MDAS光纤+千兆网络分布系统-由EP2AGX45F780+KSZ9031RNX+KSZ8041NL+LMK0
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAME12VLED_LED0603_GRNGRNLED060312V_INCON2_2PIN_3_81_3.81MM*23.81mm*22PIN_3_81ACT1LED_LED0603_GRNGRNLED0603ACT2LED_LED0603_GRNGRNLED0603ACT3LED_LED0603_GRNGRNLED0603ACT4LED_LED0603_GRNGRNLED0603ACT5LED_LED0603_GRNGRNLED0603ACT6LED_LED0603_GRNGRNLED0603ACT7LED_LED0603_GRNGRNLED0603ACT8LED_LED0603_GRNGRNLED0603ADCCON4_SIP_4P_CON4CON4SIP_4PALMCON20_2_8PIN_1_5AAA_8PIN-1.5MM8PIN -1.5mm8PIN_1_5AAAB1INDUCTOR_LB0805_BLM21PG331SN1BLM21PG331SN1LB0805BAT1CAPACITORPOL_C_BAT1_CR1220CR1220C_BAT1CPULED_LED0603_GRNGRNLED0603D1DIODEBREAKDOWN_LED0603_SD101AWSD101AWSLED0603D2DIODEBREAKDOWN_LED0603_SD101AWSD101AWSLED0603D3DIODEBREAKDOWN_LED0603_SD101AWSD101AWSLED0603D5BAS21/SOT_3_SOT23_BAS21/SOTBAS21/SOTSOT23D6LED_LED0603_GRNGRNLED0603D30DIODE_TUNINGVARACTORS_SOT23_SMVSMV-1249-074LFSOT23D31BAS21/SOT_2_SOT23_BAS21/SOTBAS21/SOTSOT23DONELED_LED0603_GRNGRNLED0603FB1IND-FB_LB0603_500@100M500@100MLB0603FB2IND-FB_LB0603_500@100M500@100MLB0603FB3IND-FB_LB0603_500@100M500@100MLB0603FB47IND-FB_LB0805_500@100M500@100MLB0805FB48FERRITE_BEAD_LB0603_BLM18PG330BLM18PG330LB0603FB49IND-FB_LB0603_500@100M500@100MLB0603FB50IND-FB_LB0805_500@100M500@100MLB0805FB74FERRITE_BEAD_LB0603_BLM18PG330BLM18PG330LB0603FB75FERRITE_BEAD_LB0603_BLM18PG330BLM18PG330LB0603FB76FERRITE_BEAD_LB0603_BLM18PG330BLM18PG330LB0603FB77FBEAD_1_LB0603_FBEADFBEADLB0603FB78FBEAD_1_LB0603_FBEADFBEADLB0603FB79FBEAD_1_LB0603_FBEADFBEADLB0603FB80FBEAD_1_LB0603_FBEADFBEADLB0603FB81FBEAD_1_LB0603_FBEADFBEADLB0603FB82FBEAD_1_LB0603_FBEADFBEADLB0603FB83FBEAD_1_LB0603_FBEADFBEADLB0603J1CON3_SIP3_CON3CON3SIP3J2JUMPER_0_B00T_FORBOOTFor BOOTB00TJ4CON20_CON20_CON20CON20CON20J5CON40_CON40_CON40CON40CON40JTAG1CON20AP_2_8XJTAG_NCNC8XJTAGL1INDUCTOR_IND_10MMX10MM2_MSS1048MSS1048-472IND_10MMX10MM2L2INDUCTOR_IND_10MMX10MM2_MSS1048MSS1048-472IND_10MMX10MM2L3INDUCTOR_IND_10MMX10MM2_MSS10_1MSS1048-332IND_10MMX10MM2L4COIL_0_LB0603_BLM21PG331SN1BLM21PG331SN1LB0603L5INDUCTOR_IND_10MMX10MM2_1.5UH/51.5uH/5AIND_10MMX10MM2L6COIL_0_LB0805_0805LS-471X_L_0805LS-471X_L_LB0805L7COIL_0_LB0603_BLM21PG331SN1BLM21PG331SN1LB0603L11INDUCTOR_IND_10MMX10MM2_1.5UH/51.5uH/5AIND_10MMX10MM2LAN1RJ45-1G _9_RJ45_RJ45BELFUSE SSRJ45 BelfuseSS-6488S-A-FLS-50RJ45LAN2RJ45-1G _9_RJ45_RJ45BELFUSE SSRJ45 BelfuseSS-6488S-A-FLS-50RJ45LAN3RJ45-1G _9_RJ45_RJ45BELFUSE SSRJ45 BelfuseSS-6488S-A-FLS-50RJ45LAN4RJ45-1G _9_RJ45_RJ45BELFUSE SSRJ45 BelfuseSS-6488S-A-FLS-50RJ45LAN5RJ45-1G _9_RJ45_RJ45BELFUSE SSRJ45 BelfuseSS-6488S-A-FLS-50RJ45LAN6RJ45-1G _9_RJ45_RJ45BELFUSE SSRJ45 BelfuseSS-6488S-A-FLS-50RJ45LAN7RJ45-1G _9_RJ45_RJ45BELFUSE SSRJ45 BelfuseSS-6488S-A-FLS-50RJ45LAN8RJ45-1G _9_RJ45_RJ45BELFUSE SSRJ45 BelfuseSS-6488S-A-FLS-50RJ45LAN9RJ45-1G _9_RJ45_RJ45BELFUSE SSRJ45 BelfuseSS-6488S-A-FLS-50RJ45LAN10RJ45-1G _9_RJ45_RJ45BELFUSE SSRJ45 BelfuseSS-6488S-A-FLS-50RJ45LINK7LED_LED0603_GRNGRNLED0603LINK8LED_LED0603_GRNGRNLED0603P1EP2AGX45F780_0_EP2AGX45F780_(S1EP2AGX45F780_2EP2AGX45F780PLLLED_LED0603_GRNGRNLED0603Q12N6249_0_SOT23_2N3904/STO232N3904/STO23SOT23Q22N6249_0_SOT23_2N3904/STO232N3904/STO23SOT23RS232CON5_CON5_5PIN_1.55Pin_1.5CON5RS485CON3_CON3_CON3CON3CON3SFP1SFP_MBPD_1.25GBPS1.25GbpsMBPDSFP2SFP_MBPD_1.25GBPS1.25GbpsMBPDSFP3SFP_MBPD_1.25GBPS1.25GbpsMBPDSFP4SFP_MBPD_1.25GBPS1.25GbpsMBPDSFP5SFP_MBPD_1.25GBPS1.25GbpsMBPDSFP6SFP_MBPD_1.25GBPS1.25GbpsMBPDSFP7SFP_MBPD_1.25GBPS1.25GbpsMBPDSFP8SFP_MBPD_1.25GBPS1.25GbpsMBPDT10H5007_1_H500X_PULSEH5007NLPULSE H5007NLH500XT11H1102_NEW_H110X_H1102H1102H110XTP1TEST POINT_TP_TESTPOINTTest pointTPTP2TEST POINT_TP_TESTPOINTTest pointTPTP3TEST POINT_TP_TESTPOINTTest pointTPTP4TEST POINT_TP_TESTPOINTTest pointTPU1FDS8984_0_SO8NB_FDS8984FDS8984SO8NBU2XRP7713_0_QFN_32_XRP7713XRP7713QFN_32U3FDS8984_0_SO8NB_FDS8984FDS8984SO8NBU4FDS8984_0_SO8NB_FDS8984FDS8984SO8NBU5LPC1778FBD144_1_TQFP144_LPC1778LPC1778FBD144TQFP144U66PIN_3_SO8NB_TMP36TMP36SO8NBU7IMP809_SOT23_CAT809SCAT809SSOT23U8KS8721_0_MLF-32P_KSZ8041NL/QFNKSZ8041NL/QFNMLF-32PU9SP3232E_0_SSOP16_SP3232SP3232SSOP16U10SST25VF080-FP_SO8NB_W25Q32(NC)W25Q32(NC)SO8NBU11KS8995M_1_KSZ9031RN_A_KSZ9031RNKSZ9031RNXKSZ9031RN_AU12OSC-HALF_1_OSC4P_50MHZ/10PPM/5X50MHZ/10PPM/5X7OSC4PU13KS8995M_1_KSZ9031RN_A_KSZ9031RNKSZ9031RNXKSZ9031RN_AU14KS8995M_1_KSZ9031RN_A_KSZ9031RNKSZ9031RNXKSZ9031RN_AU15KS8995M_1_KSZ9031RN_A_KSZ9031RNKSZ9031RNXKSZ9031RN_AU16KS8995M_1_KSZ9031RN_A_KSZ9031RNKSZ9031RNXKSZ9031RN_AU17KS8995M_1_KSZ9031RN_A_KSZ9031RNKSZ9031RNXKSZ9031RN_AU18KS8995M_1_KSZ9031RN_A_KSZ9031RNKSZ9031RNXKSZ9031RN_AU19KS8995M_1_KSZ9031RN_A_KSZ9031RNKSZ9031RNXKSZ9031RN_AU20KS8995M_1_KSZ9031RN_A_KSZ9031RNKSZ9031RNXKSZ9031RN_AU21KS8995M_1_KSZ9031RN_A_KSZ9031RNKSZ9031RNXKSZ9031RN_AU22LMK04031BISQ_0_LMK01020BBBBBB_LLMK04031BISQLMK01020BBBBBBU23AP1117_0_SOT223-3L_SPX1117M3-LSPX1117M3-LSOT223-3LU26W25Q32BVSSIG_SO8NBAAA_W25Q64BVSW25Q64BVSSIGSO8NBAAAU28MAX1487_SO8NB_MAX3485CSAMAX3485CSASO8NBU296PIN_0_SOP9-50-150_TPS54527DDATPS54527DDASOP9-50-150U30OSC-HALF_1_OSC4P_50MHZ/10PPM/5X50MHZ/10PPM/5X7OSC4PU31KS8721_0_MLF-32P_KSZ8041NL/QFNKSZ8041NL/QFNMLF-32PU32KS8721_0_MLF-32P_KSZ8041NL/QFNKSZ8041NL/QFNMLF-32PU33KS8721_0_MLF-32P_KSZ8041NL/QFNKSZ8041NL/QFNMLF-32PU34KS8721_0_MLF-32P_KSZ8041NL/QFNKSZ8041NL/QFNMLF-32PU35KS8721_0_MLF-32P_KSZ8041NL/QFNKSZ8041NL/QFNMLF-32PU36KS8721_0_MLF-32P_KSZ8041NL/QFNKSZ8041NL/QFNMLF-32PU37KS8721_0_MLF-32P_KSZ8041NL/QFNKSZ8041NL/QFNMLF-32PU38KS8721_0_MLF-32P_KSZ8041NL/QFNKSZ8041NL/QFNMLF-32PU396PIN_0_SOP9-50-150_TPS54527DDATPS54527DDASOP9-50-150U41JTAG CON_SIP_10P_JTAGCONJTAG CONSIP_10PU51TPS74801_TPS74801_SON10_TPS7480TPS74801TPS74801_SON10U52TPS74701_TPS74701_SON10_TPS7480TPS74801TPS74701_SON10XIOCON20_10X2_2X10_2.54MM2x10_2.54mm10X2Y1ZTA_Y200W_ZTAZTAY200WY2CRYSTAL_XTAL_HC49SMT_24MHZ24MHZXTAL_HC49SMTY3CRYSTAL_XTAL32768_32.8K32.8KXTAL32768Y4OSC_DIP8_9_JZ3472AAAA_12.50MHZ12.50MhzJZ3472AAAAY5CRYSTAL_XTAL_HC49SMT_HC49SM-12MHC49SM-12M288-1B25B14XTAL_HC49SMTZ1ZC2800E/SOT_5_LED0603_PESD3V3S1PESD3V3S1UBLED0603Z2ZC2800E/SOT_5_LED0603_PESD3V3S1PESD3V3S1UBLED0603Z3ZC2800E/SOT_5_LED0603_PESD3V3S1PESD3V3S1UBLED0603Z4ZC2800E/SOT_5_LED0603_PESD3V3S1PESD3V3S1UBLED0603Z5ZC2800E/SOT_5_LED0603_PESD3V3S1PESD3V3S1UBLED0603Z6ZC2800E/SOT_5_LED0603_PESD3V3S1PESD3V3S1UBLED0603Z7ZC2800E/SOT_5_LED0603_PESD3V3S1PESD3V3S1UBLED0603 本站独有,作品仅限学习交流。。禁止转载到其他网站(或网络上)。
PCB文件回复可见下载。
**** Hidden Message *****
非常感谢楼主大神分享 老吴就是牛
回 老吴 的帖子
老吴:本站独有,作品仅限学习交流。。禁止转载到其他网站(或网络上)。PCB文件回复可见下载。
[内容隐藏]
....... (2019-07-08 12:57) images/back.gif
学习一下谢谢 谢谢楼主分享
