Bill of Material ReportSYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_TOL | COMP_CLASS | REFDES |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.64M | 0.1UF | | DISCRETE | C1 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.64M | 0.1UF | | DISCRETE | C2 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 2.2uF | | DISCRETE | C3 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.64M | 0.1UF | | DISCRETE | C4 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 1000pF | | DISCRETE | C5 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.64M | 0.1UF | | DISCRETE | C6 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.64M | 0.1UF | | DISCRETE | C7 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55 | 24PF | | DISCRETE | C8 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1MM_1 | 10uF | 10% | DISCRETE | C9 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.64M | 0.1UF | | DISCRETE | C10 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.65M | 4.7UF | | DISCRETE | C11 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.64M | 0.1UF | | DISCRETE | C12 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55 | 24PF | | DISCRETE | C13 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.56M | 47PF | | DISCRETE | C14 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.56M | 47PF | | DISCRETE | C15 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.01uF | | DISCRETE | C16 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.64M | 0.1UF | | DISCRETE | C17 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.64M | 0.1UF | | DISCRETE | C18 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.64M | 0.1UF | | DISCRETE | C19 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.64M | 0.1UF | | DISCRETE | C20 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.64M | 0.1UF | | DISCRETE | C21 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.64M | 0.1UF | | DISCRETE | C22 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.64M | 0.1UF | | DISCRETE | C23 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.64M | 0.1UF | | DISCRETE | C24 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1MM_1 | 10uF | 10% | DISCRETE | C25 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.64M | 0.1UF | | DISCRETE | C26 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.64M | 0.1UF | | DISCRETE | C27 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.64M | 0.1UF | | DISCRETE | C28 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.64M | 0.1UF | | DISCRETE | C33 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1MM_1 | 10uF | 10% | DISCRETE | C34 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1MM_1 | 10uF | 10% | DISCRETE | C35 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.64M | 0.1UF | | DISCRETE | C36 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1MM_1 | 10uF | 10% | DISCRETE | C37 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1MM_1 | 10uF | 10% | DISCRETE | C38 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.64M | 0.1UF | | DISCRETE | C39 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.64M | 0.1UF | | DISCRETE | C40 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.64M | 0.1UF | | DISCRETE | C41 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.65M | 4.7UF | | DISCRETE | C42 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.64M | 0.1UF | | DISCRETE | C43 |
LED_0603 | LED_LED_0603_IC_0.45MM_370-7663 | RED | | IC | D1 |
SOT_143 | DIODE_TVS_CD143A_SOT_143_IC_1.2 | CD143A-SR05LC | | IC | D2 |
LED_0603 | LED_LED_0603_IC_0.67MM_370-7656 | LED GREEN | | IC | D3 |
SOD-123 | DIODE_SCHTKY_SOD-123_IC_1MM_480 | MBR120VLSFT1G | | IC | D4 |
SOD-123 | DIODE_SCHTKY_SOD-123_IC_1MM_480 | MBR120VLSFT1G | | IC | D5 |
SOD-123 | DIODE_SCHTKY_SOD-123_IC_1MM_480 | MBR120VLSFT1G | | IC | D6 |
SOD-123 | DIODE_SCHTKY_SOD-123_IC_1MM_480 | MBR120VLSFT1G | | IC | D7 |
LED_0603 | LED_LED_0603_IC_0.67MM_370-7656 | LED GREEN | | IC | D8 |
SOD-123 | DIODE_SCHTKY_SOD-123_IC_1MM_480 | MBR120VLSFT1G | | IC | D10 |
LED_0603 | LED_LED_0603_IC_0.45MM_370-7663 | RED | | IC | D11 |
USB_TYPE_A_12X18P8_SM | USB_A_USB_TYPE_A_12X18P8_SM_IO_ | USB-106AM-LCP | | IO | J2 |
HDR_5X2_FTSH_TH | CONN_HDR_5X2_HDR_5X2_FTSH_TH_IO | hdr_2x5 | | IO | J8 |
HDR_1X2_2P54MM | CONN_HDR_2X1_HDR_1X2_2P54MM_IO_ | HDR_1X2 | | IO | J14 |
HDR115_2MM_TH | CONN_HDR_15X1_HDR115_2MM_TH_IO_ | TMM-115-01-L-S | | IO | JP1 |
HDR115_2MM_TH | CONN_HDR_15X1_HDR115_2MM_TH_IO_ | TMM-115-01-L-S | | IO | JP2 |
IND_0603 | INDUCTOR_FERRITE_IND_0603_DISCR | 470 Ohm | | DISCRETE | L1 |
IND_0603 | INDUCTOR_FERRITE_IND_0603_DISCR | 470 Ohm | | DISCRETE | L2 |
LED4_3P4X3MM_SMT | CLV1A_LED_4P_LED4_3P4X3MM_SMT_I | CLV1A-FKB-CJ1M1F1BB7R4S3 | | IC | LED1 |
SOT23 | NPN_SOT23_IC_1.11 MM_480-75158_ | BC817-40LT1G | | IC | Q1 |
SOT23 | NPN_SOT23_IC_1.11 MM_480-75158_ | BC817-40LT1G | | IC | Q2 |
SOT23 | NPN_SOT23_IC_1.11 MM_480-75158_ | BC817-40LT1G | | IC | Q3 |
SOT23 | NPN_SOT23_IC_1.11 MM_480-75158_ | BC817-40LT1G | | IC | Q4 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4 MM_4 | 10K | | DISCRETE | R1 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40 MM_ | 180K | | DISCRETE | R2 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4 MM_4 | 10K | | DISCRETE | R3 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4 MM_4 | 10K | | DISCRETE | R4 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.41MM_1 | 4.7K | | DISCRETE | R5 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.45 MM_ | 0 | | DISCRETE | R6 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4 MM_1 | 1K | | DISCRETE | R7 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.45 MM_ | 0 | | DISCRETE | R8 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.45MM_1 | 1.0M | | DISCRETE | R9 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.41MM_4 | 33 | | DISCRETE | R10 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.45 MM_ | 0 | | DISCRETE | R11 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.41MM_4 | 33 | | DISCRETE | R12 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.41MM_1 | 4.7K | | DISCRETE | R13 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4 MM_4 | 10K | | DISCRETE | R14 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4 MM_1 | 1K | | DISCRETE | R15 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4 MM_4 | 10K | | DISCRETE | R16 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.41MM_1 | 4.7K | | DISCRETE | R17 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.45MM_4 | 470 | | DISCRETE | R18 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4 MM_1 | 1K | | DISCRETE | R19 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.45 MM_ | 0 | | DISCRETE | R20 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4 MM_4 | 10K | | DISCRETE | R21 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.41MM_1 | 4.7K | | DISCRETE | R22 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.45 MM_ | 0 | | DISCRETE | R23 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4 MM_4 | 10K | | DISCRETE | R24 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.41MM_1 | 4.7K | | DISCRETE | R25 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4 MM_4 | 10K | | DISCRETE | R26 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4 MM_4 | 10K | | DISCRETE | R27 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.45 MM_ | 0 | | DISCRETE | R28 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_47 | 1.2K | | DISCRETE | R29 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4 MM_1 | 1K | | DISCRETE | R30 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.41MM_1 | 4.7K | | DISCRETE | R31 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.41MM_1 | 4.7K | | DISCRETE | R32 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4 MM_1 | 1K | | DISCRETE | R33 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4 MM_1 | 1K | | DISCRETE | R34 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.45MM_4 | 470 | | DISCRETE | R35 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.45 MM_ | 0 | | DISCRETE | R36 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.45 MM_ | 0 | | DISCRETE | R37 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.45 MM_ | 0 | | DISCRETE | R41 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4 MM_4 | 10K | | DISCRETE | R44 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.45 MM_ | 0 | | DISCRETE | R45 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.45 MM_ | 0 | | DISCRETE | R46 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.45 MM_ | 0 | | DISCRETE | R47 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.45 MM_ | 0 | | DISCRETE | R48 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.6MM_47 | 220 | | DISCRETE | R49 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__1 | 2.2K | | DISCRETE | R50 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40 M_1 | 22K | | DISCRETE | R51 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4 MM_4 | 10K | | DISCRETE | R52 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.6MM_47 | 220 | | DISCRETE | R53 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__1 | 2.2K | | DISCRETE | R54 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40 M_1 | 22K | | DISCRETE | R55 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.45 MM_ | 0 | | DISCRETE | R56 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.6MM_47 | 220 | | DISCRETE | R57 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__1 | 2.2K | | DISCRETE | R58 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4 MM_4 | 10K | | DISCRETE | R59 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40 M_1 | 22K | | DISCRETE | R60 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.6MM_47 | 220 | | DISCRETE | R61 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__1 | 2.2K | | DISCRETE | R62 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40 M_1 | 22K | | DISCRETE | R63 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.45 MM_ | 0 | | DISCRETE | R76 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.45 MM_ | 0 | | DISCRETE | R77 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.45 MM_ | 0 | | DISCRETE | R78 |
SW2_TACT_4X3_SM | SW2P_SW2_TACT_4X3_SM_IC_2 MM_51 | KAN0444-0201E1 | | IC | SW1 |
SW2_TACT_4X3_SM | SW2P_SW2_TACT_4X3_SM_IC_2 MM_51 | KAN0444-0201E1 | | IC | SW2 |
SW2_TACT_4X3_SM | SW2P_SW2_TACT_4X3_SM_IC_2 MM_51 | KAN0444-0201E1 | | IC | SW3 |
TPAD_030 | TESTLOOP_TPAD_030_IO_0.1MM_211- | TPAD_030 | | IO | TP1 |
TPAD_030 | TESTLOOP_TPAD_030_IO_0.1MM_211- | TPAD_030 | | IO | TP2 |
TPAD_030 | TESTLOOP_TPAD_030_IO_0.1MM_211- | TPAD_030 | | IO | TP3 |
TPAD_030 | TESTLOOP_TPAD_030_IO_0.1MM_211- | TPAD_030 | | IO | TP4 |
TPAD_030 | TESTLOOP_TPAD_030_IO_0.1MM_211- | TPAD_030 | | IO | TP5 |
TPAD_030 | TESTLOOP_TPAD_030_IO_0.1MM_211- | TPAD_030 | | IO | TP6 |
TPAD_030 | TESTLOOP_TPAD_030_IO_0.1MM_211- | TPAD_030 | | IO | TP7 |
TPAD_030 | TESTLOOP_TPAD_030_IO_0.1MM_211- | TPAD_030 | | IO | TP8 |
TPAD_030 | TESTLOOP_TPAD_030_IO_0.1MM_211- | TPAD_030 | | IO | TP9 |
TPAD_030 | TESTLOOP_TPAD_030_IO_0.1MM_211- | TPAD_030 | | IO | TP10 |
TPAD_030 | TESTLOOP_TPAD_030_IO_0.1MM_211- | TPAD_030 | | IO | TP11 |
TPAD_030 | TESTLOOP_TPAD_030_IO_0.1MM_211- | TPAD_030 | | IO | TP12 |
TPAD_030 | TESTLOOP_TPAD_030_IO_0.1MM_211- | TPAD_030 | | IO | TP13 |
TPAD_030 | TESTLOOP_TPAD_030_IO_0.1MM_211- | TPAD_030 | | IO | TP14 |
TPAD_030 | TESTLOOP_TPAD_030_IO_0.1MM_211- | TPAD_030 | | IO | TP15 |
XQFN8_1P45X1P25MM | NTSX2102GU8H_8P_XQFN8_1P45X1P25 | NTSX2102GU8H | | IC | U1 |
UDFN6_1P45X1_0P5MM | NLX2G14_6P_UDFN6_1P45X1_0P5MM_I | NLX2G14 | | IC | U2 |
QFN32_S142EP | PK20DX128V_QFN_32P_QFN32_S142EP | MK20DX128VFM5 | | IC | U3 |
UDFN6_1X1P5MM | 74LVCH1T45_6P_UDFN6_1X1P5MM_IC_ | 74LVCH1T45 | | IC | U4 |
QFN8_1P6X1P6MM | 74LVC2T45GM_8P_QFN8_1P6X1P6MM_I | 74LVC2T45GM,125 | | IC | U5 |
UDFN6_1X1P5MM | 74LVCH1T45_6P_UDFN6_1X1P5MM_IC_ | 74LVCH1T45 | | IC | U6 |
UDFN6_1X1P5MM | 74LVCH1T45_6P_UDFN6_1X1P5MM_IC_ | 74LVCH1T45 | | IC | U7 |
SOT23-6_A | MIC2005-0.8YM6_SOT23-6_A_IC_1.4 | MIC2005-0.8YM6 | | IC | U8 |
SOT223 | LD1117AS18_SOT223_IC_1.8MM_312- | NCP1117ST33T3G | | IC | U9 |
QFN_34PIN_PA_MODULE | MODULE PINOUT_QFN_34PIN_PA_MODU | MODULE PINOUT | | IC | U10 |
DFN8_1P27_6X5MM_3P6X4P2 | AT45DB021E_9P_DFN8_1P27_6X5MM_3 | AT45DB041E | | IC | U11 |
XTAL4_5X3 | CRYSTAL_JXS63_XTAL4_5X3_IC_1.1M | 8MHz | | IC | Y1 |
XTAL2-3P2X1P5-SM | CRYSTAL_XTAL2-3P2X1P5-SM_IC_0.9 | 32.768KHZ | | IC | Y5 ;,Of\Efc|
