查看: 3827|回复: 3
[Allegro16.6以下] IMX6SOLOX_SABRESDB面向智能设备,基于i.MX 6SoloX应用处理器的SAB
终身成就奖原创先锋奖特殊贡献奖优秀斑竹奖金点子奖
发表于 2018-12-10 16:04:19 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
BT1BATTERY_SKT_3V_SKT_BATT_4X8_IC_2994TRSKT_BATT_4X8
CON1CONN_HDR_4X1_HDR104_IO_10.29MM_HDR 1X4HDR104
D2ZDIODE_SOD_523_1P4_IC_0.7MM_480MM5Z5V1ST1GSOD_523_1P4
D3DIODE_SCHTKY_SOD_523_IC_0.7MM_4RB521S30T1GSOD_523
D7LED_DUAL_SEP_RG_LED_DUAL_3025MMLED_RED-GRNLED_DUAL_3025MM_SM
D8DIODE_SCHTKY_SOD_523_IC_0.7MM_4RB521S30T1GSOD_523
D11LED_LED_0603_IC_1.1MM_370-75145LED_ORANGELED_0603
D12LED_LED_0603_IC_1.1MM_370-75145LED_ORANGELED_0603
D13LED_LED_0603_IC_1.1MM_370-75145LED_ORANGELED_0603
D14LED_LED_0603_IC_0.8MM_370-75077LED_GREENLED_0603
D15LED_LED_0603_IC_0.8MM_370-75076LED_YELLOWLED_0603
D16LED_DUAL_SEP_RG_LED_DUAL_3025MMLED_RED-GRNLED_DUAL_3025MM_SM
D17LED_DUAL_SEP_RG_LED_DUAL_3025MMLED_RED-GRNLED_DUAL_3025MM_SM
D18DIODE_SCHTKY_SOD_523_IC_0.7MM_4RB521S30T1GSOD_523
D19DIODE_SCHTKY_SOD_523_IC_0.7MM_4RB521S30T1GSOD_523
D22DIODE_SCHTKY_SOD323_2P4_1P8X1P4B0520WSSOD323_2P4_1P8X1P4
D23DIODE_SCHTKY_SOD123LF_IC_1.0MMMBR140SFTSOD123LF
D24LED_LED_0603_IC_0.8MM_370-75077LED_GREENLED_0603
D25DIODE_SCHTKY_SOD_523_IC_0.7MM_4RB521S30T1GSOD_523
D26DIODE_SCHTKY_SOD_523_IC_0.7MM_4RB521S30T1GSOD_523
D27DZ_DUAL_CK_C1C2A_SOT-723_IC_0.5ESD7C5.0DT5GSOT-723
D28DZ_DUAL_CK_C1C2A_SOT-723_IC_0.5ESD7C5.0DT5GSOT-723
H1SPACER_SPACER_139T_IC_16.13MM_2.635" LONGSPACER_139T
H2SPACER_SPACER_139T_IC_16.13MM_2.635" LONGSPACER_139T
H3SPACER_SPACER_139T_IC_16.13MM_2.635" LONGSPACER_139T
H4SPACER_SPACER_139T_IC_16.13MM_2.635" LONGSPACER_139T
J1DC_POWER_JACK_3_RAPC722_IO_11.0CON_1_PWRRAPC722
J2CONN_HDR_2X1_HDR102_IO_8.39MM_2HDR 1X2HDR102
J3CONN_SDCARD_DUAL_15P_CON19_SDCACONN CRD 19CON19_SDCARD_DUAL_SM_NSP
J4CONN_SDCARD_DUAL_15P_CON19_SDCACONN CRD 19CON19_SDCARD_DUAL_SM_NSP
J5CONN_SDCARD_DUAL_15P_CON19_SDCACONN CRD 19CON19_SDCARD_DUAL_SM_NSP
J6USB_A_CON_USBA_4F_TH_RA_14P8X14USB_TYPE_A_FEMALECON_USBA_4F_TH_RA_14P8X14P4
J7USB_MINI_AB_RECEPTACLE_CON5_MICMICRO USB AB 5CON5_MICROUSB
J8CONN_UMC_3P_M_CON3_VER_SMT_IO_1128-0711-20CON3_VER_SMT
J9CONN_UMC_3P_M_CON3_VER_SMT_IO_1128-0711-20CON3_VER_SMT
J103.5MM_AUDIO_JACK_CON5_AUD_JACK_Audio JackCON5_AUD_JACK_RA_TH_SJ-43514
J11QSH060_CON_120S_QSH_SM_05PITCH_QSH-060-01-L-D-ACON_120S_QSH_SM_05PITCH
J12CON30_DF19G-30P-1H_CON_DF_30F_1CON 30CON_DF_30F_1MM_SM_RA
J13FX12B-40P_CON_BBC_40P_0P4_SM_MICONN PLUG 40CON_BBC_40P_0P4_SM_MIRROR
J14CONN_SIM_6P_CON_SIMCARD_6P_100_CON 6 SIM CARDCON_SIMCARD_6P_100_SM
J15MINI_PCI_LATCH_52P_CON_2X26_0P8CON 2X26 MINI PCIEXPRESSCON_2X26_0P8_SMT_NSP
J16USB_MINI_AB_RECEPTACLE_CON5_MICMICRO USB AB 5CON5_MICROUSB
J17TSW-110-05-G-D_HDR210_TST_RA_IOTST-110-05-T-D-RAHDR210_TST_RA
J19CON20_1_CON20_FH28_SM_IO_5.4MM_CON FPC/FFC 20CON20_FH28_SM
J20HEADER5X2_HDR2X5_2P54_SMD_IO_9.HDR_2X5HDR2X5_2P54_SMD
J22CONN_HDR_2X1_HDR102_IO_8.39MM_2HDR 1X2HDR102
JP1JUMPER1X2_100MIL_TH_IO_4MM_210-SHORT_100mil100MIL_TH
L1INDUCTOR_FERRITE_IND0603_CC_DIS470 OhmIND0603_CC
L2INDUCTOR_FERRITE_IND0603_CC_DIS470 OhmIND0603_CC
L3DLW43_IND4_CHOKE_0805_DISCRETE_90OHMIND4_CHOKE_0805
L4DLW43_IND4_CHOKE_0805_DISCRETE_90OHMIND4_CHOKE_0805
L5IND_IND_1608_DISCRETE_0.95MM_18100 OHM@100MHZIND_1608
L6IND_IND_1608_DISCRETE_0.95MM_18100 OHM@100MHZIND_1608
L7DLW43_IND4_CHOKE_0805_DISCRETE_90OHMIND4_CHOKE_0805
L8DLW43_IND4_CHOKE_0805_DISCRETE_90OHMIND4_CHOKE_0805
L9DLW43_IND4_CHOKE_0805_DISCRETE_90OHMIND4_CHOKE_0805
L10DLW43_IND4_CHOKE_0805_DISCRETE_90OHMIND4_CHOKE_0805
L11BEAD_0_0603_CC_DISCRETE_0.95MM_120OHM0603_CC
L12BEAD_0_0603_CC_DISCRETE_0.95MM_120OHM0603_CC
L13BEAD_0_0603_CC_DISCRETE_0.95MM_120OHM0603_CC
L14INDUCTOR_FERRITE_IND0603_CC_DIS470 OhmIND0603_CC
L15INDUCTOR_IND_VLS3012_SM_DISCRET4.7UHIND_VLS3012_SM
L16BEAD_0_0603_CC_DISCRETE_0.95MM_120OHM0603_CC
L17INDUCTOR_FERRITE_IND0603_CC_DIS470 OhmIND0603_CC
L18INDUCTOR_IND_VLS3012_SM_DISCRET4.7UHIND_VLS3012_SM
L19BEAD_0_0603_CC_DISCRETE_0.95MM_120OHM0603_CC
L20DLW43_IND4_CHOKE_0805_DISCRETE_90OHMIND4_CHOKE_0805
L21INDUCTOR_IND2_6_8P3X8P3_DISCRET4.7uHIND2_6_8P3X8P3
L22BEAD_0_0603_CC_DISCRETE_0.95MM_120OHM0603_CC
L23BEAD_0_0603_CC_DISCRETE_0.95MM_120OHM0603_CC
L24IND_IND2_VLP6045_DISCRETE_4.5MVLP6045LT-1R0NIND2_VLP6045
L26INDUCTOR_IND2_LTF5022_DISCRETE_1.2uHIND2_LTF5022
L27INDUCTOR_IND_VLS252010_DISCRETE1UHIND_VLS252010
L29INDUCTOR_IND_VLS3012_SM_DISCR_11UHIND_VLS3012_SM
L30INDUCTOR_IND_VLS252010_DISCRETE1UHIND_VLS252010
L31INDUCTOR_IND_COILCRAFT_3X3MM_DI2.2UHIND_COILCRAFT_3X3MM
L32BEAD_0_0603_CC_DISCRETE_0.95MM_120OHM0603_CC
L35DLW43_IND4_CHOKE_0805_DISCRETE_90OHMIND4_CHOKE_0805
L36INDUCTOR_FERRITE_IND0603_CC_DIS470 OhmIND0603_CC
L37INDUCTOR_FERRITE_IND0603_CC_DIS470 OhmIND0603_CC
L38INDUCTOR_FERRITE_IND0603_CC_DIS470 OhmIND0603_CC
L39INDUCTOR_FERRITE_IND0603_CC_DIS470 OhmIND0603_CC
L40DATA_CHOKE_IND_1812_4P_DISCRETE100 uHIND_1812_4P
L41DATA_CHOKE_IND_1812_4P_DISCRETE100 uHIND_1812_4P
L42BEAD_0_0603_CC_DISCRETE_0.95MM_120OHM0603_CC
L43BEAD_0_0603_CC_DISCRETE_0.95MM_120OHM0603_CC
P1MIC_POM_MIC_WM-63PR_IC_2.7MM_5POM-2244P-C3310-2-RMIC_WM-63PR
P2DSD9M_DUALDB-9MM_IO_29.21MM_21DDB9_MDUALDB-9MM
P3RJ45_MAG_2X1_LED_CON_RJ45_2X1_MRJ45 13X2PORTSCON_RJ45_2X1_MAG_LED
Q1FDMA530PZ_MLP6_2X2MM_SLUG_IC_0.FDMA530PZMLP6_2X2MM_SLUG
Q2PNP_SC_75_IC_0.9MM_480-78465_MMMBT3906TT1GSC_75
Q3DUAL_NPN_SOT363_IC_1.1MM_480-76MBT3904DW1T1SOT363
Q6NTA4151PT_SC_75_IC_0.9MM_480-7NTA4151PT1GSC_75
Q72N7002_SOT23_IC_1.3MM_480-751592N7002SOT23
Q8MOSFET_P_SOT-23_IC_1.12MM_480-7IRLML6401SOT-23
Q11NPN_SOT_523_IC_0.9MM_480-78457MMBT3904TSOT_523
Q12MOSFET_P_SOT-23_IC_1.12MM_480-7IRLML6401SOT-23
Q132N7002_SOT23_IC_1.3MM_480-751592N7002SOT23
Q14MOSFET_P_SOT-23_IC_1.12MM_480-7IRLML6401SOT-23
Q15NPN_SOT_523_IC_0.9MM_480-78457MMBT3904TSOT_523
S1SW_DIP-2_DIP-SMT2_IC_4.83MM_51SW_DIP-2/SMDIP-SMT2
SH6RES_SHORT-2_SH0805_40_DISCRET_1SOLDER SHORTSH0805_40
SH7RES_SHORT-2_SH0805_40_DISCRETE_SOLDER SHORTSH0805_40
SH8RES_SHORT-2_SH0805_40_DISCRETE_SOLDER SHORTSH0805_40
SH9RES_SHORT-2_SH0805_40_DISCRETE_SOLDER SHORTSH0805_40
SH10RES_SHORT-2_SH0805_40_DISCRETE_SOLDER SHORTSH0805_40
SW1SW_DPDT_3_SW6_DPDT_11X6MM_IC_9.EG2209ASW6_DPDT_11X6MM
SW2SW_PB_ESW_SW4_PB_ESW_SM_P177_ICSPST PBSW4_PB_ESW_SM_P177
SW3SW_PB_ESW_SW4_PB_ESW_SM_P177_ICSPST PBSW4_PB_ESW_SM_P177
SW4SW_PB_ESW_SW4_PB_ESW_SM_P177_ICSPST PBSW4_PB_ESW_SM_P177
SW5SW_PB_ESW_SW4_PB_ESW_SM_P177_ICSPST PBSW4_PB_ESW_SM_P177
SW10SW_DIP_8_SW_DIP16_8POS_SM_IC_2.SW DIP-8SW_DIP16_8POS_SM
SW11SW_DIP_8_SW_DIP16_8POS_SM_IC_2.SW DIP-8SW_DIP16_8POS_SM
SW12SW_DIP_8_SW_DIP16_8POS_SM_IC_2.SW DIP-8SW_DIP16_8POS_SM
TVS5DIODE_TVS_BIDIR_DIODE2_SOD523_IESD5B5.0ST1GDIODE2_SOD523
U1IMX6SX_19X19_529P_PBGA529_0P8MMPCIMX6X4EVM10ABPBGA529_0P8MM
U24G_DDR3_SDRAM_256MX16_96P_BGA96MT41K256M16HA-125:EBGA96_0P8_9P15X14P15
U34G_DDR3_SDRAM_256MX16_96P_BGA96MT41K256M16HA-125:EBGA96_0P8_9P15X14P15
U4MTFC4GMVEA_WFBGA_153P_FBGA153_0MTFC8GLCDMFBGA153_0P5_11P5X13
U5ONE_AND_SC70-5_A_IC_1.1MM_312-7NC7SZ08P5XSC70-5_A
U7N25Q128A13EF840E_9P_MLP8_1P27_8N25Q256A13EF840MLP8_1P27_8X6
U825LC320A_8P_SO8_1P27_4X5_IC_1.725LC320A-I/SNSO8_1P27_4X5
U9N25Q128A13EF840E_9P_MLP8_1P27_8N25Q256A13EF840MLP8_1P27_8X6
U12MIC2526_8P_SO8_IC_1.73MM_312-75MIC2026-1YMSO8
U13WM8962_BGA_49P_CUST_BGA49_0P5_3WM8962BECSN/RBGA49_0P5_3P62X4
U15MC33901WEF-8P_SO8_1P27_4X5_IC_1MC34901WEFSO8_1P27_4X5
U17MC33901WEF-8P_SO8_1P27_4X5_IC_1MC34901WEFSO8_1P27_4X5
U18AR8031_QFN48_QFN48_0P4_6X6MM_EPAR8031QFN48_0P4_6X6MM_EPAD
U19AR8031_QFN48_QFN48_0P4_6X6MM_EPAR8031QFN48_0P4_6X6MM_EPAD
U20NLSV2T244_8P_UDFN8_0P4_1P8X1P2MNLSV2T244MUTAGUDFN8_0P4_1P8X1P2MM
U22FT2232D_LQFP48_IC_1.60MM_312-77FT2232DLQFP48
U23SN74LVC2G126DCTR_SSOP8_IC_1.30SN74LVC2G126SSOP8
U24SN74LVC2G126DCTR_SSOP8_IC_1.30SN74LVC2G126SSOP8
U25ISL29023_DFN_6_0P65_2P1X2_IC_0.ISL29023DFN_6_0P65_2P1X2
U26MMA8451Q_16P_A_QFN5X3_0P5_3X3_IMMA8451QQFN5X3_0P5_3X3
U27MAG3112_DFN_10P_DFN_10_0P4_2X2_MAG3110DFN_10_0P4_2X2_A
U28MP2119DQ_QFN10_0P5_3X3_A_IC_1MMP28115DQ-LFQFN10_0P5_3X3_A
U29MMPF0200NPAEP_QFN_56P_QFN56_0P5MMPF0200F6AEPQFN56_0P5_8X8_EP4P1X4P4
U30NCP1593_DFN10_DFN_10_0P5_3X3_ICNCP1593AMNTWGDFN_10_0P5_3X3
U34NCP692_6P_DFN6_0P95_3X3_IC_1MM_NCP692MN33T2GDFN6_0P95_3X3
U3574-244A_20P_TSSOP20_IC_1.1MM_3174LVC244APWTSSOP20
U3674-244A_20P_TSSOP20_IC_1.1MM_3174LVC244APWTSSOP20
U3774-244A_20P_TSSOP20_IC_1.1MM_3174LVC244APWTSSOP20
U382G125_MSO8_MO-187_IC_1.3MM_312-SN74LVC2G125MSO8_MO-187
U391G126_SC70-5_IC_1.1MM_312-79761NC7SP126SC70-5
U409FGV0241AKLF_24P_QFN24_0P5_4X4_9FGV0241AKLFQFN24_0P5_4X4_EP2P2
U41STM6779_6P_SOT23-6_IC_1.45MM_31STM6779YWB6FSOT23-6
U42MIC5205YM5_5P_SOT23-20X60-5_IC_MIC5205SOT23-20X60-5
X1CRYSTAL13_XTAL4_3P35X2P65_IC_0.25MHzXTAL4_3P35X2P65
X2CRYSTAL13_XTAL4_3P35X2P65_IC_0.25MHzXTAL4_3P35X2P65
X3XTAL_CS_XTAL3_4P5X2_SM_IC_1.2MM6 MHZXTAL3_4P5X2_SM
Y1CRYSTAL_JXS63_XTLOSC4_3P2X2P5MM24MHZXTLOSC4_3P2X2P5MM_SM
Y2XTAL_XTAL2-3P2X1P5-SM_IC_0.65MM32.768kHzXTAL2-3P2X1P5-SM
Y4CRYSTAL_JXS63_XTAL4_SX_3225_IC_25MHzXTAL4_SX_3225
重要提示:PCB作品文件展下载说明
 楼主| 发表于 2018-12-10 16:06:41 | 显示全部楼层
SCH-27962.DSN.rar (446 KB, 下载次数: 7) LAY-27962_C.brd.rar (3.07 MB, 下载次数: 7)
    前天 09:35
    1元学习PADS(3期)
    发表于 2018-12-11 08:44:40 | 显示全部楼层
    发表于 2022-3-1 12:52:37 | 显示全部楼层
