查看: 4395|回复: 22
[Allegro16.6以下] CY8CKIT-037 PSoC 4 Motor Control Evaluation Kit原理图与PCB文件
PADS-180606高级班
社区居民终身成就奖特殊贡献奖优秀斑竹奖
发表于 2018-12-11 13:49:21 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
2层Pins(503)
游客,如果您要查看本帖隐藏内容请回复
Bill of Material ReportSYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_TOLCOMP_CLASSREFDESC1206CAP NP_C1206_1UF/100V1uF/100V ICC1C1206CAP NP_C1206_1UF/100V1uF/100V ICC2C0603CAP NP_C0603_8200PF/50V8200pF/50V ICC3C0603CAP NP_C0603_1UF/50V1uF/50V ICC4C0603CAP NP_C0603_1800PF/50V1800pF/50V ICC5C0603CAP NP_C0603_22NF/50V22nF/50V ICC6C0603CAP NP_C0603_2700PF/50V2700pF/50V ICC7C0603CAP NP_C0603_1000PF/50V1000pF/50V ICC8SMD6X6C_SMD6X6_22UF/35V/EEE-FK1V220R22uF/35V/EEE-FK1V220R ICC9C0603CAP NP_C0603_0.1UF/50V0.1uF/50V ICC10RB4_4-11C_RB4_4-11_330UF/63V/UVZ1J331MP330uF/63V/UVZ1J331MPD ICC11C0603CAP NP_C0603_0.1UF/100V0.1uF/100V ICC12C1206CAP NP_C1206_10UF/50V10uF/50V ICC16C1206CAP NP_C1206_10UF/50V10uF/50V ICC17C1206CAP NP_C1206_10UF/50V10uF/50V ICC18C1206CAP NP_C1206_10UF/50V10uF/50V ICC19C0603CAP NP_C0603_100PF/50V100pF/50V ICC20C0603CAP NP_C0603_100PF/50V100pF/50V ICC21C0603CAP NP_C0603_100PF/50V100pF/50V ICC22C0603CAP NP_C0603_100PF/50V100pF/50V ICC23C0603CAP NP_C0603_100PF/50V100pF/50V ICC24C0603CAP NP_C0603_100PF/50V100pF/50V ICC25C0603CAP NP_C0603_0.1UF/50V0.1uF/50V ICC26C0603CAP NP_C0603_100PF/50V100pF/50V ICC29C0603CAP NP_C0603_330PF/50V330pF/50V ICC35C0603CAP NP_C0603_330PF/50V330pF/50V ICC36C0603CAP NP_C0603_330PF/50V330pF/50V ICC37C0603CAP NP_C0603_330PF/50V330pF/50V ICC38C0603CAP NP_C0603_330PF/50V330pF/50V ICC39C0603CAP NP_C0603_330PF/50V330pF/50V ICC40C0603CAP NP_C0603_1UF/50V1uF/50V ICC43C0402CAP NP_C0402_0.1UF/16V0.1uF/16V ICC44C0402CAP NP_C0402_1UF/16V1uF/16V ICC45C0402CAP NP_C0402_0.1UF/16V0.1uF/16V ICC46C0603CAP NP_C0603_1000PF/50V1000pF/50V ICC47C0402CAP NP_C0402_0.1UF/16V0.1uF/16V ICC48SOD-80LDIODE21_0_SOD-80L_SK310A-TPSK310A-TP ICD1DPAK-D_EDIODE_2_DPAK-D_E_STPS15L60CB/60STPS15L60CB/60V/7.5A ICD2SOD-80L_EDIODE_SOD-80L_E_US1A-TPUS1A-TP ICD3SOD-80L_EDIODE_SOD-80L_E_US1A-TPUS1A-TP ICD4SOD-80L_EDIODE_SOD-80L_E_US1A-TPUS1A-TP ICD5SOD-80L_EDIODE_SOD-80L_E_US1A-TPUS1A-TP ICD6CR-LED06030603_LEDESD 5VDC ICD10CR-LED06030603_LEDESD 5VDC ICD11CR-LED06030603_LEDESD 5VDC ICD12LITTELFUSE_60R250FUSE_LITTELFUSE_60R250_60R250XM60R250XMR/60V/2.50A ICF1FUSE_EFUSE_FUSE_E_NO LOAD 125V/2.5A/0NO LOAD 125V/2.5A/045202.5MRL ICF2HDR1X8HEADER 8_HDR1X8_8 PIN HEADER8 Pin Header ICJ1HDR2X9HEADER 9X2_HDR2X9_18 (9X2) PIN18 (9x2) Pin Header ICJ2HDR1X10HEADER 10_HDR1X10_10 PIN HEADER10 Pin Header ICJ3HDR1X8HEADER 8_HDR1X8_8 PIN HEADER8 Pin Header ICJ4KLDPJ102A12-24V/3A, 2.1mm, PWR CONN IOJ7HDR2-3_81_BCON2_1_HDR2-3_81_B_12-48V/3A PO12-48V/3A POWER CONN ICJ8HDR2-3_81_ACON2_1_HDR2-3_81_A_20020327-D0220020327-D021B01LF ICJ9HDR2-3_81_CCON2_3_HDR2-3_81_C_20020327-D0220020327-D021B01LF ICJ10TE_CONNECTIVITY_1734510-1USB_MINI_B_DIPUSB MINI B IOJ11HDR1X5_2_5MMHEADER 5_HDR1X5_2_5MM_5 PIN HEA5 Pin Header ICJ12HDR1X3HEADER 3_HDR1X3_3 PIN HEADER3 Pin Header ICJ13HDR1X3HEADER 3_HDR1X3_3 PIN HEADER3 Pin Header ICJ14HDR1X3HEADER 3_HDR1X3_3 PIN HEADER3 Pin Header ICJ15HDR1X3HEADER 3_HDR1X3_3 PIN HEADER3 Pin Header ICJ16HDR1X3HEADER 3_HDR1X3_3 PIN HEADER3 Pin Header ICJ17HDR1X3HEADER 3_HDR1X3_3 PIN HEADER3 Pin Header ICJ18HDR1X3HEADER 3_HDR1X3_3 PIN HEADER3 Pin Header ICJ19HDR1X3HEADER 3_HDR1X3_3 PIN HEADER3 Pin Header ICJ20HDR1X3HEADER 3_HDR1X3_3 PIN HEADER3 Pin Header ICJ21HDR1X3HEADER 3_HDR1X3_3 PIN HEADER3 Pin Header ICJ22HDR1X3HEADER 3_HDR1X3_3 PIN HEADER3 Pin Header ICJ23HDR1X3HEADER 3_HDR1X3_3 PIN HEADER3 Pin Header ICJ24R1206INDUCTOR_R1206_600OHM@100MHZ/1.600ohm@100MHz/1.5A/BLM31PG601SN1L ICL1CLF6045_EINDUCTOR_CLF6045_E_150UH/0.6A/C150uH/0.6A/CLF6045T-151M ICL2INDC2012X105NINDUCTOR_INDC2012X105N_FERRITEFERRITE BEAD ICL3INDC2012X105NINDUCTOR_INDC2012X105N_220 OHM/220 Ohm/2A ICL4R0603LED_R0603_RED LEDRed Led ICLED1R0603LED_R0603_GREENGREEN ICLED2IPAKIRFPC50/TO_1_IPAK_IRFU3607PBFIRFU3607PBF ICQ1IPAKIRFPC50/TO_1_IPAK_IRFU3607PBFIRFU3607PBF ICQ2IPAKIRFPC50/TO_1_IPAK_IRFU3607PBFIRFU3607PBF ICQ3IPAKIRFPC50/TO_1_IPAK_IRFU3607PBFIRFU3607PBF ICQ4IPAKIRFPC50/TO_1_IPAK_IRFU3607PBFIRFU3607PBF ICQ5IPAKIRFPC50/TO_1_IPAK_IRFU3607PBFIRFU3607PBF ICQ6IPAKIRFPC50/TO_1_IPAK_IRFU3607PBFIRFU3607PBF ICQ7IPAKIRFPC50/TO_1_IPAK_IRFU3607PBFIRFU3607PBF ICQ8R0603R_R0603_10K/1%10K/1% ICR1R0603R_R0603_2K/1%2K/1% ICR2R0603R_R0603_143K/1%143K/1% ICR3R0603R_R0603_18.2K/1%18.2K/1% ICR4R0603R_R0603_16.9K/1%16.9K/1% ICR5R0603R_R0603_9.1K/1%9.1K/1% ICR6R0603R_R0603_1K/1%1K/1% ICR7R0603R_R0603_5.49K /1%5.49K /1% ICR9R0603R_R0603_590/1%590/1% ICR10R0603R_R0603_2.4K/5%2.4K/5% ICR11R0603R_R0603_330 OHM/5%330 ohm/5% ICR12R0603R_R0603_22 OHM22 ohm ICR20R0603R_R0603_22 OHM22 ohm ICR21R0603R_R0603_22 OHM22 ohm ICR22R0603R_R0603_22 OHM22 ohm ICR23R0603R_R0603_22 OHM22 ohm ICR24R0603R_R0603_22 OHM22 ohm ICR25R0603R_R0603_22 OHM22 ohm ICR26R0603R_R0603_22 OHM22 ohm ICR27R1206_ER_R1206_E_30M OHM/0.5W/1%30m ohm/0.5W/1% ICR34R1206_ER_R1206_E_30M OHM/0.5W/1%30m ohm/0.5W/1% ICR35R1206_ER_R1206_E_30M OHM/0.5W/1%30m ohm/0.5W/1% ICR36R0603R_R0603_330 OHM330 ohm ICR37POT_10K_296U_VERPOT12_2_POT_10K_296U_VER_296UE1296UE103B1C ICR38R0603R_R0603_330 OHM330 ohm ICR39R0603R_R0603_20K/1%20K/1% ICR40R0603R_R0603_20K/1%20K/1% ICR41R0603R_R0603_2K/1%2K/1% ICR42R0603R_R0603_2K/1%2K/1% ICR43R0603R_R0603_10K/1%10K/1% ICR44R0603R_R0603_1K/1%1K/1% ICR45R0603R_R0603_20K/1%20K/1% ICR46R0603R_R0603_20K/1%20K/1% ICR47R0603R_R0603_2K/1%2K/1% ICR48R0603R_R0603_2K/1%2K/1% ICR49R0603R_R0603_10K/1%10K/1% ICR50R0603R_R0603_1K/1%1K/1% ICR51R0603R_R0603_1K/5%1K/5% ICR52R0603R_R0603_22 OHM/1%22 ohm/1% ICR53R0603R_R0603_1K/5%1K/5% ICR56R0603R_R0603_22 OHM/1%22 ohm/1% ICR57R0603R_R0603_1K/5%1K/5% ICR60R0603R_R0603_1K/5%1K/5% ICR61R0603R_R0603_1K/5%1K/5% ICR62R0603R_R0603_1K/1%1K/1% ICR63R0603R_R0603_2K/1%2K/1% ICR64R0603R_R0603_1K/1%1K/1% ICR65R0603R_R0603_8.2K/1%8.2K/1% ICR70R0603R_R0603_8.2K/1%8.2K/1% ICR71R0603R_R0603_8.2K/1%8.2K/1% ICR72R0603R_R0603_2K/1%2K/1% ICR73R0603R_R0603_2K/1%2K/1% ICR74R0603R_R0603_2K/1%2K/1% ICR75R0603R_R0603_3.9K/5%3.9K/5% ICR76R0603R_R0603_3.9K/5%3.9K/5% ICR77R0603R_R0603_3.9K/5%3.9K/5% ICR78R0603R_R0603_10K/5%10K/5% ICR82R0603R_R0603_1.8K/1%1.8K/1% ICR83R0603R_R0603_1.8K/1%1.8K/1% ICR84R0603R_R0603_4.7K/5%4.7k/5% ICR91R0603R_R0603_220OHM/1%220ohm/1% ICR92R0603R_R0603_220OHM/1%220ohm/1% ICR93R0603R_R0603_220OHM/1%220ohm/1% ICR94R-CR0603RESISTOR_R-CR0603_0 OHM/5%0 ohm/5% ICR103R-CR0603RESISTOR_R-CR0603_0 OHM/5%0 ohm/5% ICR104R-CR0603RESISTOR_R-CR0603_0 OHM/5% NO0 ohm/5% No Load ICR105EVQP_ESW PUSHBUTTON_EVQP_E_RESETRESET ICSW1EVQP_ESW PUSHBUTTON_EVQP_E_RUN/STOPRun/Stop ICSW2TPTPGND DISCRETETP1TPTPGND DISCRETETP2TP2TP2Ia NO LOAD DISCRETETP3TP3TP3Ic NO LOAD DISCRETETP4TP4TP4AH No Load DISCRETETP5TP5TP5AL No Load DISCRETETP6TP6TP6BH No Load DISCRETETP7TP7TP7BL No Load DISCRETETP8TP8TP8CH No Load DISCRETETP9TP9TP9CL No Load DISCRETETP10TP10TP10DH No Load DISCRETETP11TP11TP11DL No Load DISCRETETP12TP12TP13+12V DISCRETETP13TP13TP13_1Vin DISCRETETP14TP1TP21VDD DISCRETETP15TP16TP16P0_2 NO LOAD DISCRETETP16TP1TP20_1P0_1/Cmp0-_Ia_REF DISCRETETP17TP1TP1P0_7/Ic_REF DISCRETETP18TPTP19GND NO LOAD DISCRETETP19TP12TP20P2_6/VIN_SENSE NO LOAD DISCRETETP20TSSOP20LM5005MH_TSSOP20_LM5005MHX/NOPBLM5005MHX/NOPB ICU1SOIC127P600X175-8N_AAD8072_0_SOIC127P600X175-8N_A_LLM393DR ICU2SO8_MIR2101_0_SO8_M_IR2101IR2101 ICU3SO8_MIR2101_0_SO8_M_IR2101IR2101 ICU4SO8_MIR2101_0_SO8_M_IR2101IR2101 ICU5SO8_MIR2101_0_SO8_M_IR2101IR2101 ICU6SOT-23-5OPAMP/AD8601ARTZ_2_SOT-23-5_OPAOpAmp/AD8601ARTZ ICU7QFN50P500X500X100-33BNCYUSBS232_8_QFN50P500X500X100-3CY7C65213 ICU8R1210VARISTOR_R1210_V60MLA1210/67V/2V60MLA1210/67V/250A ICVR1
重要提示:PCB作品文件展下载说明
生活就是油盐酱醋再加一点糖,快活就是一天到晚乐呵呵的忙!
社区居民终身成就奖特殊贡献奖原创先锋奖
发表于 2018-12-11 14:03:57 | 显示全部楼层
非常感谢楼主大神的分享
    昨天 10:25
  • 签到天数: 123 天
    发表于 2018-12-11 22:08:14 | 显示全部楼层
    头像被屏蔽
    禁止发言
    发表于 2019-11-14 16:46:54 | 显示全部楼层
    提示: 作者被禁止或删除 内容自动屏蔽
    昨天 11:15
  • 签到天数: 191 天
    终身成就奖社区居民忠实会员社区劳模最爱沙发特殊贡献奖优秀斑竹奖
    发表于 2020-11-24 17:56:39 | 显示全部楼层
    发表于 2020-11-25 01:03:36 | 显示全部楼层
    发表于 2020-11-25 09:29:02 | 显示全部楼层
    发表于 2020-11-25 10:23:26 | 显示全部楼层
    发表于 2020-11-25 12:21:57 | 显示全部楼层
    好东西,好好补一补知识!
    发表于 2020-11-26 09:28:52 | 显示全部楼层
    值得收藏,楼主你太优秀了!
