[Allegro16.6以下] Intel I7  QM77_StackPC OXY5535A(12层电脑主板)  P
查看18502 | 回复179 | 2019-9-1 23:24:03 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
AB1L0603BEAD-80R-3AL0603
AU1LQFP-48_7_0X7_0X1_6MMREALTEK_ALC887-VD2-CGLQFP-48_7_0X7_0X1_6MM
B2L0603BEAD-80R-3AL0603
B3L0603BEAD-80R-3AL0603
B4L0603BEAD-80R-3AL0603
B5L060327NH_6_300MA_0.45L0603
B6L060327NH_6_300MA_0.45L0603
B7L060327NH_6_300MA_0.45L0603
B8L0603BEAD-80R-3AL0603
B9L0603BEAD-80R-3AL0603
B10L0603BEAD-80R-3AL0603
B11L0603BEAD-80R-3AL0603
B13L0603BEAD-80R-3AL0603
B14L0603BEAD-80R-3AL0603
B15L0603BEAD-80R-3AL0603
B16L0603BEAD-80R-3AL0603
B17L0603BEAD-80R-3AL0603
B18L0603BEAD-80R-3AL0603
BAT1BAT-CR2012-101KEYSTONE_101BAT-CR2012-101
BIOS1SOP8_209MILW25Q64FVSSIGTRSOP8_209MIL
CN18P4C1206150P_8P4C_50V_K8P4C1206
CN28P4C1206150P_8P4C_50V_K8P4C1206
CN38P4C1206150P_8P4C_50V_K8P4C1206
CN48P4C1206150P_8P4C_50V_K8P4C1206
CON_A1ASP-129637-03CONNECTOR A TOPASP-129637-03
CPU1BGA1023-INTEL-IVYIVY BRIDGE BGA1023BGA1023-INTEL-IVY
CPUFANB3B-PH-KL721-81-03TW00B3B-PH-KL
D1SOT323BAT54CW_SOT323_200MASOT323
D2SOT323BAT54CW_SOT323_200MASOT323
D3SOD-523RB521S-30_SOD523_200MASOD-523
D4SOD-523RB521S-30_SOD523_200MASOD-523
D6SOT323BAT54CW_SOT323_200MASOT323
D7SOT323BAT54AW_SOT323_200MASOT323
D8SMASX34_SMA_3A_40VSMA
D9SOT323BAT54AW_SOT323_200MASOT323
D10SOD-523RB521S-30_SOD523_200MASOD-523
D11SOT323BAT54AW_SOT323_200MASOT323
DU1QFN52_0-4-6X6MM-BWNCP6131S52MNR2G_QFN52QFN52_0-4-6X6MM-BW
EC1C040210P_4_NPO_50V_JC0402
EC2C040210P_4_NPO_50V_JC0402
EC3C040210P_4_NPO_50V_JC0402
EC4C040210P_4_NPO_50V_JC0402
EC5C040210P_4_NPO_50V_JC0402
EF1SOT23_5L_H1_1NCP380HSN10AAT1G_SOT23-5_1A_EN_HIGHSOT23_5L_H1_1
EF2SOT23_5L_H1_1NCP380HSN10AAT1G_SOT23-5_1A_EN_HIGHSOT23_5L_H1_1
EF3SOT23_5L_H1_1NCP380HSN10AAT1G_SOT23-5_1A_EN_HIGHSOT23_5L_H1_1
EF4SOT23_5L_H1_1NCP380HSN10AAT1G_SOT23-5_1A_EN_HIGHSOT23_5L_H1_1
ESD1SOD-323AZ2225-01L_SOD323SOD-323
ESD2SOD-323AZ2225-01L_SOD323SOD-323
ESD3SOT23SM712_TCTSOT23
ESD4SOT23SM712_TCTSOT23
ESD5SOT23SM712_TCTSOT23
ESD6SOT23SM712_TCTSOT23
ESD7SOT23-6AZC199-04SC_SOT23-6L_5V_1PSOT23-6
ESD8SOD-323AZ2225-01L_SOD323SOD-323
ESD9DFN2510P10EAZ1045-04F_DFN2510P10E_5V_0.5PDFN2510P10E
ESD10DFN2510P10EAZ1045-04F_DFN2510P10E_5V_0.5PDFN2510P10E
ESD11DFN2510P10EAZ1045-04F_DFN2510P10E_5V_0.5PDFN2510P10E
ESD12DFN2510P10EAZ1045-04F_DFN2510P10E_5V_0.5PDFN2510P10E
ESD13SOT23-6AZC199-04SC_SOT23-6L_5V_1PSOT23-6
ESD14DFN2510P10EAZ1045-04F_DFN2510P10E_5V_0.5PDFN2510P10E
ESD15DFN2510P10EAZ1045-04F_DFN2510P10E_5V_0.5PDFN2510P10E
ESD16DFN2510P10EAZ1045-04F_DFN2510P10E_5V_0.5PDFN2510P10E
ESD17SOT23-6AZC199-04SC_SOT23-6L_5V_1PSOT23-6
ESD18SOT23-6AZC199-04SC_SOT23-6L_5V_1PSOT23-6
ESD19SOT23-6AZC199-04SC_SOT23-6L_5V_1PSOT23-6
ESD24DFN2510P10EAZ1045-04F_DFN2510P10E_5V_0.5PDFN2510P10E
ESD25DFN2510P10EAZ1045-04F_DFN2510P10E_5V_0.5PDFN2510P10E
ESD26DFN2510P10EAZ1045-04F_DFN2510P10E_5V_0.5PDFN2510P10E
ESD27DFN2510P10EAZ1045-04F_DFN2510P10E_5V_0.5PDFN2510P10E
ESD28DFN2510P10EAZ1045-04F_DFN2510P10E_5V_0.5PDFN2510P10E
ESD29DFN2510P10EAZ1045-04F_DFN2510P10E_5V_0.5PDFN2510P10E
F2F0603POLY-FUSE-1.75A_6VF0603
F3F0603POLY-FUSE-1.75A_6VF0603
F4F0603POLY-FUSE-1.75A_6VF0603
FB1L0603BEAD-120R-3AL0603
FB2L0603BEAD-120R-3AL0603
FB3L0603BEAD-120R-3AL0603
FB4L0603BEAD-120R-3AL0603
FB5L0603BEAD-120R-3AL0603
FPESEAF-20-06_0-L-10-2-A-K-TRFPE_TOPSEAF-20-06_0-L-10-2-A-K-TR
H1MH9-6_35D3_18MM0.25PAD0.125HOLEMH9-6_35D3_18MM
H2MH9-6_35D3_18MM0.25PAD0.125HOLEMH9-6_35D3_18MM
H3MH9-6_35D3_18MM0.25PAD0.125HOLEMH9-6_35D3_18MM
H4MH9-6_35D3_18MM0.25PAD0.125HOLEMH9-6_35D3_18MM
HL_LEDLED0603KPT-1608SYCK_LED_Y_6_SLED0603
L1LD080510UH_8_300MA_0.9_SLD0805
L2LD080510UH_8_300MA_0.9_SLD0805
L3LD080510UH_8_300MA_0.9_SLD0805
L4LD080510UH_8_300MA_0.9_SLD0805
L52012F2SFWCM2012F2SF-900T042012F2SF
L62012F2SFWCM2012F2SF-900T042012F2SF
L72012F2SFWCM2012F2SF-900T042012F2SF
L82012F2SFWCM2012F2SF-900T042012F2SF
L92012F2SFWCM2012F2SF-900T042012F2SF
L102012F2SFWCM2012F2SF-900T042012F2SF
L112012F2SFWCM2012F2SF-900T042012F2SF
L122012F2SFWCM2012F2SF-900T042012F2SF
L132012F2SFWCM2012F2SF-900T042012F2SF
L142012F2SFWCM2012F2SF-900T042012F2SF
L152012F2SFWCM2012F2SF-900T042012F2SF
L162012F2SFWCM2012F2SF-900T042012F2SF
L172012F2SFWCM2012F2SF-900T042012F2SF
L182012F2SFWCM2012F2SF-900T042012F2SF
L192012F2SFWCM2012F2SF-900T042012F2SF
L202012F2SFWCM2012F2SF-900T042012F2SF
L212012F2SFWCM2012F2SF-900T042012F2SF
L222012F2SFWCM2012F2SF-900T042012F2SF
L232012F2SFWCM2012F2SF-900T042012F2SF
L242012F2SFWCM2012F2SF-900T042012F2SF
L252012F2SFWCM2012F2SF-900T042012F2SF
L262012F2SFWCM2012F2SF-900T042012F2SF
L272012F2SFWCM2012F2SF-900T042012F2SF
L282012F2SFWCM2012F2SF-900T042012F2SF
L332012F2SFWCM2012F2SF-900T042012F2SF
L342012F2SFWCM2012F2SF-900T042012F2SF
L352012F2SFWCM2012F2SF-900T042012F2SF
L362012F2SFWCM2012F2SF-900T042012F2SF
NIC1C04021U_4_X5R_6.3V_KC0402
NIC2C04020.1U_4_X7R_16V_KC0402
NIQ3SOT23-GSDP6402FMG_SOT23_-4A_64MSOT23-GSD
NIQ4SOT-363NTJD5121N_SOT363_295MA_2.5VSOT-363
NIR1R04028.2K_4R0402
NIR2R04028.2K_4R0402
NIR3R0603330_6R0603
NRL1L-SWF25204.7UH_0.8A_2520L-SWF2520
PC5C04020.1U_4_X7R_16V_KC0402
PCH1BGA_989P_24_984X984_H73CPT_PPT_REV_0P5BGA_989P_24_984X984_H73
PD1SOT323BAT54CW_SOT323_200MASOT323
PD2SMASX34_SMA_3A_40VSMA
PD3SMASX34_SMA_3A_40VSMA
PL1PCMB042T1.0UH_S_4.5A_24M_IPCMB042T
PL2MHCC10040-1R0M-R70.47UH_33A_1.2M_SMDMHCC10040-1R0M-R7
PL3MHCC10040-1R0M-R70.47UH_33A_1.2M_SMDMHCC10040-1R0M-R7
PL4SMPI0603_6_86X6_47MM0.68UH_S_16A_4.5M_ISMPI0603_6_86X6_47MM
PL5L-PCMB051H1UH_S_8A_15M_IL-PCMB051H
PL6L-PCMB051H1UH_S_8A_15M_IL-PCMB051H
PL7SMPI0603_6_86X6_47MM0.68UH_S_16A_4.5M_ISMPI0603_6_86X6_47MM
POWER_LEDLED0603KPT-1608SGC_LED_G_6_SLED0603
PQ1SOT-363NTJD5121N_SOT363_295MA_2.5VSOT-363
PQ2SOP8_THUP0105PSW8_PSOP8L_2ASOP8_TH
PQ3SOT23-GSDP3203CMG_SOT23_6A_32M_SSOT23-GSD
PQ4SOT23-GSDP6402FMG_SOT23_-4A_64MSOT23-GSD
PQ5SOT-363NTJD5121N_SOT363_295MA_2.5VSOT-363
PQ6SOT-363NTJD5121N_SOT363_295MA_2.5VSOT-363
PQ7SOT-363NTJD5121N_SOT363_295MA_2.5VSOT-363
PQ8SOT-363NTJD5121N_SOT363_295MA_2.5VSOT-363
PQ9WDFN8-3_3X3_3NTTFS4941NTAG_QFN3-3_46A_6-2MWDFN8-3_3X3_3
PQ10SOT-363NTJD5121N_SOT363_295MA_2.5VSOT-363
PRN18P4R08044.7K_8P4R_48P4R0804
PRN28P4R08044.7K_8P4R_48P4R0804
PRN38P4R08044.7K_8P4R_48P4R0804
PRN48P4R08044.7K_8P4R_48P4R0804
PU1QFN40-6X6MMNCP5369MNR2G_QFN40QFN40-6X6MM
PU2QFN40-6X6MMNCP5369MNR2G_QFN40QFN40-6X6MM
PU3PQFN16_5X6MMIR3895MTR1PBF_PQFN56PQFN16_5X6MM
PU4PQFN16_4X5MMIR3899MTR1PBF_PQFN45PQFN16_4X5MM
PU5SOT23-6NCP102SNT1G_SOT23-6SOT23-6
PU6SOP8_THAPL5932AKAI-TRL_SOP8SOP8_TH
PU7PQFN16_5X6MMIR3895MTR1PBF_PQFN56PQFN16_5X6MM
PU10DFN6-2X2MMLTC3025EDC-1#PBF_DFN2DFN6-2X2MM
PU11DFN6-2X2MMLTC3025EDC-1#PBF_DFN2DFN6-2X2MM
Q2SOT-363NTJD5121N_SOT363_295MA_2.5VSOT-363
Q3SOT-363NTJD5121N_SOT363_295MA_2.5VSOT-363
Q9SOT-363NTJD5121N_SOT363_295MA_2.5VSOT-363
Q10SOT23-GSDAO3401_SOT23SOT23-GSD
Q11SOT-363NTJD5121N_SOT363_295MA_2.5VSOT-363
Q12SOT-363NTJD5121N_SOT363_295MA_2.5VSOT-363
Q13SOT23-BEC2N3904_SOT23SOT23-BEC
Q14SOT-363NTJD5121N_SOT363_295MA_2.5VSOT-363
Q15SOT-363NTJD5121N_SOT363_295MA_2.5VSOT-363
Q16SOT223BCP69T1G_SOT223SOT223
Q17SOT23-GSDP3203CMG_SOT23_6A_32M_SSOT23-GSD
Q18SOT-363NTJD5121N_SOT363_295MA_2.5VSOT-363
Q19SOT-363NTJD5121N_SOT363_295MA_2.5VSOT-363
Q20SOT-363NTJD5121N_SOT363_295MA_2.5VSOT-363
Q21SOT-363NTJD5121N_SOT363_295MA_2.5VSOT-363
Q22SOT23-BEC2N3904_SOT23SOT23-BEC
Q149WDFN8-3_3X3_3NTTFS4985NFTAG_QFN3-3_64A_3-5MWDFN8-3_3X3_3
Q150SOT-363NTJD5121N_SOT363_295MA_2.5VSOT-363
Q151SOT-363NTJD5121N_SOT363_295MA_2.5VSOT-363
Q152SOT-363NTJD5121N_SOT363_295MA_2.5VSOT-363
RN158P4R08048.2K_8P4R_48P4R0804
SATA1SATA-WATF-07DBN6BB1UWSATA_SMD_BLACKSATA-WATF-07DBN6BB1UW
SATA2SATA-WATF-07DBN6BB1UWSATA_SMD_BLACKSATA-WATF-07DBN6BB1UW
SATA_LEDLED0603KPT-1608SGC_LED_G_6_SLED0603
SB1L0603BEAD-80R-3AL0603
SCN18P4C1206150P_8P4C_50V_K8P4C1206
SD1SOD-523RB521S-30_SOD523_200MASOD-523
SF1F0603POLY-FUSE-1.75A_6VF0603
SQ1SOT-363NTJD5121N_SOT363_295MA_2.5VSOT-363
SR1R040243_4R0402
STACKPWR_1IPBT-102-H1-T-DIPBT-102-H1-T-DIPBT-102-H1-T-D
STACKPWR_2ESQT-104-02-F-S-510ESQT-104-02-F-S-510ESQT-104-02-F-S-510
STACKPWR_3IPBT-103-H1-T-DIPBT-103-H1-T-DIPBT-103-H1-T-D
TP4TPC32T_68TP_C24_NCTPC32T_68
U1SC-70SN74LVC2G07_SC70SC-70
U2SC-70SN74LVC2G07_SC70SC-70
U3SC-70SN74LVC2G07_SC70SC-70
U5SOT23-5APL5325BI-TRL_SOT23-5_300MASOT23-5
U6TQFN10-1_6X1_3MMPI3A268CZME_TQFN10TQFN10-1_6X1_3MM
U7TQFN10-1_6X1_3MMPI3A268CZME_TQFN10TQFN10-1_6X1_3MM
U8UQFN8-1_45X1_05MMSN74LVC1G74DQER_DQE8UQFN8-1_45X1_05MM
U9TQFN10-1_6X1_3MMPI3A268CZME_TQFN10TQFN10-1_6X1_3MM
U10TQFN10-1_6X1_3MMPI3A268CZME_TQFN10TQFN10-1_6X1_3MM
U11SOT23-574AHC1G08_SOT23_5SOT23-5
U12SOT23-574AHC1G08_SOT23_5SOT23-5
U13SOT323_5L74V1T32CTR_SOT323_5LSOT323_5L
U18LQFP128_14X14MMF81866AD-ILQFP128_14X14MM
U19TSSOP28ADI_ADM213ADM213EARUTSSOP28
U20TSSOP28ADI_ADM213ADM213EARUTSSOP28
U21BGA32LTM2881IY-5#PBF_BGABGA32
U22BGA32LTM2881IY-5#PBF_BGABGA32
U23TQFN10-1_6X1_3MMPI3A268CZME_TQFN10TQFN10-1_6X1_3MM
U24SOP8APL5606KI-TRG_SOP8SOP8
U28SOP16-10_5X7_6MMADI_ADUM5402CRWZSOP16-10_5X7_6MM
U29SOP16-10_5X7_6MMADI_ADUM5402CRWZSOP16-10_5X7_6MM
U30SC-70SN74LVC2G07_SC70SC-70
U32QFN48_6X6MMINTEL_82579LMQFN48_6X6MM
U33QFN64_9X9_0_5_H1MMINTEL_82574ITQFN64_9X9_0_5_H1MM
U34SOIC-8NBMICROCHIP_25LC640-I/SN_SOIC-8NBSOIC-8NB
U35SOIC-8NBAT25128AN-10SU-1.8_SOIC-8NBSOIC-8NB
U36BGA145GLS85LS1002P_BGA145BGA145
U37AQFN136-10X10MMPEX8605-AB50NI_AQFN136AQFN136-10X10MM
U38SOIC-8NB24LC02BT-I/SN_SOP8SOIC-8NB
U39SOT23-6TPS2553DBV-1_SOT23-6SOT23-6
U40SOT23-6TPS2553DBV-1_SOT23-6SOT23-6
X17M2500002125M_10P_30PPM_3.2*2.5_507M25000021
X2MC-14632.768KHZMC-146
X37M2500002125M_10P_30PPM_3.2*2.5_507M25000021
X47M2500002125M_10P_30PPM_3.2*2.5_507M25000021
X57M2500002125M_10P_30PPM_3.2*2.5_507M25000021
XP1BOXHEADER2X5-2MM-SMDBH_5X2V_2.00MM_SMDBOXHEADER2X5-2MM-SMD
XP2BOXHEADER2X5-2MM-SMDBH_5X2V_2.00MM_SMDBOXHEADER2X5-2MM-SMD
XP3B5B-PH-KL-LF-SN721-81-05TW00B5B-PH-KL-LF-SN
XP4B5B-PH-KL-LF-SN721-81-05TW00B5B-PH-KL-LF-SN
XP5B6B-PH-KL-LF-SN721-81-06TW00B6B-PH-KL-LF-SN
XP6B5B-PH-KL-LF-SN721-81-05TW00B5B-PH-KL-LF-SN
XP7B5B-PH-KL-LF-SN721-81-05TW00B5B-PH-KL-LF-SN
XP8B2B-PH-KL-LF-SN721-81-02TW00B2B-PH-KL-LF-SN
XP9HEADER1X3_2MMPH_1X3V_2.00MM_DIPHEADER1X3_2MM
XP10DF13-30DP-1_25VDF13-30DP-1.25VDF13-30DP-1_25V
XP11DF13-20DP-1_25VDF13-20DP-1.25VDF13-20DP-1_25V
XP12BOXHEADER2X5-2MM-SMDBH_5X2V_2.00MM_SMDBOXHEADER2X5-2MM-SMD
XP13BOXHEADER2X5-2MM-SMDBH_5X2V_2.00MM_SMDBOXHEADER2X5-2MM-SMD
XP14BOXHEADER2X5-2MM-SMDBH_5X2V_2.00MM_SMDBOXHEADER2X5-2MM-SMD
XP15BOXHEADER-2X5-2MMBH_5X2V_2.00MM_DIPBOXHEADER-2X5-2MM
XP17HEADER1X2_2MMPH_1X2V2.0MM_DIPHEADER1X2_2MM
XP18HEADER1X3_2MMPH_1X3V_2.00MM_DIPHEADER1X3_2MM
XP19HEADER1X3_2MMPH_1X3V_2.00MM_DIPHEADER1X3_2MM
XP20B10B-PH-KL-LF-SN721-81-10TW00B10B-PH-KL-LF-SN
XR_ST1NUT-6MM-2_7MMSTAND-OFF_5MMNUT-6MM-2_7MM
XR_ST2NUT-6MM-2_7MMSTAND-OFF_5MMNUT-6MM-2_7MM
重要提示:PCB作品文件展下载说明
老吴 | 2019-9-1 23:26:27 | 显示全部楼层
PCB文件共享。回复可见下载。。 禁止转载到网络上。
游客,如果您要查看本帖隐藏内容请回复
richardz | 2019-9-2 07:57:06 | 显示全部楼层
VERY GOOD!
石头蛋儿 | 2019-9-2 08:02:24 | 显示全部楼层
hyldvd | 2019-9-2 08:13:28 | 显示全部楼层
学海无涯 | 2019-9-2 08:19:06 | 显示全部楼层
io357 | 2019-9-2 08:32:58 | 显示全部楼层
yeyongjicn | 2019-9-2 08:36:06 | 显示全部楼层
xiaoxiao116 | 2019-9-2 08:39:46 | 显示全部楼层
mcus | 2019-9-2 08:40:34 | 显示全部楼层
