查看: 5919|回复: 23
[Allegro16.6以下] Audio_Video_Development_Kit,_Stratix_IV_GX_Edition 开发板原理图PCB
发表于 2018-12-10 08:26:35 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
46 Audio_Video_ Development_Kit,_Stratix_IV_GX_Edition.zip (9.28 MB, 下载次数: 8)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUEREFDES
CAP_PACK_4_1206CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uFCN1
CAP_PACK_4_1206CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uFCN2
CAP_PACK_4_1206CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uFCN3
LUMEX_LED1206LED_LUMEX_LED1206_GREENLEDGREEN LEDD1
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD26
LUMEX_LED1206LED_LUMEX_LED1206_RED_LEDRed_LEDD27
SOD323ZENERDIODE_SOD323_CMDSH2_3CMDSH2_3D28
SOD323ZENERDIODE_SOD323_CMDSH2_3CMDSH2_3D29
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD30
SMB403A_03ZENERDIODE_SMB403A_03_20VZENER20V ZenerD31
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD32
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD33
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD34
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD35
SMB403A_03ZENERDIODE_SMB403A_03_20VZENER20V ZenerD36
LUMEX_LED1206LED_LUMEX_LED1206_YELLOWLEDYELLOW LEDD37
LUMEX_LED1206LED_LUMEX_LED1206_YELLOWLEDYELLOW LEDD38
LUMEX_LED1206LED_LUMEX_LED1206_YELLOWLEDYELLOW LEDD39
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD40
SMB403A_03ZC2800E/SOT_0_SMB403A_03_MBRS13MBRS130LD41
SMB403A_03ZC2800E/SOT_0_SMB403A_03_MBRS13MBRS130LD42
IR-DPAK12CWQ03FN_IR-DPAK_12CWQ03FN12CWQ03FND43
DFN12_EPADLTC4352CDD_DFN12_EPAD_LTC4352CDLTC4352CDDD44
DFN12_EPADLTC4352CDD_DFN12_EPAD_LTC4352CDLTC4352CDDD45
SMB403A_03ZENERDIODE_SMB403A_03_20VZENER20V ZenerD46
SAMTEC_QSHDP120CUSTOMQSH_HSM_SAMTEC_QSHDP120CUSTOM_AASP-122953-01J1
SAMTEC_QSHDP120CUSTOMQSH_HSM_SAMTEC_QSHDP120CUSTOM_AASP-122953-01J2
SMB_RA_JACK_RECEPBNC_VERTICAL_4POST_SMB_RA_JACK_SMBJ3
RAPC712CONN JACKPWR_3_RAPC712_CONN JACONN JACK PWRJ4
SMB_RA_JACK_RECEPBNC_VERTICAL_4POST_SMB_RA_JACK_SMBJ5
RJ45HFJ11-1G02E_RJ45_HFJ11-1G02EHFJ11-1G02EJ6
USB2_0-RAUSB_CON_USB2_0-RA_USBCONUSB CONJ7
CONN_39_26_710870247-1051_CONN_39_26_7108_702470247-1051J8
SMA_LTI-SASF546-P26-X1SMA_LTI_SASF54GT_0_SMA_LTI-SASFLTI-SASF546-P26-X1J9
MLX_22_23_2021_VRT_HDR_2PCON2_MLX_22_23_2021_MLX_22_23_222_23_2021J10
HDMI-19PINHDMI-19-PIN-CON_0_HDMI-19PIN_HDHDMI-19-01-F-SMJ11
SMA_LTI-SASF546-P26-X1SMA_SMA_LTI-SASF546-P26-X1_LTI-LTI-SASF546-P26-X1J12
SMA_LTI-SASF546-P26-X1SMA_SMA_LTI-SASF546-P26-X1_LTI-LTI-SASF546-P26-X1J13
SMA_LTI-SASF546-P26-X1SMA_LTI_SASF54GT_0_SMA_LTI-SASFLTI-SASF546-P26-X1J14
SMA_LTI-SASF546-P26-X1SMA_LTI_SASF54GT_0_SMA_LTI-SASFLTI-SASF546-P26-X1J15
HDR2X7_100MILHDR2X7_HDR2X7_100MIL_HDR2X7HDR2X7J16
PCIX-8PORTPCIE_BRACKET_X8_PCIX-8PORT_PCIEPCIE_SlotJ17
HDR2X5_100MIL_SMT2X5_HDR2X5_100MIL_SMT_DNIDNIJ18
IND_TDK_RLF12545INDUCTOR_IND_TDK_RLF12545_5.6UH5.6uHL1
IND_TDK_VLF10045INDUCTOR_IND_TDK_VLF10045_3.3UH3.3uHL2
603BEAD_FERRITE_SM_0603_120OHM FB120 Ohm FBL3
IND_0805BEAD_FERRITE_SM_IND_0805_BLM21PBLM21PG331SN1L4
402INDUCTOR_0402_3.9NH3.9nHL5
402INDUCTOR_0402_5.6NH5.6nHL6
402INDUCTOR_0402_5.6NH5.6nHL7
IND_0805BEAD_FERRITE_SM_IND_0805_BLM21PBLM21PG331SN1L8
IND_0805BEAD_FERRITE_SM_IND_0805_BLM21PBLM21PG331SN1L9
603BEAD_FERRITE_SM_0603_120OHM FB120 Ohm FBL10
603BEAD_FERRITE_SM_0603_120OHM FB120 Ohm FBL11
SOT23PWRMOSFET_EN_GSD_0_SOT23_FDV305FDV305NQ1
RES_PACK_8RES_PACK_8_RES_PACK_8_10K10KRN1
RES_PACK_8RES_PACK_8_RES_PACK_8_10K10KRN2
RES_PACK_8RES_PACK_8_RES_PACK_8_5656RN3
RES_PACK_8RES_PACK_8_RES_PACK_8_5656RN4
RES_PACK_8RES_PACK_8_RES_PACK_8_5656RN5
PUSHBUTTON_EVQEVQPAC07K_PUSHBUTTON_EVQ_PBSWITPBSwitchS1
PUSHBUTTON_EVQEVQPAC07K_PUSHBUTTON_EVQ_PBSWITPBSwitchS2
PUSHBUTTON_EVQEVQPAC07K_PUSHBUTTON_EVQ_PBSWITPBSwitchS3
PUSHBUTTON_EVQEVQPAC07K_PUSHBUTTON_EVQ_PBSWITPBSwitchS4
PUSHBUTTON_EVQEVQPAC07K_PUSHBUTTON_EVQ_PBSWITPBSwitchS5
EG4208ASWSLIDE-4P2T_1_EG4208A_SW SLIDSW SLIDE-4P2TSW1
SW_ROTARY_94HSW_ROTARY_SW_ROTARY_94H_94HCB1694HCB16WTSW2
DIPSWITCH_SMT_OCTAL76SB08_DIPSWITCH_SMT_OCTAL_TDA0TDA08H0SB1SW3
DIPSWITCH_SMT_OCTAL76SB08_DIPSWITCH_SMT_OCTAL_TDA0TDA08H0SB1SW4
DIPSWITCH_SMT_QUADSPST4_DIPSWITCH_SMT_QUAD_TDA04HTDA04H0SB1SW5
DIPSWITCH_SMT_QUADSPST4_DIPSWITCH_SMT_QUAD_TDA04HTDA04H0SB1SW6
TP_060SQ040T_POINT_R_TP_060SQ040_DNIDNITP1
TP_060SQ040T_POINT_R_TP_060SQ040_DNIDNITP2
SSOP28_NARLTC2418_SSOP28_NAR_LTC2418LTC2418U1
LLP16_EPADLMH0344_LLP16_EPAD_LMH0344LMH0344U2
M100EPM240M100_M100_EPM240M100EPM240M100U3
LLP16_EPADGS1578_LLP16_EPAD_LMH0302SQLMH0302SQU4
DDR3_96_SPECMT41J64M16_DDR3_DDR3_96_SPEC_MTMT41J64M16LAU5
DFN6-2X2_EPADLTC3025-1_DFN6-2X2_EPAD_LTC3025LTC3025-1U6
BB165ACY7C2563KV18_BB165A_CY7C2563KV1CY7C2563KV18U7
LGA118LTM4601_LGA118_LTM4601LTM4601U8
DFM10-EPADLTC4151_DFM10-EPAD_LTC4151LTC4151U9
DFN6-2X2_EPADLTC3025-1_DFN6-2X2_EPAD_LTC3025LTC3025-1U10
LGA35LTM8201EV_LGA35_LTM8201EVLTM8201EVU11
DDR3_96_SPECMT41J64M16_DDR3_DDR3_96_SPEC_MTMT41J64M16LAU12
F1517EP4SGX230KF40_F1517_F1517_(S1+SEP4SGX230KF40_F1517U13
DDR3_96_SPECMT41J64M16_DDR3_DDR3_96_SPEC_MTMT41J64M16LAU14
DFN6_EPADLTC4357_DFN6_EPAD_LTC4357LTC4357U15
FDMC8878FDMC8878_FDMC8878_FDMC8878FDMC8878U16
LGA144LTM4614_LGA144_LTM4614LTM4614U17
DDR3_96_SPECMT41J64M16_DDR3_DDR3_96_SPEC_MTMT41J64M16LAU18
DFN6_EPADLTC4357_DFN6_EPAD_LTC4357LTC4357U19
FDMC8878FDMC8878_FDMC8878_FDMC8878FDMC8878U20
BCC9688E1111_BCC96_88E111188E1111U21
BB165ACY7C2563KV18_BB165A_CY7C2563KV1CY7C2563KV18U22
SOT23-DBVSN65220DBV_SOT23-DBV_SN65220DBVSN65220DBVU23
DDR3_96_SPECMT41J64M16_DDR3_DDR3_96_SPEC_MTMT41J64M16LAU24
M76AD9889B_M76_AD9889BAD9889BU25
LGA118LTM4601_LGA118_LTM4601LTM4601U26
QSOP16MAX1619_5_QSOP16_MAX1619MAX1619U27
TSSOP14MAX3378_0_TSSOP14_MAX3378MAX3378U28
TSSOP14MAX3378_0_TSSOP14_MAX3378MAX3378U29
F165IS61VPS51236A_F165_IS61VPS51236IS61VPS51236AU30
F256EPM2210GF256_F256_(S1+S2),(S3+SEPM2210_F256FBGAU31
F64_10X13PC28FXXXP30B85_F64_10X13_PC48F4PC48F4400P0ZBQ0U32
SO8IRF7455PBF_SO8_IRF7455PBFIRF7455PbFU33
SO8IRF7455PBF_SO8_IRF7455PBFIRF7455PbFU34
QFN32LTC3727_QFN32_LTC3727LTC3727U35
SSOP28_NARLTC2418_SSOP28_NAR_LTC2418LTC2418U36
SO8IRF7455PBF_SO8_IRF7455PBFIRF7455PbFU37
SO8IRF7455PBF_SO8_IRF7455PBFIRF7455PbFU38
MSOP8-EPADLT3010_1_MSOP8-EPAD_LT3010LT3010U39
LQFP-32FT245BL_LQFP-32_FT245BLFT245BLU40
DFN8_EPADLT3080-1_DFN8_EPAD_LT3080-1/1.1LT3080-1/1.1A LDOU41
SO8AT93C46-10_SO8_AT93C46DN-SH-BAT93C46DN-SH-BU42
FDMC8878FDMC8878_FDMC8878_FDMC8878FDMC8878U43
DFN8_EPADLT3080-1_DFN8_EPAD_LT3080-1/1.1LT3080-1/1.1A LDOU44
DFN6-2X2_EPADLTC3025-1_DFN6-2X2_EPAD_LTC3025LTC3025-1U45
DFN8_EPADLT3080-1_DFN8_EPAD_LT3080-1/1.1LT3080-1/1.1A LDOU46
FDMC8878FDMC8878_FDMC8878_FDMC8878FDMC8878U47
DFN6-2X2_EPADLTC3025-1_DFN6-2X2_EPAD_LTC3025LTC3025-1U48
DFN6-2X2_EPADLTC3025-1_DFN6-2X2_EPAD_LTC3025LTC3025-1U49
DFN6-2X2_EPADLTC3025-1_DFN6-2X2_EPAD_LTC3025LTC3025-1U50
LGA118LTM4601_LGA118_LTM4601LTM4601U51
PSOP-DGQ10TPS51100_PSOP-DGQ10_TPS51100DGQTPS51100DGQU52
TSSOP20ICS8543_TSSOP20_ICS8543ICS8543U53
UTQFN10ISL54050_UTQFN10_ISL54050ISL54050U54
QFN16NB6L11S_QFN16_NB6L11SMNGNB6L11SMNGU55
TSSOP14ADG3304_TSSOP14_ADG3304ADG3304U56
MSOP8-EPADLT3010_1_MSOP8-EPAD_LT3010LT3010U57
UTQFN10ISL54050_UTQFN10_ISL54050ISL54050U58
XTAL_EG2100635L3C3_XTAL_EG2100_125.0MHZ125.0MHzX1
XTAL_EG2100635L3C3_XTAL_EG2100_156.25MHZ156.25MHzX2
CON-WIN_XTAL_VCXOCW_VCXO_CON-WIN_XTAL_VCXO_148.5148.5MHzX3
XTAL_SG310OSC_ALT_XTAL_SG310_24MHZ24MHzX4
XTAL_SG310OSC_ALT_XTAL_SG310_25.00MHZ25.00MHzX5
XTAL_SI570SI570_0_XTAL_SI570_100MHZ100MHzX6
XTAL_EG2100635L3C3_XTAL_EG2100_155.52MHZ155.52MHzX7
XTAL_XG-1000CBOSC_ALT_XTAL_XG-1000CB_50MHZ50MHzX8
XTAL_XG-1000CBOSC_ALT_XTAL_XG-1000CB_125MHZ125MHzX9
XTAL_HC49CRYSTAL_XTAL_HC49_6.000MHZ6.000MHzY1
重要提示:PCB作品文件展下载说明
发表于 2018-12-10 08:29:18 | 显示全部楼层
PADS-181217初级班
发表于 2018-12-10 08:46:47 | 显示全部楼层
    11 小时前
  • 签到天数: 61 天
    社区居民终身成就奖特殊贡献奖优秀斑竹奖
    发表于 2018-12-10 08:48:05 | 显示全部楼层
    发表于 2018-12-10 08:49:15 | 显示全部楼层
    11 小时前
  • 签到天数: 217 天
    发表于 2018-12-10 08:58:42 | 显示全部楼层
    11 小时前
  • 签到天数: 171 天
    发表于 2018-12-10 09:12:02 | 显示全部楼层
    终身成就奖社区居民忠实会员社区劳模最爱沙发优秀斑竹奖
    发表于 2018-12-10 10:43:40 | 显示全部楼层
  • 签到天数: 9 天
    发表于 2019-6-28 18:41:46 | 显示全部楼层
    发表于 2019-7-23 18:55:23 | 显示全部楼层
    正在学仿真,随书案例就是这个,有用
