查看: 3121|回复: 8
[Allegro17.4以下] 采用CY8C24894+CYRF6936设计的CY3271-FTRF原理图与PCB文件
PADS-180606高级班
社区居民终身成就奖特殊贡献奖优秀斑竹奖
发表于 2018-12-11 12:49:13 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
4层Pins(405)
游客,如果您要查看本帖隐藏内容请回复
Bill of Material ReportSYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_TOLCOMP_CLASSREFDESANT_RUFA_W32PCB-RANTENNA W_0_ANT_RUFA_W32PCB-R_AAntennova Rufa ICANT1C0402_1MMPITCH27 PFD 0402 NPO_0_C0402_1MMPITC27 pF ICC1C0402_1MMPITCH0_0.1 UFD 0402 X5R_C0402_1MMPIT0.1 uFd ICC2C0402_1MMPITCH2_0.0 PFD 0402 A NPO_C0402_1MMP2.0 pFd ICC3C0402_1MMPITCHNO LOAD CAP 0402 A_0_C0402_1MMP1.2pF ICC4C0402_1MMPITCH0_0.1 UFD 0402 X5R_C0402_1MMPIT0.1 uFd ICC5C0402_1MMPITCH27 PFD 0402 NPO_0_C0402_1MMPI_30.1uF ICC6C0402_1MMPITCH0_0.047 UFD 0402 A X5R_C0402_1M0.047 uFd ICC8C0402_1MMPITCH0_0.047 UFD 0402 A X5R_C0402_1M0.047 uFd ICC9C0402_1MMPITCH0_0.047 UFD 0402 A X5R_C0402_1M0.047 uFd ICC10C0402_1MMPITCH0_0.047 UFD 0402 A X5R_C0402_1M0.047 uFd ICC11C0402_1MMPITCH0_0.47 UFD 0402 A X5R_C0402_1MM0.47 uFd ICC12C0402_1MMPITCH0_0.047 UFD 0402 A X5R_C0402_1M0.047 uFd ICC13C0402_1MMPITCH0_0.047 UFD 0402 A X5R_C0402_1M0.047 uFd ICC14C0402_1MMPITCH27 PFD 0402 NPO_0_C0402_1MMPI_118 pF ICC15C0402_1MMPITCH27 PFD 0402 NPO_0_C0402_1MMPI_118 pF ICC16C0402_1MMPITCH2_0.0 PFD 0402 A NPO_C0402_1MMP2.0 pFd ICC17C0402_1MMPITCH27 PFD 0402 NPO_0_C0402_1MMPITC27 pF ICC22C0402_1MMPITCH27 PFD 0402 NPO_0_C0402_1MMPI_210 pF ICC23C0402_1MMPITCH2_0.0 PFD 0402 A NPO_C0402_1MMP2.0 pFd ICC24C0402_1MMPITCH27 PFD 0402 NPO_0_C0402_1MMPITC27 pF ICC25C0402_1MMPITCH27 PFD 0402 NPO_0_C0402_1MMPI_30.1uF ICC26C0402_1MMPITCH27 PFD 0402 NPO_0_C0402_1MMPI_30.1uF ICC27C0402_1MMPITCH27 PFD 0402 NPO_0_C0402_1MMPI_30.1uF ICC28C0402_1MMPITCH27 PFD 0402 NPO_0_C0402_1MMPI_30.1uF ICC29C0402_1MMPITCH27 PFD 0402 NPO_0_C0402_1MMPITC27 pF ICC30C0402_1MMPITCH27 PFD 0402 NPO_0_C0402_1MMPI_118 pF ICC31C0402_1MMPITCH27 PFD 0402 NPO_0_C0402_1MMPI_118 pF ICC32C0402_1MMPITCH27 PFD 0402 NPO_0_C0402_1MMPI_118 pF ICC33C0402_1MMPITCH27 PFD 0402 NPO_0_C0402_1MMPI_30.1uF ICC34C0402_1MMPITCH27 PFD 0402 NPO_0_C0402_1MMPI_30.1uF ICC35C0402_1MMPITCH27 PFD 0402 NPO_0_C0402_1MMPI_30.1uF ICC36C0402_1MMPITCH0_0.47 UFD 0402 A X5R_C0402_1MM0.47 uFd ICC3906030_0.1 UFD 0603 X7R_0603_0.1 UFD0.1 uFd ICC4006030_0.1 UFD 0603 X7R_0603_0.1 UFD0.1 uFd ICC4106030_0.01 UFD 0603 X7R_0603_0.01 U0.01 uFd ICC4308052.2 UFD 0805 X7R 10V_0805_DISCR2.2 uFd DISCRETEC4406030_0.1 UFD 0603 X7R_0603_0.1 UFD0.1 uFd ICC4506030_0.1 UFD 0603 X7R_0603_0.1 UFD0.1 uFd ICC4606030_0.1 UFD 0603 X7R_0603_0.1 UFD0.1 uFd ICC4706031.0 UFD 0603 X5R_0603_DISCRETE_1.0 uFd DISCRETEC480603560 PFD 0603_0603_DISCRETE_560560 pFd DISCRETEC49080510 UFD CERAMIC 16V 0805 X5R_08010 uFd 16V DISCRETEC50LEDC1608X80NLED BLUE 0603_LEDC1608X80N_LEDLED BLUE ICD1LEDC1608X80NLED GREEN 0603_0_LEDC1608X80N_LLED GREEN ICD2LEDC1608X80NLED RED 0603_LEDC1608X80N_LED RLED RED ICD31206_FUSEFUSE 350MA 1206L_0_1206_FUSE_35350mA ICF1FILT_DEA202450BTDEA202450BT-1213C1_0_FILT_DEA20DEA202450BT-1213C1 ICFLT1HEADER_5X15 PIN HEADER _HEADER_5X1_IO_5 P5 PIN HDR IOJ1CON-USB-SMRA-MOLEX48037USB A RIGHT ANGLE PLUG SMD_CON-USB A RA PLUG SMD ICJ3060347 NH INDUCTOR 0603 A_0_0603_4747 nH ICL1C0402_1MMPITCH2_0.2NH INDUCTOR 0402_C0402_1MM2.2 nH ICL2C0402_1MMPITCH2_0.2NH INDUCTOR 0402_C0402_1_112 nH ICL3C0402_1MMPITCH2_0.2NH INDUCTOR 0402_C0402_1MM2.2 nH ICL4C0402_1MMPITCH2_0.2NH INDUCTOR 0402_C0402_1_25.6 nH ICL5HEADER-8X2-RA-300PCB RECEPTACLE_16_RA_FTPC_HEADE8X2 PIN RECPT RA ICP1C0402_1MMPITCHR_C0402_1MMPITCH_140140 ICR4C0402_1MMPITCHR_C0402_1MMPITCH_160160 ICR5C0402_1MMPITCHNO LOAD RESISTOR 0402_0_C0402_1NO LOAD DISCRETER906032_0.2K OHM 5% 0603_0603_2.2K2.2K ICR1906032_0.2K OHM 5% 0603_0603_2.2K2.2K ICR2006032_0.2K OHM 5% 0603_0603_2.2K2.2K ICR210603100K OHM 1% 0603_0_0603_100K100K ICR22C0402_1MMPITCH2_0.2K OHM 5% 0402_C0402_1MMPIT2.2K ICR23C0402_1MMPITCH2_0.2K OHM 5% 0402_C0402_1MMPIT2.2K ICR240603100 OHM 5% 0603_0603_DISCRETE_1100 ohm DISCRETER250603100 OHM 5% 0603_0603_DISCRETE_1100 ohm DISCRETER260603470 OHM 5% 0603_0_0603_470470 ICR27060324 OHM 5% 0603 _0603_DISCRETE_224 ohm DISCRETER28060324 OHM 5% 0603 _0603_DISCRETE_224 ohm DISCRETER290603100 OHM 5% 0603_0603_DISCRETE_1100 ohm DISCRETER300603100 OHM 5% 0603_0603_DISCRETE_1100 ohm DISCRETER310805100K OHM 1% 0603_0_0805_100K100K ICR320603100K OHM 1% 0603_0_0603_100K100K ICR33060310K OHM 5% 0603_0603_DISCRETE_110K DISCRETER340603470 OHM 5% 0603_0_0603_470470 ICR360603470 OHM 5% 0603_0_0603_470470 ICR3706032_0.2K OHM 5% 0603_0603_2.2K2.2K ICR3806032_0.2K OHM 5% 0603_0603_2.2K2.2K ICR3906032_0.2K OHM 5% 0603_0603_2.2K2.2K ICR40C0402_1MMPITCHZERO OHM 0402_0_C0402_1MMPITCH_ZERO DISCRETER41C0402_1MMPITCHZERO OHM 0402_0_C0402_1MMPITCH_ZERO DISCRETER42SW-B3FS-1052SWITCH TACT 6MM 150GF SPST SMD_SW PUSHBUTTON SMT ICSW1TP_40_20TEST VIA 20 HOLE 40 PLATED_0_TPTV-20R ICTV1TP_40_20TEST VIA 20 HOLE 40 PLATED_0_TPTV-20R ICTV2TP_40_20TEST VIA 20 HOLE 40 PLATED_0_TPTV-20R ICTV3TP_40_20TEST VIA 20 HOLE 40 PLATED_0_TPTV-20R ICTV4TP_40_20TEST VIA 20 HOLE 40 PLATED_0_TPTV-20R ICTV5TP_40_20TEST VIA 20 HOLE 40 PLATED_0_TPTV-20R ICTV6TP_40_20TEST VIA 20 HOLE 40 PLATED_0_TPTV-20R ICTV7TP_40_20TEST VIA 20 HOLE 40 PLATED_0_TPTV-20R ICTV8TP_40_20TEST VIA 20 HOLE 40 PLATED_0_TPTV-20R ICTV9TP_40_20TEST VIA 20 HOLE 40 PLATED_0_TPTV-20R ICTV10TP_40_20TEST VIA 20 HOLE 40 PLATED_0_TPTV-20R ICTV11TP_40_20TEST VIA 20 HOLE 40 PLATED_0_TPTV-20R ICTV12TP_40_20TEST VIA 20 HOLE 40 PLATED_0_TPTV-20R ICTV13MLF_40P_05MMCYRF6936-40LFXC_MLF_40P_05MM_CYCYRF6936 ICU1TSON_6PUPG2250_TSON_6P_UPG2250UPG2250 ICU3PSON48P150X110X55-6NUPG2214TK_PSON48P150X110X55-6N_UPG2214TK ICU5PSON48P150X110X55-6NUPG2214TK_PSON48P150X110X55-6N_UPG2214TK ICU6QFN50P800X800X100-57NCY8C24894 QFN56_QFN50P800X800X1CY8C24894 QFN56 ICU7QFN50P800X800X100-57NCY8C24894 QFN56_QFN50P800X800X1CY8C24894 QFN56 ICU8SOIC8LT1763CS8-3.3 SO8_SOIC8_LT1763CLT1763CS8-3.3 ICU9SC70-5NC7SV34 SC70-5_SC70-5_NC7SV34P5NC7SV34P5X ICU10SC70-5NC7SV34 SC70-5_SC70-5_NC7SV34P5NC7SV34P5X ICU11XTAL_SM_4P_FX065ECERA FF1200030 12MHZ_XTAL_SM_4eCera FF 12MHz ICY1
重要提示:PCB作品文件展下载说明
生活就是油盐酱醋再加一点糖,快活就是一天到晚乐呵呵的忙!
头像被屏蔽
禁止发言
发表于 2019-11-14 16:52:34 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2021-3-4 18:22:46 | 显示全部楼层
发表于 2021-3-4 18:27:20 | 显示全部楼层
发表于 2021-3-5 01:03:45 | 显示全部楼层
  • 签到天数: 6 天
    发表于 2021-3-5 08:32:00 | 显示全部楼层
    发表于 2021-3-5 08:39:57 | 显示全部楼层
    发表于 2021-3-20 08:29:24 | 显示全部楼层
    前天 08:30
  • 签到天数: 193 天
    终身成就奖社区居民特殊贡献奖原创先锋奖
    发表于 2023-9-20 09:10:21 | 显示全部楼层
