W
RES-000124-01 RESC0402-01 2 R8, R11 Chip Resistor Thick Film 0402 470R 0.5% 1/16W
RES-000125-01 RESC0402-01 3 R4, R42, R47 Chip Resistor Thick Film 0402 1K00 0.5% 1/16W
RES-000127-01 RESC0402-01 2 R16, R75 Chip Resistor Thick Film 0402 4K70 0.5% 1/16W
RES-000133-01 RESC0402-01 2 R31, R32 Chip Resistor Thick Film 0402 49R9 1% 1/16W
RES-000135-01 RESC0402-01 1 R10 Chip Resistor Thick Film 0402 3K90 1% 1/16W
RES-000137-01 RESC0402-01 11 R9, R43, R52, R53, R55, R56 Chip Resistor Thick Film 0402 10K0 0.5% 1/16W
R60, R61, R62, R63, R64
RES-000139-01 RESC0402-01 11 R1, R3, R6, R14, R29, R50 Chip Resistor Thick Film 0402 100K0 0.5% 1/16W
R51, R54, R57, R65, R71
RES-000140-01 RESC0402-01 1 R12 Chip Resistor Thick Film 0402 1K50 0.5% 1/16W
RES-000141-01 RESC0402-01 9 R21, R22, R37, R39, R66, R67 Chip Resistor Thick Film 0402 0R00 1% 1/16W
R68, R69, R70
RES-000154-01 RESC0402-01 1 R7 Chip Resistor Thick Film 0402 1R87 1% 1/16W
RES-000156-01 RESC0402-01 1 R74 Chip Resistor Thick Film 0402 22R0 1% 1/10W
RES-000161-01 RESC0402-01 1 R28 Chip Resistor Thick Film 0402 6K49 1% 1/10W
RES-000164-01 RESCAF0804 2 RA11, RA12 Chip Resistor Array 0804 33R 5% 1/16W 4 x 0402
RES-000171-01 RESC0402-01 2 R18, R19 Chip Resistor Thick Film 0402 27R0 1% 1/10W
RES-000175-01 RESC0402-01 2 R23, R58 Chip Resistor Thick Film 0402 2K20 1% 1/10W
RES-000176-01 RESC0402-01 4 R24, R25, R26, R27 Chip Resistor Thick Film 0402 75 1% 1/10W
RES-000177-01 RESC0402-01 1 R2 Chip Resistor Thick Film 0402 453K 1% 1/10W
RES-000178-01 RESC1206-01 1 R38 Chip Resistor Thick Film 1206 0R56 1% 1/4W
RES-000179-01 RESC0402-01 1 R41 Chip Resistor Thick Film 0402 2K0 0.5% 1/16W
RES-000180-01 RESC0402-01 1 R44 Chip Resistor Thick Film 0402 41K2 1% 1/10W
RES-000181-01 RESC0402-01 1 R48 Chip Resistor Thick Film 0402 19K1 1% 1/10W
RES-000182-01 RESC0402-01 1 R49 Chip Resistor Thick Film 0402 13K3 1% 1/10W
RES-000184-01 RESC0402-01 1 R30 Chip Resistor Thick Film 0402 20R0 1% 1/10W
RES-000185-01 RESC0402-01 1 R40 Chip Resistor Thick Film 0402 499R 1% 1/10W
RES-000186-01 RESC0805-01 1 R36 Chip Resistor Thick Film 0805 82R0 5% 1/2W
RES-000187-01 RESC0603-01 1 R34 Chip Resistor Thick Film 0603 59K0 1% 1/10W
RES-000188-01 RESC0603-01 1 R35 Chip Resistor Thick Film 0603 80K6 1% 1/10W
RES-000189-01 RESC0603-01 1 R33 Chip Resistor Thick Film 0603 1K27 1% 1/10W
RES-000190-01 RESC1206-01 1 R45 Chip Resistor Thick Film 1206 13K7 1% 1/4W
RES-000191-01 RESC1206-01 1 R46 Chip Resistor Thick Film 1206 11K3 1% 1/4W
RES-000193-01 RESC0402-01 1 R59 Chip Resistor Thick Film 0402 143K0 1% 1/16W
RES-000199-01 RESC0805-01 2 R72, R73 Chip Resistor Thick Film 0805 10K0
RES-000200-01 RESC0402-01 1 R17 Chip Resistor Thick Film 0402 15K0 1% 1/10W
RES-000201-01 RESC0402-01 1 R20 Chip Resistor Thick Film 0402 30K0 1% 1/10W
RES-000203-01 RESC0402-01 1 R13 Chip Resistor Thick Film 0402 51K0 1% 1/10W
SPK-000009-01 BESTAR_BBASS 1 SPK1 BeStar B-Bass Sounder
SWT-000001-01 SW_C&K_KSC222J 1 S1 Sealed Push Button Switch 6.2 x 6.2mm 3.5mm High
SWT-000011-01 SW_CTS_219-5LPST 1 S3 SMD DIP Switch 5Position 2.54mm
XTL-000006-01 ABRACON_ABS07 1 X1 Crystal 32.769KHz 12.5pF SMT
[/hide] |
