查看: 2494|回复: 3
[Allegro17.4以下] CY8CKIT-148 PSoC® 4700S Inductive Sensing Evaluation Kit开发板原理图
PADS-180606高级班
社区居民终身成就奖特殊贡献奖优秀斑竹奖
发表于 2018-12-11 13:42:36 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
2层Pins(459)
游客,如果您要查看本帖隐藏内容请回复
Bill of Material ReportSYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_TOLCOMP_CLASSREFDESIND_COIL_CIR_2L_111D_25T_4W_4SINDUCTIVE_LOOP_IND_COIL_CIR_2L_Inductive_Loop ICBTN1IND_COIL_CIR_2L_111D_25T_4W_4SINDUCTIVE_LOOP_IND_COIL_CIR_2L_Inductive_Loop ICBTN2IND_COIL_CIR_2L_111D_25T_4W_4SINDUCTIVE_LOOP_IND_COIL_CIR_2L_Inductive_Loop ICBTN3CAPC1005_0402NCAPACITOR NON-POL_CAPC1005_04020.1 uF ICC1CAPC1005_0402NCAPACITOR NON-POL_CAPC1005_04_11.0 uF ICC2CAPC1005_0402NCAPACITOR NON-POL_CAPC1005_04_11.0 uF ICC3CAPC2012_0805NCAP_CAPC2012_0805N_DISCRETE_470470pF DISCRETEC4CAPC2012_0805NCAP_CAPC2012_0805N_DISCRETE_2202200pF DISCRETEC5CAPC1608_0603MCAPACITOR NON-POL_CAPC1608_060310pF ICC6CAPC1608_0603MCAPACITOR NON-POL_CAPC1608_060310pF ICC7CAPC1608_0603MCAPACITOR NON-POL_CAPC1608_060310pF ICC8CAPC1608_0603MCAPACITOR NON-POL_CAPC1608_060310pF ICC9CAPC1608_0603MCAPACITOR NON-POL_CAPC1608_060310pF ICC10CAPC1608_0603MCAPACITOR NON-POL_CAPC1608_060310pF ICC11CAPC1608_0603MCAPACITOR NON-POL_CAPC1608_060310pF ICC12CAPC1608_0603MCAPACITOR NON-POL_CAPC1608_060310pF ICC13CAPC1005_0402NCAPACITOR NON-POL_CAPC1005_04_11.0 uF ICC14CAPC1608_0603MCAPACITOR NON-POL_CAPC1608_060310pF ICC15CAPC1608_0603MCAPACITOR NON-POL_CAPC1608_060310pF ICC16CAPC1005_0402NCAPACITOR NON-POL_CAPC1005_04_20.1 uF ICC17CAPC1005_0402NCAPACITOR NON-POL_CAPC1005_04_310nF ICC18CAPC1005_0402NCAPACITOR NON-POL_CAPC1005_04_11.0 uF ICC20CAPC2012_0805NCAPACITOR NON-POL_CAPC2012_080510uF ICC21CAPC1005_0402NCAPACITOR NON-POL_CAPC1005_04_11.0 uF ICC22CAPC1005_0402NCAPACITOR NON-POL_CAPC1005_04_11.0 uF ICC23CAPC1005_0402NCAPACITOR NON-POL_CAPC1005_04_11.0 uF ICC24CAPC1005_0402NCAPACITOR NON-POL_CAPC1005_04_20.1 uF ICC25CAPC1005_0402NCAPACITOR NON-POL_CAPC1005_04_11.0 uF ICC26CAPC1005_0402NCAPACITOR NON-POL_CAPC1005_04_20.1 uF ICC27CAPC1005_0402NCAPACITOR NON-POL_CAPC1005_04_11.0 uF ICC28CAPC1005_0402NCAPACITOR NON-POL_CAPC1005_04_20.1 uF ICC29CAPC1005_0402NCAPACITOR NON-POL_CAPC1005_04_11.0 uF ICC30CAPC1005_0402NCAPACITOR NON-POL_CAPC1005_04_20.1 uF ICC31CAPC1005_0402NCAPACITOR NON-POL_CAPC1005_04_11.0 uF ICC32CAPC1005_0402NCAPACITOR NON-POL_CAPC1005_04_11.0 uF ICC33CAPC1005_0402NCAPACITOR NON-POL_CAPC1005_04_11.0 uF ICC34CAPC1005_0402NCAPACITOR NON-POL_CAPC1005_04_11.0 uF ICC35CAPC1005_0402NCAPACITOR NON-POL_CAPC1005_04_20.1 uF ICC36CAPC1005_0402NCAPACITOR NON-POL_CAPC1005_04_20.1 uF ICC37CAPC1005_0402NCAPACITOR NON-POL_CAPC1005_04_20.1 uF ICC38CAPC1005_0402NCAPACITOR NON-POL_CAPC1005_04_20.1 uF ICC39CAPC1005_0402NCAPACITOR NON-POL_CAPC1005_04_11.0 uF ICC40CAPC2012_0805NCAPACITOR NON-POL_CAPC2012_08_15nF ICC41CAPC2012_0805NCAPACITOR NON-POL_CAPC2012_08_22.2nF ICC42CAPC1005_0402NCAPACITOR NON-POL_CAPC1005_04_20.1 uF ICC43CAPC2012_0805NCAP_CAPC2012_0805N_DISCRETE_470470pF DISCRETEC44CAPC1005_0402NCAPACITOR NON-POL_CAPC1005_04_11.0 uF ICC45CAPC2012_0805NCAPACITOR NON-POL_CAPC2012_08_15nF ICC46CAPC1005_0402NCAPACITOR NON-POL_CAPC1005_04_20.1 uF ICC47CAPC1005_0402NCAPACITOR NON-POL_CAPC1005_04_20.1 uF ICC48CAPC1005_0402NCAPACITOR NON-POL_CAPC1005_04_11.0 uF ICC49CAPC1005_0402NCAPACITOR NON-POL_CAPC1005_04_11.0 uF ICC50CAPC2012_0805NCAPACITOR NON-POL_CAPC2012_08_15nF ICC51CAPC1608_0603MCAPACITOR NON-POL_CAPC1608_060310pF ICC52CAPC1608_0603MCAPACITOR NON-POL_CAPC1608_060310pF ICC53CAPC1608_0603MCAPACITOR NON-POL_CAPC1608_060310pF ICC54CAPC1608_0603MCAPACITOR NON-POL_CAPC1608_060310pF ICC55CAPC1608_0603MCAPACITOR NON-POL_CAPC1608_060310pF ICC56CAPC1608_0603MCAPACITOR NON-POL_CAPC1608_060310pF ICC57CAPC1608_0603MCAPACITOR NON-POL_CAPC1608_06_10.1uF ICC59CAPC1608_0603MCAPACITOR NON-POL_CAPC1608_06_10.1uF ICC60CAPC1608_0603MCAPACITOR NON-POL_CAPC1608_06_10.1uF ICC61CAPC1608_0603MCAPACITOR NON-POL_CAPC1608_06_10.1uF ICC62FUSER_MF-MSMF050-2FUSE_4_FUSER_MF-MSMF050-2_0ZCG00ZCG0050FF2C ICF1MOLEX_22-28-4050CONN PCB 5_MOLEX_22-28-4050_CONCON 5x1 ICJ1JAE_DX07S024XJ1R1100CONN_USB_TYPE_C_JAE_DX07S024XJ1USB TYPE-C ICJ23M_961102-6404-AR103185_2HDR2 ICJ3SULLINS_SFH11-PBPC-D08-RA-BKCONN PCB 20X2-R_2_SULLINS_SFH11SKT 16x2 ICJ4MOLEX_22-28-4070CONN PCB 5_0_MOLEX_22-28-4070_CCON 7x1 ICJ5MOLEX_528921633CON10_0_MOLEX_528921633_CON16CON16 ICJ6USB_FENCEUSB_JUMP_0_USB_FENCE_USB_HOLDUSB_Hold ICJMP1CR-LED0805LED_GREEN0805_1User LED BLUE ICLED1CR-LED0805LED_GREEN0805_1User LED BLUE ICLED2CR-LED0805LED_GREEN0805_1User LED BLUE ICLED3CR-LED0805LED_GREEN0805_1User LED BLUE ICLED4CR-LED0805LED_GREEN0805_1User LED BLUE ICLED5CR-LED0805LED_GREEN0805_1User LED BLUE ICLED6CR-LED0805LED_GREEN0805_1User LED BLUE ICLED7LEDC2012X120MLED_2_LEDC2012X120M_AMBER LEDAMBER LED ICLED8LEDC2012X120MLED_2_LEDC2012X120M_AMBER LEDAMBER LED ICLED9IND_COIL_CIR_2L_147P402D_40T_4W_4SINDUCTIVE_LOOP_IND_COIL_CIR_2_1Inductive_Loop ICPROXIMITYRESC1005_0402MRESISTOR_RESC1005_0402M_330OHM330ohm ICR1RESC1005_0402MRESISTOR_RESC1005_0402M_5.1K5.1K ICR2RESC1005_0402MRESISTOR_RESC1005_0402M_100K100K ICR3RESC1005_0402MRESISTOR_RESC1005_0402M_49.9K49.9K ICR4RESC1005_0402MRESISTOR_RESC1005_0402M_270OHM270ohm ICR5RESC1005_0402MRESISTOR_RESC1005_0402M_49.9K49.9K ICR6RESC1005_0402MRESISTOR_RESC1005_0402M_750 OHM750 OHM ICR7RESC1005_0402MRESISTOR_RESC1005_0402M_15K15K ICR8RESC1005_0402MRESISTOR_RESC1005_0402M_30K30K ICR9RESC1005_0402MRESISTOR_RESC1005_0402M_22E22E ICR10RESC1005_0402MRESISTOR_RESC1005_0402M_22E22E ICR11RESC1608_0603MRESISTOR_RESC1608_0603M_0 OHM0 OHM ICR12RESC1608_0603MRESISTOR_RESC1608_0603M_0 OHM0 OHM ICR13RESC1608_0603MRESISTOR_RESC1608_0603M_0 OHM0 OHM ICR14RESC1608_0603MRESISTOR_RESC1608_0603M_0 OHM0 OHM ICR15RESC1608_0603MRESISTOR_RESC1608_0603M_0 OHM0 OHM ICR16RESC1608_0603MRESISTOR_RESC1608_0603M_0 OHM0 OHM ICR17RESC1608_0603MRESISTOR_RESC1608_0603M_0 OHM0 OHM ICR18RESC1005_0402MRESISTOR_RESC1005_0402M_270OHM270ohm ICR19RESC1005_0402MRESISTOR_RESC1005_0402M_270OHM270ohm ICR20RESC1005_0402MRESISTOR_RESC1005_0402M_4.7K4.7K ICR21RESC1005_0402MRESISTOR_RESC1005_0402M_100K100K ICR22RESC1608_0603MRESISTOR_RESC1608_0603M_0 OHM0 OHM ICR24RESC1005_0402MRESISTOR_RESC1005_0402M_5.1K5.1K ICR25RESC1608_0603MRESISTOR_RESC1608_0603M_0 OHM0 OHM ICR26RESC1005_0402MRESISTOR_RESC1005_0402M_270OHM270ohm ICR27RESC1005_0402MRESISTOR_RESC1005_0402M_270OHM270ohm ICR28RESC1005_0402MRESISTOR_RESC1005_0402M_270OHM270ohm ICR29RESC1005_0402MRESISTOR_RESC1005_0402M_270OHM270ohm ICR30RESC1005_0402MRESISTOR_RESC1005_0402M_15K15K ICR31RESC2012_0805MRESISTOR_RESC2012_0805M_330 OHM330 Ohm ICR32RESC1005_0402MRESISTOR_RESC1005_0402M_30K30K ICR33RESC2012_0805MRESISTOR_RESC2012_0805M_330 OHM330 Ohm ICR34RESC2012_0805MRESISTOR_RESC2012_0805M_330 OHM330 Ohm ICR39RESC1608_0603MRESISTOR_RESC1608_0603M_0 OHM0 OHM ICR46RESC2012_0805MRESISTOR_RESC2012_0805M_330 OHM330 Ohm ICR49RESC1005_0402MRESISTOR_RESC1005_0402M_4.7K4.7K ICR50RESC1005_0402MRESISTOR_RESC1005_0402M_4.7K4.7K ICR51SW_SKRPACE010SW PUSH NO 4-PIN_SW_SKRPACE010_SKRPACE010 ICSW1SW_SKRPACE010SW PUSH NO 4-PIN_SW_SKRPACE010_SKRPACE010 ICSW2TP50_12D_24BOT_MILTEST_POINT_TP50_12D_24BOT_MIL__TP_SMD ICTP1TP50_12D_24BOT_MILTEST_POINT_TP50_12D_24BOT_MIL__TP_SMD ICTP2TP50_12D_24BOT_MILTEST_POINT_TP50_12D_24BOT_MIL__TP_SMD ICTP3KEYSTONE_5000TEST_POINT_KEYSTONE_5000_IO_REDRED IOTP4KEYSTONE_5000TEST_POINT_KEYSTONE_5000_IO_REDRED IOTP5KEYSTONE_5000TEST_POINT_KEYSTONE_5000_IO_REDRED IOTP6KEYSTONE_5000TEST_POINT_KEYSTONE_5000_IO_REDRED IOTP7TP50_12D_24BOT_MILTEST_POINT_TP50_12D_24BOT_MIL__TP_SMD ICTP8TP50_12D_24BOT_MILTEST_POINT_TP50_12D_24BOT_MIL__TP_SMD ICTP9SON50P160X160X50-7MPUSBM12VX4-TL,115_0_SON50P160X1PUSBM12VX4-TL,115 ICU1QFN40P800X800X100-69MCY8C38***-QFN68_0_QFN40P800X800CY8C5868LTI-LP039 ICU2TQFP50P900X900X160-48NCY8C4745AZI-S413_TQFP50P900X900CY8C4745AZI-S413 ICU3SOT95P285X140-5MAP7365-WG-7_0_SOT95P285X140-5M_AP7365-33WG-7 ICU4TDFN50P160X120X60-5MSIP32408_0_TDFN50P160X120X60-5MSiP32408 ICU5
重要提示:PCB作品文件展下载说明
生活就是油盐酱醋再加一点糖,快活就是一天到晚乐呵呵的忙!
社区居民终身成就奖特殊贡献奖原创先锋奖
发表于 2018-12-11 14:04:48 | 显示全部楼层
非常感谢楼主大神的分享
头像被屏蔽
禁止发言
发表于 2019-11-14 16:49:56 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
    前天 08:30
  • 签到天数: 193 天
    终身成就奖社区居民特殊贡献奖原创先锋奖
    发表于 2023-9-20 09:10:11 | 显示全部楼层
