(MTK6763)MT6763VCT_LPDDR4X+MT6356WA 10层手机板PCB
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEANT1700IV441000060_ANT1-0103-009_1010610106115524ANT1-0103-009ANT1701IV441000060_ANT1-0103-009_1010610106115524ANT1-0103-009ANT2001SMR-TS-2-1-5-1-25DGR2_SMR-TS-2-SMR-TS-2-1-5-1-25DGR2SMR-TS-2-15-125DGR2ANT2002SMR-TS-2-1-5-1-25DGR2_SMR-TS-2-SMR-TS-2-1-5-1-25DGR2SMR-TS-2-15-125DGR2ANT2003SMR-TS-2-1-5-1-25DGR2_SMR-TS-2-SMR-TS-2-1-5-1-25DGR2SMR-TS-2-15-125DGR2ANT2004SMR-TS-2-1-5-1-25DGR2_SMR-TS-2-SMR-TS-2-1-5-1-25DGR2SMR-TS-2-15-125DGR2ANT220410103114014_ANT1-0203-014_1010310103114014ANT1-0203-014ANT3006IV441000071_ANT1-0103-018C_3.1.3.1.29.0518ANT1-0103-018CANT430310103114014_ANT1-0203-014_1010310103114014ANT1-0203-014ANT430610103114014_ANT1-0203-014_1010310103114014ANT1-0203-014ANT4307730300033_CLAMP1-0104-012_L0226L0226-T1SMP-0WV-LCLAMP1-0104-012ANT43081191740044_CLAMP1-0103-012_11911191740044CLAMP1-0103-012D801140000023_DF0402-004B_LRB521BS-LRB521BS-30T5GDF0402-004BD1002140000013_D0603-005_DS160-40THDDS160-40THD02D0603-005D1701130300040_DDF0201-003_ESD5451Z-ESD5451Z-2/TRDDF0201-003D1702130300040_DDF0201-003_ESD5451Z-ESD5451Z-2/TRDDF0201-003D1707130100012_VSR0201-003_SDV0603E5SDV0603E5R5C220NPTFVSR0201-003D1708130300040_DDF0201-003_NC_ESD545NC_ESD5451Z-2/TRDDF0201-003D1712130300040_DDF0201-003_ESD5451Z-ESD5451Z-2/TRDDF0201-003D1720130100012_VSR0201-003_SDV0603E5SDV0603E5R5C220NPTFVSR0201-003D1721130100012_VSR0201-003_SDV0603E5SDV0603E5R5C220NPTFVSR0201-003D1901130300040_DDF0201-003_NC_ESD545NC_ESD5451Z-2/TRDDF0201-003D1902130300040_DDF0201-003_NC_ESD545NC_ESD5451Z-2/TRDDF0201-003D2000130300040_DDF0201-003_ESD5451Z-ESD5451Z-2/TRDDF0201-003D2001130100012_VSR0201-003_NC_SDV060NC_SDV0603E5R5C220NPTFVSR0201-003D2002130100012_VSR0201-003_NC_SDV060NC_SDV0603E5R5C220NPTFVSR0201-003D2003130300040_DDF0201-003_ESD5451Z-ESD5451Z-2/TRDDF0201-003D2004130100012_VSR0201-003_SDV0603E5SDV0603E5R5C220NPTFVSR0201-003D2005130300040_DDF0201-003_ESD5451Z-ESD5451Z-2/TRDDF0201-003D2006130100012_VSR0201-003_SDV0603E5SDV0603E5R5C220NPTFVSR0201-003D2007130100012_VSR0201-003_SDV0603E5SDV0603E5R5C220NPTFVSR0201-003D2008140200006_SOD323-2-009_LM3Z5V1PLM3Z5V1PT1GSOD323-2-009D2009130300036_DDF0402-005_ESD5651N_ESD5651NDDF0402-005D2010130300040_DDF0201-003_ESD5451Z-ESD5451Z-2/TRDDF0201-003D2011130300040_DDF0201-003_ESD5451Z-ESD5451Z-2/TRDDF0201-003D2012130100012_VSR0201-003_SDV0603E5SDV0603E5R5C220NPTFVSR0201-003D2013130300027_DF0402-004A_LESD8D12TLESD8D12T5GDF0402-004AD2014130100012_VSR0201-003_SDV0603E5SDV0603E5R5C220NPTFVSR0201-003D3004130300038_DDF0201-003_ESD5311Z-ESD5311Z-2/TRDDF0201-003D3005130300038_DDF0201-003_ESD5311Z-ESD5311Z-2/TRDDF0201-003FB1600130000009_LB0603-008_BLM18PG181BLM18PG181SN1DLB0603-008FB1601130000009_LB0603-008_BLM18PG181BLM18PG181SN1DLB0603-008FB1701130000042_L0402-005_BLM15HD102SBLM15HD102SN1DL0402-005FB1702130000042_L0402-005_BLM15HD102SBLM15HD102SN1DL0402-005FB1704130000044_LB0402-005_BLM15AG102BLM15AG102SN1LB0402-005FB1705130000044_LB0402-005_BLM15AG102BLM15AG102SN1LB0402-005FB1707130000044_LB0402-005_BLM15AG102BLM15AG102SN1LB0402-005FB2201130000046_L0201-003_BLM03AX241SBLM03AX241SN1L0201-003FL2201310200272_SFLT5-0101-005B_SFHG8SFHG89GA002SFLT5-0101-005BFL2202310200354_SFLT5-0101-005B_B3924B39242B8840P810SFLT5-0101-005BFL2204310500026_SFLT6-20-0102-006_DP1DP1608-V1524CAT/LFSFLT6-20-0102-006FL4101310200360_SFLT5-0101-005B_B3923B39232B8845P810SFLT5-0101-005BFL4102310200182_SFLT5-0101-005_SAFEA1SAFEA1G90MA0F0AR15SFLT5-0101-005FL4103310200395_SFLT5-0101-006A_SF14-SF14-2605M5UUA1SFLT5-0101-006AFL4201310400177_SFLT8-0102-006_SD18-1SD18-1950R8UUQ1SFLT8-0102-006FL4301310200417_SFLT5-0101-005B_HDFB0HDFB01RSS-B5SFLT5-0101-005BFL4302310200415_SFLT5-0101-005B_HDFB0HDFB05RSS-B5SFLT5-0101-005BFL4303310200330_SFLT5-0101-005B_SFHG5SFHG56BA002SFLT5-0101-005BFL4304310200414_SFLT5-0101-005B_HDFB0HDFB08RSS-B5SFLT5-0101-005BFL4305310200411_SFLT5-0101-005B_HDFB4HDFB40RSS-B5SFLT5-0101-005BFL4306310200278_SFLT10-0201-006_SFWG0SFWG00DB002SFLT10-0201-006FL4307310200399_SFLT5-0101-005B_SAFFBSAFFB2G60AA0F0ASFLT5-0101-005BFL4308310200268_SFLT5-0101-005B_SAFFBSAFFB1G84AB0F0AR15SFLT5-0101-005BHOLE3001FUNCTIONALITY-TEST_NUT_64_102_Pfunctionality-test-pointNUT_64_102_PHOLE3002FUNCTIONALITY-TEST_NUT_64_102_Pfunctionality-test-pointNUT_64_102_PHOLE3003FUNCTIONALITY-TEST_NUT_64_102_Pfunctionality-test-pointNUT_64_102_PHOLE3004FUNCTIONALITY-TEST_NUT_64_102_Pfunctionality-test-pointNUT_64_102_PHOLE3005FUNCTIONALITY-TEST_NUT_64_102_Pfunctionality-test-pointNUT_64_102_PHOLE3006FUNCTIONALITY-TEST_NUT_64_102_Pfunctionality-test-pointNUT_64_102_PHOLE3008FUNCTIONALITY-TEST_NUT_64_102_Pfunctionality-test-pointNUT_64_102_PHOLE3009FUNCTIONALITY-TEST_NUT_64_102_Pfunctionality-test-pointNUT_64_102_PHOLE3010HOLE80_0_HOLE80_0_NC_HOLE80_0NC_HOLE80_0HOLE80_0HOLE3011HOLE80_0_HOLE80_0_NC_HOLE80_0NC_HOLE80_0HOLE80_0HOLE3012HOLE80_0_HOLE80_0_NC_HOLE80_0NC_HOLE80_0HOLE80_0HOLE3013HOLE80_0_HOLE80_0_NC_HOLE80_0NC_HOLE80_0HOLE80_0ID3003ID-BOARD_ID-BOARD_SET_POINTSET_POINTID-BOARDID3004ID-BOARD_ID-BOARD_SET_POINTSET_POINTID-BOARDID3005ID-BOARD_ID-BOARD_SET_POINTSET_POINTID-BOARDID3006ID-BOARD_ID-BOARD_SET_POINTSET_POINTID-BOARDID3007ID_ID_SINGLE_POINTSingle_pointIDID3008ID_ID_SINGLE_POINTSingle_pointIDID3009ID_ID_SINGLE_POINTSingle_pointIDID3010ID_ID_SINGLE_POINTSingle_pointIDID3011ID-BOARD_ID-BOARD_SET_POINTSET_POINTID-BOARDID3012ID-BOARD_ID-BOARD_SET_POINTSET_POINTID-BOARDID3013ID-BOARD_ID-BOARD_SET_POINTSET_POINTID-BOARDID3014ID-BOARD_ID-BOARD_SET_POINTSET_POINTID-BOARDJ1701440800046_VAF5-0811-039B-BRK_PJPJ-D3167A-ABK7AU05L-RHVAF5-0811-039B-BRKJ1800440000119_SED40-16-S-007_WP7B-SWP7B-S040VA1SED40-16-S-007J1900440000117_SED30-16-S-007_WP7A-SWP7A-S030VA1SED30-16-S-007J1901SJ116217_SED24-14-S-006A_SJ1162SJ116217SED24-14-S-006AJ1902SJ116217_SED24-14-S-006A_SJ1162SJ116217SED24-14-S-006AJ2001440000156_SED30-14-S-007_2458524 5857 030 201 829+SED30-14-S-007J2002440400094_SIM12-1826-015_1.063A1.063A0-013-5R0SIM12-1826-015J2003440500064_PWC6-0206-007_WP10-S0WP10-S002VA10-R15000PWC6-0206-007J2101440000092_SED10-16-S-007_WP7A-SWP7A-S010VA1SED10-16-S-007J2102440000092_SED10-16-S-007_WP7A-SWP7A-S010VA1SED10-16-S-007J2201440600015_RF2-0202-009A_7.022A07.022A0-000-1R0RF2-0202-009AJ4201440600015_RF2-0202-009A_7.022_17.022A0-000-1R0RF2-0202-009AJ4202440600015_RF2-0202-009A_7.022_17.022A0-000-1R0RF2-0202-009AJ4204440600020_RF4-0202-012_1002005910020059RF4-0202-012L801120000236_L0201-003_22NH_IV12022 nHL0201-003L802120000236_L0201-003_22NH_IV12022 nHL0201-003L803130000044_LB0402-005_BLM15AG1_1BLM15AG102SN1LB0402-005L1003120300106_PL0203-012D_10UH_IV110 uHPL0203-012DL1006130000042_L0402-005_BLM15HD102SBLM15HD102SN1DL0402-005L1701100000001_R0402-004_0R_100000000RR0402-004L1702100000001_R0402-004_0R_100000000RR0402-004L1703100000001_R0402-004_0R_100000000RR0402-004L1704100000001_R0402-004_0R_100000000RR0402-004L1707120000132_L0402-007_68NH_IV12068 nHL0402-007L1708130000036_LB0603-008_PZ1608D102PZ1608D102-R80TFLB0603-008L1801130000054_LB0201-003_BLM03HD102BLM03HD102SN1LB0201-003L1802100000004_R0201-003_0R_100000000RR0201-003L1804100000001_R0402-004_0R_100000000RR0402-004L2000100000001_R0402-004_0R_IV1000000RR0402-004L2001100000001_R0402-004_0R_IV1000000RR0402-004L2003100000000_R0603-005_0R_IV1000000RR0603-005L2105100000089_R0201-003_24R_100000024RR0201-003L2106100000089_R0201-003_24R_100000024RR0201-003L2201120000296_L0201-003_82NH_1200082 nHL0201-003L2202120000296_L0201-003_82NH_1200082 nHL0201-003L2204120000277_L0201-003_9.1NH_12009.1 nHL0201-003L2205120000287_L0201-003_27NH_1200027 nHL0201-003L2207120000269_L0201-003_12NH_1200012 nHL0201-003L2208120000242_L0201-003_NC_8.2NH_1NC_8.2 nHL0201-003L2211120000049_L0201-003_NC_2.2NH_IVNC_2.2nHL0201-003L2213120000186_L0201-003_10NH_1200010 nHL0201-003L2216100000004_R0201-003_0R_100000000RR0201-003L4101110000064_C0201-003_33PF/50V_I33pF/50 VC0201-003L4102120000248_L0201-003_NC_1.8NH_INC_1.8 nHL0201-003L4103120000241_L0201-003_NC_3.9NH_INC_3.9 nHL0201-003L4104120000241_L0201-003_3.9NH_IV123.9 nHL0201-003L4105120000187_L0201-003_5.1NH_IV125.1 nHL0201-003L4106120000277_L0201-003_9.1NH_IV129.1 nHL0201-003L4107120000184_L0201-003_4.7NH_IV124.7 nHL0201-003L4108120000058_L0201-003_3.3NH_IV1203.3nHL0201-003L4109110000094_C0201-003_NC_2.2PF/25NC_2.2pF/25 VC0201-003L4110120000248_L0201-003_NC_1.8NH_INC_1.8 nHL0201-003L4112120000245_L0201-003_1.2NH_IV121.2 nHL0201-003L4113120000241_L0201-003_NC_3.9NH_INC_3.9 nHL0201-003L4114120000241_L0201-003_NC_3.9NH_INC_3.9 nHL0201-003L4115120000058_L0201-003_NC_3.3NH_IVNC_3.3nHL0201-003L4116120000245_L0201-003_1.2NH_IV121.2 nHL0201-003L4117120000248_L0201-003_NC_1.8NH_1NC_1.8 nHL0201-003L4118120000238_L0201-003_2NH_IV12002 nHL0201-003L4119120000238_L0201-003_2NH_IV12002 nHL0201-003L4120110000064_C0201-003_33PF/50V_1133pF/50VC0201-003L4205120000188_L0201-003_NC_3.3NH_1NC_3.3 nHL0201-003L4206120000250_L0201-003_1.5NH_IV121.5 nHL0201-003L4207120000233_L0201-003_15NH_IV12015 nHL0201-003L4208120000188_L0201-003_NC_3.3NH_1NC_3.3 nHL0201-003L4211120000223_L0201-003_1.3NH_IV121.3 nHL0201-003L4212120000249_L0201-003_7.5NH_IV127.5 nHL0201-003L4216120000241_L0201-003_3.9NH_IV123.9 nHL0201-003L4218120000240_L0201-003_6.8NH_IV126.8 nHL0201-003L4219120000250_L0201-003_1.5NH_IV121.5 nHL0201-003L4220120000242_L0201-003_8.2NH_IV128.2 nHL0201-003L4221120000176_L0201-003_2.4NH_IV122.4 nHL0201-003L4229120000058_L0201-003_3.3NH_120003.3nHL0201-003L4230120000293_L0201-003_2.4000NH_I2.4000 nHL0201-003L4231120000304_L0201-003_NC_10NH_IVNC_10 nHL0201-003L4232120000304_L0201-003_NC_10NH_IVNC_10 nHL0201-003L4233120000265_L0201-003_5.6NH_IV125.6 nHL0201-003L4234120000237_L0201-003_1NH_IV12001 nHL0201-003L4239120000243_L0201-003_NC_18NH_12NC_18 nHL0201-003L4240120000117_L0201-003_NC_18NH_120NC_18nHL0201-003L4242120000246_L0201-003_NC_3.6NH_INC_3.6 nHL0201-003L4243120000240_L0201-003_NC_6.8NH_INC_6.8 nHL0201-003L4244120000117_L0201-003_NC_18NH_120NC_18nHL0201-003L4245120000242_L0201-003_NC_8.2NH_INC_8.2 nHL0201-003L4249120000241_L0201-003_NC_3.9NH_1NC_3.9 nHL0201-003L4253120000250_L0201-003_NC_1.5NH_INC_1.5 nHL0201-003L4254120000246_L0201-003_NC_3.6NH_INC_3.6 nHL0201-003L4255110000064_C0201-003_33PF/50V_I33pF/50 VC0201-003L4256120000265_L0201-003_NC_5.6NH_INC_5.6 nHL0201-003L4257120000239_L0201-003_NC_12NH_IVNC_12 nHL0201-003L4301120000288_L0201-003_27NH_IV12027 nHL0201-003L4302120000244_L0201-003_9.1NH_IV129.1 nHL0201-003L4303120000219_L0201-003_6.2NH_IV126.2 nHL0201-003L4304120000058_L0201-003_NC_3.3NH_IVNC_3.3nHL0201-003L4305120000058_L0201-003_NC_3.3NH_IVNC_3.3nHL0201-003L4306120000232_L0201-003_NC_2.7NH_INC_2.7 nHL0201-003L4307120000232_L0201-003_NC_2.7NH_INC_2.7 nHL0201-003L4308110000094_C0201-003_2.2PF/25V_2.2pF/25 VC0201-003L4309120000249_L0201-003_NC_7.5NH_INC_7.5 nHL0201-003L4310120000293_L0201-003_2.4000NH_I2.4000 nHL0201-003L4311120000249_L0201-003_NC_7.5NH_INC_7.5 nHL0201-003L4312120000232_L0201-003_2.7NH_IV122.7 nHL0201-003L4313120000249_L0201-003_NC_7.5NH_INC_7.5 nHL0201-003L4314120000243_L0201-003_18NH_1200018 nHL0201-003L4315120000058_L0201-003_NC_3.3NH_IVNC_3.3nHL0201-003L4316120000058_L0201-003_NC_3.3NH_IVNC_3.3nHL0201-003L4321120000232_L0201-003_NC_2.7NH_INC_2.7 nHL0201-003L4322120000232_L0201-003_NC_2.7NH_INC_2.7 nHL0201-003L4323120000232_L0201-003_NC_2.7NH_INC_2.7 nHL0201-003L4324120000232_L0201-003_NC_2.7NH_INC_2.7 nHL0201-003L4325120000265_L0201-003_5.6NH_IV125.6 nHL0201-003L4326120000240_L0201-003_6.8NH_IV126.8 nHL0201-003L4327120000240_L0201-003_6.8NH_IV126.8 nHL0201-003L4329120000058_L0201-003_NC_3.3NH_IVNC_3.3nHL0201-003L4330120000058_L0201-003_NC_3.3NH_IVNC_3.3nHL0201-003L4331120000058_L0201-003_NC_3.3NH_12NC_3.3nHL0201-003L4333100000004_R0201-003_NC_0R_10000NC_0RR0201-003L4334100000004_R0201-003_0R_100000000RR0201-003L4335100000004_R0201-003_0R_100000000RR0201-003L4337110000211_C0201-003_0.5PF/50V_10.5pF/50VC0201-003L4338110000211_C0201-003_0.5PF/50V_10.5pF/50VC0201-003L4339100000004_R0201-003_0R_100000000RR0201-003L4340120000246_L0201-003_3.6NH_IV123.6 nHL0201-003LB1901130500013_LB0403-005B_EXC14CT90EXC14CT900ULB0403-005BLB1902130500013_LB0403-005B_EXC14CT90EXC14CT900ULB0403-005BLB1903130500013_LB0403-005B_EXC14CT90EXC14CT900ULB0403-005BLB1904130500013_LB0403-005B_EXC14CT90EXC14CT900ULB0403-005BLB1905130500013_LB0403-005B_EXC14CT90EXC14CT900ULB0403-005BLB1906130500013_LB0403-005B_EXC14CT90EXC14CT900ULB0403-005BLB1907130500013_LB0403-005B_EXC14CT90EXC14CT900ULB0403-005BLB1909130500013_LB0403-005B_EXC14CT90EXC14CT900ULB0403-005BLB1915130500013_LB0403-005B_EXC14CT90EXC14CT900ULB0403-005BLB1916130500013_LB0403-005B_EXC14CT90EXC14CT900ULB0403-005BLB1917130500013_LB0403-005B_EXC14CT90EXC14CT900ULB0403-005BLED1912IV470100003_LED2-0203-026-BOA_IIV470100003LED2-0203-026-BOALED1913IV470100002_LED2-0203-019-BOA_IIV470100002LED2-0203-019-BOAMIC1701IV460000097_MIC5-0304-010A_S18OS18OB381-015MIC5-0304-010AMR2101100300005_TSR0402-005_100K_1003100KTSR0402-005PL601120300197_PL0203-012D_0.47000U0.47000 uHPL0203-012DPL602120300197_PL0203-012D_0.47000U0.47000 uHPL0203-012DPL603120300236_PL0202-010D_1UH_IV121 uHPL0202-010DPL604120300236_PL0202-010D_1UH_IV121 uHPL0202-010DPL605120300261_PL0203-010F_1UH_IV121 uHPL0203-010FPL606120300261_PL0203-010F_1UH_IV121 uHPL0203-010FPL1001120300261_PL0203-010F_1UH_IV121 uHPL0203-010FPL1002120300239_PL0202-010D_2.2000UH2.2000 uHPL0202-010DPL1600120300261_PL0203-010F_1UH_IV121 uHPL0203-010FTP3028MANUFACTURAL-TEST_32_TP32_MANUFmanufactural-test-pointTP32TP3029MANUFACTURAL-TEST_32_TP32_MANUFmanufactural-test-pointTP32TP3030FUNCTIONALITY-TEST_TP24_FUNCTIOfunctionality-test-pointTP24U101MT6763VCT_LPDDR4X_BGA566-16-111MT6763VCT_LPDDR4XBGA566-16-1112-009U601MT6356WA_BGA181-16-0606-006_MT6MT6356WABGA181-16-0606-006U1001MT6370P_BGA93-16-0404-006_MT637MT6370PBGA93-16-0404-006U1500220300233_BGA221-20-1213-010_KMKMRX1000BM-B614BGA221-20-1213-010U1602AW87319CSR_BGA19-20-0203-006_AWAW87319CSRBGA19-20-0203-006U1801130500013_LB0403-005B_EXC14CT90EXC14CT900ULB0403-005BU1803130500013_LB0403-005B_EXC14CT90EXC14CT900ULB0403-005BU1804130500013_LB0403-005B_EXC14CT90EXC14CT900ULB0403-005BU1810130500013_LB0403-005B_EXC14CT90EXC14CT900ULB0403-005BU1811130500013_LB0403-005B_EXC14CT90EXC14CT900ULB0403-005BU1902230000103_DFN4-26-0101-006_NCP1NCP114AMX120TCGDFN4-26-0101-006U1907IV270100036_BGA36-16-0202-006_FFSA644BUCXBGA36-16-0202-006U1911230000096_DFN4-26-0101-006_NCP1NCP114AMX105TCGDFN4-26-0101-006U1912230000113_DFN4-26-0101-004_WL28WL2820D28-4/TRDFN4-26-0101-004U1913230000113_DFN4-26-0101-004_WL28WL2820D28-4/TRDFN4-26-0101-004U1914230000113_DFN4-26-0101-004_WL28WL2820D28-4/TRDFN4-26-0101-004U2002230600010_BGA12-16-0102-006C_NCNC_KTS1681BGA12-16-0102-006CU2101ICM-20608D_BCC16-20-0303-008_ICICM-20608DBCC16-20-0303-008U2201240700008_QFN40-16-0505-009A_MTMT6625LQFN40-16-0505-009AU2202320300021_BCC6-16-0101-005_AW50AW5015DNRBCC6-16-0101-005U4001MT6177_RF_BGA144-16-0505-007_MTMT6177_RFBGA144-16-0505-007U4101320100104_BCC42-17-0407-007_320320100104BCC42-17-0407-007U4202310400181_SFLT8-0102-006_SD18-1SD18-1880R8UUA1SFLT8-0102-006U4204310400163_SFLT8-0102-006_SD18-0SD18-0836R8UUQ1SFLT8-0102-006U4205320100064_BCC38-19-0506-008A_RFRF5216BCC38-19-0506-008AU4206310400170_SFLT8-0102-005A_B3927B39272B8674P810SFLT8-0102-005AU4207310400215_SFLT8-0102-006_SAYEY8SAYEY897MBG0F0AR05SFLT8-0102-006U4208310200278_SFLT10-0201-006_SFWG0SFWG00DB002SFLT10-0201-006U4209320500050_QFN12-20-0202-006A_SKSKY13396-397LFQFN12-20-0202-006AU4211310400220_SFLT8-0102-005A_B3918B39182B8680P810SFLT8-0102-005AU4301MXD8680_BCC14-16-0202-006_MXD86MXD8680BCC14-16-0202-006U4308320500109_BGA8-16-0101-005C_NC_NC_SKY19223-001BGA8-16-0101-005CU4309320500114_BGA11-16-0202-004B_CXCXA4429GCBGA11-16-0202-004BX801190000099_X4-0203-010_26/MHZ_IV26/MHzX4-0203-010X2201190100048_X4-0203-009_26/MHZ_IV26/MHzX4-0203-009 PCB和原理图一起打包。还没有完全画完的。仅做参考。
**** Hidden Message ***** 学习资料不错 老大牛 学习资料不错 学习资料不错
