REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
D9 | BAT60A_SOD323_BAT60A10V, 3A | BAT60A10V, 3A | SOD323 |
J5 | EDGELAUNCH SMA_0_CON_32K243-40 | HSTXBP | CON_32K243-40M |
J6 | EDGELAUNCH SMA_0_CON_32K243-_1 | HSTXBN | CON_32K243-40M |
J7 | EDGELAUNCH SMA_0_CON_32K243-_2 | HSRXBP | CON_32K243-40M |
J8 | EDGELAUNCH SMA_0_CON_32K243-_3 | HSRXBN | CON_32K243-40M |
J41 | SMA_SURFACE_32K141-40M-FR4WVI_2 | REFCLK0P | 32K141-40M-FR4WVIA |
J42 | SMA_SURFACE_32K141-40M-FR4WVI_3 | REFCLK0N | 32K141-40M-FR4WVIA |
J43 | SMA_SURFACE_32K141-40M-FR4WVI_4 | REFCLK1P | 32K141-40M-FR4WVIA |
J44 | SMA_SURFACE_32K141-40M-FR4WVI_5 | REFCLK1N | 32K141-40M-FR4WVIA |
J45 | SMA_SURFACE_32K141-40M-FR4WVI_6 | CLKOUTAP | 32K141-40M-FR4WVIA |
J46 | SMA_SURFACE_32K141-40M-FR4WVI_7 | CLKOUTAN | 32K141-40M-FR4WVIA |
J47 | SMA_SURFACE_32K141-40M-FR4WVI_8 | CLKOUTBP | 32K141-40M-FR4WVIA |
J48 | SMA_SURFACE_32K141-40M-FR4WVI_9 | CLKOUTBN | 32K141-40M-FR4WVIA |
J72 | SEAF_ASP-134486-01_0_ASP-134486 | SEAF_ASP-134486-01 | ASP-134486 |
J73 | SFP_PLUS_CONN_WITH_CAGE_AMP_SFP | SFP_PLUS_CONN_WITH_CAGE | AMP_SFPCAGE_WIDECHANNEL |
J100 | MEC1-130-02-F-D-ACONNECTOR_MEC | MEC1-130-02-F-D-AConnector | MEC1-130-02-F-D-A |
J101 | MEC1-120-02-F-D-ACONNECTOR_MEC | MEC1-120-02-F-D-AConnector | MEC1-120-02-F-D-A |
J102 | SEAF_ASP-134486-01_0_ASP-134486 | SEAF_ASP-134486-01 | ASP-134486 |
J103 | SMA_SURFACE_32K141-40M-FR4WVIA_ | PRI_REF_IN_P | 32K141-40M-FR4WVIA |
J104 | SMA_SURFACE_32K141-40M-FR4WVI_1 | PRI_REF_IN_N | 32K141-40M-FR4WVIA |
JMP35 | 3PIN BERG JUMPER_BERG3_3 PIN B | 3Pin Berg | BERG3 |
JMP36 | 2PIN BERG JUMPER_HDR_THVT_1X2_ | Header1x2 | HDR_THVT_1X2_100 |
JMP41 | 3PIN BERG JUMPER_BERG3_3 PIN B | 3Pin Berg | BERG3 |
JMP42 | 3PIN BERG JUMPER_BERG3_3 PIN B | 3Pin Berg | BERG3 |
JMP47 | HEADER5X2_BERG2X5_HEADER 5X2 | Header5x2 | BERG2X5 |
JMP48 | HEADER5X2_BERG2X5_HEADER 5X2 | Header5x2 | BERG2X5 |
JMP50 | HEADER2X2_BERG2X2_HEADER 2X2 | Header2x2 | BERG2X2 |
JMP61 | HEADER4X2_BERG2X4_HEADER 4X2 | Header4x2 | BERG2X4 |
JMP62 | 3PIN BERG JUMPER SINGLE SIDE_B | 3Pin Berg | BERG3 |
JMP77 | HEADERT 4PIN_BERG2X3TEE_HEADER | HeaderT 4pin | BERG2X3TEE |
JMP100 | 2PIN BERG JUMPER_BERG2_2 PIN B | 2Pin Berg | BERG2 |
JMP101 | 2PIN BERG JUMPER STRAIGHT_HDR_ | Header2x1 | HDR_THVT_1X2_100 |
JMP102 | HEADER6X2_HDR_THVT_2X6_100_HEA | Header2x6 | HDR_THVT_2X6_100 |
JMP103 | HEADER2X2_HDR_THVT_2X2_100_HEA | Header2x2 | HDR_THVT_2X2_100 |
JMP104 | HEADER6X2_HDR_THVT_2X6_100_H_1 | Header6x2 | HDR_THVT_2X6_100 |
JMP105 | HEADER2X2_HDR_THVT_2X2_100_HEA | Header2x2 | HDR_THVT_2X2_100 |
K1 | AQY221R2T_PANASONIC_AQY221R2T_V | AQY221R2T | PANASONIC_AQY221R2T_VSSOP |
K2 | AQY221R2T_PANASONIC_AQY221R2T_V | AQY221R2T | PANASONIC_AQY221R2T_VSSOP |
K3 | AQY221R2T_PANASONIC_AQY221R2T_V | AQY221R2T | PANASONIC_AQY221R2T_VSSOP |
K4 | AQY221R2T_PANASONIC_AQY221R2T_V | AQY221R2T | PANASONIC_AQY221R2T_VSSOP |
L1 | FERRITEBEAD_1206_R1210_FERRITE | FerriteBead_1210 | R1210 |
L15 | INDUCTOR_1210_1210_4.7UH | 4.7uH | 1210 |
L16 | INDUCTOR_1210_1210_4.7UH | 4.7uH | 1210 |
L100 | INDUCTOR_0_0603_BLM15HD102SN1D | BLM15HD102SN1D | 603 |
L101 | INDUCTOR_0_0603_BLM15HD102SN1D | BLM15HD102SN1D | 603 |
L102 | INDUCTOR_0_0603_BLM15HD102SN1D | BLM15HD102SN1D | 603 |
L103 | INDUCTOR_0_0603_BLM15HD102SN1D | BLM15HD102SN1D | 603 |
L104 | INDUCTOR_0_0603_BLM15HD102SN1D | BLM15HD102SN1D | 603 |
L105 | INDUCTOR_0_0603_BLM15HD102SN1D | BLM15HD102SN1D | 603 |
L106 | INDUCTOR_0_0603_BLM15HD102SN1D | BLM15HD102SN1D | 603 |
P1 | BANANA-JACK_BJACK_5V_BJ_3267 | 5V_BJ | BJACK |
P14 | BANANA-JACK_BJACK_GND_3267 | GND | BJACK |
P26 | RAPC722_CON_RAPC722_JACK_THVT_3 | RAPC722 | CON_RAPC722_JACK_THVT_3 |
Q3 | FDV301N_NFET_1_SOT23_FDV301N_FD | FDV301N | SOT23 |
Q4 | FDV301N_NFET_1_SOT23_FDV301N_FD | FDV301N | SOT23 |
Q5 | FDV301N_NFET_1_SOT23_FDV301N_FD | FDV301N | SOT23 |
Q6 | FDV301N_NFET_1_SOT23_FDV301N_FD | FDV301N | SOT23 |
Q7 | FDV301N_NFET_1_SOT23_FDV301N_FD | FDV301N | SOT23 |
Q11 | FDV301N_NFET_1_SOT23_FDV301N_FD | FDV301N | SOT23 |
Q12 | FDV301N_NFET_1_SOT23_FDV301N_FD | FDV301N | SOT23 |
Q100 | FDV301N_NFET_1_SOT23_FDV301N_FD | FDV301N | SOT23 |
Q101 | FDV301N_NFET_1_FAIRCHILD_NFET_F | FDV301N | FAIRCHILD_NFET_FDV301N |
Q102 | FDV301N_NFET_1_FAIRCHILD_NFET_F | FDV301N | FAIRCHILD_NFET_FDV301N |
Q103 | FDV301N_NFET_1_FAIRCHILD_NFET_F | FDV301N | FAIRCHILD_NFET_FDV301N |
Q104 | FDV301N_NFET_1_FAIRCHILD_NFET_F | FDV301N | FAIRCHILD_NFET_FDV301N |
Q105 | FDV301N_NFET_1_SOT23_FDV301N_FD | FDV301N | SOT23 |
Q106 | FDV301N_NFET_1_SOT23_FDV301N_FD | FDV301N | SOT23 |
SW10 | B3U-1100P_OMRON_3PIN_US_B3U-110 | B3U-1100P | OMRON_3PIN_US_B3U-1100P |
SW11 | ROCKERSWITCH 10 POSITION_0_GDH | RockerSwitch 10 position | GDH10S_THOMASBETTS |
SW12 | ROCKERSWITCH 4 POSITION_0_GDH0 | RockerSwitch 4 position | GDH04S_THOMASBETTS |
SW13 | B3U-1100P_OMRON_3PIN_US_B3U-110 | B3U-1100P | OMRON_3PIN_US_B3U-1100P |
SW14 | B3U-1100P_OMRON_3PIN_US_B3U-110 | B3U-1100P | OMRON_3PIN_US_B3U-1100P |
SW15 | B3U-1100P_OMRON_3PIN_US_B3U-110 | B3U-1100P | OMRON_3PIN_US_B3U-1100P |
SW16 | ROCKERSWITCH 4 POSITION_0_GDH0 | RockerSwitch 4 position | GDH04S_THOMASBETTS |
SW17 | ROCKERSWITCH 8 POSITION_1_GDH0 | RockerSwitch 8 position | GDH08S_THOMASBETTS |
SW18 | ROCKERSWITCH 2 POSITION_GDH02S | RockerSwitch 2 position | GDH02S_THOMASBETTS |
SW19 | ROCKERSWITCH 2 POSITION_GDH02S | RockerSwitch 2 position | GDH02S_THOMASBETTS |
TH1 | HEADER1X1_0_THERMAL_HOLE_HEADE | Header1x1 | THERMAL_HOLE |
U1 | TLK10081_ZWQ144_(S1+S2+S3+S4+S5 | TLK10081 | ZWQ144 |
U8 | TPS74X01RGW_0_RGW20_TPS74401RGW | TPS74401RGW | RGW20 |
U10 | TPS74X01RGW_0_RGW20_TPS74401RGW | TPS74401RGW | RGW20 |
U12 | TPS74X01RGW_0_RGW20_TPS74401RGW | TPS74401RGW | RGW20 |
U16 | TPS74X01RGW_0_RGW20_TPS74401RGW | TPS74401RGW | RGW20 |
U22 | TPS74X01RGW_0_RGW20_TPS74401RGW | TPS74401RGW | RGW20 |
U24 | TPS74X01RGW_0_RGW20_TPS74401RGW | TPS74401RGW | RGW20 |
U36 | SN74AVCH1T45DBV_DCK6_SN74AVCH1T | SN74AVCH1T45DBV | DCK6 |
U37 | TPS3125J18_0_SOT23_5PIN_TPS3125 | TPS3125J18 | SOT23_5PIN |
U38 | ZXTD09N50DE6_DDC6_ZXTD09N50DE6 | ZXTD09N50DE6 | DDC6 |
U40 | TXB0108PWR_PW20_TXB0108PWR | TXB0108PWR | PW20 |
U41 | TXB0108PWR_PW20_TXB0108PWR | TXB0108PWR | PW20 |
U42 | TCA6424_0_RGJ32_TCA6424 | TCA6424 | RGJ32 |
U43 | TXS0108EPWR_PW20_TXS0108EPWR | TXS0108EPWR | PW20 |
U64 | TXB0108PWR_PW20_TXB0108PWR | TXB0108PWR | PW20 |
U92 | TPS3125J18_0_SOT23_5PIN_TPS3125 | TPS3125J18 | SOT23_5PIN |
U93 | ZXTD09N50DE6_DDC6_ZXTD09N50DE6 | ZXTD09N50DE6 | DDC6 |
U94 | ZXTD09N50DE6_DDC6_ZXTD09N50DE6 | ZXTD09N50DE6 | DDC6 |
U100 | CDCM6208_HQFN_48_282X282_20_(S1 | CDCM6208 | HQFN_48_282X282_20 |
U101 | TPS74X01RGW_0_RGW20_TPS74401RGW | TPS74401RGW | RGW20 |
U102 | TPS74X01RGW_0_RGW20_TPS74401RGW | TPS74401RGW | RGW20 |
U103 | TLV713_SOT23_5PIN_TLV70225 | TLV70225 | SOT23_5PIN |
U104 | CDCLVP1204_QFN50P300X300X100-16 | CDCLVP1204 | QFN50P300X300X100-16 |
U105 | CDCLVP1204_QFN50P300X300X100-16 | CDCLVP1204 | QFN50P300X300X100-16 |
U106 | ZXTD09N50DE6_DDC6_ZXTD09N50DE6 | ZXTD09N50DE6 | DDC6 |
U107 | SN74LVC1G08-Q1DBV_DBV_SN74LVC1G | SN74LVC1G08-Q1DBV | DBV |
U108 | TPS3125J18_SOT23_5PIN_TPS3125J1 | TPS3125J18 | SOT23_5PIN |
U109 | ZXTD09N50DE6_DDC6_ZXTD09N50DE6 | ZXTD09N50DE6 | DDC6 |
U110 | TPS3125J18_SOT23_5PIN_TPS3125J1 | TPS3125J18 | SOT23_5PIN |
U111 | ZXTD09N50DE6_DDC6_ZXTD09N50DE6 | ZXTD09N50DE6 | DDC6 |
U112 | TPS3125J18_SOT23_5PIN_TPS3125J1 | TPS3125J18 | SOT23_5PIN |
U113 | ZXTD09N50DE6_DDC6_ZXTD09N50DE6 | ZXTD09N50DE6 | DDC6 |
U114 | TLV713_SOT23_5PIN_TLV70233 | TLV70233 | SOT23_5PIN |
U115 | TLV713_SOT23_5PIN_TLV70233 | TLV70233 | SOT23_5PIN |
Y10 | NZ2016SA_30.72MHZ_NZ2016SA-ICXO | NZ2016SA_30.72MHz | NZ2016SA-ICXO |
Y11 | NZ2016SA_31.25MHZ_NZ2016SA-ICXO | NZ2016SA_31.25MHz | NZ2016SA-ICXO |
