查看: 3142|回复: 6
[Allegro17.4以下] 采用BCM20737A1KML2G设计的BCM92073X_LE_TAG4 Evaluation and Debug Kit原理
PADS-180606高级班
社区居民终身成就奖特殊贡献奖优秀斑竹奖
发表于 2018-12-11 10:05:09 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
4层Pins(522)
游客,如果您要查看本帖隐藏内容请回复
Bill of Material ReportSYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_TOLCOMP_CLASSREFDESTRACEINV_F_ANTENNA_1_TRACE_INV_F_ANTENNAINV_F_ANTENNA ICA1CAPC1608_IS0603QCAP_CAPC1608_IS0603Q_DISCRETE_0.9000 MM_4.7UF4.7uF DISCRETEC1CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.6350 MM_0.1UF0.1uF DISCRETEC2CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.6350 MM_0.1UF0.1uF DISCRETEC3CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.6350 MM_0.1UF0.1uF DISCRETEC4CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.6350 MM_0.1UF0.1uF DISCRETEC5CAPC2012_IS0805QCAP_CAPC2012_IS0805Q_DISCRETE_1.4500 MM_47UF47uF DISCRETEC6CAPC2012_IS0805QCAP_CAPC2012_IS0805Q_DISCRETE_1.4500 MM_47UF47uF DISCRETEC7CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.5500 MM_2.2UF2.2uF DISCRETEC8CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.5500 MM_1UF1uF DISCRETEC9CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.5500 MM_0.01UF0.01uF DISCRETEC10CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.5500 MM_10PF10pF DISCRETEC11CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.5500 MM_0.01UF0.01uF DISCRETEC12CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.5500 MM_0.01UF0.01uF DISCRETEC13CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.5500 MM_1.8PF1.8pF DISCRETEC14CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.5500 MM_1.8PF1.8pF DISCRETEC15CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.5500 MM_1.8PF (DNI)1.8pF (DNI) DISCRETEC16CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.5500 MM_1.8PF (DNI)1.8pF (DNI) DISCRETEC17CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.6100 MM_15PF15pF DISCRETEC18CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.6100 MM_15PF15pF DISCRETEC19CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.5500 MM_12PF12pF DISCRETEC20CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.5500 MM_12PF12pF DISCRETEC21CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.5500 MM_150PF150pF DISCRETEC22CAPC1608_IS0603QCAP_CAPC1608_IS0603Q_DISCRETE_0.9000 MM_4.7UF4.7uF DISCRETEC23CAPC1608_IS0603QCAP_CAPC1608_IS0603Q_DISCRETE_1.0000 MM_10UF10uF DISCRETEC24CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.7000 MM_10UF10uF DISCRETEC25CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.5500 MM_0.1UF0.1uF DISCRETEC26CAPC1608_IS0603QCAP_CAPC1608_IS0603Q_DISCRETE_0.9500 MM_4.7UF4.7uF DISCRETEC28CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.6350 MM_0.1UF0.1uF DISCRETEC29CAPC2012_IS0805QCAP_CAPC2012_IS0805Q_DISCRETE_1.4500 MM_22UF22uF DISCRETEC30CAPC2012_IS0805QCAP_CAPC2012_IS0805Q_DISCRETE_1.4500 MM_22UF22uF DISCRETEC31CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.7000 MM_10UF10uF DISCRETEC34CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.6350 MM_0.1UF0.1uF DISCRETEC37CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.5500 MM_0.1UF0.1uF DISCRETEC54CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.6350 MM_0.1UF0.1uF DISCRETEC58CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.6350 MM_0.1UF0.1uF DISCRETEC59CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.6500 MM_4.7UF4.7uF DISCRETEC60CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.6350 MM_0.1UF0.1uF DISCRETEC61CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.6350 MM_0.1UF0.1uF DISCRETEC62CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.6350 MM_0.1UF0.1uF DISCRETEC63CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.6350 MM_0.1UF0.1uF DISCRETEC64CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.5500 MM_1UF1uF DISCRETEC66CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.6350 MM_0.1UF0.1uF DISCRETEC68CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.6350 MM_0.1UF0.1uF DISCRETEC69LEDC1608QDIO-LED_LEDC1608Q_0.9000 MM_LTST-C190CKTLTST-C190CKT ICD1LEDS4_KING_APTB1615QLED-DUAL-RED1-GRN2_LEDS4_KING_APTB1615Q_DISCRETE_0.9000MM_APTB1615SURKCGKC-F01APTB1615SURKCGKC-F01 DISCRETED3FUSC1005_IS0402QDIO-TVS-BIPOLAR-2_FUSC1005_IS0402Q_DISCRETE_0.6000 MM_10V10V DISCRETED4FUSC1005_IS0402QDIO-TVS-BIPOLAR-2_FUSC1005_IS0402Q_DISCRETE_0.6000 MM_10V10V DISCRETED5FUSC1005_IS0402QDIO-TVS-BIPOLAR-2_FUSC1005_IS0402Q_DISCRETE_0.6000 MM_10V10V DISCRETED6FUSC1005_IS0402QDIO-TVS-BIPOLAR-2_FUSC1005_IS0402Q_DISCRETE_0.6000 MM_10V10V DISCRETED7INDC1005_IS0402QFB_INDC1005_IS0402Q_DISCRETE_0.6000 MM_120OHMS120Ohms DISCRETEFB1INDC1005_IS0402QFB_INDC1005_IS0402Q_DISCRETE_0.6000 MM_120OHMS120Ohms DISCRETEFB2INDC1005_IS0402QFB_INDC1005_IS0402Q_DISCRETE_0.6000 MM_600OHMS600Ohms DISCRETEFB3IPX_20279-001E-01RF-2GND-J_IPX_20279-001E-01_IO_1.2450 MM_20279-001E-0420279-001E-04 IOJ1CTST254PSS4PLG-4-J_CTST254PSS4_IO_8.8900 MM_PBC04SAANPBC04SAAN IOJ2TYCO_1981568-1USB-5P-6SH-J_TYCO_1981568-1_IO_2.5100 MM_1981568-11981568-1 IOJ7CTST254PSS4PLG-4-J_CTST254PSS4_IO_8.8900 MM_PBC04SAANPBC04SAAN IOJ8CTST254PSS4PLG-4-J_CTST254PSS4_IO_8.8900 MM_PBC04SAANPBC04SAAN IOJ9CTST254PDS18PLG-18-ODD-EVEN-J_CTST254PDS18_IO_8.8900 MM_S-M-.100-2X9S-M-.100-2X9 IOJ10CTST254PDS18PLG-18-ODD-EVEN-J_CTST254PDS18_IO_8.8900 MM_S-M-.100-2X9 (DNI)S-M-.100-2X9 (DNI) IOJ11CTST254PSS2HDR1X2-J_CTST254PSS2_IO_8.8900 MM_PBC02SAANPBC02SAAN IOJ12CTST254PDS18PLG-18-ODD-EVEN-J_CTST254PDS18_IO_8.8900 MM_S-M-.100-2X9 (DNI)S-M-.100-2X9 (DNI) IOJ13INDS2_TDK_VLS201610CXQIND-SHIELDED-NO-DOT_INDS2_TDK_VLS201610CXQ_DISCRETE_1.0000MM_10UH10uH DISCRETEL1INDS2_MUR_LQM21NQIND_INDS2_MUR_LQM21NQ_DISCRETE_1.4500 MM_4.7UH4.7uH DISCRETEL2SPKRS2_MUR_PKLCS1212QSPEAKER_SPKRS2_MUR_PKLCS1212Q_IO_3.0000 MM_PKLCS1212E4001-R1PKLCS1212E4001-R1 IOLS1SOT23_B_E_CNPN_SOT23_B_E_C_DISCRETE_1.5600 MM_2SC2712-Y,LF2SC2712-Y,LF DISCRETEQ1SOT883_SC-101_B_E_CPNP_SOT883_SC-101_B_E_C_DISCRETE_0.5000 MM_PBSS3540MPBSS3540M DISCRETEQ3RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_10K10K DISCRETER1RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_00 DISCRETER2RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_00 DISCRETER3RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_00 DISCRETER4RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_00 DISCRETER5RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_1K1K DISCRETER6RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_1K1K DISCRETER7RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_10K10K DISCRETER8RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_00 DISCRETER9RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_100K100K DISCRETER10RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_470470 DISCRETER11RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_10K (DNI)10K (DNI) DISCRETER12RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_00 DISCRETER13RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_5.6K5.6K DISCRETER14RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_10K10K DISCRETER15RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_10K10K DISCRETER16RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_10K10K DISCRETER17RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_4.7K4.7K DISCRETER18RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_4.7K4.7K DISCRETER19RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_200200 DISCRETER22RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_10K10K DISCRETER23INDC1005_IS0402QIND-DOT-1_INDC1005_IS0402Q_DISCRETE_0.3500 MM_2.7NH2.7nH DISCRETER24RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_00 DISCRETER25RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_0 (DNI)0 (DNI) DISCRETER26RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_0 (DNI)0 (DNI) DISCRETER27RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_10M10M DISCRETER28RESC1608_IS0603QRES_RESC1608_IS0603Q_DISCRETE_0.6000 MM_00 DISCRETER29RESC1005_IS0402Q_OPT_ABRES-OPT-B-A_RESC1005_IS0402Q_OPT_AB_DISCRETE_0.4000 MM_10K10K DISCRETER30RESC1005_IS0402Q_OPT_ABRES-OPT-A-B_RESC1005_IS0402Q_OPT_AB_DISCRETE_0.4000 MM_10K10K DISCRETER31RESC1005_IS0402Q_OPT_ABRES-OPT-B-A_RESC1005_IS0402Q_OPT_AB_DISCRETE_0.4000 MM_10K10K DISCRETER32RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_00 DISCRETER39RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_4.7K4.7K DISCRETER40RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_4.7K4.7K DISCRETER41RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_00 DISCRETER50RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_00 DISCRETER51RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_00 DISCRETER59RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_200 (DNI)200 (DNI) DISCRETER60RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_200 (DNI)200 (DNI) DISCRETER61RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_0 (DNI)0 (DNI) DISCRETER62RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_10K10K DISCRETER63RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_10K10K DISCRETER64RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_10K10K DISCRETER65RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_10K (DNI)10K (DNI) DISCRETER66RESC1005_IS0402Q_OPT_ABRES-OPT-B-A_RESC1005_IS0402Q_OPT_AB_DISCRETE_0.4000 MM_00 DISCRETERD5RESC1005_IS0402Q_OPT_ABRES-OPT-B-A_RESC1005_IS0402Q_OPT_AB_DISCRETE_0.4000 MM_00 DISCRETERD6RESC1005_IS0402Q_OPT_ABRES-OPT-A-B_RESC1005_IS0402Q_OPT_AB_DISCRETE_0.4000 MM_00 DISCRETERD7RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_360K360K DISCRETERFB1RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_240K240K DISCRETERFB2SWPBS4_CK_KMR2XXGSWITCH-PB-13-24_SWPBS4_CK_KMR2XXG_DISCRETE_2.1000 MM_KMR221GLFSKMR221GLFS DISCRETESW1SWPBS4_CK_KMR2XXGSWITCH-PB-13-24_SWPBS4_CK_KMR2XXG_DISCRETE_2.1000 MM_KMR221GLFSKMR221GLFS DISCRETESW2SWPBS4_CK_KMR2XXGSWITCH-PB-13-24_SWPBS4_CK_KMR2XXG_DISCRETE_2.1000 MM_KMR221GLFSKMR221GLFS DISCRETESW3SWSLS3_ALPS_SSSS811101SWITCH-SPDT-CP2NC3NO1-4SHLD_SWSLS3_ALPS_SSSS811101_DISCRETE_1.4000MM_SSSS811101SSSS811101 DISCRETESW4SWSLS3_ALPS_SSSS811101SWITCH-SPDT-CP2NC3NO1-4SHLD_SWSLS3_ALPS_SSSS811101_DISCRETE_1.4000MM_SSSS811101SSSS811101 DISCRETESW5SWDPS8_OMRON_A6H-4102SW-DIP-4_SWDPS8_OMRON_A6H-4102_DISCRETE_1.9500 MM_A6H-4101A6H-4101 DISCRETESW6SWDPS16_ITT_TDA08H0SK1SW-DIP-8_SWDPS16_ITT_TDA08H0SK1_DISCRETE_2.3000 MM_TDA08H0SB1TDA08H0SB1 DISCRETESW8SWDPS8_OMRON_A6H-4102SW-DIP-4_SWDPS8_OMRON_A6H-4102_DISCRETE_1.9500 MM_A6H-4101A6H-4101 DISCRETESW9TP_SMD_030RDTP_TP_SMD_030RD_IO__TP-SMT-030-RNDTP-SMT-030-RND IOTP5TP_SMD_030RDTP_TP_SMD_030RD_IO__TP-SMT-030-RNDTP-SMT-030-RND IOTP6TP_SMD_030RDTP_TP_SMD_030RD_IO__TP-SMT-030-RNDTP-SMT-030-RND IOTP7TP_SMD_030RDTP_TP_SMD_030RD_IO__TP-SMT-030-RNDTP-SMT-030-RND IOTP8TP_SMD_030RDTP_TP_SMD_030RD_IO__TP-SMT-030-RNDTP-SMT-030-RND IOTP9TP_SMD_030RDTP_TP_SMD_030RD_IO__TP-SMT-030-RNDTP-SMT-030-RND IOTP11TP_SMD_030RDTP_TP_SMD_030RD_IO__TP-SMT-030-RNDTP-SMT-030-RND IOTP12TP_SMD_030RDTP_TP_SMD_030RD_IO__TP-SMT-030-RNDTP-SMT-030-RND IOTP13TP_SMD_030RDTP_TP_SMD_030RD_IO__TP-SMT-030-RNDTP-SMT-030-RND IOTP14TSOP65P640_8_D300N24XX512-DIL8_TSOP65P640_8_D300N_IC_1.2000 MM_24FC512-I/ST24FC512-I/ST ICU1QFN50P500X500_32_HS370_BCMBCM20736A1KML2G-W1000-27301_QFN50P500X500_32_HS370_BCM_IC_1.0000MM_BCM20737A1KML2GBCM20737A1KML2G ICU2SOIC127P600_8_D490NMX25U4033E-DIL8_SOIC127P600_8_D490N_IC_1.7500MM_MX25U4033EM1I-12GMX25U4033EM1I-12G ICU3SON55P200X180_6_USP-6ELQXC9265-DFN6H_SON55P200X180_6_USP-6ELQ_IC_0.4000MM_XC9265B1214R-GXC9265B1214R-G ICU4SON50P200X180_6_USP-6CQXC9236-ADJ-DFN6H_SON50P200X180_6_USP-6CQ_IC_0.6100 MM_XC9236_ADJXC9236_ADJ ICU5QFN50P400X400_24_HS280NUSB-CP2105-QFN24H_QFN50P400X400_24_HS280N_IC_0.8000MM_CP2105-F01-GMCP2105-F01-GM ICU6MODS6_ST_HLGA-6LNHTS221-LGA6_MODS6_ST_HLGA-6LN_IC_1.0000 MM_HTS221HTS221 ICU8QFN50P160X160_8_MAC08AQVOLT-XLATOR-FXM2IC102_QFN50P160X160_8_MAC08AQ_IC_0.5590MM_FXM2IC102FXM2IC102 ICU9QFN60P250X250_10_ST-LGA-10LNLPS25HB-LGA10_QFN60P250X250_10_ST-LGA-10LN_IC_0.8000MM_LPS25HBTRLPS25HBTR ICU10LGA50P300X250_14_ST-LGA14NLSM6DS3-LGA14_LGA50P300X250_14_ST-LGA14N_IC_0.8600 MM_LSM6DS3LSM6DS3 ICU15QFN50P200X200_12_ST_LGA-12QLIS3MDL-LGA12_QFN50P200X200_12_ST_LGA-12Q_IC_1.0000 MM_LIS3MDLTRLIS3MDLTR ICU16XTALS4_3M2X2M5XTAL-1G3G_XTALS4_3M2X2M5_DISCRETE_0.9000 MM_24.000MHZ24.000MHz DISCRETEY1XTALS2_ABR_ABS07QXTAL_XTALS2_ABR_ABS07Q_DISCRETE_0.9000 MM_0.03277MHZ0.03277MHz DISCRETEY2BATHS3_KEY_3002QBATTERY-HOLDER-P2N1_BATHS3_KEY_3002Q_DISCRETE_4.2100 MM_3002TR3002TR DISCRETEZB1
重要提示:PCB作品文件展下载说明
生活就是油盐酱醋再加一点糖,快活就是一天到晚乐呵呵的忙!
    昨天 09:33
  • 签到天数: 150 天
    4万
    终身成就奖特殊贡献奖社区居民忠实会员社区劳模最爱沙发社区明星优秀斑竹奖宣传大使奖
    发表于 2018-12-11 10:45:10 | 显示全部楼层
    社区居民忠实会员终身成就奖特殊贡献奖优秀斑竹奖
    发表于 2018-12-11 10:48:39 | 显示全部楼层
    社区居民忠实会员社区劳模原创达人最爱沙发终身成就奖特殊贡献奖原创先锋奖优秀斑竹奖
    发表于 2018-12-11 20:08:09 | 显示全部楼层
    5 天前
  • 签到天数: 114 天
    发表于 2018-12-11 21:52:19 | 显示全部楼层
    是博通公司的作品吗?
    头像被屏蔽
    禁止发言
    发表于 2019-11-14 17:09:16 | 显示全部楼层
    提示: 作者被禁止或删除 内容自动屏蔽
    社区居民终身成就奖特殊贡献奖
    发表于 2024-5-13 13:24:59 | 显示全部楼层
