v1<gNb)` RK_MINIEVB_RV1108_V10开发板 资料 6层板 3198pin PCB文件 , 原理图文件,,2018年2月发布的 配套的用户手册 都在最 最底下 下面,BOM下面 8^M5k%P r)Ts(#Z _F>1b16:/P :zfnp,Gv Bill Of Materials January 25,2019 19:42:52 Page1 E0[!jZ:c EQ`;=I3J9y {Item} {Quantity} {Reference} {Value} {pcb footprint} {Quantity} ?g|K"P<1 ______________________________________________ -cs
4< w]]`/` 1 1 ANT1 ANT_DIPOLE_1 ANT2_40R00X9R00 1 -q' n p0H 2 30 C1003,C1005,C1014,C1403, 1uF C0402 30 )V~Fl$A C1601,C1703,C1804,C1805, 9|WBJ6 C1806,C1907,C2202,C2205, 6}
"?eW C2221,C2224,C2230,C2501, q9o =,[ C3004,C4402,CC4408,C4410, cnvxTI< C4414,C4418,C4813,C4901, '`?\CXX C7900,C8001,C8006,C8009, ^_6%dKLK C8201,C8202 ~K% ]9
3 2 CM2500,CM4900 47uF/16V MTM-B 2 z1}YoCj1 4 1 CON2000 2_54MM-3P cn3_2r54_dip 1 [0.>:wT 5 1 CON4400 FPC24-0.5 CON24_0R50 1 75i
M_e\ 6 2 CON4401,CON4402 FPC30-0.5 CON30_0R50 2 w,TyV%b[_ 7 2 C25,C6025 NP C0402 2 c:I1XC 8 1 C55 220nF C0402 1 -v?,{?$0 9 2 C1000,C1002 12pF C0402 2 *}R5=r0 10 128 C1001,C1004,C1006,C1007, 100nF C0402 128 ;e;lPM{+ C1008,C1009,C1010,C1011, nR4L4tdS C1012,C1013,C1100,C1101, v:1l2Y)g C1102,C1200,C1204,C1303, {:m5<6?x) C1304,C1305,C1400,C1401, 0h!2--Aur C1402,C1501,C1600,C1602, h`+Gs{1qw C1700,C1701,C1702,C1705, 2!f0!<te C1707,C1800,C1801,C1802, }u
cqzdk#2 C1901,C1904,C1906,C1908, `%AFKmc^; C2000,C2005,C2007,C2010, 84L!r C2013,C2030,C2035,C2200, f/Km$#xOr C2208,C2212,C2217,C2222, cd{3JGgB C2223,C2233,C3005,C3006, &N1C"Eov? C3007,C3008,C3009,C3010, 9(lIz{ C3011,C3012,C4100,C4101, zYpIG8"o5 C4102,C4400,C4403,C4404, 5&7)hMppI C4405,C4407,C4409,C4413, }<7Dyn, C4417,C4421,C4422,C4423, ac>}$Uw) C4424,C4425,C4428,C4429, RtH[OZu(8 C4430,C4431,C4432,C4433, dvxD{UH C4434,C4435,C4436,C4437, AbUU#C7 C4441,C4442,C4443,C4444, Tj*o [2mD C4814,C4817,C4900,C4902, ,'5P[- C5301,C5302,C5303,C6021, ;d G.oUk= C6028,C6200,C6201,C6202, % \N.m/5 C6205,C6206,C6207,C7001, bL_s[-7 C7007,C7008,C7009,C7011, S#0y\ C7014,C7015,C7021,C7901, }#zE`IT C7903,C7904,C7906,C7914, ?"+'OOqik C7915,C7918,C8000,C8007, nkHr(tF
7 C8010,C8100,C8101,C8203, 2#_9x7g+ C8205,C8207,C8332,C8712 z/ T| 11 13 C1015,C1016,C1306,C2209, 22uF C0603 13 %8`zaa C2211,C2213,C2214,C2216,
j^KM C2236,C2239,C2244,C2247, @
:Q];rc C5300 !Y=s_)X 12 8 C1017,C2002,C2225,C2226, 22uF C0805 8 9UOx~Ty C2227,C2228,C2229,C6020 lnbw-IE! 13 23 C1201,C1203,C1205,C1206, 4.7uF C0603 23 n-,~Bp
[ C1207,C1900,C1902,C1905, TCU|k , C1909,C2004,C2207,C2218, 6v GcM3M C2231,C2232,C2241,C2242, NF0IF#;a C2243,C4401,C4406,C4412, hw_7N)} C4416,C4420,C8004 eC9~
wc 14 5 C1202,C1704,C6008,C6009, DNP C0402 5 C JiMg'K C8705 l1jS2O( 15 12 C1300,C1301,C1500,C1709, 1nF C0402 12 %xxe U C2249,C2250,C3000,C3001, pX6T7 C3013,C7006,C7012,C8713 '\1%%F7 16 5 C1302,C4426,C8002,C8008, 10nF C0402 5 <| |Lj C8704 /.'1i4Xa1P 17 4 C1706,C1708,C2215,C8003 1uF C0603 4 8v1asFxs. 18 1 C1903 100nF C0603 1 5gF}7D@ 19 5 C2001,C2210,C2234,C2235, 22pF C0402 5 Y8.0R-:ZAN C6006 A42At] 20 1 C2003 100uF E_E7 1
)%;#~\A 21 22 C2008,C2201,C2204,C2220, 10uF C0603 22 '7>Vmr6 C2237,C2238,C2245,C2246, \#tr4g~u C2248,C3002,C3003,C4427, #Vul#JHW C4438,C4439,C4440,C4903, |Y(].G, C6001,C6203,C6204,C7002, f:7Y C7013,C8102 F
xFK 22 7 C2203,C2219,C6014,C6016, 0.1uF C0402 7 "$0f.FO:i C6024,C6029,C6030 8i-?\VZD 23 5 C2206,C2240,C4411,C4415, 47pF C0402 5 A40 -])'! C4419 'P@a_*I 24 6 C3014,C7003,C7004,C7005, 100pF C0402 6 CvQ LF9| C7908,C7910 z &<Rx[ 25 1 C4800 20pF C0402 1 W7(OrA! 26 2 C4806,C6005 10pF C0402 2 g?j"d{.9t 27 1 C4807 390pF C0402 1 U{>!`RN 28 1 C4816 2.2uF C0402 1 54uTu2 29 2 C6007,C6039 4.7uF C0402 2 H/)= 30 2 C6010,C6011 1.2pF C0402 2 ,)]ZD H 31 7 C6013,C6015,C6017,C6018, NC/5.6pF C0402 7 Syp|s3u; C6022,C6023,C8706 pKEMp&geo 32 2 C6034,C6035 6.2pF C0402 2 q6j]j~JxB 33 3 C6036,C6037,C6038 33pF C0402 3 ]qV J> 34 1 C6208 102/2KV C1206 1 7{<F6F^P 35 5 C7000,C7010,C7902,C7905, 10uF C0805 5 H:[z#f|t C8331 cR@z^ 36 1 C7020 10uF C1206 1 D>G&aQ 37 2 C7907,C7909 22uF C1206 2 DT 9i<kl 38 2 D3,D8204 SS32 DO214AC 2 ! \awT 39 1 D1200 BAT54C SOT_23 1 k[v n: 40 9 D1201,ED1500,ED2000, ESD5451N ESD0402 9 -vjjcyTt ED2201,ED2202,ED4901, uT-WQ/id ED7000,ED7001,ED8204 MIR17%G 41 2 D2001,D2002 SS32 DO_214AC 2 JH)&Ca>S 42 1 D2003 1N4148W SOD_123 1 G)< k5U4 43 1 D4800 BAT54S SOT_23 1 tD4IwX 44 2 D8000,D8001 1N4148WS SOD_323 2 cK-!Evv 45 11 D8100,D8101,D8102,D8103, ESD5471X ESD0402 11 saRB~[6I D8104,D8105,D8106,ED8200, dk(-yv' ED8201,ED8202,ED8203 :A[bqRqe 46 1 D8108 1N5819 SOD123 1 n]j(tP 47 1 D8200 B5819W SOD_123 1 Ok:@F/ v 48 1 D8201 BZT52C3V0 SOD_123 1 b7>;UX 49 1 D8203 ESD5641D12 DFN3_2R00X2R00X0R65 1 zG@!(
50 2 ED2200,ED4900 AZ5825-01F ESD0402 2 F`u{'w:Hv 51 1 ED6000 ESD5311N ESD0402 1 j zPC9 52 8 FB1700,FB4400,FB4401, 180R-100M L0603 8 ZVGw@3 FB4402,FB4403,FB5303, jG.*tuf FB5304,L6200 o9~qJnB/O 53 2 FB2000,FB4900 90R-100M L0603D 2 6@I7UL > 54 1 F2000 JK-SMD200L-24 F8050 1 eQ9x l 55 1 J2000 12V DC-0007-5P 1 -y/?w*Cx 56 4 J2200,J2201,J2202,J2203 GND_GATE CN2_5R08_DIP 4 Hb]7>[L 57 6 J4400,J4401,J4402,J4403, PJ270 PJ270 6 /FYa{.Vlr J4801,J4900 {M%"z,GL7J 58 1 J4800 AV1-8.4-5G_Y AV1-8R4-5G 1 J,~)9Kh$ 59 1 J6200 HR911105A HR911105A 1 r{<u\>6X>P 60 1 J7000 30PIN FPC CON CNN30_1R00_FP05SL_V 1 hh8UKEM- 61 1 J7001 CON2 cnn2_2r00_6r30x4r90x6r30_v 1 M?\)&2f[Z 62 1 J7900 USBmin USB-5PAA 1 L>L4%? 63 1 J7901 JTAG_ARM JTAG_ARM 1 d3{Zhn@ 64 1 J7902 CON4_1.27mm CON4_1R27mm 1 Y]Fq)- 65 1 J8100 TF_SD_SOCKET TF-CKT01-009D 1 &
9?vQq|% 66 1 J8202 HDMI_A HDMIA19_HDMI_01A 1 \7C >4 67 1 J8303 JTAG_DSP JTAG_DSP 1 VJ$C)0xQA 68 2 LED2200,LED7904 LED_GREEN LED0603 2 aIfog+Lp 69 1 LED7903 LED_RED LED0603 1 }pTj8Tr 70 1 LED7905 LED_BLUE LED0603 1 DC$
S.
{n 71 1 L3 2u2H IND_303015 1 FF_$)%YUp 72 1 L2000 4.7uH IND_404030 1 A>4k4*aFm# 73 2 L2200,L2201 2.2uH IND_303010 2 =}q4ked/ 74 4 L2202,L2203,L2204,L2205 1uH IND_323015 4 m+u>%Ys` 75 1 L4800 1.8uH L0603 1 Tbwq_3fK 76 1 L6000 2.2nH L0402 1 pDKJLa 77 1 MIC7000 MIC-4020 MIC2_4020 1 k|lxJ^V# 78 6 M1,M2,M3,M4,M5,M6 MARK MARK 6 .xk<7^ZD 79 3 Q1100,Q1101,Q1800 S8050 SOT_23 3 7"[lWC!As5 80 4 Q2000,Q2001,Q2200,Q8702 AO3401 SOT23 4 J%A`M\ 81 2 Q4801,Q4802 8050 SOT23 2 z)]EB6uRg 82 2 Q7900,Q8700 WPM2341-3/TR SOT_23 2 +(/Z=4;,[ 83 4 Q7901,Q7903,Q8200,Q8201 WNM2021-3/TR SOT_323 4 IB?A]oN1{ 84 4 Q7902,Q8000,Q8001,Q8701 MMBT3904 SOT_23 4 e;pNB 85 1 Q8100 WPM2015-3/TR SOT_23 1 lGM3?AN 86 1 Q8204 WNM3018-3/TR SOT_23 1 pUwX
cy<n 87 2 R2,R14 100KR R0402 2 lZua"Ju 88 154 R4,R1101,R1102,R1111, 0R R0402 154 cj8r-Vu/N R1115,R1119,R1120,R1121, CVUJ(D&Q R1123,R1124,R1127,R1128, tEEhSG)s% R1129,R1130,R1131,R1132, }3*h`(Bv7 R1133,R1134,R1135,R1140, +
zrwz\ R1141,R1142,R1143,R1144, |knP R1201,R1203,R1205,R1403, 6d.m@T6~ R1404,R1406,R1407,R1600, /Z% ?; R1604,R1605,R1606,R1607, K;97/"
R1608,R1609,R1610,R1611, ,,Db:4qfjD R1612,R1613,R1614,R1615, .kYzB.3@] R1616,R1617,R1618,R1619, mvL'l) R1620,R1621,R1622,R1623, g SwG=e\ R1624,R1625,R1715,R1716, 0Fw\iy1o R1717,R1718,R1719,R1721, N Hh
R1722,R1723,R1724,R1725, C[KU~@ R1726,R1744,R1746,R1748, ;`+RSr^8$ R1750,R1752,R1754,R1756, S]o R1758,R1760,R1761,R1762, Ly<;x^D R1805,R1806,R1807,R1808, j(BS;J$i R1809,R1810,R1811,R1812, !Q3Snu= R1822,R1823,R1824,R1825, R P X`2zr R1826,R1827,R1828,R1829, =%u|8Ea*` R1830,R1831,R1832,R1833, KALg6DZe: R1834,R1835,R1836,R1837, 2at?9{b R1838,R1839,R1840,R4403, LAKZAi%O0 R4404,R4439,R4444,R4446, 6m"
75 R4456,R4457,R4459,R4461, UbibGa=
) R4463,R4464,R4465,R4466, ^hHeH:@ R4822,R4823,R5300,R5301, 0B4(t6o R5302,R5303,R6005,R6006, Hb+#*42v R6008,R6012,R6201,R6202, 'f}S,i +q R6203,R6206,R6209,R6210, 0;H6b= R6211,R6212,R6213,R6214, u20b+c4 R6215,R6216,R6217,R6218, 48ma&f; R8002,R8003,R8011,R8012, p)^:~ll R8013,R8014,R8015,R8016, ]6;AK\9TM R8018,R8019,R8020,R8100, h]MVFn{ R8737,R8740 M$W#Q\<*#r 89 4 R10,R4406,R4412,R4418 NC R0402 4 .fsk DW 90 1 R15 NP R0402 1 )ra66E 91 4 R36,R2211,R2217,R2219 0.1R R0805 4 (rG1_lUDu 92 22 R1000,R1122,R1800,R4428, 22R R0402 22 u/[]g+ R4429,R4433,R4434,R4438, GA_`C"mx R4442,R6007,R6017,R6019, 3uw7 J5x R6021,R6023,R6025,R6026, ],YYFU} R8104,R8105,R8106,R8107, :.Qe=}9 R8108,R8109 :|M/+XPu 93 35 R1001,R1002,R1003,R1109, 0.1R R0603 35 \zI&n &T R1200,R1202,R1204,R1400, Crhi+D R1402,R1405,R1509,R1601, BXo|CITso R1701,R1707,R1714,R1803, V0 F30rK R1804,R1813,R1821,R1900, e8 7-
B1` R1902,R1903,R1904,R2212, n2{{S(N R2238,R2240,R2241,R4411, jDX<iX%e R4423,R4451,R4900,R4911, $vLV<
y07 R7013,R7021,R8208 |3s&Y`x-D 94 5 R1004,R2224,R2234,R2235, 100R R0402 5 3NN'E$"3 R7015 CdDd+h8 95 63 R1100,R1106,R1107,R1500, 10K R0402 63 ?66(t R1507,R1508,R1510,R1820, YU=ZZEVi R2013,R2015,R2030,R2230, )h0E$* R2233,R4000,R4001,R4002, IOkC [([ R4431,R4432,R4450,R4452, '=
<`@ R4453,R4454,R4820,R4824, i5KwYoN R4826,R6016,R6018,R6020, >NRz*h # R6022,R6024,R6027,R6028, klJ[ {p R6120,R6204,R7017,R7018, ?GNF=#=M R7019,R7020,R7022,R7912, z>33O5U R7913,R7914,R7915,R7916, :dguQ|e R7917,R7918,R7919,R7923, n]DN xC@b R7924,R7926,R7927,R7928, HQ3`:l R7929,R7930,R8001,R8004, j 3MciQ` R8017,R8102,R8217,R8218, bjBeiKH R8710,R8745,R8761 _`_IUuj$E 96 13 R1103,R1108,R1113,R1818, 47K R0402 13 6rQpK&Jx R1819,R2005,R2012,R2203, (bx\4Ws R2205,R2213,R4407,R8005, aoDD&JE R8007 m6r )Z5}f 97 2 R1104,R1114 39K R0402 2 [u9JL3 98 2 R1105,R4409 68K R0402 2 [Hj'nA^ 99 9 R1300,R1301,R3000,R3001, 1K R0402 9 WYC1rfd= R7014,R7016,R8009,R8201, R==cz^# R8711 8F^,8kIR 100 3 R1302,R3002,R3003 240R R0402 3 uR;-eK 101 1 R1401 133R R0402 1 ~$4.Mf,u 102 1 R1501 10R R0402 1 }utNZhJ 103 1 R1503 1.2K R0402 1 P$3=i`X!nw 104 1 R1505 1.8K R0402 1 o? i.v0@!K 105 7 R1506,R2221,R2231,R2232, 2.2K R0402 7 v0C;j(2zb R4401,R4402,R8762 oKYhE 106 1 R1511 3K R0402 1 lP* 107 15 R1512,R2011,R2201,R2220, 4.7K R0402 15 eky(;%Sz R2223,R2505,R4100,R4413, 5eOj,[? R4419,R4910,R8000,R8202, qggk:cN1 R8203,R8210,R8211 N<06sRg# 108 1 R1513 6.8K R0402 1 Wzqb>. 109 9 R1514,R2016,R2031,R4455, 15K R0402 9 rMHQzQ0% R4458,R4460,R4462,R4821,
_@!QY
R4825 FKox0Jmh= 110 8 R1602,R1731,R1901,R7901, 2K R0402 8 (]Ye[j^"7 R7904,R7905,R7922,R7925 a_{io`h3& 111 2 R1603,R4417 0.1R R0402 2 hDljY!P>p 112 1 R1735 1R R0603 1 =zm0w~']E! 113 12 R1801,R1816,R2000,R2014, 100K R0402 12 abo>_"9- R2202,R2226,R2229,R6010, *`ZB+ \* R7907,R7910,R8008,R8709 VyWYfPK 114 1 R1802 33R R0402 1 .%?-As 115 1 R1815 124K R0402 1 WQ[}&kY~ 116 1 R1817 66.5K R0402 1 i
Y*o;z,~ 117 5 R1909,R1910,R2002,R2209, 200K R0402 5 q9^Y?` R8006 %{7_E*I@n 118 5 R2001,R2204,R2214,R2218, 1M R0402 5 %o@['9U[j R4909 dK}WM46$ 119 1 R2003 13K R0402 1 E- )VPZ1D 120 7 R2004,R2206,R2207,R4408, 120K R0402 7 d&|z=%9xl R4414,R4420,R4421 ({%oi h 121 4 R2006,R2009,R4901,R4904 2.2R R0603 4 dG\U)WA(p 122 1 R2010 470K R0402 1 mDQEXMD 123 2 R2208,R4410 130K R0402 2 2W3NL|P 124 1 R2210 36K R0402 1 _[OF"X2 125 1 R2215 590K R0402 1 _F`$ d2 126 2 R2216,R2227 180K R0402 2 NoCDY2 $ 127 3 R2222,R8010,R8757 510K R0402 3 ;&Bna#~B 128 1 R2225 56K R0402 1 Ot`LZ"H: 129 1 R2228 430K R0402 1 XM6".eF)M 130 4 R2236,R2237,R2239,R8738 0.02R R0603 4 ~u /aOd 131 7 R2504,R4440,R4441,R4443, DNP R0402 7 s\'y-UITi1 R4445,R6205,R6207 Xhcn] 132 2 R3004,R3005 49.9R R0402 2 b
, juF2 133 2 R3314,R8739 0.02R R0805 2 C.J`8@a]? 134 2 R4400,R4405 51K R0402 2 L*g.
6+2 135 1 R4415 102K R0402 1 :}y9$p
136 2 R4416,R8760 82K R0402 2 #NvQmz?J? 137 1 R4422 300K R0402 1 0]AN; 138 5 R4424,R4425,R4426,R4427, 75R R0402 5 4q>7OB:e R4802 Ih.rC>)rx 139 1 R4430 5.6K R0402 1 *16<M)7 140 12 R4435,R4816,R4902,R4903, 0R R0603 12 ^WE4*.( R4905,R4906,R4907,R6219, .sM<6; R6220,R6221,R6222,R8216 /g_9m 141 2 R4436,R4437 22R RP4_0408 2 ?y~TC qV 142 1 R4811 18K R0603 1 ))7LE|1l 143 2 R4812,R4819 100K R0603 2 4k8*E5cx 144 1 R4814 10K R0603 1 D.'h?^kA 145 1 R4817 47R R0603 1 lVPOYl% 146 1 R4818 28R R0603 1 +I t#Z3 147 3 R6200,R7906,R7911 1.5K R0402 3 ]@v}y& 148 1 R6208 4.87K R0402 1 &V'519vmoZ 149 4 R6223,R6224,R6225,R6226 49.9R R0603 4 'E4AV58. 150 2 R6227,R6228 510R R0402 2 &
_; y.! 151 2 R7908,R7909 27R R0402 2 HTmI1 152 2 R7920,R7921 0R R0805 2 V=pMq?Nr 153 1 R8712 22K R0402 1 Hd9XfU 154 9 SMTSO1,SMTSO2,SMTSO3, SMTSO3080CTJ SMTSO_M3_C4R1_C6R0_L8R0 9 ^ eQFg> SMTSO4,SMTSO5,SMTSO6, qnB<k,8T SMTSO7,SMTSO8,SMTSO17 dsJm>U) 155 2 SMTSO9,SMTSO10 SMTSO2050CTJ SMTSO_M2_C3R6_C6R0_L5R0 2 @q K]JK 156 6 SMTSO11,SMTSO12,SMTSO13, SMTSO3050CTJ SMTSO_M3_C4R1_C6R0_L5R0 6 bS.s?a SMTSO14,SMTSO15,SMTSO16 (Uk>?XAr 157 1 SW1 Update SW-5P 1 7A5p["?Z 158 1 SW1501 ESC/RECOVERY sw-5p 1 L!t@-5~
159 1 SW1502 RIGHT sw-5p 1 9 Ycn0 160 1 SW1503 UP/REC sw-5p 1 q:I$EpKf?Q 161 1 SW1504 DOWN/MIC sw-5p 1 tz26=8 162 1 SW1505 LEFT sw-5p 1 3jjMY 163 1 SW1506 MENU sw-5p 1 kb71q:[ 164 1 SW1507 MODE/TAB sw-5p 1 ohUdGO[/ 165 1 SW1508 ENTER sw-5p 1 {(
#zcK 166 1 SW1509 RESET sw-5p 1 'JieIKu 167 1 SW1510 PWR sw-5p 1 j~;;l!({i 168 1 S501 PSW3_B SW3-JT601-103AB2 1 f`jc#f5+' 169 11 TP10,TP12,TP13,TP14, TP_1.0 TP_1R00 11 8WL8/ TP1800,TP4805,TP4810, &(EHq TP7900,TP7901,TP7902, dBSbu=^$ ) TP7918 NYwR2oX 170 12 TP1000,TP1001,TP1002, TEST_METAL_RING TP_1R00 12 ~@T<gA9V TP1101,TP1102,TP2201, >nzu],U TP2203,TP2204,TP2205, QT!
4[,4 TP2206,TP2207,TP5300 mpgO s 171 7 TP2000,TP2001,TP2002, TP_0.7 TP_1R00 7 $&{ti.l TP2003,TP4900,TP4901, ;}qhc l+ TP4902 +k.%PO0np 172 2 T2,T1704 TP TEST_METAL_RING 2 ndink$ 173 1 USB2000 HUM011D-5-S microUSB_DIP 1 ~. YWV 174 1 USB4900 USB-HUB_PORTBA USB20A4_USB_AF_01_001 1 ~e `Bq> 175 1 U2 NVP6124B_76QFN QFN76_9R00X9R00X0R80_S 1 <A>)[u 176 1 U6 RTL8703BS/8723CS QFN40_5R00X5R00X1R00_T 1 pd3,pQ 177 5 U10,U11,U12,U1801,U2201 TT2102 SOT_23_5 5 ]5}=^ 178 1 U1001 RV1108 BGA359_14R00X14R00X1R20 1 u7fK1 ^O 179 1 U1201 PT5108E23E-18 SOT_23_5 1 f$.?$ 180 1 U1800 MPU-6500 QFN24_3R00X3R00X0R90 1 ZE?f!ifp 181 1 U2000 SY8113B SOT_23_6 1 Fk"Ee&H)( 182 6 U2002,U4900,U4902,U6210, ESD5302F SOT_23 6 J NVr U6211,U7901 DZ$`
4;C[ 183 1 U2200 XC6228D122VR-G SOT_23_5 1 k|vI<:'p, 184 1 U2202 SY8089AAC SOT_23_5 1 QzOkpewf 185 1 U2203 SY7069 SOT_23_6 1 r@U3sO#N 186 1 U2204 PT5108E23-33 SOT25 1 J@_ctGv 187 1 U2205 PT6181E23E SOT_23_5 1
|l0Ea 188 1 U2206 RK805-2 QFN32_4R00X4R00X0R90_T 1 26 I 189 3 U2500,U4901,U8202 SY6280AAC SOT_23_5 3 H#i{?RM@l 190 1 U3000 256x16bit,800M FBGA96_14R00X11R00X1R20 1 \3Pv# ) 191 1 U4002 GD25Q256C SOP16-10R50X7R60X2R75 1 \25/$Ae}c 192 1 U4100 TC58BVG0S3HTA00 TSOP48_18R40X12R10X1R20 1 ehNzDr\s 193 2 U5300,U6301 61083-041402LF CNN40_0R80_61083 2 X(A.X:" 194 1 U6200 DP83848N QFN40_58 1 >&,[H:Z 195 1 U7000 CS8508E SOP8_5R00X4R00X1R75_T 1 G(iJi 196 1 U7900 FT232RL SSOP28 1 izgp*M, 197 1 U8000 BMA250 LGA12_2X2MM 1 `'I{U5;e 198 2 U8200,U8201 ESD5304D SLP2510P8 2 2S"Nf8>zp 199 1 Y1000 24MHz CRY4_3R20X2R50X0R80 1 \f:z+F!6R 200 1 Y2200 32.768KHz CRY2_6R90X1R40X1R30 1 6at1bQ$ 201 1 Y4400 27MHzOSC CRY4_3R20X2R50X0R80 1 7F^#o-@=J 202 1 Y8302 24.000MHz CRY4_3R20X2R50X0R80 1 Yd
EptAI .zg8i_ 原理图文件 购买后,将显示帖子中所有出售内容。 管理员提醒:此类销售贴,谨慎购买,有可能里面什么都没有,也可能有资料但不能下载。请谨慎。再谨慎购买。。 若发现会员采用欺骗的方法获取积分,请立刻举报,我们会对该会员处以N倍的罚金,严重者封掉ID! 此段为出售的内容,购买后显示 ,PCB文件 此段为出售的内容,购买后显示 ,用户指南 此段为出售的内容,购买后显示 ,原理图 PDF原理图PDF RK_MINIEVB_RV1108_V10_20170524LYH.pdf (767 K) 下载次数:9 ;5_{MCPM t5B7I59 JyL a#\ R [ 此帖被pekyhuang6在2019-01-25 20:59重新编辑 ]
