本部分内容设定了隐藏,需要回复后才能看到(回复后还看不到就刷新一下即可)
4$N,|bt ;Z"Iv rAW7Zp~KK mAIl)mq|g Part Value Package Library Position (mil) Orientation
F/j ; q
(=gqqOOl~ ADCH 8x1F-H8.5 1X08 SmartPrj (3250 100) R0
A>S7Ap4z> ADCL 8x1F-H8.5 1X08 SmartPrj (2350 100) R0
~mah.8G
BR1 NM J0402 bibaja (1108 834) R270
8(q8}s$> C1 10u SMC_B rcl (1432 376) R0
F8tMZ,: C2 10u SMC_B rcl (1087 1592) R180
JW2f 6!b C3 10u SMC_B rcl (1672 376) R0
"la0@/n C4 100n C0402 SmartPrj (1416 804) R0
SLN OOEN C5 100n C0402 SmartPrj (2052 1604) R270
wkPomTO C6 100n C0402 SmartPrj (1376 904) R0
3?h!nVI+2J C7 100n C0402 SmartPrj (2240 484) R90
`2V{]F C8 100n C0402 SmartPrj (2420 1024) R270
)NZ&m$I|- C9 100n C0402 SmartPrj (1376 1284) R0
5OOXCtIKf C10 100n C0402 SmartPrj (1440 588) R90
&n83>Q C11 10u SMC_B rcl (1231 861) R180
oHSDi C12 100n C0402 SmartPrj (1348 820) R90
"OkZ
[E) C13 100n C0402 SmartPrj (2132 1604) R270
zI(uexxPqd C14 100n C0402 SmartPrj (1364 1200) R0
#%OS=.V C15 100n C0402 SmartPrj (1364 1000) R0
MP_ C16 100n C0402 SmartPrj (2168 484) R90
$SFreyI;Uf C17 100n C0402 SmartPrj (2424 920) R90
xZV|QVY; C18 100n C0402 SmartPrj (1448 480) R180
z
[u!C/ C19 100n C0402 SmartPrj (1608 484) R90
/Q#eP m C20 10n C0402 SmartPrj (88 1772) R180
AtAu$"ue C21 22p C0402 SmartPrj (1584 1624) R90
e(DuJ- C22 22p C0402 SmartPrj (1376 1608) R90
XJS^{=/ C23 22pF_NM C0402 SmartPrj (1144 1096) R180
Kh&a# ~c C24 22pF_NM C0402 SmartPrj (1144 1200) R180
~ \u>jel C25 22p C0402 SmartPrj (1136 1466) R180
~:_10g]r C26 10n C0402 SmartPrj (416 1732) R180
`r\/5|M C27 10u SMC_B rcl (668 1776) R90
*8%uXkM m C28 100n C0402 SmartPrj (68 1240) R90
| -Gb Hfz C29 10u SMC_B rcl (2856 1320) R90
bsI?=lO C30 100n C0402 SmartPrj (715 985) R90
NW21{}=4 C31 100n C0402 SmartPrj (731 1201) R180
u^VQwu6?G C32 100n C0402 SmartPrj (1668 1596) R180
kqC7^x C33 10u SMC_B rcl (1720 1688) R0
!|ic{1!_ C34 100n C0402 SmartPrj (1168 776) R180
+f_3JL$ C35 10u SMC_B rcl (540 1776) R90
pg<cvok C36 100n C0402 SmartPrj (544 756) R90
md : Wx C37 100n C0402 SmartPrj (420.8189 537.54331) R180
!@+4&B= C38 1u C0402 SmartPrj (772 984) R90
"zFTPL" C39 22p C0402 SmartPrj (300 728) R180
oVfRp.a C40 22p C0402 SmartPrj (452 728) R0
+tYskx/ C41 10u SMC_B rcl (3412 672) R90
Gh%dVP9B@P C42 10n C0603-ROUND SmartPrj (3232 632) R0
[Mv'*.7 COMMUNICATION 8x1F-H8.5 1X08 SmartPrj (3050 2000) R0
[e:ccm D2 CD1206-S01575 MINIMELF diode (992 868) R270
O#vIn} D3 CD1206-S01575 MINIMELF diode (3108 676) R90
/" &Jf}r D4 SS1P3L DO220AAL SmartPrj (3264 724) R0
ah!RQ2hDrV D5 SS1P3L DO220AAL SmartPrj (712 284) R90
/KO2y0` DEBUG STRIP 4x1V M 1X04 pinhead (1160 1712) R180
S^i<_?nwg ERASE SMD_157SW SmartPrj (2856 1524) R180
SvQj'5~< F1 MF-MSMF050-2 500mA L1812 rcl (494 1606) R180
"(\]-%:7 F2 MF-MSMF050-2 500mA L1812 rcl (168 1176) R270
ai4ro"H FID1 FIDUCIALMOUNT FIDUCIA-MOUNT SmartPrj (3540 1286.62992) R0
JVPLE*T FID2 FIDUCIALMOUNT FIDUCIA-MOUNT SmartPrj (3669 177) R0
nqcD#HUv FID3 FIDUCIALMOUNT FIDUCIA-MOUNT SmartPrj (245 1920) R0
W[73q>' FID4 FIDUCIALMOUNT FIDUCIA-MOUNT SmartPrj (105 95) R0
VK}H; IC1 LMV358IDGKR MSOP08 linear (762 1100) R90
jH 9.N4L IC2 LM2734Y SOT23-6 SmartPrj (3232 532) R270
f2Tz5slE IC4 NCP1117ST33T3G -3V3 SOT223 linear (3204 1256) R270
TP=#U^g* IC6 ATMEGA16U2-MU MLF32 SmartPrj (716 768) R0
IU]@%jA_:A IC10 74LVC1G125DCK SC70-5 74xx-little-us (522.17323 574.80315) R0
3J^'x ICSP1 3x2M 2X03 SmartPrj (975.93701 580) R90
JU=4v!0 J3 USB-MICRO B CON2_USB_MICRO_B_AT SmartPrj (55 875) R270
anUH'mcK* JP5 2x2M - NM 2X02 SmartPrj (760.06299 492) R180
p;2NO& JR1 0R R0402 SmartPrj (1108 784) R90
95tHire JTAG PINHEAD_2X05_127 Arduino_Wifi_shield_v018_tG (912 1516) R180
Iw</X}#\ L YELLOW CHIP-LED0805 led (415 1164) R90
c 9zMI L1 MH2029-300Y 0805 wuerth-elektronik (1252 552) R0
0VI[6t@ L2 MH2029-300Y 0805 wuerth-elektronik (1268 1552) R180
U {sT %G L3 MH2029-300Y 0805 wuerth-elektronik (1252 476) R0
Aq &H-g]s L4 10u SRR0604-100ML SRR0604 SmartPrj (3220 912) R0
Ar[$% L5 MH2029-300Y 0805 wuerth-elektronik (1484 1724) R0
82=>I*0Q L6 MH2029-300Y 0805 wuerth-elektronik (620 304) R270
- I j ON GREEN CHIP-LED0805 led (415 1090) R90
ItQ3|-^ PC1 47u PANASONIC_D rcl (899 236) R270
<%LN3T PC2 47u PANASONIC_D rcl (2936 700) R90
-[5yp 2F-{ POWER 8x1F-H8.5 1X08 SmartPrj (1450 100) R0
+H3;{ h9, PWMH 10x1F-H8.5 1X10 SmartPrj (1190 2000) R180
(#r>v
h ( PWML 8x1F-H8.5 1X08 SmartPrj (2150 2000) R180
Uv=hxV[7y Q2 BC847BSMD SOT23 transistor-npn (1000 1054) R90
:k oXS R1 0R R0402 SmartPrj (904 1704) R90
:x_;- R2 10K R0402 SmartPrj (772 1688) R180
d@<~u,Mt&F R3 1K R0402 SmartPrj (1144 1000) R180
/y5a~3 R4 100K R0402 SmartPrj (1284 1000) R180
d " i R5 39R 1% R0402 SmartPrj (1456 1428) R90
uJt*> ;Kp R6 39R 1% R0402 SmartPrj (1356 1378) R270
vA@\V)s
R7 6k8 1% R0603-ROUND SmartPrj (1036 1444) R90
7E)*]7B% R8 0R_NM R0402 SmartPrj (1364 1112) R0
7?~*F7F R9 1M_NM R0402 SmartPrj (376 728) R0
83gp'W{| R10 10k R0402 SmartPrj (3408 548) R180
J[4IO R11 10K R0603-ROUND SmartPrj (3128 504) R90
/AUXO] R12 52K3 R0603-ROUND SmartPrj (3036 468) R0
c
UHKE\F R13 10K R0402 SmartPrj (908 940) R0
Zd[6-/-: R14 1K R0402 SmartPrj (132 596) R270
aQ.mvuMa7' R15 1K R0402 SmartPrj (80 596) R90
bl`vT3 R18 10K R0402 SmartPrj (642.11024 451.05512) R270
N:7;c}~ R19 22R R0402 SmartPrj (572 944) R180
Z3nmC-NE R20 22R R0402 SmartPrj (572 988) R180
CXhE+oS5z' R21 1K R0402 SmartPrj (824 944) R90
^-pHhh|g R23 1K R0402 SmartPrj (904 792) R0
G'
a{;3 R99 10K R0402 SmartPrj (1116 700) R90
$tFmp) RESET TS42 TS42 SmartPrj (245 1920) R0
jMB&(r RN1 100K CAT16 resistor-dil (772 1588) R90
9~C$C RN2 100K CAT16 resistor-dil (700 1431) R270
P[bj{lo RN3 1k CAY16 resistor-dil (547 1218) R270
|c5r&oM&m RN4 100K CAT16 resistor-dil (972 1200) R270
6.
6g9 RN5 1K5 CAT16 resistor-dil (3224 1460) R90
]W>kbHImz RX YELLOW CHIP-LED0805 led (415 1312) R90
}O7b&G:nW RX1 YELLOW CHIP-LED0805 led (168 664) R270
h oL"K SPI 3x2M 2X03 SmartPrj (2555 1100) R270
/qX=rlQ/ n T1 FDN340P SOT-23 zetex (566 1079) R180
*wVWyC T2 FDN340P SOT-23 zetex (400 876) R180
bQu1L>c,Uw T3 FDN340P SOT-23 zetex (1160 612) R90
HOrD20 TX YELLOW CHIP-LED0805 led (415 1238) R90
auV<=1<zJ TX1 YELLOW CHIP-LED0805 led (172 528) R270
v08Xe*gNU U1 ATSAM3X8EA-AU LQFP144 SmartPrj (1925 1025) R180
jV!9IK;HA. USB1 MICRO-USB-AB1 MCR-AB1-S-RA-SMT SmartPrj (55 1500) R270
u!WjG@ X2 POWERSUPPLY_DC21MMX POWERSUPPLY_DC-21MM SmartPrj (210 330) R90
exQU XIO 18x2F-H8.5 2X18 SmartPrj (3750 1150) R270
A ^wIsAxT Y1 12MHz KX-7 20pF CRYSTAL-3.2-2.5 SmartPrj (1475 1600) R270
MehMhHY Y2 32.768Khz RESONATOR_EPSON_FC_145 Arduino_Wifi_shield_v018_tG (1232 1152) R90
V]$J&aD Y4 16MHz KX-7 20pF CRYSTAL-3.2-2.5 SmartPrj (376 628) R0
j)neVPf%v Z1 CG0603MLC-05E CT/CN0603 varistor (312 1432) R270
DU>#eR0G Z2 CG0603MLC-05E CT/CN0603 varistor (312 1576) R90
S;]][h= Z3 CG0603MLC-05E CT/CN0603 varistor (260 972) R270
QCvz| ) Z4 CG0603MLC-05E CT/CN0603 varistor (232 816) R90
@mB*fl?- Z5 CG0603MLC-05E CT/CN0603 varistor (176 1716) R0
nVVQ^i}`G Q(J6;s#b [ 此帖被topdenzengzhi在2018-12-13 10:51重新编辑 ]
