查看: 2638|回复: 3
[Allegro16.6以下] Cyclone_V_E_FPGA_Development_Kit Cyclone V E FPGA 开发套件 原理图PCB
发表于 2018-12-10 05:45:42 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
06 Cyclone_V_E_FPGA_Development_Kit.zip (8.02 MB, 下载次数: 4)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUEREFDES
KEYSTONE_BT1_1060CONN, BATTERY HOLDERGOLD_KEYSTBattery HolderBT1
CAP_PACK_4_1206CAP, ARRAY0.1UF_CAP_PACK_4_1200.1uFCN1
CAP_PACK_4_1206CAP, ARRAY0.1UF_CAP_PACK_4_1200.1uFCN2
CAP_PACK_4_1206CAP, ARRAY0.1UF_CAP_PACK_4_1200.1uFCN3
LUMEX_LED0805LED, GREEN 0805LUMEX_LUMEX_LEDGreen_LEDD31
SOT23DIODE PACK 100V 200MAMMBD1205_MMBD1205D32
SOD323DIODE, SCHOTTKYCMDSH-3_SOD323_CMDSH-3D33
SOD323DIODE, SCHOTTKYCMDSH-3_SOD323_CMDSH-3D34
LUMEX_LED0805LED, BLUE 0805LUMEX_LUMEX_LED0BLUE LEDD35
SOD323DIODE, SCHOTTKYCMDSH-3_SOD323_CMDSH-3D36
SOD323DIODE, SCHOTTKYCMDSH-3_SOD323_CMDSH-3D37
SOD-123DIODE, SCHOTKKY1N6263W-7-F_SOD1N6263W-7-FD38
SOD-123DIODE, SCHOTKKY1N6263W-7-F_SOD1N6263W-7-FD39
SMA_LTI-SASF546-P26-X1CONN,SMA_SMA_LTI-SASF546-P26-XSMAJ1
SMA_LTI-SASF546-P26-X1CONN,SMA_SMA_LTI-SASF546-P26-XSMAJ2
SMA_LTI-SASF546-P26-X1CONN,SMA_SMA_LTI-SASF546-P26-XSMAJ3
MLX_SHROUD_VRT_HDR_10PINHDR 2X5,VERTICAL_MLX_SHROUD_VRHDR 2X5, VERTICALJ4
CONN_TSW_103_07_L_SHEADER,1X3-PIN_CONN_TSW_103_07HEADER, 1x3-PINJ5
HDR2X5_100MIL_SMTHEADER,2X5-PIN_HDR2X5_100MIL_SDNIJ6
SAMTEC_QSHDP120CUSTOMCONN,HSMC_MALE_SAMTEC_QSHDP120HSMCJ7
RJ45_ACONN RJ45 1-PORT TSEBASE-T_RJ47499111001AJ8
RJ45_ACONN RJ45 1-PORT TSEBASE-T_RJ47499111001AJ9
USB2_0-RACONN, USB TYPEB_USB2_0-RA_USBUSB Type BJ10
HDR2X5_100MIL_SMTHEADER,2X5-PIN_HDR2X5_100MIL_SDNIJ11
WURTH_DB9_9_FEMALECONN, DB9 FEMALERIGHT ANGLE_WUDSUB9 FEMALEJ12
USB2_H_FEMALE_TYPE-ACONN, USB HORIZONTAL,TYPE A_USUSB Type AJ13
HDR2X7_100MILHDR 2X7, VT, THM,TSW-107-07_HDHDR 2X7, VT, THM,TSW-107-07J14
HDR2X8_100MIL_SMTHEADER,2X8-PIN_HDR2X8_100MIL_S2X8J15
HDR2X8_100MIL_SMTHEADER,2X8-PIN_HDR2X8_100MIL_S2X8J16
RAPC712CONN, DC JACKRAPC712_RAPC712_CCONN JACK PWRJ17
MLX_22_23_2021_VRT_HDR_2PHDR 1X2, VT, THM,MOLEX, FAN_ML22_23_2021J18
806IND 10UH 245MA0.82OHM 0806 SMD10uHL1
IND_WURTH_744311470IND 2.2UH IR=9A 7040SMD _IND_W2.2uHL2
IND_WURTH_744311330IND 3.3UH ISAT=11A17.2MOHM_IND3.3uHL3
IND_WURTH_744314047IND 0.47UH IR=18AISAT=20A SMD_0.47uHL4
IND_0805IND FERRITE 08054A/33 OHMS_IND4A, 33 Ohm FBL5
IND_WURTH_744314047IND 0.47UH IR=18AISAT=20A SMD_0.47uHL6
IND_WURTH_744031100IND 10UH ISAT=560MA0.205OHM_IN10uHL7
IND_WURTH_74402500047IND 0.47UH IR=3.3ASMD_IND_WURT0.47uHL8
FDMC8878MOSFET N-CHANNEL,FDMC8878_FDMCFDMC8878Q1
SO8MOSFET N-CHANNEL HILOSI4816BDYSI4816BDYQ2
SO8MOSFET N-CHANNEL HILOSI4816BDYSI4816BDYQ3
SOT23MOSFET, N-CHANNEL,FDV305N_SOT2FDV305NQ4
PUSHBUTTON_EVQSWITCH, PUSHBUTTON_PUSHBUTTON_Switch, Push ButtonS1
PUSHBUTTON_EVQSWITCH, PUSHBUTTON_PUSHBUTTON_Switch, Push ButtonS2
PUSHBUTTON_EVQSWITCH, PUSHBUTTON_PUSHBUTTON_Switch, Push ButtonS3
PUSHBUTTON_EVQSWITCH, PUSHBUTTON_PUSHBUTTON_Switch, Push ButtonS4
PUSHBUTTON_EVQSWITCH, PUSHBUTTON_PUSHBUTTON_Switch, Push ButtonS5
PUSHBUTTON_EVQSWITCH, PUSHBUTTON_PUSHBUTTON_Switch, Push ButtonS6
PUSHBUTTON_EVQSWITCH, PUSHBUTTON_PUSHBUTTON_Switch, Push ButtonS7
PUSHBUTTON_EVQSWITCH, PUSHBUTTON_PUSHBUTTON_Switch, Push ButtonS8
DIPSWITCH_SMT_QUADSWITCH, DIP X4,TDA04H0SB1_DIPSSwitch, DIP x4,TDA04H0SB1SW1
DIPSWITCH_SMT_QUADSWITCH, DIP X4,TDA04H0SB1_DIPSSwitch, DIP x4,TDA04H0SB1SW2
DIPSWITCH_SMT_QUADSWITCH, DIP X4,TDA04H0SB1_DIPSSwitch, DIP x4,TDA04H0SB1SW3
DIPSWITCH_SMT_QUADSWITCH, DIP X4,TDA04H0SB1_DIPSSwitch, DIP x4,TDA04H0SB1SW4
EG2201ASWITCH, SLIDEEE2201A_EG2201A_SSwitch, SLIDE EE2201ASW5
FBGA8965CEFA7F31C7NES_F896_FBGA896_(S15CEFA7F31U1
SO16_WIDEEPCQ256_SO16_WIDE_EPCQ256EPCQ256U2
TSSOP20CLOCK BUFFER,ICS8543_TSSOP20_IICS8543U3
TDFN-10CLK BUFFER 1TO3LVCMOS SL18860_SL18860DCU4
MSOP10DUAL 10 OHM SPDT,TS5A23157_MSOTS5A23157U5
MSOP10DUAL 10 OHM SPDT,TS5A23157_MSOTS5A23157U6
MICRON_DDR3_96_8X14DDR3 SDRAM,MT41J128M16JT-125D_MT41J128M16JT-125U7
MICRON_DDR3_96_8X14DDR3 SDRAM,MT41J128M16JT-125D_MT41J128M16JT-125U8
WFBGA168LPDDR2,MT42L128M32D1LF-25WT_WFMT42L128M32D1LF-25WTU9
F64_10X8FLASH,PC28F512P30BF_F64_10X8_FFlash, PC28F512P30BFU10
TQFP100PSRAM,IS61VPS102418A-250TQL_TQFSRAM,IS61VPS102418A-250TQLU11
MSOP8EEPROM, 24AA64, MSOP,8-LEAD_MS24AA64-I/MSU12
F256MAX V,5M2210ZF256I5N_F256_MAXMAX V, 5M2210ZF256U13
BCC96ETHERNET PHY,88E1111_BCC96_ETHEthernet PHY, 88E1111U14
BCC96ETHERNET PHY,88E1111_BCC96_ETHEthernet PHY, 88E1111U15
F100MAX II,EPM570GF100I5N_F100_EPMEPM570GF100U16
SOT-143RESET,MAX811_SOT-143_RESET, MARESET, MAX811U17
VFBGA56USB MICROCONTROLLER,CY7C68013AUSB Microcontroller,CY7C68013AU18
DRTDIODE, ESDTPD2EUSB30_DRT_TPD2ETPD2EUSB30U19
SSOP16RS-232 TRANSCEIVER,LTC2803-1_SLTC2803-1U20
QFN24USB-TO-UART BRIDGE,CP2104_QFN2CP2104U21
DRY6_1MMX1P5MMDIODE, 4-CH ESD,TPD4S012DRYR_DDIODE, 4-Ch ESD,TPD4S012DRYRU22
DFN6_EPADDIODE CONTROLLER,LTC4357_DFN6_LTC4357U23
QFN40REG SWITCHING,LTC3855_QFN40_LTLTC3855EUH-1U24
QFN52_3EPADREG SWITCHING,LTC3608_QFN52_3ELTC3608U25
QFN52_3EPADREG SWITCHING,LTC3608_QFN52_3ELTC3608U26
DFM10-EPADREGULATOR,LTC3103_DFM10-EPAD_LLTC3103U27
DFN12_EPAD_3X3REG SWITCHING,LTC3600EDD_DFN12LTC3600U28
DFN6-2X2_EPADREGULATOR,LTC3025-1_DFN6-2X2_ELTC3025-1U29
DFN6-2X2_EPADREGULATOR,LT3009EDC_DFN6-2X2_ELT3009xDCU30
DFM10-EPADREGULATOR,LTC3026_EDD_DFM10-EPLTC3026U31
DFM10-EPADREGULATOR,LTC3026_EDD_DFM10-EPLTC3026U32
PSOP-DGQ10REGULATOR,TPS51100DGQ_PSOP-DGQTPS51100DGQU33
DFN6-2X2_EPADREGULATOR,LT3009EDC_DFN6-2X2_ELT3009xDCU34
SSOP28_NARADC, LTC241816-CH_SSOP28_NAR_AADC, LTC2418 16-ChU35
TSSOP14LEVEL SHIFTER,MAX3378_TSSOP14_Level Shifter,MAX3378U36
SENSESENSEPAD_SENSE_SENSE_PADSENSE_PADV49
XTAL_SI570XO, I2C PROGRAMMABLE2.5V SI570Si570X1
SMY3X5_4PXO, 50MHZ CMOS,3.2X5MM, SI510_Si510 - 50MHzX2
SMY3X5_4POSC, 100MHZ 2.5V X1CMOS, SI510Si510 - 100MHzX3
XTAL_SG310OSC, 25MHZ2.5V_XTAL_SG310_25.025.00MHzX4
XTAL_SG310OSC, 25MHZ2.5V_XTAL_SG310_25.025.00MHzX5
XTAL_FA-128OSC, CRYSTAL 24MHZMINI XTL_XTA24MHzY1
重要提示:PCB作品文件展下载说明
    昨天 13:10
  • 签到天数: 26 天
    发表于 2020-10-2 19:52:16 | 显示全部楼层
    5 天前
  • 签到天数: 114 天
    发表于 2020-10-3 09:44:42 | 显示全部楼层
    还不错,下载学习一下
    发表于 2020-10-4 13:11:51 | 显示全部楼层
