论坛风格切换切换到宽版
发帖 回复
  • 10918阅读
  • 72回复
[Pads_VX.2x]全球首发-MT8173 /MTK8173方案平板电脑PCB原理图(MT6397S+GSL3692+MT6630) [复制链接]
上一主题 下一主题
在线老吴
性别:
帅哥
发帖
15545
金币
156970
提示:会员销售的附件,下载积分 = 版块积分 + 销售积分       图酷模式  只看楼主 倒序阅读 使用道具 0楼 发表于: 2020-10-22
重要提示:本版需2级以上才能下载,有些需购买的帖,若没2级请不要购买,购买也下载不了【可充值秒升级】也可发帖,做任务,签到等升级。若已2级以上,忽略本提示
Ii SO {
AQ@A$
L[<MBgF Kv
-K+grsb g
@ -g^R4e<
I C7n;n9
!i{@B
}?"f#bI
CEt_wKz f
& 9IMZAo
F^KoEWj[H
 5Gg`+o
NamePCB DecalValuePart Type
BEAD1401B0603UPZ1608U221-2R2TFB0603-75R
CON150MM4829-2702BNC/MHC-310CON-RF-TEST-MM4829-2702B-MURATA
CON151MM4829-2702BMHC-310CON-RF-TEST-MM4829-2702B-MURATA
D200SOD1231N5819DIODE_SCHOTTKY_2
D201SOD123NC/1N5819DIODE_SCHOTTKY_2
D901SOD123NCDIODE_0_3
D1401ELJ_TVSESD9X5VL-2_SOD-923_H0.45ELJ_TVSESD9X5VL-2_SOD-923_H0.45ELJ_TVSESD9X5VL-2_SOD-923_H0.45
D1701SOD1231N5819DIODE_SCHOTTKY_2
D2000SOD323/SMD/MM3Z2V4T1PZ3D4V2H (PRISEMI)TVS-6V2-PZ3D4V2H-ROHM
D23001EMD2-SOD523RB521S301PS79SB30
EMI1FILTER/SMD/TCM0806GNCEMIX21A390FNPE_1
ESD1ELJ_TVSESD9X5VL-2_SOD-923_H0.45NC ESD5301NELJ_TVSESD9X5VL-2_SOD-923_H0.45
ESD151ELJ_TVSESD9X5VL-2_SOD-923_H0.45NC ESD5301NELJ_TVSESD9X5VL-2_SOD-923_H0.45
H1PTH_HOLE_1.6/2.8MMADNIPTH_HOLE_1.6/2.8MM
J3ELJ-KS270013KS270013ELJ-KS270013
J32ELJ-BAT1254001-05YZ_5PIN-1.25JP-H1.9ELJ-BAT1254001-05YZ_5PIN-1.25JP-H1.9ELJ-BAT1254001-05YZ_5PIN-1.25JP-H1.9
J901ELJ_FH26-51S-0.3SHW_PH0.6-FPC0309-51B3FPC51P-0.3MMELJ_FH26-51S-0.3SHW_PH0.6-FPC0309-51B3
J1001ELJ_FH26-31S-0.3SHW_ZIF_PH0.6_H1.0ELJ_FH26-31S-0.3SHW_ZIF_PH0.6_H1.0
J1002ELJ_FH26-39S-0.3SHW_PH0.6-FPC0309-39B3AXK7L30227GELJ_FH26-39S-0.3SHW_PH0.6-FPC0309-39B3
J1003ELJ_L-TF03-GFC4-07-R_TF-FCB1.1-KTELJ_L-TF03-GFC4-07-R_TF-FCB1.1-KTELJ_L-TF03-GFC4-07-R_TF-FCB1.1-KT
J1005ELJ_HC301-13RL-GF_ZIF-H1.0ELJ_HC301-13RL-GF_ZIF-H1.0ELJ_HC301-13RL-GF_ZIF-H1.0
J1101ELJ_BAR080T028-4YZ_0.8T-4PINElJ_BAR080T028-4YZ_0.8T-4PINELJ_BAR080T028-4YZ_0.8T-4PIN
J1102ELJ_BAR080T028-4YZ_0.8T-4PINElJ_BAR080T028-4YZ_0.8T-4PINELJ_BAR080T028-4YZ_0.8T-4PIN
J1201ELJ_HC503-6R-GF_PJ_0.5_H1.0ELJ_HC503-6R-GF_PJ_0.5_H1.0ELJ_HC503-6R-GF_PJ_0.5_H1.0
J1301ELJ_MC0R-240224-04G_CB0.8-24PINELJ_MC0R-240224-04G_CB0.8-24PINELJ_MC0R-240224-04G_CB0.8-24PIN
J1302ELJ_HC503-6R-GF_PJ_0.5_H1.0ELJ_HC503-6R-GF_PJ_0.5_H1.0ELJ_HC503-6R-GF_PJ_0.5_H1.0
J1303ELJ-KS270013KS270013ELJ-KS270013
J1304ELJ-HC301_61RL-GF_ZIF-H1.0-FANELJ-HC301_61RL-GF_ZIF-H1.0-FANELJ-HC301_61RL-GF_ZIF-H1.0-FAN
J1308ELJ-KS270013KS270013ELJ-KS270013
J1309ELJ-KS270013KS270013ELJ-KS270013
J1311ELJ-KS270013KS270013ELJ-KS270013
J1314ELJ-KS270013KS270013ELJ-KS270013
J1403ELJ_BAR080T028-NYZ_2P-0.8JP-H1.85NC ELJ_BAR080T028-NYZ_2P-0.8JP-H1.85ELJ_BAR080T028-NYZ_2P-0.8JP-H1.85
J1701ELJ_HC503-6R-GF_PJ_0.5_H1.0HC503-6R-GFELJ_HC503-6R-GF_PJ_0.5_H1.0
J1801ELJ_BAR080T028-NYZ_2P-0.8JP-H1.85ELJ_BAR080T028-NYZ_2P-0.8JP-H1.85ELJ_BAR080T028-NYZ_2P-0.8JP-H1.85
J2202NC_BAT_CON_3NCNC_BAT_CON_3
J6503ELJ_HC503-6R-GF_PJ_0.5_H1.0ELJ_HC503-6R-GF_PJ_0.5_H1.0ELJ_HC503-6R-GF_PJ_0.5_H1.0
L10L020182nHL0201_8.2NH
L11L02010.8NH +-0.1NHL0201
L12L02010.8NH +-0.1NHL0201
L14L02011.2 nH +-0.1nHL0201_5.6NH
L15L0201L / 5.6 / nH / 0201L0201_5.6NH
L17L02013.3NH +-0.1NHL0201_5.6NH
L18FILTER/SMD/FB2012/SFB2012-05N2R4GT-LF_8PFILTER/SMD/FB2012/S
L21L/IND/SMD/VLS201610EMPH201610S2R2VLS201610E
L901MPH252012NRH2410T4R7MNMPH252012
L902MPH252012NRH2410T4R7MNMPH252012
L903MPH252012NRH2410T4R7MNMPH252012
L1401L0603NC BLM18PG221SN1D_2P_DBEAD-470-100MHZ-1A-0603-BLM18PG471SN1
L1409L0402BLM15HD182SN1D_2PBEAD-0402
L1410L0603100NH +-2% LQW18ANR10G00DL0603-LQM18NN82NM00
L1701SQC322517HP-220M-NSWPA3012S100MTIND-POWER-22UH-SQC322517HP-220M-N
L2006WPN4020HWPN4020H1R0MTWPN4020H
MARK1000MARK_ALLDNIMARK_ALL_A
MARK1001MARK_ALLDNIMARK_ALL_A
MARK1002MARK_ALLDNIMARK_ALL_A
MARK1003MARK_ALLDNIMARK_ALL_A
NC222NC/MMD/L5/4MILBNC PAD 0402NC/MMD/L5/4MIL
NTC2000R0402NTCG104EF104FRES0402
PL1501L25200.68UH_PHT25201B-R68MS_2.97A_20%L2520-22U
PL1503L25200.68UH_PHT25201B-R68MS_2.97A_20%L2520-22U
PL1505L25200.68UH_PHT25201B-R68MS_2.97A_20%L2520-22U
PL1506L25201UH_PHT25201B-1R0MS_2.45A_20%L2520-22U
PL1507L25201UH_PHT25201B-1R0MS_2.45A_20%L2520-22U
PL1508L25200.68UH_PHT25201B-R68MS_2.97A_20%L2520-22U
PL1509L25202.2UH_PHT25201B-2R2MS_20%L2520-22U
PL1701CD43SWPA4018S100MTIND-CD43
PL2103L25200.47UH_PHT25201B-R47MS_3.5A_20%L2520-22U
PL2401L25200.47UH_PIFE25201B-R47MS_4A_20%L2520-22U
PL2402L25200.47UH_PIFE25201B-R47MS_4A_20%L2520-22U
PL2403L25200.47UH_PIFE25201B-R47MS_4A_20%L2520-22U
PL2404L25200.47UH_PIFE25201B-R47MS_4A_20%L2520-22U
PQ1701SOT23_3WPM2026IRF5210/TO_6
PQ1702SC-75_SOT-416_DTC114EET1-DDTC114YET1SC-75_SOT-416_DTC114EET1-D
PU1702LP8557E00AYFQR_DSBGA_16PLP8557E00AYFQR_DSBGA16LP8557E00AYFQR_DSBGA_16P
PU1704MT6397S/TFBGA266/P0.4/B0.25/8.6X8.6MT6397S/TFBGA266/P0.4/B0.25/8.6X8.6MT6397S/TFBGA266/P0.4/B0.25/8.6X8.6
PU1706CSP16/SMD/P0.4/B0.25/TPS6128X/STPS61280YFFR_DSBGA16CSP16/SMD/P0.4/B0.25/TPS6128X/S
PU2401WLCSP42/P0.4/B0.25/DA9212DA9212-ADUU2_WL-CSP42WLCSP42/P0.4/B0.25/DA9212
SH2001NC/MMD/L1/4MILSHORT / NC-MMD-L9-4MILNO_PAD_0402_SMD_1
SH2002NC/MMD/L1/4MILSHORT / NC-MMD-L9-4MILNO_PAD_0402_SMD_1
SH2100KLINK_NO_PAD_0.1MM_LAYER7SHORT / NC-MMD-L9-4MILKLINK_NO_PAD_0.1MM_LAYER7
U5VQFN24/SMD/P0.5/BQ24196Bq24296VQFN24/SMD/P0.5/BQ24196
U19MT6630/WLCSP113/P0.4/B0.25/5.013X5.013MT6630QP_WLCSP113MT6630/WLCSP113/P0.4/B0.25/5.013X5.013
U150DIPLEXER/6P/SMD/DP1608LFD181G58DP8D754DIPLEXER/6P/SMD/DP1608
U151SAFEB1G57KE0F00NC SAFEB1G57KE0F00IC-SAW-SAFEB1G57KE0F00-MURATA
U152MAX2659MAX2659ELTIC-GPS-LNAP-MAX2659-MAXIM
U801FBGA256/P0.4/B0.25/14X14/K3QF3F30BM/SAMLPDDR3_SS_0FBGA256/P0.4/B0.25/14X14/K3QF3F30BM/SAM
U901SOT23_5WD1013EA/TCS4150-ETCS4150-E
U902DFN12-3X3TCS3512SY7686_1
U1002SOT23-5WL2003E33WL2003E
U1301GSL3692GSL3692GSL3692
U1305TCS1320TCS1320TCS1320
U1401FUSB340TMXFUSB340TMXFUSB340TMX
U1402AW8736FCRZYL6138AW8736FCR
U1403AW8736FCRZYL6138AW8736FCR
U1703SOT23_6CP2121AP3031_0
U1801BMA250BMA223IC-3-A-ACCELEROMETER-BMA250-BOSCH
U1802TLE4917-TSOP-6-2OCH168TWADTLE4917
U1803TMP103AYFFR_DSBGA4NC TMP103AYFFR_DSBGA4TMP103AYFFR_DSBGA4
U1805CLI_MPU5400_GYROSCOPE_0.4PTH_3X3X0.9MMCLI_MPU5400_GYROSCOPE_0.4PTH_3X3X0.9MM
U3002BGA169/P0.5/B0.27/THGBM1GXDXEBAI/TOSHIBASamsung KLM2G1HE3F-B001BGA169/P0.5/B0.27/THGBM1GXDXEBAI/TOSHIBA
UM1MT8173/VFBGA825/P0.4/B0.25/15X15MT8137B-1.8G_VFBGA825MT8173/VFBGA825/P0.4/B0.25/15X15
VR1001R0402NCVR0402
VR1015ELJ_TVSESD9X5VL-2_SOD-923_H0.45ESD9X5VL-2/TRELJ_TVSESD9X5VL-2_SOD-923_H0.45
VR1016R0402NC ESD9B5V-2/TRVAR_0402
VR1017R0402NC ESD9B5V-2/TRVAR_0402
VR1310ELJ_TVSESD9X5VL-2_SOD-923_H0.45ESD9X5VL-2/TRELJ_TVSESD9X5VL-2_SOD-923_H0.45
VR1408R0402NC SFI0402-180E10RPP-LFVR0402
VR1417R0402NC/EZJZ0V500AAVR0402
VR1418R0402NC/EZJZ0V500AAVR0402
VR1701R0402ESD9B5V-2/TRVAR_0402
VR1702ELJ_TVSESD9X5VL-2_SOD-923_H0.45ESD9X5VL-2/TRELJ_TVSESD9X5VL-2_SOD-923_H0.45
VR1703ELJ_TVSESD9X5VL-2_SOD-923_H0.45ESD9X5VL-2/TRELJ_TVSESD9X5VL-2_SOD-923_H0.45
VR2201SOD323/SMD/MM3Z2V4T1NC EDS56131WPTVSHC3D4V5B
VR2202R0402SFI0402-180E10RPP-LFVR0402
VR2203R0402SFI0402-180E10RPP-LFVR0402
VR6012MLV0402SFI0402-180E10RPP-LFVAR_0402
VR6013MLV0402ESD9B5V-2/TRVAR_0402
VR6018MLV0402ESD9B5V-2/TRVAR_0402
VR6026ESD5641D07NC ESD5641D07ESD5641D07
X126M_TCXO_2520TC7L26002015_2016L26421TCXO / 26 / MHz / IT2205AE26M_TCXO_2520TC7L26002015_2016L26421
X426M_TCXO3225_2520_7M26000028_DSA26MHZ_11PF_8Z2600005426M_TCXO3225_2520_7M26000028_DSA
X2000CRYS/SMD/3.2X1.5/9H032000XX/TXC32.768KHz¡À20ppmCRYS/SMD/3.2X1.5/9H032000XX/TXC
 6 5qH
评价一下你浏览此帖子的感受
精彩
感动
搞笑
愤怒
一般
差劲
在线老吴
性别:
帅哥
发帖
15545
金币
156970
提示:会员销售的附件,下载积分 = 版块积分 + 销售积分       只看该作者 1楼 发表于: 2020-10-22
着芯片资料。网上根本找不着。全网首发。下载请不要发其他网站上。 Y*dzoN.sW
对不起!您没有登录,请先登录论坛.
Ud\Jc:DG
离线470168757
性别:
美女
发帖
846
金币
1851
提示:会员销售的附件,下载积分 = 版块积分 + 销售积分       只看该作者 2楼 发表于: 2020-10-22
觉得自己板子难画的时候看看这种密密麻麻的~心情立马就好了~!
离线mirage
性别:
人妖
发帖
12173
金币
7830
提示:会员销售的附件,下载积分 = 版块积分 + 销售积分       只看该作者 3楼 发表于: 2020-10-22
谢谢分享
在线老吴
性别:
帅哥
发帖
15545
金币
156970
提示:会员销售的附件,下载积分 = 版块积分 + 销售积分       只看该作者 4楼 发表于: 2020-10-22
回 470168757 的帖子
470168757:觉得自己板子难画的时候看看这种密密麻麻的~心情立马就好了~! (2020-10-22 10:11)  e@"1W
-f IX6
和我以前刚会画板时一样。自己的板子实在画不下去了。就去打开一些别人画的复杂的板子看看。马上就有动力继续画了。。
离线刘七
性别:
帅哥
发帖
349
金币
411
提示:会员销售的附件,下载积分 = 版块积分 + 销售积分       只看该作者 5楼 发表于: 2020-10-22
性别:
帅哥
发帖
2938
金币
2257
提示:会员销售的附件,下载积分 = 版块积分 + 销售积分       只看该作者 6楼 发表于: 2020-10-22
在线kanxue_nmg
性别:
人妖
发帖
8840
金币
8823
提示:会员销售的附件,下载积分 = 版块积分 + 销售积分       只看该作者 7楼 发表于: 2020-10-22
离线我要你mm
性别:
人妖
发帖
1597
金币
943
提示:会员销售的附件,下载积分 = 版块积分 + 销售积分       只看该作者 8楼 发表于: 2020-10-22
太棒了,辛苦您了!
离线一点一滴
性别:
人妖
发帖
660
金币
66
提示:会员销售的附件,下载积分 = 版块积分 + 销售积分       只看该作者 9楼 发表于: 2020-10-22
h; 6G~D
离线一点一滴
性别:
人妖
发帖
660
金币
66
提示:会员销售的附件,下载积分 = 版块积分 + 销售积分       只看该作者 10楼 发表于: 2020-10-22
/d">}%Jn
离线sym21ic
性别:
帅哥
发帖
3419
金币
477
提示:会员销售的附件,下载积分 = 版块积分 + 销售积分       只看该作者 11楼 发表于: 2020-10-22
离线huangweiqiao
性别:
帅哥
发帖
2197
金币
1192
提示:会员销售的附件,下载积分 = 版块积分 + 销售积分       只看该作者 12楼 发表于: 2020-10-23
离线记好586
性别:
帅哥
发帖
3043
金币
994
提示:会员销售的附件,下载积分 = 版块积分 + 销售积分       只看该作者 13楼 发表于: 2020-10-23
离线2592047508
性别:
帅哥
发帖
4166
金币
3040
提示:会员销售的附件,下载积分 = 版块积分 + 销售积分       只看该作者 14楼 发表于: 2020-10-24
快速回复
限150 字节
上一个 下一个
