查看: 1372|回复: 6
[技术文章] Altium Designer 17软件安装包以及安装教程
    发表于 2021-4-25 10:51:04 | 显示全部楼层 |阅读模式
    这里下载安装包 :http://bbs.ntpcb.com/read-htm-tid-171764.html
    打开“AD17.0.6”文件夹,鼠标右击“AltiumDesignerSetup_17_0_6”,选择“以管理员身份运行”
    32a127723d03bbea665c58fcea43d7d449315472.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500% (93.64 MB, 下载次数: 0)
    点击“Next”
    49701aebf6a75f0fe2f11c5a97324b18502c4c72.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500% (265.45 MB, 下载次数: 0)
    选择“Chinese”,再选择“I accept the agreement”,然后点击“Next”
    8db0c6a726334884a4392398ddee7b7f870e4572.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500% (274.11 MB, 下载次数: 0)
    选择需要安装的功能。如果只需要PCB Design(原理图)保持默认设置即可(可以取消其他选项以节省存储空间,也可根据自身需求选择其他选项),然后点击“Next”
    e4b5e2f5ee0d3aced90d1adf87e265e7350fbb72.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500% (274.39 MB, 下载次数: 0)
    选择安装路径。可以使用默认路径,也可以自行更改,建议把AD软件安装到除C盘以外的磁盘(路径中不要有中文即可)。然后点击“Next”。如下图默认路径为: C:\Program Files (x86)\Altium\AD17 和 C:\Users\Public\Documents\Altium\AD17    可以直接将C改为E,安装到E盘
    65390a23beb9763e5d18d3626ad06de89b61b072.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500% (271.79 MB, 下载次数: 0)
    点击“Next”
    cfa9ae04541bd10f75fc652eba0e1799e82aa772.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500% (261.22 MB, 下载次数: 0)
    软件正在安装过程中(进度条要走完时可能会出现假死状态),请耐心稍等
    e86ba4b842406afe4cce99711eee41c1b6279f72.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500% (260.26 MB, 下载次数: 0)
    9
    将“Run Altium Designer ”前面复选框的勾去掉,然后点击“Finish”
    b666b2530688912c3210b45c1b4800fc76f79772.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500% (258.84 MB, 下载次数: 0)
    打开“AD17.0.6”>>“Licenses”文件夹,复制“NB201601.alf”文件
    91091efc77f7980ec2fa2bc5d4db3620b83a9172.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500% (85.85 MB, 下载次数: 0)
    打开软件安装目录 E:\Program Files (x86)\Altium\AD17 ,粘贴刚刚复制的“NB201601.alf”文件
    ccc83ec5260f88357b50316ace07880139708672.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500% (144.5 MB, 下载次数: 0)
    点击左下角(开始)菜单栏,进入所有程序,找到“Altium Designer”软件,然后鼠标左键单击打开
    a749bb0f94fc508c2a14af4c01775ddd894cfd72.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500% (46.24 MB, 下载次数: 0)
    点击“OK”
    6a408cdd3340b6f32f5d6ba812c0affce086ee72.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500% (13.61 MB, 下载次数: 0)
    选择“Yes , l want to participate in the program”,然后点击“OK”
    bfa52adaf05e4a23b3ab96a91dd818196020e272.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500% (241.88 MB, 下载次数: 0)
    点击“Add standalone license file”
    7496877bbbf4da58a500b6fdea0f8b56ac04d772.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500% (195.54 MB, 下载次数: 0)
    在软件安装目录 E:\Program Files (x86)\Altium\AD17 中,找到刚刚粘贴的“NB201601.alf”文件,选择后在点击“打开”
    d47cb624d8e9ccd25ebc39ed0e40102a05e2c972.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500% (211.63 MB, 下载次数: 0)
    如图所示,出现以下状态说明激活成功
    a13bbe10bc33ec38c461715b295f0c14c37b3c73.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500% (202.32 MB, 下载次数: 0)
    选择“DXP”,然后点击“Preferences”
    a31e1214c27bd2827053c9f23cb1eef97ebd3673.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500% (194.48 MB, 下载次数: 0)
    选择“General”,再将“Use localized resources”前面的复选框挑勾,然后点击“OK”。关闭软件后重新打开就可以汉化成功
    87c8bf46b7b1eef9856724c8bfb33c4132ba3273.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500% (219.04 MB, 下载次数: 0)
    安装完成,汉化后软件界面如下
    4d3d2ab33c4133ba2c9b6bc96a37c97623bc2f73.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500% (210.96 MB, 下载次数: 0)
    发表于 2021-4-25 14:07:06 | 显示全部楼层
    发表于 2021-4-25 15:36:33 | 显示全部楼层
    发表于 2021-4-25 15:38:08 | 显示全部楼层
    发表于 2021-4-26 09:38:54 | 显示全部楼层
    发表于 2021-4-26 11:07:08 | 显示全部楼层
  • 签到天数: 69 天
    发表于 2021-4-29 08:10:51 | 显示全部楼层
