飞思卡尔 IMX6 挂一个LPDDR2 PCB和原理图共享+WM
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMECON4CONN_HDR_4X1_HDR104_IO_10.29MM_HDR 1X4HDR104CON500SM04B_CON_4M_1MM_SM_RA_IO_2.95MSM04B-SRSS-TBCON_4M_1MM_SM_RAD1DIODE_TVS_SOD-923_IC_0.40MM_480ESD9L5.0ST5GSOD-923D2ZDIODE_SOD123_IC_1.35MM_480-768MMSZ5231BT1GSOD123D3DIODE_DO_VMN2_IC_0.4MM_480-7793RB521CS-30DO_VMN2D4DIODE_DO_CASE_267_IC_5.3MM_480-1N5400DO_CASE_267D6LED_LED_0603_IC_1.1MM_370-76427LED RedLED_0603D11LED_LED_0603_IC_1.1MM_370-76425LED GreenLED_0603D12DIODE_SCHTKY_SOD123LF_IC_1.0MMMBR140SFTSOD123LFD13DIODE_TVS_SOD-923_IC_0.40MM_480ESD9L5.0ST5GSOD-923D14DIODE_TVS_SOD-923_IC_0.40MM_480ESD9L5.0ST5GSOD-923D15LED_LED_0603_IC_1.1MM_370-76425LED GreenLED_0603D18LED_LED_0603_IC_1.1MM_370-76427LED RedLED_0603D19DUALDIODE_CA_SOT23_SOT23_IC_1.1BAT54A-7-FSOT23D20DUALDIODE_CA_SOT23_SOT23_IC_1.1BAT54A-7-FSOT23D21LED_LED_0603_IC_1.1MM_370-76427LED RedLED_0603D22LED_LED_0603_IC_1.1MM_370-76425LED GreenLED_0603D23LED_LED_0603_IC_1.1MM_370-76425LED GreenLED_0603D24DUALDIODE_CC_SOT23_SHTKY_SOT23-BAT54C-7-FSOT23-40X40H1SPACER_SPACER_139T_IC_16.13MM_2.635" LONGSPACER_139TH2SPACER_SPACER_139T_IC_16.13MM_2.635" LONGSPACER_139TH3SPACER_SPACER_139T_IC_16.13MM_2.635" LONGSPACER_139TH4SPACER_SPACER_139T_IC_16.13MM_2.635" LONGSPACER_139TJ1HDR_1X2_M_CON_PH_2M_78_TH_IO_6.B2B-PH-K-SCON_PH_2M_78_THJ2CONN_HDR_3X1_HDR103_49MIL_IO_4.CON_1X3HDR103_49MILJ6DC_POWER_JACK_3_RAPC722_IO_11.0CON_1_PWRRAPC722J7TSW-110-05-G-D_HDR210_TST_RA_IOTST-110-05-T-D-RAHDR210_TST_RAJ8MINI_PCI_LATCH_52P_CON_2X26_0P8CON 2X26 MINI PCIEXPRESSCON_2X26_0P8_SMT_AJ9USB_MINI_AB_RECEPTACLE_CON5_MICMICRO USB AB 5CON5_MICROUSBJ10USB_A_USB_A_IO_7.01MM_210-30008USB_TYPE_AUSB_AJ11RJ45_MAG_LED_SI-50170-F_RJ45_8_RJ45 8RJ45_8_MAGJACK_THJ12QSH060_CON_120S_QSH_SM_05PITCH_QSH-060-01-L-D-ACON_120S_QSH_SM_05PITCHJ13QSH060_CON_120S_QSH_SM_05PITCH_QSH-060-01-L-D-ACON_120S_QSH_SM_05PITCHJ14CONN_HDR_2X1_HDR102_IO_8.39MM_2HDR 1X2HDR102J16CONN_HDR_3X1_HDR103_IO_8.586MMHDR_1X3HDR103J17CONN_HDR_3X1_HDR103_IO_8.586MMHDR_1X3HDR103J18CONN_HDR_2X1_HDR102_IO_8.39MM_2HDR 1X2HDR102J19CONN_UMC_3P_M_CON3_VER_SMT_IO_1128-0711-20CON3_VER_SMTJ20CONN_UMC_3P_M_CON3_VER_SMT_IO_1128-0711-20CON3_VER_SMTJ21CONN_SDCARD_DUAL_15P_CON19_SDCACONN CRD 19CON19_SDCARD_DUAL_SM_NSPJ22CONN_SDCARD_DUAL_15P_CON19_SDCACONN CRD 19CON19_SDCARD_DUAL_SM_NSPJ23CONN_SDCARD_DUAL_15P_CON19_SDCACONN CRD 19CON19_SDCARD_DUAL_SM_NSPJ24FX12B-40P_CON_BBC_40P_0P4_SM_IOCONN PLUG 40CON_BBC_40P_0P4_SMJ26USB_MINI_AB_RECEPTACLE_CON5_MICMICRO USB AB 5CON5_MICROUSBJ1303.5MM_AUDIO_JACK_CON5_AUD_JACK_Audio JackCON5_AUD_JACK_RA_TH_SJ-43514J133SF7W006S1A_CON_SIM_CD_2P54MM_IOCON 6 SIM CARDCON_SIM_CD_2P54MMJ136CONN_HDR_4X2_HDR2X4_2P54_TSM_SMHDR 2X4HDR2X4_2P54_TSM_SMJP1JUMPER1X2_100MIL_TH_IO_4MM_210-SHORT_100mil100MIL_THL2INDUCTOR_IND_VLS252010_DISCRETE1UHIND_VLS252010L3INDUCTOR_IND_VLS3012_SM_DISCRET1UHIND_VLS3012_SML4INDUCTOR_IND_VLS252010_DISCRETE1UHIND_VLS252010L5INDUCTOR_IND_VLS252010_DISCRETE1UHIND_VLS252010L6INDUCTOR_IND_VLS252010_DISCRETE1UHIND_VLS252010L7INDUCTOR_IND_VLS3012_SM_DISCRET1UHIND_VLS3012_SML8INDUCTOR_FERRITE_A_IND_LPS4018_2.2uHIND_LPS4018L10BEAD_0_0603_CC_DISCRETE_0.95MM_120OHM0603_CCL11BEAD_0_0603_CC_DISCRETE_0.95MM_120OHM0603_CCL14DLW43_IND4_CHOKE_0805_DISCRETE_90OHMIND4_CHOKE_0805L15DLW43_IND4_CHOKE_0805_DISCRETE_90OHMIND4_CHOKE_0805L17BEAD_0_0603_CC_DISCRETE_0.95MM_120OHM0603_CCL18BEAD_0_0603_CC_DISCRETE_0.95MM_120OHM0603_CCL19BEAD_0_0603_CC_DISCRETE_0.95MM_120OHM0603_CCL20BEAD_0_0603_CC_DISCRETE_0.95MM_120OHM0603_CCL21BEAD_0_0603_CC_DISCRETE_0.95MM_120OHM0603_CCL22BEAD_0_0603_CC_DISCRETE_0.95MM_120OHM0603_CCL23BEAD_0_0603_CC_DISCRETE_0.95MM_120OHM0603_CCL24BEAD_0_0603_CC_DISCRETE_0.95MM_120OHM0603_CCP4MIC_MIC_WM-63PR_IC_2.2MM_510-7WM-64PCTMIC_WM-63PRQ1FDMS6681Z_SO8_PAK_IC_1.10MM_480FDMS6681ZSO8_PAKQ2PNP_DUAL_SOT363_IC_1.1MM_480-77MBT3906DW1T1SOT363Q3MOSFET_N_SC70_3_IC_1.0MM_480-76NTS4001NT1GSC70_3Q5NPN_SOT23_IC_1.12MM_480-75757_MMMBT3904SOT23Q6MOSFET_P_SOT-23_IC_1.12MM_480-7IRLML6401SOT-23Q72N7002_SOT23_IC_1.3MM_480-751592N7002SOT23Q30MOSFET_P_SOT-23_IC_1.12MM_480-7IRLML6401SOT-23Q312N7002_SOT23_IC_1.3MM_480-751592N7002SOT23RT1THERMISTOR_0603_CC_DISCRETE_47010K0603_CCS1SW_DIP-2_DIP-SMT2_IC_4.83MM_51SW_DIP-2/SMDIP-SMT2SH1RES_SHORT-2_SH0805_40_DISCRETE_SOLDER SHORTSH0805_40SH2RES_SHORT-2_SH0805_40_DISCRETE_SOLDER SHORTSH0805_40SH3RES_SHORT-2_SH0805_40_DISCRETE_SOLDER SHORTSH0805_40SH4RES_SHORT-2_SH0805_40_DISCRETE_SOLDER SHORTSH0805_40SH5RES_SHORT-2_SH0805_40_DISCRETE_SOLDER SHORTSH0805_40SH7RES_SHORT-2_SH0603_DISCRETE_0.10SH0603SH8RES_SHORT-2_SH0603_DISCRETE_0.10SH0603SH11RES_SHORT-2_SH0805_40_DISCRETE_SOLDER SHORTSH0805_40SH12RES_SHORT-3_1TO2_SH0603-X2_PIN10SH0603-X2_PIN1TO2SH13RES_SHORT-3_1TO2_SH0603-X2_PIN10SH0603-X2_PIN1TO2SH14RES_SHORT-2_SH0805_40_DISCRETE_SOLDER SHORTSH0805_40SH15RES_SHORT-2_SH0805_40_DISCRETE_SOLDER SHORTSH0805_40SH16RES_SHORT-2_SH0805_40_DISCRETE_SOLDER SHORTSH0805_40SW1SW_PB_ESW_SW4_PB_ESW_SM_P177_ICSPST PBSW4_PB_ESW_SM_P177SW2SW_PB_ESW_SW4_PB_ESW_SM_P177_ICSPST PBSW4_PB_ESW_SM_P177SW3SW_DIP_8_SW_DIP16_8POS_SM_IC_2.SW DIP-8SW_DIP16_8POS_SMSW4SW_DIP_8_SW_DIP16_8POS_SM_IC_2.SW DIP-8SW_DIP16_8POS_SMSW5SW_DIP_8_SW_DIP16_8POS_SM_IC_2.SW DIP-8SW_DIP16_8POS_SMSW6SW_PB_ESW_SW4_PB_ESW_SM_P177_ICSPST PBSW4_PB_ESW_SM_P177SW7SW_PB_ESW_SW4_PB_ESW_SM_P177_ICSPST PBSW4_PB_ESW_SM_P177SW8SW_PB_ESW_SW4_PB_ESW_SM_P177_ICSPST PBSW4_PB_ESW_SM_P177SW9SW_PB_ESW_SW4_PB_ESW_SM_P177_ICSPST PBSW4_PB_ESW_SM_P177SW10SW_PB_ESW_SW4_PB_ESW_SM_P177_ICSPST PBSW4_PB_ESW_SM_P177SW11SW_PB_ESW_SW4_PB_ESW_SM_P177_ICSPST PBSW4_PB_ESW_SM_P177SW12SW_PB_ESW_SW4_PB_ESW_SM_P177_ICSPST PBSW4_PB_ESW_SM_P177SW13SW_PB_ESW_SW4_PB_ESW_SM_P177_ICSPST PBSW4_PB_ESW_SM_P177SW14SW3_SPDT_SLIDE_SW3_SLIDE_TH_IC_SPDT_PWR_SWITCHSW3_SLIDE_THTP8TEST PAD_C035S_IC_0.1MM_280-75TEST POINTC035STP25TESTLOOP_TPAD_020_IO_0.1MM_211-TPAD_020TPAD_020TP29TEST PAD_C035S_IC_0.1MM_280-75TEST POINTC035STP72TESTLOOP_TEST_PIN_TP107_2.286MMTESTLOOPTEST_PIN_TP107TP73TEST PAD_C035S_IC_0.1MM_280-75TEST POINTC035STP74TEST PAD_C035S_IC_0.1MM_280-75TEST POINTC035STP75T POINTR_TESTPOINT_35MIL_IC_0.TP_35MILTESTPOINT_35MILTP76T POINTR_TESTPOINT_35MIL_IC_0.TP_35MILTESTPOINT_35MILU1MX6SL_432P_MX6SL_BGA_IC_1MM_344PCIMX6L8DVN10AAMX6SL_BGAU2MT42L256M32D2_FBGA_168P_FBGA168MT42L256M32D2FBGA168_0P5_12X12MM_NSPU3MMPF0100NPZES_56P_QFN56_0P5_8X8MMPF0100F1EPQFN56_0P5_8X8_EP4P1X4P4U4MAX8903A_TQFN_28P_TQFN28_0P4_4XMAX8903BTQFN28_0P4_4X4U5SDIN5C2_TFBGA_169P_BGA169_0P5_1SDIN5C2-8GBGA169_0P5_12X16U6WM8962_BGA_49P_CUST_BGA49_0P5_3WM8962BGA49_0P5_3P62X4U8LAN8720A-QFN24_QFN24_4X4MM_SLUGLAN8720AQFN24_4X4MM_SLUGU13M25P32_SO8WST_IC_2.5MM_334-7733M25P32-VMW6TGSO8WSTU17SRV05-4_SOT23_S6_IC_1.45MM_480-SRV05-4SOT23_S6U18SRV05-4_SOT23_S6_IC_1.45MM_480-SRV05-4SOT23_S6U19MIC2526_8P_SO8_IC_1.73MM_312-75MIC2026-1YMSO8U2174-244A_20P_TSSOP20_IC_1.1MM_3174LVC244APWTSSOP20U2374-244A_20P_TSSOP20_IC_1.1MM_3174LVC244APWTSSOP20U2474-244A_20P_TSSOP20_IC_1.1MM_3174LVC244APWTSSOP20U27SN74LVC2G126DCTR_SSOP8_IC_1.30MSN74LVC2G126SSOP8U28FT232RQ_QFN32_MC1320X_IC_1.05MMFT232RQQFN32_MC1320XU312G125_2_MSO8_MO-187_IC_1.3MM_31SN74LVC2G125MSO8_MO-187U32ONE_AND_SC70-5_IC_1.1MM_312-303NC7SZ08P5SC70-5U33FDC6331L_SSOT6_1P7X3_IC_1.1MM_3FDC6331LSSOT6_1P7X3U34TXB0102_PSOP8_IC_0.9MM_315-7889TXS0102PSOP8Y1XTAL_XTAL2-3P2X1P5-SM_IC_0.65MM32.768kHzXTAL2-3P2X1P5-SMY3CRYSTAL_JXS63_XTLOSC4_3P2X2P5MM24MHZXTLOSC4_3P2X2P5MM_SM PCB 和原理图。回复可见下载。
**** Hidden Message ***** 谢谢分享!!! 好资料,多谢
