老吴 发表于 2019-9-1 23:24:03
Intel I7  QM77_StackPC OXY5535A(12层电脑主板)&
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEAB1L0603BEAD-80R-3AL0603AU1LQFP-48_7_0X7_0X1_6MMREALTEK_ALC887-VD2-CGLQFP-48_7_0X7_0X1_6MMB1L0603BEAD-80R-3AL0603B2L0603BEAD-80R-3AL0603B3L0603BEAD-80R-3AL0603B4L0603BEAD-80R-3AL0603B5L060327NH_6_300MA_0.45L0603B6L060327NH_6_300MA_0.45L0603B7L060327NH_6_300MA_0.45L0603B8L0603BEAD-80R-3AL0603B9L0603BEAD-80R-3AL0603B10L0603BEAD-80R-3AL0603B11L0603BEAD-80R-3AL0603B13L0603BEAD-80R-3AL0603B14L0603BEAD-80R-3AL0603B15L0603BEAD-80R-3AL0603B16L0603BEAD-80R-3AL0603B17L0603BEAD-80R-3AL0603B18L0603BEAD-80R-3AL0603BAT1BAT-CR2012-101KEYSTONE_101BAT-CR2012-101BIOS1SOP8_209MILW25Q64FVSSIGTRSOP8_209MILCN18P4C1206150P_8P4C_50V_K8P4C1206CN28P4C1206150P_8P4C_50V_K8P4C1206CN38P4C1206150P_8P4C_50V_K8P4C1206CN48P4C1206150P_8P4C_50V_K8P4C1206CON_A1ASP-129637-03CONNECTOR A TOPASP-129637-03CPU1BGA1023-INTEL-IVYIVY BRIDGE BGA1023BGA1023-INTEL-IVYCPUFANB3B-PH-KL721-81-03TW00B3B-PH-KLD1SOT323BAT54CW_SOT323_200MASOT323D2SOT323BAT54CW_SOT323_200MASOT323D3SOD-523RB521S-30_SOD523_200MASOD-523D4SOD-523RB521S-30_SOD523_200MASOD-523D6SOT323BAT54CW_SOT323_200MASOT323D7SOT323BAT54AW_SOT323_200MASOT323D8SMASX34_SMA_3A_40VSMAD9SOT323BAT54AW_SOT323_200MASOT323D10SOD-523RB521S-30_SOD523_200MASOD-523D11SOT323BAT54AW_SOT323_200MASOT323DU1QFN52_0-4-6X6MM-BWNCP6131S52MNR2G_QFN52QFN52_0-4-6X6MM-BWEC1C040210P_4_NPO_50V_JC0402EC2C040210P_4_NPO_50V_JC0402EC3C040210P_4_NPO_50V_JC0402EC4C040210P_4_NPO_50V_JC0402EC5C040210P_4_NPO_50V_JC0402EF1SOT23_5L_H1_1NCP380HSN10AAT1G_SOT23-5_1A_EN_HIGHSOT23_5L_H1_1EF2SOT23_5L_H1_1NCP380HSN10AAT1G_SOT23-5_1A_EN_HIGHSOT23_5L_H1_1EF3SOT23_5L_H1_1NCP380HSN10AAT1G_SOT23-5_1A_EN_HIGHSOT23_5L_H1_1EF4SOT23_5L_H1_1NCP380HSN10AAT1G_SOT23-5_1A_EN_HIGHSOT23_5L_H1_1ESD1SOD-323AZ2225-01L_SOD323SOD-323ESD2SOD-323AZ2225-01L_SOD323SOD-323ESD3SOT23SM712_TCTSOT23ESD4SOT23SM712_TCTSOT23ESD5SOT23SM712_TCTSOT23ESD6SOT23SM712_TCTSOT23ESD7SOT23-6AZC199-04SC_SOT23-6L_5V_1PSOT23-6ESD8SOD-323AZ2225-01L_SOD323SOD-323ESD9DFN2510P10EAZ1045-04F_DFN2510P10E_5V_0.5PDFN2510P10EESD10DFN2510P10EAZ1045-04F_DFN2510P10E_5V_0.5PDFN2510P10EESD11DFN2510P10EAZ1045-04F_DFN2510P10E_5V_0.5PDFN2510P10EESD12DFN2510P10EAZ1045-04F_DFN2510P10E_5V_0.5PDFN2510P10EESD13SOT23-6AZC199-04SC_SOT23-6L_5V_1PSOT23-6ESD14DFN2510P10EAZ1045-04F_DFN2510P10E_5V_0.5PDFN2510P10EESD15DFN2510P10EAZ1045-04F_DFN2510P10E_5V_0.5PDFN2510P10EESD16DFN2510P10EAZ1045-04F_DFN2510P10E_5V_0.5PDFN2510P10EESD17SOT23-6AZC199-04SC_SOT23-6L_5V_1PSOT23-6ESD18SOT23-6AZC199-04SC_SOT23-6L_5V_1PSOT23-6ESD19SOT23-6AZC199-04SC_SOT23-6L_5V_1PSOT23-6ESD24DFN2510P10EAZ1045-04F_DFN2510P10E_5V_0.5PDFN2510P10EESD25DFN2510P10EAZ1045-04F_DFN2510P10E_5V_0.5PDFN2510P10EESD26DFN2510P10EAZ1045-04F_DFN2510P10E_5V_0.5PDFN2510P10EESD27DFN2510P10EAZ1045-04F_DFN2510P10E_5V_0.5PDFN2510P10EESD28DFN2510P10EAZ1045-04F_DFN2510P10E_5V_0.5PDFN2510P10EESD29DFN2510P10EAZ1045-04F_DFN2510P10E_5V_0.5PDFN2510P10EF2F0603POLY-FUSE-1.75A_6VF0603F3F0603POLY-FUSE-1.75A_6VF0603F4F0603POLY-FUSE-1.75A_6VF0603FB1L0603BEAD-120R-3AL0603FB2L0603BEAD-120R-3AL0603FB3L0603BEAD-120R-3AL0603FB4L0603BEAD-120R-3AL0603FB5L0603BEAD-120R-3AL0603FPESEAF-20-06_0-L-10-2-A-K-TRFPE_TOPSEAF-20-06_0-L-10-2-A-K-TRH1MH9-6_35D3_18MM0.25PAD0.125HOLEMH9-6_35D3_18MMH2MH9-6_35D3_18MM0.25PAD0.125HOLEMH9-6_35D3_18MMH3MH9-6_35D3_18MM0.25PAD0.125HOLEMH9-6_35D3_18MMH4MH9-6_35D3_18MM0.25PAD0.125HOLEMH9-6_35D3_18MMHL_LEDLED0603KPT-1608SYCK_LED_Y_6_SLED0603L1LD080510UH_8_300MA_0.9_SLD0805L2LD080510UH_8_300MA_0.9_SLD0805L3LD080510UH_8_300MA_0.9_SLD0805L4LD080510UH_8_300MA_0.9_SLD0805L52012F2SFWCM2012F2SF-900T042012F2SFL62012F2SFWCM2012F2SF-900T042012F2SFL72012F2SFWCM2012F2SF-900T042012F2SFL82012F2SFWCM2012F2SF-900T042012F2SFL92012F2SFWCM2012F2SF-900T042012F2SFL102012F2SFWCM2012F2SF-900T042012F2SFL112012F2SFWCM2012F2SF-900T042012F2SFL122012F2SFWCM2012F2SF-900T042012F2SFL132012F2SFWCM2012F2SF-900T042012F2SFL142012F2SFWCM2012F2SF-900T042012F2SFL152012F2SFWCM2012F2SF-900T042012F2SFL162012F2SFWCM2012F2SF-900T042012F2SFL172012F2SFWCM2012F2SF-900T042012F2SFL182012F2SFWCM2012F2SF-900T042012F2SFL192012F2SFWCM2012F2SF-900T042012F2SFL202012F2SFWCM2012F2SF-900T042012F2SFL212012F2SFWCM2012F2SF-900T042012F2SFL222012F2SFWCM2012F2SF-900T042012F2SFL232012F2SFWCM2012F2SF-900T042012F2SFL242012F2SFWCM2012F2SF-900T042012F2SFL252012F2SFWCM2012F2SF-900T042012F2SFL262012F2SFWCM2012F2SF-900T042012F2SFL272012F2SFWCM2012F2SF-900T042012F2SFL282012F2SFWCM2012F2SF-900T042012F2SFL332012F2SFWCM2012F2SF-900T042012F2SFL342012F2SFWCM2012F2SF-900T042012F2SFL352012F2SFWCM2012F2SF-900T042012F2SFL362012F2SFWCM2012F2SF-900T042012F2SFNIC1C04021U_4_X5R_6.3V_KC0402NIC2C04020.1U_4_X7R_16V_KC0402NIQ3SOT23-GSDP6402FMG_SOT23_-4A_64MSOT23-GSDNIQ4SOT-363NTJD5121N_SOT363_295MA_2.5VSOT-363NIR1R04028.2K_4R0402NIR2R04028.2K_4R0402NIR3R0603330_6R0603NRL1L-SWF25204.7UH_0.8A_2520L-SWF2520PC5C04020.1U_4_X7R_16V_KC0402PCH1BGA_989P_24_984X984_H73CPT_PPT_REV_0P5BGA_989P_24_984X984_H73PD1SOT323BAT54CW_SOT323_200MASOT323PD2SMASX34_SMA_3A_40VSMAPD3SMASX34_SMA_3A_40VSMAPL1PCMB042T1.0UH_S_4.5A_24M_IPCMB042TPL2MHCC10040-1R0M-R70.47UH_33A_1.2M_SMDMHCC10040-1R0M-R7PL3MHCC10040-1R0M-R70.47UH_33A_1.2M_SMDMHCC10040-1R0M-R7PL4SMPI0603_6_86X6_47MM0.68UH_S_16A_4.5M_ISMPI0603_6_86X6_47MMPL5L-PCMB051H1UH_S_8A_15M_IL-PCMB051HPL6L-PCMB051H1UH_S_8A_15M_IL-PCMB051HPL7SMPI0603_6_86X6_47MM0.68UH_S_16A_4.5M_ISMPI0603_6_86X6_47MMPOWER_LEDLED0603KPT-1608SGC_LED_G_6_SLED0603PQ1SOT-363NTJD5121N_SOT363_295MA_2.5VSOT-363PQ2SOP8_THUP0105PSW8_PSOP8L_2ASOP8_THPQ3SOT23-GSDP3203CMG_SOT23_6A_32M_SSOT23-GSDPQ4SOT23-GSDP6402FMG_SOT23_-4A_64MSOT23-GSDPQ5SOT-363NTJD5121N_SOT363_295MA_2.5VSOT-363PQ6SOT-363NTJD5121N_SOT363_295MA_2.5VSOT-363PQ7SOT-363NTJD5121N_SOT363_295MA_2.5VSOT-363PQ8SOT-363NTJD5121N_SOT363_295MA_2.5VSOT-363PQ9WDFN8-3_3X3_3NTTFS4941NTAG_QFN3-3_46A_6-2MWDFN8-3_3X3_3PQ10SOT-363NTJD5121N_SOT363_295MA_2.5VSOT-363PRN18P4R08044.7K_8P4R_48P4R0804PRN28P4R08044.7K_8P4R_48P4R0804PRN38P4R08044.7K_8P4R_48P4R0804PRN48P4R08044.7K_8P4R_48P4R0804PU1QFN40-6X6MMNCP5369MNR2G_QFN40QFN40-6X6MMPU2QFN40-6X6MMNCP5369MNR2G_QFN40QFN40-6X6MMPU3PQFN16_5X6MMIR3895MTR1PBF_PQFN56PQFN16_5X6MMPU4PQFN16_4X5MMIR3899MTR1PBF_PQFN45PQFN16_4X5MMPU5SOT23-6NCP102SNT1G_SOT23-6SOT23-6PU6SOP8_THAPL5932AKAI-TRL_SOP8SOP8_THPU7PQFN16_5X6MMIR3895MTR1PBF_PQFN56PQFN16_5X6MMPU10DFN6-2X2MMLTC3025EDC-1#PBF_DFN2DFN6-2X2MMPU11DFN6-2X2MMLTC3025EDC-1#PBF_DFN2DFN6-2X2MMQ1SOT-363NTJD5121N_SOT363_295MA_2.5VSOT-363Q2SOT-363NTJD5121N_SOT363_295MA_2.5VSOT-363Q3SOT-363NTJD5121N_SOT363_295MA_2.5VSOT-363Q4SOT-363NTJD5121N_SOT363_295MA_2.5VSOT-363Q5SOT-363NTJD5121N_SOT363_295MA_2.5VSOT-363Q8SOT-363NTJD5121N_SOT363_295MA_2.5VSOT-363Q9SOT-363NTJD5121N_SOT363_295MA_2.5VSOT-363Q10SOT23-GSDAO3401_SOT23SOT23-GSDQ11SOT-363NTJD5121N_SOT363_295MA_2.5VSOT-363Q12SOT-363NTJD5121N_SOT363_295MA_2.5VSOT-363Q13SOT23-BEC2N3904_SOT23SOT23-BECQ14SOT-363NTJD5121N_SOT363_295MA_2.5VSOT-363Q15SOT-363NTJD5121N_SOT363_295MA_2.5VSOT-363Q16SOT223BCP69T1G_SOT223SOT223Q17SOT23-GSDP3203CMG_SOT23_6A_32M_SSOT23-GSDQ18SOT-363NTJD5121N_SOT363_295MA_2.5VSOT-363Q19SOT-363NTJD5121N_SOT363_295MA_2.5VSOT-363Q20SOT-363NTJD5121N_SOT363_295MA_2.5VSOT-363Q21SOT-363NTJD5121N_SOT363_295MA_2.5VSOT-363Q22SOT23-BEC2N3904_SOT23SOT23-BECQ149WDFN8-3_3X3_3NTTFS4985NFTAG_QFN3-3_64A_3-5MWDFN8-3_3X3_3Q150SOT-363NTJD5121N_SOT363_295MA_2.5VSOT-363Q151SOT-363NTJD5121N_SOT363_295MA_2.5VSOT-363Q152SOT-363NTJD5121N_SOT363_295MA_2.5VSOT-363RN158P4R08048.2K_8P4R_48P4R0804SATA1SATA-WATF-07DBN6BB1UWSATA_SMD_BLACKSATA-WATF-07DBN6BB1UWSATA2SATA-WATF-07DBN6BB1UWSATA_SMD_BLACKSATA-WATF-07DBN6BB1UWSATA_LEDLED0603KPT-1608SGC_LED_G_6_SLED0603SB1L0603BEAD-80R-3AL0603SCN18P4C1206150P_8P4C_50V_K8P4C1206SD1SOD-523RB521S-30_SOD523_200MASOD-523SF1F0603POLY-FUSE-1.75A_6VF0603SQ1SOT-363NTJD5121N_SOT363_295MA_2.5VSOT-363SR1R040243_4R0402STACKPWR_1IPBT-102-H1-T-DIPBT-102-H1-T-DIPBT-102-H1-T-DSTACKPWR_2ESQT-104-02-F-S-510ESQT-104-02-F-S-510ESQT-104-02-F-S-510STACKPWR_3IPBT-103-H1-T-DIPBT-103-H1-T-DIPBT-103-H1-T-DTP4TPC32T_68TP_C24_NCTPC32T_68U1SC-70SN74LVC2G07_SC70SC-70U2SC-70SN74LVC2G07_SC70SC-70U3SC-70SN74LVC2G07_SC70SC-70U5SOT23-5APL5325BI-TRL_SOT23-5_300MASOT23-5U6TQFN10-1_6X1_3MMPI3A268CZME_TQFN10TQFN10-1_6X1_3MMU7TQFN10-1_6X1_3MMPI3A268CZME_TQFN10TQFN10-1_6X1_3MMU8UQFN8-1_45X1_05MMSN74LVC1G74DQER_DQE8UQFN8-1_45X1_05MMU9TQFN10-1_6X1_3MMPI3A268CZME_TQFN10TQFN10-1_6X1_3MMU10TQFN10-1_6X1_3MMPI3A268CZME_TQFN10TQFN10-1_6X1_3MMU11SOT23-574AHC1G08_SOT23_5SOT23-5U12SOT23-574AHC1G08_SOT23_5SOT23-5U13SOT323_5L74V1T32CTR_SOT323_5LSOT323_5LU18LQFP128_14X14MMF81866AD-ILQFP128_14X14MMU19TSSOP28ADI_ADM213ADM213EARUTSSOP28U20TSSOP28ADI_ADM213ADM213EARUTSSOP28U21BGA32LTM2881IY-5#PBF_BGABGA32U22BGA32LTM2881IY-5#PBF_BGABGA32U23TQFN10-1_6X1_3MMPI3A268CZME_TQFN10TQFN10-1_6X1_3MMU24SOP8APL5606KI-TRG_SOP8SOP8U28SOP16-10_5X7_6MMADI_ADUM5402CRWZSOP16-10_5X7_6MMU29SOP16-10_5X7_6MMADI_ADUM5402CRWZSOP16-10_5X7_6MMU30SC-70SN74LVC2G07_SC70SC-70U32QFN48_6X6MMINTEL_82579LMQFN48_6X6MMU33QFN64_9X9_0_5_H1MMINTEL_82574ITQFN64_9X9_0_5_H1MMU34SOIC-8NBMICROCHIP_25LC640-I/SN_SOIC-8NBSOIC-8NBU35SOIC-8NBAT25128AN-10SU-1.8_SOIC-8NBSOIC-8NBU36BGA145GLS85LS1002P_BGA145BGA145U37AQFN136-10X10MMPEX8605-AB50NI_AQFN136AQFN136-10X10MMU38SOIC-8NB24LC02BT-I/SN_SOP8SOIC-8NBU39SOT23-6TPS2553DBV-1_SOT23-6SOT23-6U40SOT23-6TPS2553DBV-1_SOT23-6SOT23-6X17M2500002125M_10P_30PPM_3.2*2.5_507M25000021X2MC-14632.768KHZMC-146X37M2500002125M_10P_30PPM_3.2*2.5_507M25000021X47M2500002125M_10P_30PPM_3.2*2.5_507M25000021X57M2500002125M_10P_30PPM_3.2*2.5_507M25000021XP1BOXHEADER2X5-2MM-SMDBH_5X2V_2.00MM_SMDBOXHEADER2X5-2MM-SMDXP2BOXHEADER2X5-2MM-SMDBH_5X2V_2.00MM_SMDBOXHEADER2X5-2MM-SMDXP3B5B-PH-KL-LF-SN721-81-05TW00B5B-PH-KL-LF-SNXP4B5B-PH-KL-LF-SN721-81-05TW00B5B-PH-KL-LF-SNXP5B6B-PH-KL-LF-SN721-81-06TW00B6B-PH-KL-LF-SNXP6B5B-PH-KL-LF-SN721-81-05TW00B5B-PH-KL-LF-SNXP7B5B-PH-KL-LF-SN721-81-05TW00B5B-PH-KL-LF-SNXP8B2B-PH-KL-LF-SN721-81-02TW00B2B-PH-KL-LF-SNXP9HEADER1X3_2MMPH_1X3V_2.00MM_DIPHEADER1X3_2MMXP10DF13-30DP-1_25VDF13-30DP-1.25VDF13-30DP-1_25VXP11DF13-20DP-1_25VDF13-20DP-1.25VDF13-20DP-1_25VXP12BOXHEADER2X5-2MM-SMDBH_5X2V_2.00MM_SMDBOXHEADER2X5-2MM-SMDXP13BOXHEADER2X5-2MM-SMDBH_5X2V_2.00MM_SMDBOXHEADER2X5-2MM-SMDXP14BOXHEADER2X5-2MM-SMDBH_5X2V_2.00MM_SMDBOXHEADER2X5-2MM-SMDXP15BOXHEADER-2X5-2MMBH_5X2V_2.00MM_DIPBOXHEADER-2X5-2MMXP17HEADER1X2_2MMPH_1X2V2.0MM_DIPHEADER1X2_2MMXP18HEADER1X3_2MMPH_1X3V_2.00MM_DIPHEADER1X3_2MMXP19HEADER1X3_2MMPH_1X3V_2.00MM_DIPHEADER1X3_2MMXP20B10B-PH-KL-LF-SN721-81-10TW00B10B-PH-KL-LF-SNXR_ST1NUT-6MM-2_7MMSTAND-OFF_5MMNUT-6MM-2_7MMXR_ST2NUT-6MM-2_7MMSTAND-OFF_5MMNUT-6MM-2_7MM
老吴 发表于 2019-9-1 23:26:27
PCB文件共享。回复可见下载。。 禁止转载到网络上。
**** Hidden Message *****
richardz 发表于 2019-9-2 07:57:06
石头蛋儿 发表于 2019-9-2 08:02:24
hyldvd 发表于 2019-9-2 08:13:28
学海无涯 发表于 2019-9-2 08:19:06
io357 发表于 2019-9-2 08:32:58
yeyongjicn 发表于 2019-9-2 08:36:06
谢谢分享!!!
xiaoxiao116 发表于 2019-9-2 08:39:46
来看看了
mcus 发表于 2019-9-2 08:40:34
观摩一下
页: [1] 2 3 4 5 6 7 8 9 10
查看完整版本: Intel I7  QM77_StackPC OXY5535A(12层电脑主板)  P
