本部分内容设定了隐藏,需要回复后才能看到(回复后还看不到就刷新一下即可)
fn#qcZv? j)ME%17 E)%DLZ qCkC 2Fy( Part Value Package Library Position (mil) Orientation
9;7Gzr6A" j*\oK@ AIN-1 TB2/3.5mm CON3-3.5MM con-wago-500 (238.97638 910.62992) R270
N TcojA{V$ AIN-2 TB2/3.5mm CON3-3.5MM con-wago-500 (239.17323 498.0315) R270
j(A>M_f; AVRISP BH10S CON2X5_SS2 gogo (3720.47244 755.90551) R270
YdDP;,
DA BUT T1107A(6x3.8x2.5mm) SW-TAKT_6X3.5_SMD gogo (2322.83465 1454.17323) R0
mW2 D"-s C1 4n7 C0603 DOUBLE-SIDE (2950.7874 1259.84252) R180
`>0%Ha C2 1uF/50v C0805@1 rcl (3442.91339 1425.19685) R0
&V|kv"Wwj C3 100n C0603 rcl (3401.5748 1320.86614) R270
E+ctiVL C4 220uF/35V E3,5-8 rcl (3324.80315 697.71654) R90
|k$6"dXSO C5 220u/10V/tant CT7343 rcl (3031.49606 1102.3622) R0
Q.?(h! )9 C6 10n C0603@1 rcl (3293.30709 1106.29921) R0
[QFAkEJ--o C7 100n C0603@1 rcl (3151.5748 2015.74803) R0
EHy 15RL C8 100n C0603@1 rcl (3151.5748 2102.3622) R0
!9.k%B: C9 47uF/6.3V CT3528 rcl (3299.2126 2070.86614) R90
$Qz<:?D C10 100n C0603 rcl (2066.92913 1257.87402) R90
}.a{;{y C11 NA C0603 rcl (2143.70079 940.94488) R0
L{&>,ww C12 33p C0603 rcl (1513.77953 1082.67717) R180
Y'{}L@"t C13 33p C0603 rcl (1645.66929 1082.67717) R0
yg.o?eML C14 100n C0603 rcl (458.66142 1236.22047) R180
ebn3r:IU- C15 100n C0603 rcl (458.66142 1149.6063) R0
k%3)J"|/ C16 100n C0603 rcl (935.03937 858.26772) R0
NH;e|8 C17 100n C0603 rcl (962.59843 1547.24409) R180
{#st>%i C18 100n C0603 rcl (1375.98425 1082.67717) R0
4> uN H5 C19 100n C0603 rcl (2157.48031 1377.95276) R270
T+^Sa
J C20 33nF C0603@1 rcl (458.66142 803.14961) R180
wFF,rUV C21 33nF C0603@1 rcl (458.66142 555.11811) R180
7]} I C22 33nF C0603@1 rcl (458.66142 307.08661) R180
_&~l,%)& C23 33nF C0603@1 rcl (458.66142 141.73228) R180
?wu@+ D1 1N5819(smd) MLL-41 gogo (2982.48031 1519.68504) R0
p5jR;nOZ%l D2 1N4148/SMD SOD80C diode (952.75591 488.18898) R270
,4S[<(T" D3 1N4148/SMD SOD80C diode (1472.44094 488.18898) R270
w$IUm_~waa D4 1N4148/SMD SOD80C diode (1996.06299 488.18898) R270
=;+gge!?bB D5 1N4148/SMD SOD80C diode (2511.81102 488.18898) R270
XD?Lu
_. D6 1N4148/SMD SOD80C diode (444.88189 1736.22047) R270
V~VUl) D7 1N4148/SMD SOD80C diode (1110.23622 1732.28346) R270
_CPj]m{ D8 1N4148/SMD SOD80C diode (1795.27559 1732.28346) R270
m.rV1#AI D9 1N4148/SMD SOD80C diode (2488.18898 1736.22047) R270
0$ON`Vsu| EXT WF6S CON2.54MM-6-0 DOUBLE-SIDE (3375.98425 3019.68504) R0
Mq#m;v$E G1 DB104(SMD) DB104_SMD DOUBLE-SIDE (2867.71654 624.96063) R180
g zlxkv-F{ GND TESTPAD40/70 TESTPAD gogo (3820.07874 294.09449) R0
qdLzB IN1 TB2/5MM W237-102 con-wago-500 (893.70079 215.35433) R0
Ypl;jkHP IN2 TB2/5MM W237-102 con-wago-500 (1413.38583 215.35433) R0
v-N4&9)%9 IN3 TB2/5MM W237-102 con-wago-500 (1933.07087 215.35433) R0
/lbj!\~ IN4 TB2/5MM W237-102 con-wago-500 (2452.75591 215.35433) R0
T ay226 JTAG BH10S CON2X5_SS2 gogo (3720.47244 2413.38583) R270
tmOy"mq67 L1 100uH/SW68 SW68 SINGLE-SIDE (2740.15748 1306.10236) R270
-.r"|\1X LED1 red LED-0805 DOUBLE-SIDE (1059.05512 591.1811) R270
r!1f>F*dt LED2 red LED-0805 DOUBLE-SIDE (1578.74016 589.92126) R270
-. o,bg LED3 red LED-0805 DOUBLE-SIDE (2102.3622 596.45669) R270
1 $1>cuu LED4 red LED-0805 DOUBLE-SIDE (2618.11024 593.30709) R270
Oe
x
O1 green LED-0805 DOUBLE-SIDE (657.48031 1755.27559) R90
r&Nh>6<&/ O2 green LED-0805 DOUBLE-SIDE (1334.64567 1751.9685) R90
(V&8
WN O3 green LED-0805 DOUBLE-SIDE (2011.81102 1751.9685) R90
H#7=s{u O4 green LED-0805 DOUBLE-SIDE (2685.03937 1753.93701) R90
q_6lD~~q^ OUT1 TB3/5MM W237-103 con-wago-500 (659.05512 2939.37008) R180
sVr|kvn2 OUT2 TB3/5MM W237-103 con-wago-500 (1334.05512 2939.37008) R180
z{&Av OUT3 TB3/5MM W237-103 con-wago-500 (2009.05512 2939.37008) R180
xe^M2$clb\ OUT4 TB3/5MM W237-103 con-wago-500 (2684.05512 2939.37008) R180
pdm(7^ PWR_J YDJ-1134 PWR_JACK_UNI gogo (3378.97638 420.35433) R90
n-2!<`UFX PWR_LED red LED-0805 DOUBLE-SIDE (3563.62205 137.79528) R0
DLP@?]BBOA Q1 8MHz/20pF HC49/SMD2_THIN crystal (1576.37795 1228.34646) R180
1X2|jj Q2 32768Hz/6pF TC26H_3_REPAIR crystal (599.52756 1347.6378) R90
p7 !y# R1 150k R0603 rcl (2950.7874 1342.51969) R180
bl&9O R2 110k R0603 rcl (3484.25197 1320.86614) R90
C[<{>fl) R3 0603_0R OLIMEX_DISCRET (2618.66142 858.26772) R0
)5n0P
Zi R4 8.2K R0603 rcl (3293.30709 1188.97638) R0
M*bsA/Z R5 2K R0603 rcl (3293.30709 1023.62205) R180
1) K<x R6 390R/1% R0603 rcl (3446.85039 2098.4252) R180
qLN\>Z,3; R7 240R/1% R0603 rcl (3446.85039 2011.81102) R180
,t QNL\t R8 1K R0603 rcl (3523.62205 257.87402) R90
34X]b[^ R9 100R R0603 rcl (2157.48031 1257.87402) R90
GApvRR+Z R10 10K R0603 rcl (2127.95276 858.26772) R180
nTc#I~\ R11 330R R0603 rcl (2377.95276 1104.33071) R90
9od c : R12 4.7K R0603 rcl (2066.92913 1377.95276) R90
JBA{i45x R13 100R R0603 rcl (1891.73228 1405.51181) R180
@{#'y4\> R14 NA R0603_NA rcl (458.66142 1066.92913) R0
H{yBDxw R15 4.7K R0603 rcl (3655.51181 1507.87402) R180
QnOs8%HS- R16 NA R0603_NA rcl (3805.11811 1251.9685) R180
n|? sNM<J3 R17 4.7K R0603 rcl (3655.51181 1610.23622) R180
s0]ZE\`H> R18 4.7K R0603 rcl (3655.51181 1708.66142) R180
X.>~DT%0Lm R19 100R R0603 rcl (458.66142 968.50394) R0
mE1Vr R20 NA R0603_NA rcl (458.66142 885.82677) R0
@YRy)+ R21 100R R0603 rcl (458.66142 720.47244) R0
{>vgtk J R22 NA R0603_NA rcl (458.66142 637.79528) R0
]mi\Y"RO R23 100R R0603 rcl (458.66142 472.44094) R0
-O,:~a=*_ R24 NA R0603_NA rcl (458.66142 389.76378) R0
AX&Emz- R25 100R R0603 rcl (458.66142 59.05512) R180
;nL7Hizo, R26 NA R0603_NA rcl (458.66142 224.40945) R0
9>0OpgvC( R27 3.9k R0603 rcl (2622.04724 438.97638) R90
wSCI? R28 47K R0603 rcl (2301.1811 858.26772) R180
8@+<W%+th R29 3.9k R0603 rcl (2106.29921 442.91339) R90
.b`8
+ R30 47K R0603 rcl (1732.28346 874.01575) R180
(w2lVL& R31 3.9k R0603 rcl (1578.74016 442.91339) R90
>);M\,1\I R32 47K R0603 rcl (1281.49606 862.20472) R0
p5OoDo R33 3.9k R0603 rcl (1059.05512 442.91339) R90
p<h( R34 47K R0603 rcl (765.74803 862.20472) R0
7)1%Z{Dy R35 1K R0603 rcl (3027.55906 1753.93701) R270
g18zo~LZ R36 10K R0603 rcl (2944.88189 1753.93701) R270
tS\Db'C7 R37 1K R0603 rcl (2578.74016 1753.93701) R90
qhG2j; R38 1K R0603 rcl (2350.3937 1757.87402) R270
Z_dL@\#| R39 10K R0603 rcl (2267.71654 1757.87402) R270
=`>ei R40 1K R0603 rcl (1885.82677 1750) R90
b@=H$" R41 1K R0603 rcl (1669.29134 1750) R270
3!cenyE R42 10K R0603 rcl (1586.61417 1750) R270
etX(~"gG_ R43 1K R0603 rcl (1196.85039 1750) R90
I(kEvfxc" R44 1K R0603 rcl (992.12598 1753.93701) R270
R rH{Y0 R45 10K R0603 rcl (909.44882 1753.93701) R270
Q(Q?L5
R46 1K R0603 rcl (531.49606 1750) R90
Gg
GjBt REL1 RAS-05-15 H200-FAT SINGLE-SIDE (659.05512 2339.37008) R90
5+Tx01) REL2 RAS-05-15 H200-FAT SINGLE-SIDE (1334.05512 2339.37008) R90
*kZH~] REL3 RAS-05-15 H200-FAT SINGLE-SIDE (2009.05512 2339.37008) R90
+t*I{X( REL4 RAS-05-15 H200-FAT SINGLE-SIDE (2684.05512 2339.37008) R90
-Jv3D$f]a RST T1107A(6x3.8x2.5mm) SW-TAKT_6X3.5_SMD gogo (2037.95276 1082.67717) R90
Wi5Dl= STAT yellow LED-0805 DOUBLE-SIDE (2511.81102 1099.05512) R90
@*L-lx T1 BC817 SOT23 semicon-smd-ipc (787.40157 1753.93701) R90
^*UtF9~%n T2 BC817 SOT23 semicon-smd-ipc (1464.56693 1753.93701) R90
(RrC<5" T3 BC817 SOT23 semicon-smd-ipc (2141.73228 1753.93701) R90
})kx#_o]'d T4 BC817 SOT23 semicon-smd-ipc (2818.89764 1753.93701) R90
7BqP3T=&_ U1 ATMEGA16L 44TQFP gogo (968.50394 1204.72441) R180
=zrfh-lwH U2 MCP130T SOT23 gogo (1954.72441 897.6378) R0
Khv}q.)F U3 H11A817SMD OPTOCOUPLER_SMD4PIN OLIMEX_DISCRET (782.28346 590.35433) R0
KRn[(yr`% U4 H11A817SMD OPTOCOUPLER_SMD4PIN OLIMEX_DISCRET (1300 592.32283) R0
\+/ciPzA- U5 H11A817SMD OPTOCOUPLER_SMD4PIN OLIMEX_DISCRET (1823.62205 592.32283) R0
ndT_;== U6 H11A817SMD OPTOCOUPLER_SMD4PIN OLIMEX_DISCRET (2343.30709 592.32283) R0
z{PPPFk4J UEXT_FEMALE IDC10S/PCB ML10L_PADS_FEMAIL con-harting-ml (3980.31496 1574.80315) MR90
"X!1^)W-8 UEXT_MALE BH10S ML10_PADS con-harting-ml (82.67717 1574.80315) R90
a{}#t} VR1(5V) BD9001FSO-8 SO-8 OLIMEX_IC (3185.03937 1350.19685) R270
i4WHjeo\ VR2(3.3V) LM1117IMPX-ADJ SOT223 arm (3283.91339 1775.6378) R180
O[L#|_BnEO
