Bill of Material ReportSYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_TOL | COMP_CLASS | REFDES |
CAPC2012X140N | CAP_CAPC2012X140N_DISCRETE_10 U | 10 uF | | DISCRETE | C1 |
CAPC1608X55N | CAP_CAPC1608X55N_DISCRETE_1.0 U | 1.0 uF | | DISCRETE | C2 |
CAPC1608X55N | CAP_CAPC1608X55N_DISCRETE_1.0 U | 1.0 uF | | DISCRETE | C3 |
CAPC1608X55N | CAP_CAPC1608X55N_DISCRETE_1.0 U | 1.0 uF | | DISCRETE | C4 |
CAPC1608X55N | CAP_CAPC1608X55N_DISCRETE_1.0 U | 1.0 uF | | DISCRETE | C5 |
CAPC1608X55N | CAP_CAPC1608X55N_DISCRETE_1.0 U | 1.0 uF | | DISCRETE | C6 |
CAPC1608X55N | CAP_CAPC1608X55N_DISCRETE_1.0 U | 1.0 uF | | DISCRETE | C7 |
CAPC2012X100N | CAP_CAPC2012X100N_DISCRETE_1.0 | 1.0 uF | | DISCRETE | C8 |
CAPC1608X55N | CAP_CAPC1608X55N_DISCRETE_0.1 U | 0.1 uF | | DISCRETE | C9 |
CAPC3225X160N | CAP_CAPC3225X160N_DISCRETE_22 U | 22 uF | | DISCRETE | C10 |
CAPC2012X100N | CAP_CAPC2012X100N_DISCRETE_1.0 | 1.0 uF | | DISCRETE | C11 |
CAPC3225X160N | CAP_CAPC3225X160N_DISCRETE_22 U | 22 uF | | DISCRETE | C12 |
CAPC2012X140N | CAP_CAPC2012X140N_DISCRETE_10 U | 10 uF | | DISCRETE | C14 |
CAPC1005X55N | CAP_CAPC1005X55N_DISCRETE_0.1 U | 0.1 uF | | DISCRETE | C15 |
CAPC1005X55N | CAP_CAPC1005X55N_DISCRETE_0.1 U | 0.1 uF | | DISCRETE | C16 |
CAPC1005X55N | CAP_CAPC1005X55N_DISCRETE_0.1 U | 0.1 uF | | DISCRETE | C17 |
CAPC1608X55N | CAP_CAPC1608X55N_DISCRETE_2200 | 2200 pF | | DISCRETE | C18 |
CAPC1608X55N | CAP_CAPC1608X55N_DISCRETE_22 PF | 22 pF | | DISCRETE | C19 |
CAPC1608X55N | CAP_CAPC1608X55N_DISCRETE_22 PF | 22 pF | | DISCRETE | C20 |
CAPC1005X55N | CAP_CAPC1005X55N_DISCRETE_0.1 U | 0.1 uF | | DISCRETE | C21 |
CAPC1005X55N | CAP_CAPC1005X55N_DISCRETE_0.1 U | 0.1 uF | | DISCRETE | C22 |
CAPC1005X55N | CAP_CAPC1005X55N_DISCRETE_0.1 U | 0.1 uF | | DISCRETE | C23 |
CAPC1005X55N | CAP_CAPC1005X55N_DISCRETE_0.1 U | 0.1 uF | | DISCRETE | C24 |
CAPC1608X55N | CAP_CAPC1608X55N_DISCRETE_0.1 U | 0.1 uF | | DISCRETE | C25 |
CAPC1608X55N | CAP_CAPC1608X55N_DISCRETE_NO LO | NO LOAD | | DISCRETE | C26 |
CAPC1608X55N | CAP_CAPC1608X55N_DISCRETE_NO LO | NO LOAD | | DISCRETE | C27 |
CAPC1608X55N | CAP_CAPC1608X55N_DISCRETE_1.0 U | 1.0 uF | | DISCRETE | C28 |
CAPC1005X55N | CAP_CAPC1005X55N_DISCRETE_0.1 U | 0.1 uF | | DISCRETE | C29 |
SOT-23-3 | DIODE_SCHOTTKY_21_SOT-23-3_DISC | ZHCS1000TA | | DISCRETE | D1 |
HDR16X2-0P05 | HDR_2X16_SHRD_HDR16X2-0P05_HEAD | Header 2x16 | | IC | J1 |
HDR16X2-0P05 | HDR_2X16_SHRD_HDR16X2-0P05_HEAD | Header 2x16 | | IC | J2 |
HDR16X2-0P05 | HDR_2X16_SHRD_HDR16X2-0P05_HEAD | Header 2x16 | | IC | J3 |
HDR16X2-0P05 | HDR_2X16_SHRD_HDR16X2-0P05_HEAD | Header 2x16 | | IC | J4 |
FTSH-105-XX-X-DV-K | HDR_2X5_FTSH-105-XX-X-DV-K_IO_H | Header Keyed 50mil SMD | | IO | J5 |
FTSH-105-XX-X-DV-K | HDR_2X5_FTSH-105-XX-X-DV-K_IO_H | Header Keyed 50mil SMD | | IO | J6 |
L-IND-SLF7032 | IND_L-IND-SLF7032_22 UH_L-IND-S | 22 uH | | IC | L1 |
RESC2012X70N | RES_RESC2012X70N_DISCRETE_NO LO | NO LOAD | | DISCRETE | R6 |
RESC2012X70N | RES_RESC2012X70N_DISCRETE_NO LO | NO LOAD | | DISCRETE | R7 |
RESC1608X50AN | RES_RESC1608X50AN_DISCRETE_27 O | 27 Ohms | | DISCRETE | R8 |
RESC1608X50AN | RES_RESC1608X50AN_DISCRETE_27 O | 27 Ohms | | DISCRETE | R9 |
RESC1608X50AN | RES_RESC1608X50AN_DISCRETE_NO L | NO LOAD | | DISCRETE | R10 |
RESC2012X70N | RES_RESC2012X70N_DISCRETE_NO LO | NO LOAD | | DISCRETE | R14 |
RESC2012X70N | RES_RESC2012X70N_DISCRETE_NO LO | NO LOAD | | DISCRETE | R15 |
RESC2012X70N | RES_RESC2012X70N_DISCRETE_NO LO | NO LOAD | | DISCRETE | R16 |
RESC2012X70N | RES_RESC2012X70N_DISCRETE_NO LO | NO LOAD | | DISCRETE | R17 |
RESC1608X50AN | RES_RESC1608X50AN_DISCRETE_ZERO | ZERO | | DISCRETE | R31 |
RESC1608X50AN | RES_RESC1608X50AN_DISCRETE_ZERO | ZERO | | DISCRETE | R32 |
RESC1608X50AN | RES_RESC1608X50AN_DISCRETE_NO L | NO LOAD | | DISCRETE | R34 |
RESC1608X50AN | RES_RESC1608X50AN_DISCRETE_NO L | NO LOAD | | DISCRETE | R35 |
RESC1608X50AN | RES_RESC1608X50AN_DISCRETE_ZERO | ZERO | | DISCRETE | R36 |
RESC1608X50AN | RES_RESC1608X50AN_DISCRETE_NO L | NO LOAD | | DISCRETE | R37 |
RESC1608X50AN | RES_RESC1608X50AN_DISCRETE_ZERO | ZERO | | DISCRETE | R38 |
RESC1608X50AN | RES_RESC1608X50AN_DISCRETE_ZERO | ZERO | | DISCRETE | R39 |
RESC1608X50AN | RES_RESC1608X50AN_DISCRETE_ZERO | ZERO | | DISCRETE | R40 |
RESC1608X50AN | RES_RESC1608X50AN_DISCRETE_ZERO | ZERO | | DISCRETE | R41 |
RESC1608X50AN | RES_RESC1608X50AN_DISCRETE_ZERO | ZERO | | DISCRETE | R42 |
RESC1608X50AN | RES_RESC1608X50AN_DISCRETE_NO L | NO LOAD | | DISCRETE | R43 |
RESC2012X70N | RES_RESC2012X70N_DISCRETE_0_RES | 0 | | DISCRETE | R44 |
RESC1608X50AN | RES_RESC1608X50AN_DISCRETE_ZERO | ZERO | | DISCRETE | R45 |
RESC1608X50AN | RES_RESC1608X50AN_DISCRETE_ZERO | ZERO | | DISCRETE | R46 |
RESC1608X50AN | RES_RESC1608X50AN_DISCRETE_ZERO | ZERO | | DISCRETE | R47 |
RESC1608X50AN | RES_RESC1608X50AN_DISCRETE_ZERO | ZERO | | DISCRETE | R48 |
RESC1608X50AN | RES_RESC1608X50AN_DISCRETE_ZERO | ZERO | | DISCRETE | R49 |
TP_43_65 | TEST_POINT_TP_43_65_IO_RED | RED | | IO | TP1 |
TP_43_65 | TEST_POINT_TP_43_65_IO_BLACK | BLACK | | IO | TP2 |
TP_43_65 | TEST_POINT_TP_43_65_IO_RED | RED | | IO | TP3 |
TP_43_65 | TEST_POINT_TP_43_65_IO_RED | RED | | IO | TP4 |
TP_43_65 | TEST_POINT_TP_43_65_IO_RED | RED | | IO | TP5 |
TP_43_65 | TEST_POINT_TP_43_65_IO_RED | RED | | IO | TP6 |
TP_43_65 | TEST_POINT_TP_43_65_IO_RED | RED | | IO | TP7 |
TP_43_65 | TEST_POINT_TP_43_65_IO_RED | RED | | IO | TP8 |
TP_43_65 | TEST_POINT_TP_43_65_IO_BLACK | BLACK | | IO | TP9 |
TP_43_65 | TEST_POINT_TP_43_65_IO_WHITE | WHITE | | IO | TP10 |
TQFPA100 | CY8C55XX_100P_ALT_TQFPA100_IC_C | CY8C5588AXI-060 | | IC | U1 |
Y-XTAL-CFS308-SMT | CRYSTAL12_G_Y-XTAL-CFS308-SMT_D | 32kHz XTAL | | DISCRETE | Y1 |
HC49SMD | HC49SMD | MHz Crystal NO LOAD | | DISCRETE | Y2 |
