查看: 5558|回复: 21
[PADS9.5以下] SP8830A(手机板)-2_PCB_V1.0.4
    昨天 09:23
  • 签到天数: 52 天
    1元学习Allegro(1期)
    发表于 2018-12-18 17:56:26 | 显示全部楼层 |阅读模式
    重要提示:PCB作品文件展下载说明
    SP8830A-2_PCB_V1.0.4
    6层HDI    3171PIN
    NamePCB DecalValuePart Type
    D0300SOD-523DIODE-SCHOTTKY-RB521S30T1
    D4100SOD-323DIODE-SCHOTTKY-WSB5503W-2/TR
    D5100DIODE-LED-LTPL-C064WD-WADIODE-LED-LTPL-C064WD-WA
    D6100SOD-323(NF)DIODE-ZENER-PZU5.1B
    D6101DIODE-SCHOTTKY-CRS08NFDIODE-SCHOTTKY-CRS08
    D6200DIODE-SCHOTTKY-RB520G-30DIODE-SCHOTTKY-RB520G-30
    FB3100SL04021000ohm@100MHzBEAD-1K-OHM-100MHZ-250MA-0402
    FB3102SR02010RES-0-0201
    FB3103SL0603-S600ohm@100MHz 500mABEAD-600-OHM-100MHZ-0603
    FB3104SL0603-S600ohm@100MHz 500mABEAD-600-OHM-100MHZ-0603
    FB3105SR02010RES-0-0201
    FB3106SL04021000ohm@100MHzBEAD-1K-OHM-100MHZ-250MA-0402
    FB3107SL04021000ohm@100MHzBEAD-1K-OHM-100MHZ-250MA-0402
    FB3108SL04021000ohm@100MHzBEAD-1K-OHM-100MHZ-250MA-0402
    FB4100SL0603-S470ohm@100MHz 500mABEAD-470-OHM-100MHZ-0.5A-0603
    FB4102SL0603-S600ohm@100MHz 500mABEAD-600-OHM-100MHZ-0603
    FB7200SL04021000ohm@100MHzBEAD-1K-OHM-100MHZ-250MA-0402
    J0400CON-RF-SWITCH-MM8430-2610RA1CON-RF-SWITCH-MM8430-2610RA1
    J0401CON-RF-ARF00-0285051-0001CON-RF-ARF00-0285051-0001
    J3100CON-EAR-KJ-366CN-L3CON-EAR-KJ-366CN-L3
    J4101CON-FPC-FH26-33S-0.3SHW(05)CON-FPC-FH26-33S-0.3SHW(05)
    J4103CON-BTB-F-DF37NC-10DS-0.4VCON-BTB-F-DF37NC-10DS-0.4V
    J5100CON-BTB-F-BBR43-30KB533_2CON-BTB-F-BBR43-30KB533_2
    J6100CON-BAT-B09-AB03F15DCON-BAT-B09-AB03F15D
    J6200CON-USB-MICRO-HY07-AB0720CON-USB-MICRO-HY07-AB0720
    J6201CON-BTB-M-HTST-110-01-L-DV-ACON-BTB-M-HTST-110-01-L-DV-A
    J6202CON-CLIP-SHIELD-PTC0703BCON-CLIP-SHIELD-PTC0703B
    J6204CON-CLIP-SHIELD-PTC0703BCON-CLIP-SHIELD-PTC0703B
    J6206CON-CLIP-SHIELD-PTC0703BCON-CLIP-SHIELD-PTC0703B
    J6208CON-CLIP-SHIELD-PTC0703BCON-CLIP-SHIELD-PTC0703B
    J6209CON-CLIP-SHIELD-PTC0703BCON-CLIP-SHIELD-PTC0703B
    J6214CON-CLIP-SHIELD-PTC0703BCON-CLIP-SHIELD-PTC0703B
    J6215CON-CLIP-SHIELD-PTC0703BCON-CLIP-SHIELD-PTC0703B
    J6216CON-CLIP-SHIELD-PTC0703BCON-CLIP-SHIELD-PTC0703B
    J6217CON-CLIP-SHIELD-PTC0703BCON-CLIP-SHIELD-PTC0703B
    J6221CON-CLIP-SHIELD-PTC0703BCON-CLIP-SHIELD-PTC0703B
    J6223CON-CLIP-SHIELD-PTC0703BCON-CLIP-SHIELD-PTC0703B
    J6224CON-CLIP-SHIELD-PTC0703BCON-CLIP-SHIELD-PTC0703B
    J6225CON-CLIP-SHIELD-PTC0703BNFCON-CLIP-SHIELD-PTC0703B
    J6226CON-CLIP-SHIELD-PTC0703BCON-CLIP-SHIELD-PTC0703B
    J6227CON-CLIP-SHIELD-PTC0703BCON-CLIP-SHIELD-PTC0703B
    J6231CON-CLIP-SHIELD-PTC0703BCON-CLIP-SHIELD-PTC0703B
    J6232CON-BTB-F-DF37NC-16DS-0.4VCON-BTB-F-DF37NC-16DS-0.4V
    J6233CON-BTB-F-DF37NC-20DS-0.4VCON-BTB-F-DF37NC-20DS-0.4V
    J6234CON-USB-MICRO-UAF95-05254-S113CON-USB-MICRO-UAF95-05254-S113
    J6401SOCKET-SIM-WKSM018-3001SOCKET-SIM-WKSM018-3001
    J6500SOCKET-CARD-T-FLASH-WKTFH001-005SOCKET-CARD-T-FLASH-WKTFH001-005
    J7200CON-RF-SWITCH-MM8430-2610RA1CON-RF-SWITCH-MM8430-2610RA1
    J7202CON-RF-SWITCH-MM8430-2610RA1CON-RF-SWITCH-MM8430-2610RA1
    TVS3125TVS-ESD9L5.0ST5GTVS-ESD9L5.0ST5G
    TVS4100SOT-553-5TVS-NZQA6V8XV5T1G
    TVS4102SOD-523NFTVS-ESD5Z5.0T1G
    TVS6100SOD-523TVS-ESD5Z3.3T1G-3.3V-105PF-SOD-523
    TVS6200TVS-ESD9L5.0ST5GTVS-ESD9L5.0ST5G
    TVS6201TVS-ESD9L5.0ST5GTVS-ESD9L5.0ST5G
    TVS6202SOD-523TVS-ESD5Z7.0T1G
    TVS6203TVS-ESD9L5.0ST5GTVS-ESD9L5.0ST5G
    TVS6204TVS-ESD9L5.0ST5GTVS-ESD9L5.0ST5G
    U0200BGA7.9X7.9-201-0.5-SC2713ASIC-SC2713-201-0.5
    U0400RF-TRANCEIVER-SR3500ARF-TRANCEIVER-SR3500A
    U0401RF-SW+PA-SKYWORKS-6X6-28PINRF-SW+PA-SKY77590-51
    U0402RF-PA-SKYWORKS-3X3-10PINRF-PA-SKY77709
    U0403RF-SAW-1.35X1.052.35GRF-SAW-SAFEA2G35MB0F00
    U0404RF-SAW-1.80X1.35RF-SAW-SAWEN1G84BH0F00
    U0405RF-SAW-1.35X1.05RF-SAW-SAFEA2G34FA1F00
    U0406RF-SAW-1.80X1.35RF-SAW-SAWEN881MCX0F00
    U0407RF-SAW-SAWFD1G90CA0F00RF-SAW-SAWFD1G90CA0F00
    U0500BGA11.5X13-162-0.5MEM-NAND+LPDDR2-K5A4G2GQCM-B019
    U2100BGA12.5X12.5-539-0.4-SC5735AASIC-SC5735A-539-0.4
    U3103ANA-SWITCH-PI3A223ZMEANA-SWITCH-PI3A223ZME
    U3104ANA-SWITCH-PI3A223ZMEANA-SWITCH-PI3A223ZME
    U4100CMF+ESD-1.27X1.0-ICT90ohm @ 100MHzCMF+ESD-ICMEF112P900MFR-90-OHM
    U4101CMF+ESD-1.27X1.0-ICT90ohm @ 100MHzCMF+ESD-ICMEF112P900MFR-90-OHM
    U4102CMF+ESD-1.27X1.0-ICT90ohm @ 100MHzCMF+ESD-ICMEF112P900MFR-90-OHM
    U4103CMF+ESD-1.27X1.0-ICT90ohm @ 100MHzCMF+ESD-ICMEF112P900MFR-90-OHM
    U4104CMF+ESD-1.27X1.0-ICT90ohm @ 100MHzCMF+ESD-ICMEF112P900MFR-90-OHM
    U5101CMF+ESD-1.27X1.0-ICT90ohm @ 100MHzCMF+ESD-ICMEF112P900MFR-90-OHM
    U5102CMF+ESD-1.27X1.0-ICT90ohm @ 100MHzCMF+ESD-ICMEF112P900MFR-90-OHM
    U5103CMF+ESD-1.27X1.0-ICT90ohm @ 100MHzCMF+ESD-ICMEF112P900MFR-90-OHM
    U5104CMF+ESD-1.27X1.0-ICT90ohm @ 100MHzCMF+ESD-ICMEF112P900MFR-90-OHM
    U5105CMF+ESD-1.27X1.0-ICT90ohm @ 100MHzCMF+ESD-ICMEF112P900MFR-90-OHM
    U5200SENSOR-MOTION-LIS3DHSENSOR-MOTION-LIS3DH
    U6100MICROFET-2X2nfFET-P-FDMA6023PZT
    U6200USB2UART-FT4232HL-LQFP64USB2UART-FT4232HL-LQFP64
    U6201SOT23-53.3VPOWER-LDO-XC6219B332MR
    U6202DRIVER-LINE-TXS0102DCURDRIVER-LINE-TXS0102DCUR
    U6203DRIVER-LINE-TXS0102DCURDRIVER-LINE-TXS0102DCUR
    U6205DRIVER-LINE-TXS0102DCURDRIVER-LINE-TXS0102DCUR
    U6500SOT-89-5L3.3V 800mA(NF)POWER-LDO-WL2803K33-5/TR
    U7200BT+WIFI+FM+GPS-SR2351BT+WIFI+FM+GPS-SR2351
    U7202RF-SAW-LFB212G45CL1D172RF-SAW-LFB212G45CL1D172
    U7203RF-SAW-1.35X1.05RF-SAW-SAFEA1G57KE0F00
    U7204RF-LNA-GPS-BGU7005RF-LNA-GPS-BGU7005
    U7205RF-SAW-1.35X1.05RF-SAW-SAFEA1G57KE0F00
    U7206RF-SW+PA-2.4G-RFX8422RF-SW+PA-2.4G-RFX8422
    U7207SOT23-53.3VPOWER-LDO-WL2801E33-5/TR
    U7208DRIVER-BUFFER-NB3L02-DDRIVER-BUFFER-NB3L02-D
    U7209SC70-5LOGIC-GATE-NL17SZ04DFT2G
    X0200XTAL-CRYSTAL-32.768K-TFX-02-12.5-J0117332.768KXTAL-CRYSTAL-32.768K-TFX-02-12.5-J01173
    X0400CRYSTAL-26M26MHzXTAL-CRYSTAL-SQ3D02600B2IBA
    X6200CRYSTAL-12MXTAL-CRY-E3SB12.0000F18E33
    Y7200XTAL-TCXO-26MHZ-1XTW26000CCA26MHzXTAL-TCXO-26MHZ-1XTW26000CCA
    SP8830A-2_PCB_V1.0.4.rar
    3.59 MB, 下载次数: 11, 下载积分: 金币 -5 枚
    重要提示:PCB作品文件展下载说明
    昨天 10:08
  • 签到天数: 226 天
    发表于 2018-12-18 20:21:05 | 显示全部楼层
    PADS-180606高级班
    社区居民终身成就奖特殊贡献奖优秀斑竹奖
    发表于 2018-12-18 23:27:40 | 显示全部楼层
    生活就是油盐酱醋再加一点糖,快活就是一天到晚乐呵呵的忙!
    PADS-171101高级班
    终身成就奖社区居民优秀斑竹奖特殊贡献奖
    发表于 2018-12-19 07:56:09 | 显示全部楼层
    PADS-171101高级班
    终身成就奖社区居民优秀斑竹奖特殊贡献奖
    发表于 2018-12-19 07:56:19 | 显示全部楼层
    社区居民忠实会员社区劳模特殊贡献奖最爱沙发终身成就奖优秀斑竹奖原创先锋奖
    发表于 2018-12-19 08:38:05 | 显示全部楼层
  • 签到天数: 6 天
    承接PCB设计
    发表于 2018-12-19 08:39:48 | 显示全部楼层
    发表于 2018-12-19 08:50:10 | 显示全部楼层
    PADS高级班留级2期
    发表于 2018-12-19 08:51:23 | 显示全部楼层
    社区居民终身成就奖优秀斑竹奖社区明星宣传大使奖特殊贡献奖原创先锋奖
    发表于 2018-12-19 08:51:44 | 显示全部楼层
