老吴 发表于 2019-3-3 16:44:17
8层笔记本电脑主板PCB文件共享 CULV45D-F1  SU2300
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEAMIC_CONWTOB_2P_49_2HOLD_RA_LINGYAWTOB_CON_2PAG_WTOB_2P_49_2HOLD_RA_LINGAQ2SOT363_NBUM6K1NSOT363_NBAT1NB_TPC26T_68TPC26TNB_TPC26T_68AT2NB_TPC26T_68TPC26TNB_TPC26T_68AU1NB_QFN_48P_20_276X276_VIAALC269Q-GRNB_QFN_48P_20_276X276_VIAAU2MB_SOT23_S5_MAXUP7714BMA5-00MB_SOT23_S5_MAXBAT_CONBATT_7P_79_2HOLD_RA_LF3BATT_CON_7PAG_BATT_7P_79_2HD_RA_LF2BIOSSOIC_8P_50_212X315MX25L8005M2C_15GSOIC_8P_50_212X315BIOS_SEL_HEADERHD_1X3P_100_JVE_LF3HEADER_1X3PMB_HD_1X3P_100_LF3BT_CONWTOB_10P_39_2HOLD_RA_LINGYAWTOB_CON_10PAG_WTOB_10P_39_2HOLD_RA_LINCL1R0603_H240OhmR0603_H24CL2R0603_H240OhmR0603_H24CLRTCNB_OPEN2_5MIL_PTSGL_JUMPOPEN2_5MILCPUFAN_CONWTOB_3P_49_2HOLD_RA_LINGYAWTOB_CON_3PAG_WTOB_3P_49_2HOLD_RA_LINGCR22R04020OhmR0402CT1NB_TPC26T_68TPC26TNB_TPC26T_68CT2NB_TPC26T_68TPC26TNB_TPC26T_68CT3NB_TPC26T_68TPC26TNB_TPC26T_68CU1SOIC_56P_20_555X319ICS9LPRS427CGLFTSOIC_56P_20_555X319CX1XTAL_2P_315X17714.318MhzXTAL_2P_315X177D3C1C0805_H5710UF/6.3VC0805_H57D3CE1C7343D_H75100UF/2.5VC7343D_H75D3R1R0402_H160OhmR0402_H16D3R2R0402_H161KOhmR0402_H16D3R3R0402_H160OhmR0402_H16D3R4R0402_H161KOhmR0402_H16D3R5R0402_H160OhmR0402_H16DC_JACKDC_PWR_JACK_3P_2H_LF3DC_PWR_JACK_3PAG_DC_PWR_JACK_3P_2H_LF2DEBUG_CONAG_FPC_12P_20_2HOLD_RA_LINGFPC_CON_12PAG_FPC_12P_20_2HOLD_RA_LINGDIMM1DDR3_DIMM_204P_4H_STD_FNNDDR3_DIMM_204PAG_DDR3_DIMM_204P_4H_STD_FNGD1SOT323BAT54AWSOT323GD2SOT323BAT54AWSOT323GD3SOT23_H43BAV99SOT23_H43GD4SOT23_H43BAV99SOT23_H43GJP5SHORTPIN_5X10SHORTPIN_5X10SHORTPIN_5X10GJP6SHORTPIN_5X10SHORTPIN_5X10SHORTPIN_5X10GJP7SHORTPIN_5X10SHORTPIN_5X10SHORTPIN_5X10GL1R0603_H240OhmR0603_H24GL2R0603_H240OhmR0603_H24GL3R0603_H240OhmR0603_H24GL4R0603_H240OhmR0603_H24GL5R0603_H240OhmR0603_H24GL6R0603_H240OhmR0603_H24GL7R0603_H240OhmR0603_H24GL26L0603120Ohm/100MhzL0603GQ2SOT23_H432N7002ET1GSOT23_H43GQ3SOT23_H432N7002ET1GSOT23_H43GR1R04021.27KOhmR0402GT37NB_TPC26T_68TPC26TNB_TPC26T_68GU1NB_BGA_631P_31_937X937PARK-XT-S3NB_BGA_631P_31_937X937GU6SOIC_8P_50_197X236G781-1SOIC_8P_50_197X236GU11NB_BGA_96P_31_512X295H5TQ1G63BFR-12CNB_BGA_96P_31_512X295GU12NB_BGA_96P_31_512X295H5TQ1G63BFR-12CNB_BGA_96P_31_512X295GU13NB_BGA_96P_31_512X295H5TQ1G63BFR-12CNB_BGA_96P_31_512X295GU14NB_BGA_96P_31_512X295H5TQ1G63BFR-12CNB_BGA_96P_31_512X295GX1XTAL_2P_315X177_H5927MhzXTAL_2P_315X177_H59H1NB_H_C276D87N_M2_P2_V4C276D87NNB_H_C276D87N_M2_P2_V4H14NB_H_C276D87N_M2_P2_V4C276D87NNB_H_C276D87N_M2_P2_V4H15HOLE_O63X47DO63X47NO63x47DO63x47NHOLE_O63X47DO63X47NH16HOLE_C79D79NC79D79NHOLE_C79D79NH21NB_H_C276D87N_M2_P2_V4C276D87NNB_H_C276D87N_M2_P2_V4H33NB_H_C276D87N_M2_P2_V4C276D87NNB_H_C276D87N_M2_P2_V4HALL_SENNB_SOT23_ANACHIP_H55EC2648-B3-FNB_SOT23_ANACHIP_H55HD1SOT323BAT54AWSOT323HDD_CONAG_FPC_12P_20_2HOLD_RA_LINGFPC_CON_12PAG_FPC_12P_20_2HOLD_RA_LINGHDMINB_HDMI_19P_4HLD_RA_LF2HDMI_CON_19PNB_HDMI_19P_4HLD_RA_LF2HJP1NB_PWR_FB_SHORT_PTSHORT_PINNB_PWR_FB_SHORT_PTHQ1SOT23_H432N7002ET1GSOT23_H43HRN14R8P0402_H20S56Ohm4R8P0402_H20HS2NB_NUT_C217BC87D47_LF2HT-G4041M20TFENB_NUT_C217BC87D47_LF2HS3NB_NUT_C217BC87D47_LF2HT-G4041M20TFENB_NUT_C217BC87D47_LF2HS4NB_NUT_C217BC87D47_LF2HT-G4041M20TFENB_NUT_C217BC87D47_LF2HS5NB_NUT_C217BC87D47_LF2HT-G4041M20TFENB_NUT_C217BC87D47_LF2HU1NB_BGA_956P_19_866X866SU2300NB_BGA_956P_19_866X866HU2SOIC_8P_26_122X193_H48G781P8FSOIC_8P_26_122X193_H48IC1C04020.1UF/16VC0402IC3C04020.1UF/16VC0402IC4C040210PF/50VC0402IC41C0402_RD91UF/6.3VC0402IC42C0402_RD91UF/6.3VC0402IC43C0805_H5710UF/6.3VC0805_H57IC58C0402_RD91UF/6.3VC0402IH1NB_H_C276D87N_M2_P2_V4C276D87NNB_H_C276D87N_M2_P2_V4IH2NB_H_C276D87N_M2_P2_V4C276D87NNB_H_C276D87N_M2_P2_V4IH3HOLE_C87D87NSCREW_HOLEHOLE_C87D87NIO_CONFPC_30P_20_2HOLD_RA_LINFPC_CON_30PAG_FPC_30P_20_2HOLD_RA_LINIR3R040233OhmR0402IR4R0402499OhmR0402ITP1HH_EMI_SPRING_150X87SPRING_PADHH_EMI_SPRING_150X87ITP2HH_EMI_SPRING_150X87SPRING_PADHH_EMI_SPRING_150X87KB_CONFPC_24P_39_2HOLD_RAFPC_CON_24PFPC_24P_39_2HOLD_RALC1C04020.1UF/16VC0402LC26C040212PF/50VC0402LCD_CONWTOB_30P_39_2HOLD_RA_ACESWTOB_CON_30PWTOB_30P_39_2HOLD_RA_ACESLCX3C04020.1UF/16VC0402LCX4C04020.1UF/16VC0402LINE_OUTAG_PHONE_JACK_8P_RA_LF2PHONE_JACK_8PAG_PHONE_JACK_8P_RA_LF2LL3R0603_H240OhmR0603_H24LT1NB_TPC26T_68TPC26TNB_TPC26T_68LU1QFP_48P_20_354X354RTL8103EL-GRQFP_48P_20_354X354LX1NB_XTAL_4P_126X98_HOSON_H2825MhzNB_XTAL_4P_126X98_HOSON_H28MIC_JACKAG_PHONE_JACK_8P_RA_LF2PHONE_JACK_8PAG_PHONE_JACK_8P_RA_LF2NCE3C7343D_H75100UF/2.5VC7343D_H75NCE4C7343D_H75100UF/2.5VC7343D_H75ND1SOT323BAT54CWSOT323NJP10NB_PWR_FB_SHORT_PTSHORT_PINNB_PWR_FB_SHORT_PTNJP12NB_PWR_FB_SHORT_PTSHORT_PINNB_PWR_FB_SHORT_PTNJP13NB_PWR_FB_SHORT_PTSHORT_PINNB_PWR_FB_SHORT_PTNJP14NB_PWR_FB_SHORT_PTSHORT_PINNB_PWR_FB_SHORT_PTNL13L0603120Ohm/100MhzL0603NQ1SOT23_H432N7002ET1GSOT23_H43NU1NB_BGA_1362P_1063X984_HDI897605NB_BGA_1362P_1063X984NU2QFN_48P_20_S276_PAD_MICROTUASM1442TQFN_48P_20_S276_PAD_MICROTUOL3R0603_H240OhmR0603_H24OQ3SOT23_H432N7002ET1GSOT23_H43OQ16SOT23_H432N7002ET1GSOT23_H43OT54NB_TPC26T_68TPC26TNB_TPC26T_68OU1QFP_128P_16_630X630IT8500E-LQFP_128P_16_630X630OX2XTAL_4P_272X5532.768KhzXTAL_4P_272X55PC1C06030.1UF/25VC0603PC2C1206_H7510UF/25VC1206_H75PCE1NB_C7343D_H83220UF/2VNB_C7343D_H83PCE2C7343D_H87100UF/6.3VC7343D_H87PCE3C7343D_H87100UF/6.3VC7343D_H87PCE4NB_C7343D_H83220UF/2VNB_C7343D_H83PCE5NB_C7343D_H83220UF/2VNB_C7343D_H83PCE7C352847UF/6.3VC3528PCE8NB_C7343D_H83220UF/2VNB_C7343D_H83PCE9NB_C7343D_H83220UF/2VNB_C7343D_H83PD1SMASS14SMAPD2VARISTOR_0402V0402MHS03VARISTOR_0402PD3VARISTOR_0402V0402MHS03VARISTOR_0402PD4VARISTOR_0402V0402MHS03VARISTOR_0402PD5SOT323BAT54CWSOT323PD17SMASS14SMAPJP23NB_PWR_FB_SHORT_PTSHORT_PINNB_PWR_FB_SHORT_PTPL1L1812_H67150Ohm/100MhzL1812_H67PL2L1812_H67150Ohm/100MhzL1812_H67PL3L0603120Ohm/100MhzL0603PL4L0603120Ohm/100MhzL0603PL5L0603120Ohm/100MhzL0603PL6L0805_H4370Ohm/100MhzL0805_H43PL7L0805_H4370Ohm/100MhzL0805_H43PL8INDUCTOR_2P_287X2606.8UHINDUCTOR_2P_287X260PL9L0805_H4370Ohm/100MhzL0805_H43PL10L0805_H4370Ohm/100MhzL0805_H43PL11INDUCTOR_2P_287X2601UHINDUCTOR_2P_287X260PL12L0805_H4370Ohm/100MhzL0805_H43PL13L0805_H4370Ohm/100MhzL0805_H43PL14INDUCTOR_2P_287X2604.7UHINDUCTOR_2P_287X260PL15INDUCTOR_2P_287X2604.7UHINDUCTOR_2P_287X260PL17L0805_H4370Ohm/100MhzL0805_H43PL18INDUCTOR_2P_287X2601UHINDUCTOR_2P_287X260PL19L0805_H4370Ohm/100MhzL0805_H43PL20L0805_H4370Ohm/100MhzL0805_H43PL21L0805_H4370Ohm/100MhzL0805_H43PL22INDUCTOR_2P_287X2601UHINDUCTOR_2P_287X260PL23L0805_H4370Ohm/100MhzL0805_H43PL24L0805_H4370Ohm/100MhzL0805_H43PL25L0805_H4370Ohm/100MhzL0805_H43PL26L0805_H4370Ohm/100MhzL0805_H43PL27INDUCTOR_2P_287X2601UHINDUCTOR_2P_287X260PL28L0805_H4370Ohm/100MhzL0805_H43PL29L0805_H4370Ohm/100MhzL0805_H43PL30L0805_H4370Ohm/100MhzL0805_H43PL31INDUCTOR_2P_118X118_TK_H7915UHINDUCTOR_2P_118X118_TK_H79PQ1SOIC_8P_50_201X236EMB24B03GSOIC_8P_50_201X236PQ2SOIC_8P_50_197X242AP4835GMSOIC_8P_50_197X242PQ3SOT23_H432N7002ET1GSOT23_H43PQ4SOT23_H432N7002ET1GSOT23_H43PQ5SOT23_H43PMBS3906SOT23_H43PQ6NB_SI7900EDN_H44SI7326DN_T1_E3NB_SI7900EDN_H44PQ7NB_SI7900EDN_H44SI7326DN_T1_E3NB_SI7900EDN_H44PQ8SOT363_NBUM6K1NSOT363_NBPQ9SOT23_H432N7002ET1GSOT23_H43PQ10SOT23_H432N7002ET1GSOT23_H43PQ11SOT363_NBUM6K1NSOT363_NBPQ12SOT363_NBUM6K1NSOT363_NBPQ13MB_SOT669_COLAYRJK0355DPA-00-J0MB_SOT669_COLAYPQ14MB_SOT669_COLAYRJK0355DPA-00-J0MB_SOT669_COLAYPQ17SOT363_NBUM6K1NSOT363_NBPQ18SOT23_H432N7002ET1GSOT23_H43PQ19NB_SI7900EDN_H44SI7326DN_T1_E3NB_SI7900EDN_H44PQ20NB_SI7900EDN_H44SI7326DN_T1_E3NB_SI7900EDN_H44PQ21NB_SI7900EDN_H44SI7326DN_T1_E3NB_SI7900EDN_H44PQ22MB_SOT669_COLAYRJK0355DPA-00-J0MB_SOT669_COLAYPQ27NB_SI7900EDN_H44SI7326DN_T1_E3NB_SI7900EDN_H44PQ28MB_SOT669_COLAYRJK0355DPA-00-J0MB_SOT669_COLAYPQ30SOT363_NBUM6K1NSOT363_NBPQ33NB_SI7900EDN_H44SI7326DN_T1_E3NB_SI7900EDN_H44PQ34MB_SOT669_COLAYRJK0355DPA-00-J0MB_SOT669_COLAYPQ35SOT23_H432N7002ET1GSOT23_H43PQ36SOT363_NBUM6K1NSOT363_NBPQ620SOT89STF826SOT89PQ621SOT23_H432N7002ET1GSOT23_H43PQ622SOT363_NBUM6K1NSOT363_NBPQ624MB_SOT669_COLAYRJK0355DPA-00-J0MB_SOT669_COLAYPQ625NB_SI7900EDN_H44SI7326DN_T1_E3NB_SI7900EDN_H44PQ626NB_SI7900EDN_H44SI7326DN_T1_E3NB_SI7900EDN_H44PQ627NB_SI7900EDN_H44SI7326DN_T1_E3NB_SI7900EDN_H44PQ629MB_SOT669_COLAYRJK0355DPA-00-J0MB_SOT669_COLAYPQ630MB_SOT669_COLAYRJK0355DPA-00-J0MB_SOT669_COLAYPQ631SOT363_NBUM6K1NSOT363_NBPQ632SOT363_NBUM6K1NSOT363_NBPQ633NB_SI7900EDN_H44SI7326DN_T1_E3NB_SI7900EDN_H44PQ634NB_SI7900EDN_H44SI7326DN_T1_E3NB_SI7900EDN_H44PQ635NB_SI7900EDN_H44SI7326DN_T1_E3NB_SI7900EDN_H44PQ636SOT363_NBUM6K1NSOT363_NBPQ637SOT363_NBUM6K1NSOT363_NBPQ638SOT23_H432N7002ET1GSOT23_H43PQ639SOT23_H432N7002ET1GSOT23_H43PQ641SOT363_NBUM6K1NSOT363_NBPQ642SOT363_NBUM6K1NSOT363_NBPQ643SOT363_NBUM6K1NSOT363_NBPQ644SOT363_NBUM6K1NSOT363_NBPQ645SOT363_NBUM6K1NSOT363_NBPQ646SOT363_NBUM6K1NSOT363_NBPQ647SOT363_NBUM6K1NSOT363_NBPQ648SOT23_H432N7002ET1GSOT23_H43PQ649SOT363_NBUM6K1NSOT363_NBPT_TOP26NB_TPC26T_68TPC26TNB_TPC26T_68PU1QFN_32P_20_197X197_PAD_AMIMB39A132MB_QFN_32P_20_S197_PAD_A_4VPU2MB_QFN_32P_20_S197_RIC_4VIART8152DGQWMB_QFN_32P_20_S197_RIC_4VIAPU3QFN_24P_20_S157_PAD_RC_4VIART8205CGQWQFN_24P_20_S157_PAD_RC_4VIAPU4QFN_16P_20_118X118_PAD_H31RT8202APQWMB_QFN_16P_20_S118_PAD_4VPU5SOIC_8P_50_197X236_PAD_GMUP7711U8MB_SOIC_8P_50_197X236_PD_4VPU6QFN_16P_20_118X118_PAD_H31RT8202APQWMB_QFN_16P_20_S118_PAD_4VPU7SOIC_8P_50_197X236_PAD_ANPEAPL5912KACTRLSOIC_8P_50_197X236_PAD_ANPEPU13SOIC_8P_50_197X236AS358MTR-E1SOIC_8P_50_197X236PU14SOT23_S5_RD1LMV321IDBVRNB_SOT23_S5_TPU16QFN_16P_20_118X118_PAD_H31RT8202APQWMB_QFN_16P_20_S118_PAD_4VPU17SOT23_S6_FITI_H39MP3202DJSOT23_S6_FITI_H39PWRBTN_CONFPC_CON_6P_20_2HOLD_RA_LINFPC_CON_6PAG_FPC_CON_6P_20_2HD_RA_LINPWRBTN_CON1FPC_CON_6P_20_2HOLD_RA_LINFPC_CON_6PAG_FPC_CON_6P_20_2HD_RA_LINPWR_BTNTP_SW_4P_2HOLD_LYTACT_SWITCH_4PTP_SW_4P_2HOLD_LYPWR_BTN1TP_SW_4P_2HOLD_LYTACT_SWITCH_4PTP_SW_4P_2HOLD_LYPWR_LEDLED_2P_63X31_H30Y&GLED_2P_63X31_H30PWR_LED1HH_LED_2P_63X31WHITEHH_LED_2P_63X31Q65NBS_SOT23_H432N7002NBS_SOT23_H43R19R0402_H16330OhmR0402_H16RD1SOT323BAT54CWSOT323RTC_CONWTOB_2P_49_2HOLD_RA_LINGYAWTOB_CON_2PAG_WTOB_2P_49_2HOLD_RA_LINGSATA_CONAG_FPC_12P_20_2HOLD_RA_LINGFPC_CON_12PAG_FPC_12P_20_2HOLD_RA_LINGSATA_SLOTAG_SATA_22P_50_2H_LF2SATA_CON_22PAG_SATA_22P_50_2H_LF2SD3SOT323BAT54CWSOT323SJP2NB_PWR_FB_SHORT_PTSHORT_PINNB_PWR_FB_SHORT_PTSJP31MM_OPEN_5MIL_FLASHING1MM_OPEN_5MILNB_1MM_OPEN_5MIL_FLASH_LFSJP13NB_PWR_FB_SHORT_PTSHORT_PINNB_PWR_FB_SHORT_PTSL3L0603120Ohm/100MhzL0603SL4L0603120Ohm/100MhzL0603SL5L0805_H4370Ohm/100MhzL0805_H43SL6L0603120Ohm/100MhzL0603SL7L0805_H4370Ohm/100MhzL0805_H43SPI2HD_2X4P_100_K8_PRX_LF3HEADER_2X4P_K8HD_2X4P_100_K8_PRX_LF3SPI_CONFPC_CON_6P_20_2HOLD_RA_LINFPC_CON_6PAG_FPC_CON_6P_20_2HD_RA_LINSPI_CON2AG_FPC_12P_20_2HOLD_RA_LINGFPC_CON_12PAG_FPC_12P_20_2HOLD_RA_LINGSPI_CON3FPC_CON_6P_20_2HOLD_RA_LINFPC_CON_6PAG_FPC_CON_6P_20_2HD_RA_LINSPI_PWRLED_2P_63X31_H16ORANGELED_2P_63X31_H16SPI_SLOTMB_IC_SOCKET_D_8P_100_LF3IC_SCK_8PMB_IC_SOCKET_D_8P_100_LF3SPKR_CONWTOB_4P_39_2HOLD_RA_LINWtoB_CON_4PAG_WTOB_4P_39_2HOLD_RA_LINSQ5SOT363_NBUM6K1NSOT363_NBST23NB_TPC26T_68TPC26TNB_TPC26T_68SU1NB_BGA_569P_630X630ICH9M_SFFNB_BGA_569P_630X630_NONHDISX1XTAL_4P_272X5532.768KhzXTAL_4P_272X55TC1C1206_H7547UF/6.3VC1206_H75TC2C04020.1UF/16VC0402TC3C06031UF/16VC0603TH1NB_H_C276D87N_M2_P2_V4C276D87NNB_H_C276D87N_M2_P2_V4TH2HOLE_C47D47N_PLACEC47D47NHOLE_C47D47N_PLACETH3NB_H_C276D87N_M2_P2_V4C276D87NNB_H_C276D87N_M2_P2_V4TH4HOLE_O59X47DO59X47NO59X47DO59X47NHOLE_O59X47DO59X47NTP_CONAG_FPC_12P_20_2HOLD_RA_LINGFPC_CON_12PAG_FPC_12P_20_2HOLD_RA_LINGU4974LVC125APW_TSSOP1474LVC125APWSOIC_14P_26_201X252U3CE1C7343D_H87100UF/6.3VC7343D_H87U3D1SOIC_8P_26_122X193AZ1065-06QSOIC_8P_26_122X193U3F1POLYSWITCH_2P_1206_H391.5A/6VPOLYSWITCH_2P_1206_H39U3L1R0603_H240OhmR0603_H24U3L2R0603_H240OhmR0603_H24U3L3R0603_H240OhmR0603_H24U3L4R0603_H240OhmR0603_H24U3L5R0603_H240OhmR0603_H24U3L6R0603_H240OhmR0603_H24U3L7R0603_H240OhmR0603_H24U3L8R0805_H240OhmR0805_H24U3L10CHOKE_4P_79X47_H5190Ohm/100MHzCHOKE_4P_79X47_H51U3L11CHOKE_4P_79X47_H5190Ohm/100MHzCHOKE_4P_79X47_H51U3L12L0805_H4370Ohm/100MhzL0805_H43U3Q1SOT23_H432N7002ET1GSOT23_H43U3R1R0402_H160OhmR0402_H16U3R2R040212KOhmR0402U3R3R0402_H164.7KOhmR0402_H16U3R4R040210MOhmR0402U3R6R040212KOhmR0402U3R8R0402_H160OhmR0402_H16U3R9R0402_H160OhmR0402_H16U3R10R0402_H160OhmR0402_H16U3R11R0402_H160OhmR0402_H16U3R12R0402_H1610KOhmR0402_H16U3R13R0402_H164.7KOhmR0402_H16U3R14R0402_H1610KOhmR0402_H16U3R15R0402_H160OhmR0402_H16U3R16R0402_H145.1KOhmR0402_H14U3R17R0402_H1610KOhmR0402_H16U3RN14R8PS0Ohm4R8PU3T1TPC26B_S4_68TPC26bMB_TPC26B_S4_68U3T2TPC26B_S4_68TPC26bMB_TPC26B_S4_68U3T3TPC26B_S4_68TPC26bMB_TPC26B_S4_68U3U1BGA_100P_30_315X315FL1000GBGA_100P_30_315X315U3U2MB_SOT23_S5_MAXUP7714BMA5-00MB_SOT23_S5_MAXU3USB1NB_USB_9P_4HD_FOX_LF2USB_CON_9PNB_USB_9P_4HD_FOX_LF2U3X1XTAL_4P_197X12610MhzXTAL_4P_197X126VD25SOT323BAV99W_LSOT323VF1POLYSWITCH_2P_1206_H391.5A/6VPOLYSWITCH_2P_1206_H39VGAAG_D_SUB_15P_2H_F_LY_LF2D_SUB_15PAG_D_SUB_15P_2H_F_LY_LF2VL1R0603_H240OhmR0603_H24VL2R0603_H240OhmR0603_H24VL3R0603_H240OhmR0603_H24VL4CHOKE_4P_79X47_H5190Ohm/100MHzCHOKE_4P_79X47_H51VL5CHOKE_4P_79X47_H5190Ohm/100MHzCHOKE_4P_79X47_H51VL6CHOKE_4P_79X47_H5190Ohm/100MHzCHOKE_4P_79X47_H51VL7CHOKE_4P_79X47_H5190Ohm/100MHzCHOKE_4P_79X47_H51VPC1R0402_H160OhmR0402_H16VPC2C06030.1UF/25VC0603VPC3C0805_H5710UF/6.3VC0805_H57VPC4C0805_H5710UF/6.3VC0805_H57VPC5C1206_H7510UF/25VC1206_H75VPC6C1206_H7510UF/25VC1206_H75VPC7C04020.1UF/16VC0402VPD1SMASS14SMAVPJP1NB_PWR_FB_SHORT_PTSHORT_PINNB_PWR_FB_SHORT_PTVPL1L0805_H4370Ohm/100MhzL0805_H43VPL2INDUCTOR_2P_118X118_TK_H7915UHINDUCTOR_2P_118X118_TK_H79VPR1R0402845KOhmR0402VPR2R04027.32KOhmR0402VPR3R0402_H16100KOhmR0402_H16VPU1SOT23_S6_FITI_H39MP3202DJSOT23_S6_FITI_H39VQ3SOT23_H49AP2301GNMB_SOT23VQ5SOT23_H432N7002ET1GSOT23_H43VQ6SOT23_H49AP2301GNMB_SOT23VQ7SOT23_H49AP2301GNMB_SOT23VQ8SOT23_H432N7002ET1GSOT23_H43VQ9SOT23_H43MMBT3904SOT23_H43VQ10SOT23_H432N7002ET1GSOT23_H43VQ11SOT363_NBUM6K1NSOT363_NBVR1R0402_H1610KOhmR0402_H16V_12V_OUTWTOB_4P_31_2HOLD_RAWTOB_CON_4PWTOB_4P_31_2HOLD_RAV_5V_INWTOB_4P_31_2HOLD_RAWTOB_CON_4PWTOB_4P_31_2HOLD_RAWC2C0402_RD91UF/6.3VC0402WC5C06034.7uF/6.3VC0603WC6C0402_RD91UF/6.3VC0402WC7C04020.1UF/16VC0402WC8C0805_H5710UF/6.3VC0805_H57WC9C04020.1UF/16VC0402WC10C0402_RD91UF/6.3VC0402WH1NB_SMT_NUT_C236B189D150_LF2U5F-M-EXPREENB_SMT_NUT_C236B189D150_LF2WLAN_SLOTAG_MINI_PCI_52P_4HOD_F_0MINI_PCI_LATCH_52PAG_MINI_PCI_52P_4HOD_HALFWQ1SOT23_H432N7002ET1GSOT23_H43WQ4SOT23_H432N7002ET1GSOT23_H43WQ5SOT23_H432N7002ET1GSOT23_H43WR1R0805_H240OhmR0805_H24WR2R0402_H1610KOhmR0402_H16WT1NB_TPC26T_68TPC26TNB_TPC26T_68WT2NB_TPC26T_68TPC26TNB_TPC26T_68WT3NB_TPC26T_68TPC26TNB_TPC26T_68WT4NB_TPC26T_68TPC26TNB_TPC26T_68WT5NB_TPC26T_68TPC26TNB_TPC26T_68
老吴 发表于 2019-3-3 16:47:21
PCB文件共享,没有原理图。 回复可见下载。
**** Hidden Message *****
PS:老吴花钱弄来的文件给大家共享的,请大家下载学习就好。不要发网上。
hsin 发表于 2019-3-3 17:53:06
miaomiao 发表于 2019-3-3 18:43:25
牛X,谢谢分享牛X,谢谢分享
lbmone 发表于 2019-3-3 21:55:14
真心不错,遵守约定
boatxin 发表于 2019-3-4 06:51:47
lijunming1983cn 发表于 2019-3-4 08:58:29
baihushan 发表于 2019-3-4 10:10:13
不知道有没有原理图
veis 发表于 2019-3-4 15:57:07
高端,感谢老吴分享
yfhaotian168 发表于 2019-3-5 09:00:04
页: [1] 2 3 4 5 6
查看完整版本: 8层笔记本电脑主板PCB文件共享 CULV45D-F1  SU2300
