基于环境光传感器和接近传感器的背光和智能照明控制参考 设计 "B3&v%b gof'NT\c OuuN~yC Iq["(!7E5 5g\>x;cc .bloaeu- Cyu= c1D ; Comment | Description | Designator | Quantity | Printed Circuit Board | PrintedCircuit Board | !PCB | 1 | EA LED55X46-W | LEDBacklight, White | BL1 | 1 | 202R18W102KV4E | CAP,CERM, 1000 pF, 2000 V, +/- 10%, X7R, 1206_190 | C1 | 1 | 08055C103JAT2A | CAP,CERM, 0.01 µF, 50 V, +/- 5%, X7R, 0805 | C2 | 1 | C1608X7R1C105K | CAP,CERM, 1 µF, 16 V, +/- 10%, X7R, 0603, CAP, CERM, 1uF, 16V, +/-10%, X7R, 0603 | C3,C4, C5, C6, C8, C9, C10, C11, C12, C13, C14, C15, C18, C20, C30 | 15 | GRM188R71A225KE15D | CAP,CERM, 2.2uF, 10V, +/-10%, X7R, 0603 | C7 | 1 | UMK107AB7105KA-T | CAP,CERM, 1uF, 50V, +/-10%, X7R, 0603 | C16 | 1 | GRM155R71C104KA88D | CAP,CERM, 0.1uF, 16V, +/-10%, X7R, 0402 | C17,C21, C28, C31 | 4 | C2012X7R0J106M125AB | CAP,CERM, 10 µF, 6.3 V, +/- 20%, X7R, 0805 | C19,C22 | 2 | C1005X7R1H222K | CAP,CERM, 2200 pF, 50 V, +/- 10%, X7R, 0402 | C23,C24, C25 | 3 | GRM1885C2A180JA01D | CAP,CERM, 18pF, 100V, +/-5%, C0G/NP0, 0603 | C26,C27 | 2 | 06033C104JAT2A | CAP,CERM, 0.1 µF, 25 V, +/- 5%, X7R, 0603 | C29 | 1 | Used in BOM report | CAP,CERM, xxxF, xxV, [TempCo], xx%, [PackageReference] | C32,C33, C34, C35 | 4 | SMBJ6.0CA | Diode,TVS, Bi, 6 V, 600 W, SMB | D1 | 1 | NSR0240V2T1G | Diode,Schottky, 40V, 0.25A, SOD-523 | D2 | 1 | 1SS315TPH3F | Diode,Schottky, 5V, 0.03A, SOD-323 | D3 | 1 | SML-P12PTT86 | LED,Green, SMD | D4 | 1 | Fiducial | Fiducialmark. There is nothing to buy ormount. | FID1,FID2, FID3, FID4, FID5, FID6 | 6 | NY PMS 440 0025 PH | MachineScrew, Round, #4-40 x 1/4, Nylon, Philips panhead | H1,H2, H3, H4 | 4 | 1902E | Standoff,Hex, 1"L #4-40 Nylon | H5,H6, H7, H8 | 4 | NY PMS 256 0025 PH | NylonScrew, Panhead, Phillips, 2-56 | H11,H12 | 2 | NY HN 256 | NylonNut, 2-56, 3/16" | H13,H14 | 2 | 90120-0122 | Header,100mil, 2x1, Tin, TH | J1,J3 | 2 | 1051330001 | Connector,Receptacle, USB TYPE B, Vertical, TH | J2 | 1 | TFM-110-02-L-D-A | StraightLow Profile Header, 10x2 Position,1.27 mm Pitch, SMT | J4,J5 | 2 | LPPB061NFSC-RC | Receptacle,1.27mm, 6x1, Gold, SMT | J6 | 1 | 0015910080 | Header,100mil, 4x2, Gold, SMT | J7 | 1 | BLM18SG331TN1D | FerriteBead, 330 ohm @ 100 MHz, 1.5 A, 0603, 1.5A Ferrite Bead, 330 ohm @ 100MHz,SMD | L1,L3, L5, L6 | 4 | SRF2012-361YA | Inductor,Wirewound, Ferrite, , 0.3 A, 0.45 ohm, SMD | L2 | 1 | VLF252015MT-100M | Inductor,Shielded, Ferrite, 10uH, 0.47A, 0.24 ohm, SMD | L4 | 1 | BSS138 | MOSFET,N-CH, 50V, 0.22A, SOT-23 | Q1 | 1 | CRCW06030000Z0EA | RES,0, 5%, 0.1 W, 0603 | R1 | 1 | CRCW04020000Z0ED | RES,0 ohm, 5%, 0.063W, 0402, RES, 0, 5%, 0.063 W, 0402 | R2,R3, R4, R5, R6, R7, R8, R9, R10, R11, R12, R13, R14, R15, R24, R25, R26, R27 | 18 | CRCW04024K99FKED | RES,4.99k ohm, 1%, 0.063W, 0402, RES, 4.99 k, 1%, 0.063 W, 0402 | R16,R17, R23 | 3 | CRCW040247K5FKED | RES,47.5 k, 1%, 0.063 W, 0402 | R18,R19, R20 | 3 | CRCW0402221RFKED | RES,221 ohm, 1%, 0.063W, 0402 | R21 | 1 | CRCW040210K0JNED | RES,10 k, 5%, 0.063 W, 0402 | R22 | 1 | 4-1437565-1 | Switch,Tactile, SPST-NO, 0.05A, 12V, SMT | S1,S2, S3 | 3 | 2SN-BK-G | Shunt,2mm, Gold plated, Black | SH-J1,SH-J2, SH-J3, SH-J4, SH-J5, SH-J6 | 6 | 5000 | TestPoint, Miniature, Red, TH | TP1,TP2, TP3 | 3 | 5001 | TestPoint, Miniature, Black, TH | TP4 | 1 | 5009 | TestPoint, Compact, Yellow, TH | TP5,TP6 | 2 | TLV71333PDBV | Capacitor-Free,150-mA, Low-Dropout Regulator with Foldback Current Limit for PortableDevices, DBV0005A | U1 | 1 | TPD2E2U06DRL | DUALCHANNEL HIGH SPEED ESD PROTECTION DEVICE, DRL0005A | U2 | 1 | EA DOGM128W-6 | Module,128x64-pixel graphics display | U3 | 1 | LM3630ATME | LM3630AHigh-Efficiency Dual-String White LED Driver, YFQ0012AKAR | U4 | 1 | TPD1E10B06DPYR | ESDin 0402 Package with 10 pF Capacitance and 6 V Breakdown, 1 Channel, -40 to+125 degC, 2-pin X2SON (DPY), Green (RoHS & no Sb/Br) | U5,U6 | 2 | MSP430FR5969IRGZ | MixedSignal Microcontroller, RGZ0048B | U7 | 1 | HDC1000YPA | HDC1000Low power integrated humidity and temperature Sensor, YPA0008AGAE | U8 | 1 | OPT3001DNP | AmbientLight Sensor, DNP0006A | U9 | 1 | FDC1004DSC | 4-ChannelCapacitance-to-Digital Converter for Capacitive Sensing Solutions, DSC0010B | U10 | 1 | NX3225GD-8MHZ-STD-CRA-3 | Crystal,8MHz, 5pF, SMD | Y1 | 1 | n3B#M}R YQ$EN>.eO 4Mck/i2 |zCT~#
