S9S08DZ60MLH +TDA7719+TPS2543+TDA7388 做的车载主板PCB和原理图
NamePCB DecalValuePart TypeANT1CON_MM9329-2700NCCON_MM9329-2700ANT2ANT-2P-846CON_14-2500-0001-00ANT3CON-2017.01.2510.00GTA-1.6CF(70)GPS_ANTBPZ1BPZBPZCN3B_TO_B_80PIN_MALEIMSA-9828B-60Y921B_TO_B_84PIND1SDSMC2723BAANCDDD8SMASMA_B340ASMA-SMBD9SD08051N4148DIODE4148D10SD08051N4148DIODE4148D12SDSMC27231-5SMC24AT3DDD13SMASMA_B340ASCHOTTKYD14SD08051N4148DIODE4148DD1TO-252-TAASTPS15H100CBPNP_2DL5DLW21S_SQACM2012-121-2P-T001TDKZJYS81E23AE6_547UF/25VCAP_E_3ESD1ESDESDESD2F1SF1206ASMD1812P260TF/12FUSE1206F2FU0805100MA/12VFUSE0805F3SF1206500MA/12VFUSE1206IC1IC_TDA7719TDA7719IC_TDA7719IC7SOT-23-5XC6228D332VR/TLV70233DBVTXC6209B332MRIC19IC_IVT_BLUESOLEIL_I38EAIVT_BlueSoleil_i50eIC_IVT_BLUESOLEIL_I50EISO28P1ISO28PAAAAAAAISO28PJ1DZ60_DEBUGHEADER_3X2J2CN-SMD60P-H-0.5-ACON-60PIN-0.5-DOWN(HannStar TFT)CON60JP4HOLE118-8STARCON9CON9L10805/L1.8UHINDUCTOR_2L21206/FBFB121INDUCTOR_3L31206/FBFB121INDUCTOR_3L4NFE31PTNFE31PT222Z1E9D_6ACAP_FEEDL8L1608-330330UHINDUCTOR2L91206/FB215nHINDUCTORL100805/FB270nHFB_S_2L121206/FB3.3uHINDUCTOR_3L26CDR7D28MN10uHLL300805/L27nHINDUCTOR_2L31NFM21CNFM21CC471R1H3EMIFILL320603/L15NHL2L34CDR7D28MN10uHL_3L350805/FBFB31RL_3L36CDR7D28MN10uHL_3MU1IC_JN3.B3A2.LRNEO-6MIC_JN3.B3A2.LRQ1TO-252-T_2SA2072TLQPNP_2Q2SOT-23PMBT3904NPN3Q4SOT-323DTC114EUADTC_114Q6SOT89BCX53-16PNPQ8TO-252-T_2SA2072TLQPNP_2Q12SOT-323DTC114EUADTC_114Q21SOT-23PMBT3904NPN3U1PCM5102AAS U4PCM5102AU4HVQFN32-5X5TEF6686NXP665XU5SOT1117-223TLV1117LV33DLYR-3.3VOLTREGU6SO8LM9076BMA-3.3LM22670U7SOT1117-223TLV1117LV33DLYR-3.3VOLTREGU8SO-G14TPS54386PWPRQ1TPS54386-Q1U10S-PWQFN-N16ATPS2543TPS2543U13SQFP10X10-64AAS9S08DZ60MLH_DZMCUMC9S08DZ60U15SOT-143TC1270ASVRCTRMIC811U16SO-G14TPS54386PWPRQ1TPS54386-Q1U20FLEXIWAT25/TDA7386TDA73887388U24SO14BA14741FBA14741U25SSOP5LT1931ES5LT1931Y1SMHF-49B4MHz_SMHF-49BXTALY2SMHF-49B4MHzXTAL_2 PCB 原理图,回复可见。
**** Hidden Message ***** 感谢分享
